View Full Version : Audi Original "S" Cars
- I have to share my ride home tonight, a run in with a Ford SVT pickup
- Picture I snapped yesterday at a local Audi drive.
- my '93 just keeps gettin better...
- Channel 51c coolant temperature, which sensor?
- anyone with bentley CD willing to burn a copy or upload a disc image for me?
- Question. N75/wastegatefreqvalve. INstalled in any orientation other than stock cause damage to
- Anyone have used lowering springs for sale?
- no longer just a troller
- S6 says In . 1 in odo. How to clear/reset this w/ VAG 1552? --->
- UrScubed is needed again
- Part # for ignition coil?
- What exactly is the air flow flap?
- Barber (Audi Club Nationals) Track Report... Comming soon (with pics)
- So... interesting occurance I'd like to describe and share with you guys. (longish)
- Anyone have a working front pass side seat adjustment switch?
- Late braking + insane road holding = bye bye porsches, vettes and more...
- really need some install help with aftermarket headunit
- This brings tears to my eyes. Anybody with the UrS4 equivalent?
- Can you change a passenger side seat into a driver side seat?
- Radio Problem - Tuner or Antenna ?
- Garrett 3071 software
- Cylinder missfire only during boost, best way to diagnose?
- How to tighten sunroof headliner fabric
- Defroster flap problem fixed (& really boring movie)
- Anyone have a picture of their Koni/bilstein setup without the wheels on??
- Well guys - I guess this is goodbye.
- A new source of UrS aftermarket parts including suspension and fuel pumps, etc.
- safe mode on radio
- so whats the trick to make a 2.5 bar PT into a 3 bar? (pics inside)
- Anyone here have any EXCELLENT CONDITION RF door hinges??
- PROVING IT ONCE AGAIN!!!
- my car , part III, brakes +
- Sat Nav RNS-D install
- My Dream car: 92 Cyclamen S4 Avant
- That guy who needed his ECU tested. I met him. Turns out I have met him before.
- Can someone verify against their own car. Shouldn't this valve on the CC Unit have a vacuum hose?
- Quick Torque Wrench Question
- Audiworld encompasses all things Audi everywhere. The users are what make it great.
- This may sound silly! How do we fine tune these cars after we put all the "cadgets" and "goodies"
- Dynoed my car today
- wanted.. ecs camber plates and lowering springs
- People... And what run at your machines?..
- s4 to s6 steering wheel swap?
- Not that I am complaining, but why is the T-belt so cheap for the S6?
- A lil off-topic... I have the chance after i graduate to get a...
- Improvement of headlights
- Катушки
- i have a nasty clicking sound coming from my hydraulic pump/serpentine tensioner area
- Still having problems with the S4
- Any Ideas why the heater wouldn't blow hot air? Just checked the heater core it is not clogged.
- AUDIHERE1730 - YGM.
- Speedo = One light bulb or two?
- Ugly Elmwood
- S4 advert from May 93 European Car
- Can Anyone Identify these chips? PROVE IT pictures inside...
- Finally Changed Subframe Bushing - Observations
- POLL: What Cars Have You Owned So Far?
- Anyone running staggered wheels on an UrS? Thinking about 7.5 front and 9 rear....
- Another case of failed H&R springs, front
- is it possible to get rid of daytime running lights?
- warnign light for headlights/rear light going off buy my lights all work?
- winter tires, 225-50-16 or 205-55-16 on Avus 16x7.5?
- high milage should i mod?
- Anybody have a spare wide 1st 5spd tranny?
- Trying to figure out heel and toe downshifting in the S6
- Just back from the Stealer
- [Poll] Money no object - space to store unlimited - what cars would you have?
- Just cranked down the WG spring.
- grinding noise
- I need to flush my system and put new coolant. Should I go with Red or stick to Blue?
- kinderutz, YGM about ECU. things look positive.
- Flap problems...
- New exhaust installed
- Cabin Filter Install - Bosch Filter Doesn't Fit?
- Need help checking my AAN ECM
- Its official- NO 1993's were imported into Canada. At least , that's what...
- Anyone know if Variable turbine turbos are available yet(and not attached to a $100k Porsche...)
- Would someone(s) mind giving me an estimate on what I should pay for this..
- Dang - Failed ! All because stoopid Check Engine Light doesn't come on when key is turned - ideas ?
- Has anyone used these guys? Bose amp repair...
- What do you stand-alone controller folks do when you want to tune by knock voltages ?
