PDA
View Full Version : Audi Original "S" Cars
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127
  1. Can somebody run carfax for WAUED54B31N102445? My account expired :(
  2. spiralsmurf. YGM
  3. Putting my custom sub box and subs back in the car... Electrical/AMP Question??
  4. ARP Head studs
  5. 70mm Throttle Body worked well - Two thumbs up
  6. PSA : Boost Taper = Boost leak. Don't be an idiot pushing the pedal harder
  7. Good thing it's dark because my car is Hella dirtay!
  8. silver s4 seen on rt32 near I95 in MD, anyone here?
  9. anyone been the guinne pig yet and try the center bearing for the driveshaft from Blau?
  10. Odd rear brake clicking noise...
  11. And while Im at it, thanks Brian(spoolin S6) for your patience on that ecu!
  12. A BIG Thanks to ericAL. I sent a money order for 2B camber plates on the 1st, they arrived yesterday
  13. Anyone know how to replace the light(s) on this?
  14. Wheel Adapter kits - fit BMW rims on to Audi - thoughts and availability
  15. smoked taillights
  16. s6 1995.5 i hear a zing type noise when i press the clutch when moving?
  17. Bot low beam HID for my S6...
  18. this sucks baaad...i fixed my A6 so i can focus on my S6 and now my license is about to be suspended
  19. Alignment Specs for my S6 w/H&R springs!!!
  20. wipers working fine and all a sudden the drivers side wiper goes off windshield
  21. my front tires are wearing excessively on the outer edges. would you say is my alignment problem?
  22. 993tt brake question
  23. Now that I have rechecked all the clamps in the intake, what else can cause the "limp home mode"?
  24. more from the interesting night, WG spring related
  25. interesting night fixing interior lights..
  26. How do you replace the light on the Climate control unit
  27. Had two of my tires repaired, and all 4 balanced by a hunter balancer...
  28. OK, this is really the dumbest thing ever...
  29. Low speed rearend collision: what should i check?
  30. OK, so who is this in the URS4?
  31. MAF help needed
  32. Re: From the prior posts I remember that people succesfully used different spark plugs...
  33. Bodywork/paint advice needed (long)
  34. oh my would you look at this...
  35. For those of you w/ a 92.......is there a bracket/clip that holds the intensive washer bottle......
  36. Any fellas in Chicagoland with stock UrS4/6 16" wheels? I'll supply beer for a quick test fitment.
  37. Motorstadt III: Anyone in Michigan attending?
  38. Stupid question: Which way is the bypass valve installed?
  39. Source for Euro bumpers and lights?
  40. Bolero's
  41. RE: Random misfire started yesterday....
  42. 3 UrS'es spotted in northern NJ in 24 hours
  43. Need a working, non-leaking set of used OEM injectors...
  44. Hey lskolnick, do you have a cruise control module?
  45. What parameters will throw the computer into the "limp home" mode?
  46. Would a CPS from an S4
  47. Feeler post: maybe off to a good home.
  48. I hit a F'ing tire on the highway today. I hate STUPID drivers! <long rant w/ lots of pics>
  49. Does anyone have a used one of these to sell me...
  50. Loss of power at WOT. Any ideas?
  51. Anyone have the part numbers for:......
  52. What kind of power steering fluid you guys using? Mine decided it liked the floor better......
  53. Y'all seen this?
  54. 93 S4
  55. Can wheel size affect MPG number?
  56. Crapple - Did you ever find the answer to your boost problem?
  57. Rear upper control arm brackets...
  58. RS2Spec, i left town this weekend for a family emergency, can i still paypal you for the CPS GB?
  59. Leaking air from Maf to Turbo hose under boost. Does an aftermarket
  60. Anyone interested in attending German Car Day at the Larz Anderson Museum of Transportation 6/18?
  61. Do any of you guys who got the cheap 314x30 rotors from Tire Rack want to part with them?
  62. Sticky Minus Temperature Button
  63. Still searching for '92 springs...
  64. You can add me to the broken H&R spring club :(
  65. Spotted: Cashmere S6 on SSR GT7 wheels in Boulder.
  66. TB & IM inlet enlargement update:
  67. I called the stealer... $1007 for a antracite floor carpet piece... My is ruined from all the...
  68. a wee bit OT buttt - what's a sliding caliper as opposed to a fixed one? benefits? any down side?
  69. Cooling fan stuck on, can only turn off by removing fuse....
  70. Pulling Center Console...
  71. Should I Sell my S4 or Fix It?
  72. x-post update
  73. NEW AUDI PARTS
  74. Progress.......
  75. New addition to garage...(non-automotive)
  76. so my insurance has finally dropped to sane levels, which means i can afford to get a nicer car
  77. Stiff brake pedal
  78. Update:CT S4 ROAD RALLY & BBQ SUN JUNE 11TH
  79. '79 Trans Am....smoked!
