View Full Version : Audi Original "S" Cars
- How do i adjust this lil fella?
- how to diy repair for cracked bumper?
- ok, another video diagnosis. squeaky steering wheel
- Is this the G110 Temp Sensor?
- Custom FMIC tubing
- Failed coil looks like this, black goop squeezing out.
- Something in my rear suspension is squeaking a lot. It's gotten very bad with summer here!
- I've pulled the G28 engine speed sensor code twice, safe bet it's toast?
- Where to get an Audi Electronic Climate Control LCD Kit ??
- Something blue to drool over
- trans noise upon clutch release, have a listen on youtube...
- Anybody going the AudiWorld/Inskip GTG in Rhode Island tomorrow?
- Metal block coolant fitting and thermostat housing are sitting in Evapo-Rust.
- HOW do you adjust the clutch pedal return thing? the black plastic piston looking thing...
- Yep, it finally happened :( (Warning: Carnage pics)
- having engine run problems
- how much do strut bearings go for? ECS has for $13 each, thought I saw some on AF
- Shifter adjustment question
- I may be bad at searching but am not finding much about aftermarket alarms.
- Le Coupe Quattro is FS
- PSA; I get 2mgp more on Shell 91oct than on BP/Amoco 92oct.
- Well, it isn't just us...
- So what is the capacity of the rear diff, and what redline oil are you using?
- Autocheck brakepad light comes on when horn is applied...
- Anyone doing a t-belt and need the crank timing sprocket?
- Guys can someone tell me what length bolt i need to go with 15mm H&R wheelspacer?
- Just got my car back from the sprayshop,ur s6plus small lip arches fitted!!awesome..
- Does somebody have tools 3312 and 3212 in Seattle area?
- So, I found this box on my porch last week...
- What tire sizes fit well on the 16" Fuch's?
- MY CAR IS FIXED!!!!! That is all... carry on.... *Scott runs away and does happy dance*
- Soooo. What is my S worth?
- why did audi use one stage red paint? saab did the same thing
- servotronic failure when it rains, odd.
- Anyone here familiar with ECU tables? (Winols users? VRLife?)
- Update on vacuum hoses for Dave F, And questions on Bearing Diagnosis (450exc115)
- Too funny...
- Measured my 1.8T coil pack temperatures at 200DegF...........
- Had you guys seen this yet?
- got the H&Rs on, 4 springs, 4 tires M&B - 4 1/2 hours.
- Finally my "new" UrS6 is home in my garage - x-post
- Anyone else disgusted by the packaging that comes with the parts you order?
- Failed strut housing + highway speeds = blue smoke, a dead tire and long tow ride home.
- Anyone with a green S6 Avant in Las Vegas, New Mexico tonight? I waliked out of...
- bulb cover question
- the parts department wasnt any help. whats the part # for the black trim for the front bumper?
- Im Still Having A Vibration Issue, Today It Felt Timed With My "Surge" Issue...
- Mild success with driveshaft rebuild this weekend... but not all seems hunky-dory =(
- Will stock lines fit the stage II (993 Turbo caliper) kit?
- Sounds like Emre's car... parting?
- Where to buy heat resistant tubing for coil wires? Eagleday?
- 93 Child Restraint System
- FYI Stepbro Exhaust For Sale on Audifans
- Great comparison of Gruppe B rallye cars, including the S1 (with videos)
- someone have a source for a ball joint separator that works for cheap
- Had a vivid dream last night: Bought a wrecked blue RS2 from a government wrecker for $2000.
- cialowicz: That wasn't carnage. *This* is carnage.
- Where to purchase the "3256" crank pulley tool?
- ECS has 26x1.5 drainplugs. right size should be 22x1.5 right?
- Thanks Audi for making the coolant flange into the block plastic.
- A forum post should be like a skirt.
- Repost - Still needing to know what part is the "metal cup" that is missing in my suspension...
- THE BIG 044 fuel pump --Just How loud is this thing ?
- Photos of the carnage...
- Well Dave i tested for airleaks, Found nothing... What to do next?
- how does the '97 S6 differ from the earlier years?
- hrmm.. replaced a noisy fuel pump with a brand new VDO one .. now car is acting up.
- Does this make any sense?
- So my UrS4 immigrated to Canada : (
- estimated time to swap in 4 H&R's +alignment?
- So few 245/40 tire choices on tirerack, great deal on 255/40 but I have 8" Bolero
- After run pump??
- Need help getting all the part for my BBK, for the most part a BBK is:
- Eric16v? Hes on this forum right? Well he needs your well wishes
- Did the Ultimate VIN Decoder move? Doesn't appear to work. :o(
- Friend is selling his UrS6.
- Anyone have a good used AC Compressor for cheap??
- Testing for vacuum leaks, what's a safe psi for turbo seals
- what's up with my new bentley CD's? can't view a bunch of stuff
- different colour(base) int bulbs
- So I washed the car and decided to look in the well for the blower motor and,,,
- ok has anyone retro fitted s6plus blk window surround piping to their urs6?
- New tranny mounts filled with window weld impression..
- Walbro impressions.
- Guys will an RS2 Maf fit onto our standard ur s6 turbo hose?
- 034 injector retrofit kit impressions?
- Timing belt... now or later?
- More on being stuck in open loop. Can anyone help?
- Exhaust gaskets for Stromung stuff??
- Buying an S4 and need some expert advice.
- Paging deephouse... why don't you post your mixes anymore?
- Dave F, noobie spark plug Q (also question for EB_1920)
- Bose tune up Q: piercing dog attracting noise; coming from bad HU or amp?
- Ok, so I finally got my tranny dropped to see what I did wrong... how DUMB!!!