- Anyone have that link for checkin the POS?
- A new world record !
- Killer Avant for sale....
- Any interest in an AAN ECU with 3 sets of Dahlback chips for T04e/K26 hybrid?
- will this work with my car?
- Manual Transmission additive
- Flywheel lock?
- Pics of the FMIC
- bilstein forsure but I dont know what to get for lowering springs?????
- blauparts reviews?
- is it "normal" (or expected) to hear the whine/hiss of the turbo spooling? Just replaced BPV with
- So with recent talks on audifans of the p.s. hose to the steering rack...
- Can someone hook me up with a working ETKA?
- question on Lexus' new car... little OT maybe.
- WTF?? Just put a centerforce in the thing....please help
- This can be handy looking for obsolete OEM parts.
- any tricks on ow to desolder OEM chips?
- Did we ever resolve the dyno issue of drivetrain losses being a constant?
- CNC porting and polishing
- who is running an MTM 1+ clone chipset? anybody?
- Paint code for Emerald Green 1995 S6
- Electric fan and after-run coolant pump?
- final drive seal part no. needed
- X-Post - Half-shafts from C4 chassis are best ?
- mistery chips again..can anyone identify these pls?
- which ur-s car headlights had H1 bulbs? euro lamps? tia
- Does this look right?
- Who's going to Barber?
- Bought new tires for the S6 today...
- Looking to add Real good NAV
- How do I remove the rear tail light (center pieces)?
- I almost lost my S4 today
- Selling an audi online... need advice...
- Euro convex mirrors & headlight lenses: source & part number request
- Does anyone know if the Eibach Pro Kit has been discontinued?
- RS2 replica injectors - before and after emission results
- S-car in need of adpotion
- motronic wizards: how can an ecu with stock chips make 20psi peak boost?
- FRUITY PANTS post up
- Bypass Valve question....
- wooosh! when letting up on the throttle..
- UrScubed-SatNav+
- New engine for my car
- Happy halloween, suckas!
- p/n requests for RS2 install
- They made S cars before the B5 you know...
- Is this the RF module for the keyless entry?
- Any suggestions for camera mounts?
- Pictures of the new exhaust!
- Sirius Dealer Installation
- I genuinely miss my car :( but i will say this burnouts in a duramax diesel are fun as hell
- Believe it or not, THIS is the ancestor of your S-car
- does steering damper make noise if its leaking?
- So, my car's broken. I'd like to sell it to someone for $1000.
- Opinion poll, please... 16 or 17 inch Avus wheels for winter tires?
- So my door locks and starter immobilizer are out of synch
- Engine Coolant Flushing Procedure when switching to G12
- Who has the best Price on a Big Brake Upgade these Days ?
- For those of you who have installed the LLTEK lower valence...
- How much is an AAN head worth?
- Interesting quirk when going back to stock : engine cuts out before ~6K rpm - any thoughts?
- Dave, how many PDF's of procedures do you have?
- Silver is becoming a popular color on this forum lately.
- Look what I saw in New York last week (R8 Sneak Peek)!
- Creeking noise? Contemplating installing the 2B plates, but would like to know if anyone has a pict
- PSA: Check your strut mounts, this could be the source of your clunk.
- you know what someone needs to make for the AAN/3B...
- The C4 S-car story outline for hyperlinks to pdf'd articles. Does it sound correct?
- Who's ready for Quattro weather?
- V1 Install (Captian Obvious to the rescue?)
- Anyone changed a front strut insert while on the car...seems possible
- Ipod go bluetooth in the URS?
- Mike Cialowicz's "new" wagon after the Sawzall and Bondo. KewL
- For those of you with non working seat heaters...
- If you bought that big brake kit for the fancy white Porsche logo...
- To those of you (S6ers) without an oil pressure gauge...
- Pic of the S6...
- Some free stuff if you will be my friend...clamps...
- Brian Weldon, your email server has been bouncing like crazy.
- Stocker Throttle Body Pipe ? Anyone ? Borrow or buy. . .
- New member needs some help.
- Showed an Acura TL Type-S what an S6 RS2'd with 5 people can do :)
- Cleaned the headlights today, man were they dirty
- Stupid antenna...
- Drove my cousin's B6 S4 yesterday and i've concluded i need a new clutch
- 92-94 UrS4 euro front bumper parts needed BADLY
- Does anyone have a pic of the recirc flap?
- "On the Bed" Including the pup.
- Winter Oil Recommendation?