  80. SUNROOF Leak ? -water channel - Solved -complete description....
  81. Colorado winters
  82. so there's a broken A6 across the street, steering seems disconnected, ideas?
  83. Thanks to everyone...
  84. Speaking of big brake kits...
  85. What a pain in the balls trying to find a 6mm hex socket to use for the damn bumper.....
  86. Rattle snake sound + white smoke out the exhaust = Diverter valve?
  87. If i was to put a 7A Cam set in my AAN After >>>>>>>
  88. Low Beam Right Hand Light Comes On after you turn ignition off, and light swith off.
  89. PSA: B5 S4 Oil Filter fits UrS4 Cars
  90. Sudden decrease MPG
  91. FYI: ECS tuning website has a bunch of electrical connectors...
  92. on the subject of cruise control. my car will hold the speed, but then very slowly
  93. Cruise Control Module, anyone got a used one available?
  94. Chickaan Stripping 1 & 2 tribute banners for lskolnick's wrecking of the sedan & avant
  95. Just picked up the 034 motorsport 1.8t coilpack kit today
  96. Car will not start - Headlight on with switch off and keys out
  97. Friggen Oil Drain Plug wont come off errrrrrrrrr.
  98. Bira 3
  99. '96 S6 sedan (pics are on the way) project ideas? Lets hear em!
  100. has anybody put on a euro s6+ bumper?
  101. Looking at Magnaflow cat, center and rear muffler for a 3" exhaust system...
  102. Urs4 or A8?
  103. Project S4 Update: Still need some guidance!!!!
  104. Someone find me a good deal on a red Alfa...
  105. 93' Audi S4 Belly Pan
  106. Good idea to change cam chain when doing timing belt?
  107. Here you go Mr. Pop:
  108. Brake pad recommendadtions??
  109. Anybody want to trade their 5300K HID bulbs for my 6000K?
  110. Tom (tabularasa)
  111. hey SoCal, check out upcoming JUNE Events - Pine Mtn Drive/Winefest & Streets of Willow track
  112. Poll : RS2/Stage 3 or above, what's your Clutch ? Street drivability ?
  113. where to buy an s6 plus bumper???
  114. If I had a black S4 or pre-95.5 S6 I'd be bidding on these...
  115. A sport badged pearl CQ stoped next to me at a light & bid a hidey -ho! this PM
  116. 93' S4 Boost Reading
  117. CPS GB #2 closes out tonight
  118. Shocks arrived!
  119. Do any of you maniacs know the weight difference between stock exhaust and Stromung system?
  120. Does anyone know Michael Cancellier?
  121. anyone have link on how to socket + chips into ECU.
  122. got the head off today,question ?
  123. advice on damaged wheel... (easy emre)
  124. You know what really grinds my gears...
  125. Strange oil.....
  126. Advice needed- Im trying to make a purchase from a fellow AW'er
  127. Too much bling for one man.
  128. Xeon HID Euro Headlights for '92 S-4
  129. Unexpected standing coolant in the drivers side floor board today....
  130. CPS GB #2 Update and Canadian Payment Instructions
  131. Ok, I need to make a decision this week: 255/35-18's or 245/35-18's?
  132. Wheel Options??
  133. Poll: Have you dissabled your Speed Limiter? (Yes/No)
  134. Italian S-cars
  135. I'm not by my Bentley ATM, so...
  136. '93 Audi S4 for sale 7500
  137. Has anyone got a spare stock turbo?
  138. Interesting to put the oil catch can on the breather system?
  139. Any of you who have "upgraded" your oil cooler......question...........
  140. Strange phone call today. Seems someone abandonned an S4 in Calgary and left
  141. headlight warning after HID install
  142. compression test value needed?
  143. Installed a block of hollowed aluminum and a small snail today.
  144. blauparts problem
  145. 95.5 S6 front bumper cover
  146. Brought home the Canadian S4 today...
  147. Sometimes you just hate your car...
  148. Well, she's finally gone...
  149. Replaced my fuel pump today... it's really not a bad job aside from the fumes.
  150. Looking for two new or good used RS2 injectors.
  151. COREY. PICK UP YOUR SUNROOF OR GREYHOUND IS GOING TO THROW IT AWAY.
  152. S6 (Stage 2 TAP Chip )v 2006 3.2L Boxster
  153. Some nice info on the Torsen
  154. Anyone here get this?
  155. CPS GB #2 Payment Instructions
  156. Since I don't have the time this week to do the repair to the HVAC system...
  157. Anyone else ever broken one of their H&R springs?
  158. Front Axle
  159. Brake pads
  160. Coolant is dripping into the left and right side floor boards... Why???
  161. Newbie with some questions...
  162. HELP, has this happened to anyone?
  163. Anyone has been facing the turbo oil hose clogged up?
  164. Noise when turning right
  165. Boston area: need to find good Audi mechanic for pre-purchase inspection
  166. Bucking, hesitating, surging at 15psi...help!
  167. Valentine 1 remote display integrated into Ur S4 instrument cluster
  168. Audi Expo 2006 - Come be a part of history again!
  169. 3rd Annual Old School quattro gathering in Cumberland, MD starts July 28 - click to sign up now!!