- Here's some exciting news: my climate control now works properly.
- I STFA all day about this... Rain Channel removal....
- New guy... just got an S6.
- Prove it.
- *snide remark* and/or *point of disagreement*
- For those of you with Big Reds (or Blacks), what pads are you using for street driving?
- Sunroof leaks! Help me figure out what I need to do...
- power steering...
- Any BTDT with HK Special HID shakiness?
- Thanks to Dave F and AMD!
- Wiper blade question for the masses...
- Runnin tip top with new clutch and exhaust... except one thing.
- new...better pix....hopefully... :p....i passed PA inspection...yeah baby!
- I got de-Stromung'd today...sooo sad :(
- How can I differentiate between blink codes 1111 and 0000
- This is insane
- Anyone have experience pairing '92 springs with adjustable Koni Yellows?
- Installed properly?
- My car was somehow damaged trying to push start. What's the deal? And what might be broken?
- Thank you guys for defending Stromung... Friend thought I got ripped.
- Phantom sunroof gremlin: how to fix?
- These things handle like much smaller cars. I love the rain.
- I have no dome light ..is there a module or something for it?
- i want your honest opinion please....
- BAM!!!
- How much could I sell my s6 avant for?
- Anyone else feel stromung is a little overpriced?
- About to order a bunch of parts...am I missing anything?
- is it possible to pop the hood while the car is locked?
- creaking/howling noise when I turn wheel to the right, sounds like its coming from
- is this the right bearing to order for Serp. tensioner R&R
- Sunroof / battery / central locking system gremlins. Yesterday while drving
- Maintenance Checklist - S6
- anyone have link to aftermarket head unit install?
- anyone know how many 93 s4 came to canada?
- Maybe celebrated prematurely. The car just had a huge miss twice on second gear like it wanted to
- STaSIS Motorsports Wraps up its Best Year in Racing at Laguna Finale *SPOILER*
- Kday, making a harness to relay my headlights.
- Finally finished the TB!
- Transformation after Apikol FMIC and Stromung installation
- No More Allroad Suspension!!
- '95.5 CD Changer woes
- Anyone have a drivers side outer rear avant tail light to get rid of? The wifes is cracked....
- Need Driver's Side A6-S6 mirror motor assy
- i have a code15 for air flow flap, but i cant get air to footwell/defroster
- Will 95.5 A6/S6 rear door panels w/ speakers fin in earlier S6 w/ rear speakers in package tray?
- Off topic / Passat wagon related, but you guys are helpful.....
- B5 S4 transmission (6-spd) into 95 S6 - rear diff. will be ok?
- Anyone have a good spare crank sitting around?
- Any interest in a TDS-1?
- Looking to buy a S4 some questions.
- anyone know where to buy oem clear front turn signals?
- I have 15" rims on my s4 what size winter tires?
- Strange ABS pulsing when coming to a stop
- why is everything so difficult on my car?
- i'm getting water inside my right rear taillight.....no cracks dough...where is it coming from?
- Back from 2 weeks in Germany- Octoberfest was quite insane...
- Megasquirt-II. Discuss....
- anyone in MD or VA want to help a poor college student change the HVAC footwell flap?
- Crank bolt removal help
- Aircare question?
- If someone has carfax, please email me. Thanks!
- Thinking about selling...
- Anyone looking to buy a 928 MAF?
- anyone know the inlet/outlet size for the diverter valve? 20 or 25mm?
- Drivetrain loss & WHP vs. CHP calculation discussion (read this if you want to do it right)
- Anyone know of who has RS2 manifolds in stock?
- I can't believe my eyes!
- 16'' S6 avus wheels wanted
- Does anyone have any before and after photos of the bumper for Apikol FMIC install?
- REGISTER NOW: New England GTG on Wed, Nov 15 in Framingham, MA
- My car is still not starting, and it's got a new starter! Help?
- Is there an equation to predict HP based on turbo pressure and flow?
- Anyone have grey seats FS? (& Dave F is he on the BC/AB mailing list?)
- Anyone got an extra LH front wheel well liner and IC duct?
- RS2'd guys... when do you hit full boost in 5th? I got 27psi @ 2850-2900 RPMs last night!
- any of you guys with spare parts have a right tierod? i can't get my tierod end off and i dont want
- Some Photos on the progress? The FMIC is taking longer than I thought. Wheel has been fixed.
- Manifold Absolute Pressure (MAP) sensor (G71) location and function
- rs2 upgrade - or equal - calls for advice