  170. What's # 10 for?
  171. Brake problem?
  172. I really don't want to give up my Cashmere S6, but...
  173. What's the diameter of crossover on the t-side? Trying to order some clamps for FMIC project.......
  174. So for those who care, here are the updated interior pics.
  175. Whats the list of things to do when doing a timing belt job?
  176. attention attorneys or legal experts....
  177. Question about this EM.....
  178. a/c woes...advice much appreciated.
  179. Where to get a Cam position sensor, (need fast cant wait for the group buy)
  180. Is there a fuse/ circuit breaker for the cd player??
  181. any of you guys gonna try the new aluminum 034 motor mounts?
  182. Ok, for someone who has the part numbers handy....
  183. H&R/Bilsteins Setup is creaking in the rear...
  184. What ever happened to the fellow from FL w/ the sick black sedan.....GT500R or something like that?
  185. Poll: Is your Servotronic On or Off ???
  186. insane slalom through traffic
  187. PSA : 100 octane is worse than crack
  188. I really need new brakes.....
  189. Lookin at S4s
  190. any guess as to the reliability and maintenance of an 89 911 C4 compared to S6?
  191. so the car is running better with toluene. what now?
  192. Boy do I think this is sexy.....
  193. how to get the air out from the brake lines?
  194. Please remind me again. What's the max you can get out of a AAN without internal work?
  195. Just dropped my car off at Dick's Auto Body. Back in 3 weeks.
  196. well, putting toluene in my tank fixed one thing
  197. Schoener Christi Himmelfahrt feiern!
  198. did you guys see this craziness at mid-ohio last weekend?
  199. s6 1995.5 new fob reprogramming info needed dealer has no idea!!
  200. Since one of my low beam HID ballasts are dead, I'm looking to replaced the lows with a new kit.
  201. Extended Warranty Coverage - Long post, great prices and coverage
  202. Talla
  203. Getting alignment done today!!!
  204. so my boost cut issue is getting weirder and weirder
  205. CPS GB #2 hits 100!!
  206. Update:CT S4/RS ROAD RALLY & BBQ SUN JUNE 11TH
  207. another satisfied customer...Rieger shift knob...more red inside my S6
  208. A drastic unexpected change in my AC system
  209. how does one tell if a wheel is out of round?
  210. New front axle
  211. my A/C stopped coming on. things to check?
  212. CPS GB #2 -- Update #3 X-post from S-List
  213. Going to do a coolant flush over the next few weeks. Any bits I should replace in the process???...
  214. am i done here? need your opinion(much apreciated)
  215. Need help for surging.
  216. saw a 2007 S6 V10 today
  217. Looking for nice 95.5 S6 sedan or avant
  218. Upholstery done, Adriano et al...
  219. BPV problem?
  220. i need help
  221. My car turned 130,000 today. I don't know why that seems like a significant number, but it does.
  222. Poll : Nicest clutch for 400+ hp daily driver ?
  223. so i finally got it cert. and emissions tested...then KABOOM...
  224. For those that have upgraded to big reds or big blacks, would the original brake line work?
  225. are any of you guys going to US Gran Prix on July 2nd? I will be there.
  226. last minute track time at NHIS, $150 all day w/SCCA
  227. who has an aluminum flywheel in their urs4/6??
  228. Bad driveshaft bearing...
  229. Suspension Question
  230. Anyone put S6 door moulding on S4 doors???Need help.
  231. Three buttons under inst. cluster - no info. in manual.
  232. My 005 FP arrived and my (future) software problems seem to be solved!!!
  233. CPS GB #2 Update
  234. Found some pics of my car on a friends page.... A local Hooters meet of the ricer cars in the area.
  235. '96 Audi S6 stock suspension: Sell or garbage?
  236. Hap, where do I get new heim links and bushings for HRSB
  237. aluminum flywheel problem?
  238. where can i buy wheels spacers for a set of 17" bbs wheels...
  239. ABS light on...............
  240. Let's MADNESS begin.Oil burning issue.....
  241. RACE RESULTS INSIDE - Please do not post in subject line for those who want to watch the race
  242. Anyone have a spare lower engine tray?
  243. do mirror control, cig lighter and diff switch all use the same T1 12v 60ma bulbs?
  244. Anyone have a new/used Samco Michelin Man hose for sale? Email me...
  245. CPS GB #2 Update (X-post from S-List)
  246. d'oh...so apparently the cell antenna on the avant IS the FM antenna
  247. dash display is intermittant..........
  248. 200 Mile Post-Op Report...
  249. BAH i feel like a bit of an idiot
  250. Happy Fete de la Reine, 'Eh?