- anyone ever use five star shine?
- lets see pics of your ride with 17" wheels. during my search i seen alot of red x's
- Door shell replaced, thanks Skollie.
- Secrets to fixing an air compressor
- Can i use an Rs2 maf on my standard boost urs6??
- Steering Wheel Conversion - Help With T13a to T14a Wiring Needed
- With all the car parting that has gone on, does anyone have a good prop shaft bearing for me?
- S2 launching and testing sound with BOV.
- Need a new ISV. Anyone have one for me?
- Is anyone here running Dahlback software? .....
- Piston powered aircraft manifold pressure gauge used as boost gauge in urS6 (video)
- Location of Autocheck Module
- location of fuse for after run pump on S6?
- I need a new crank position sensor (black connector) Anybody have a cheap one?
- Good bye tick tick tick!
- My new battery is going pretty flat after a week of non use?
- impressions on new springs (long)
- The 5th annual Audis at Carlisle gathering is next weekend!!
- Confucius says, "he who makes boost, also makes wallet hurt"... ;-)
- Jonny K where did you buy your Flik wheels?
- Don't know if this is a repost but if you are a bike guy you will appreciate it.
- where can I find KATE ?
- some creaking from steering while not rolling, checked mount for crack, did not see
- any one have a dealer hook up on the east coast?
- anyone running the 034 1+ tuning?
- 300 dollar Big Blacks came in
- So the Rear View Mirror fell off yesterday...has anyone done a auto diming RVM conversion?
- Question on Dave's boost leak test... (making sure i have a grasp on it)
- Fuel filter crush washer part numbers, anyone have them handy? My new filter didn't come w/them.
- Just got replacement rubber lower door trim(front doors)
- Anyone looking for a set of Bentley manuals?
- what can i expect to pay for a 100k mile AAN longblock?
- How many miles expect the lifters to be repressurized?
- anyone have a valentine-one hardwire write-up?
- you hear a faint pop in the speakers with radio on when you turn on your headlights? (HIDs)
- Discuss : Twin Scroll Turbine is better than Single
- could someone describe "limp mode" to me? do our cars do it? what causes it?
- I wonder how these wheels would look on my S4...
- I haven't driven my S6 in over a month :(
- So anyone buy any Audifans go-fast schwag from this guy, Demetri Xanthos?
- 1.8T coils are in and car runs much better........
- anyone buy from this place recently? i havent recieved a email
- Anyone know where my buddy can get a TT BBK for his A4 for cheap?
- Passed my emissions retest
- Will 3 spoke wheel p/n 4A0419091AD fit 93 UrS4?
- Found some Ronal R7s on CL for cheap if any socal-ers want a shot
- Yesterday I found out one of the ECU I have is broken. What can I do w/ that?
- Is there an easy procedure for checking the condition of the steering dampener?
- Found fault code for altitude sensor. Makes sense since its missing. Anyone got one for sale? Gabe?
- URs4 now on LPG gas. (And you thought I was joking about poo power coming in the future)
- so i have a fault code for my engine speed sensor
- Stupid questions,,,
- Champagne bubbles in the coolant overflow but not the head gasket?
- My '95 S6 suddenly developed loud knocking from the engine bay while I was cruising on the freeway..
- NEEDED: Turbo Inlet Hose (corr term?). I need the hose that goes from the intake to the turbo ASAP
- Sold the Avant and bought a....
- So I noticed the carpet was cut on the pass. side of the S4 that I just bought...
- 034EFI RS2 chip impression.. (edit)
- An Elise gives an Audi a "wedgy"
- Dave F. do you know where the Volvo connector is used on the Volvos?
- Kinda nifty A/F gauge set-up.
- May I replace ECU in urs4 without turning the battery off?
- Calling Dave F. or anyone who has done the 1.8T coils
- Is this the same Andre from NY that used to own an UrS4??
- so you want to listen to your engine?
- If you had the chance to buy used H&Rs would you do it?
- A little oil seepage around the top of the EM gasket by the front most cylinder...
- IC computer scramble and warning bulb issue (just confirming)
- bay area CL S6A
- A few mm of play in the rear suspension upper link...
- Ski Bag Installation Trick?
- I decided to replace my S6... I got myself a brand new Infiniti M35.
- Low mileage avant
- Snapped off a rear shock mount stud today. Anyone BTDT?
- Keegan Bartel
- Sean D (quattro20v) What's the offset on your wheels?
- Europrice is back to it's roots...
- she is going in for the respray and euro s6plus extensions tommorow.
- S6 ignition -> A4 Coil Conversion Harness?
- So what do you guys think
- who needs cf trim when you can have burberry
- finally worked on the s4 again, engine is missing
- about to get car inspected, rev in nuetral is surging..
- is this for srs?
- short shifter confusion
- Update: car would not start (once every two months...), replaced ignition switch:
- IGOR camber mods have been my afternoon project...
- How do Abt Springs compare to stock 92 springs, comfy or harsher?
- Definitive Stromung Revision List and Notes (Draft)
- Hey anyone remember that black on ecru 95.5 sedan rs2'd fmic on ebay a while back?
- Anyone know the part number for a front abs sensor to fit 100 s4?
- What clamps are you using for your silicone boost hoses?
- qyuick inspection and back of block is wet... is the G62 known to fail and leak?
- Does anyone have a good working Gamma HU with code they want to sell?
- Headlight Upgrade HIR + Euro Lens
- I heard tick tick tick sound when the car idle.
- Went to the One Lap of America (Cannon Ball Run,) at Road America today.
- Clutch issue finally resolved. TO bearing, PP and disc were toast. Ended up installing..
- Seems my CD changer silver transceiver has gone bad. Out of the blue it stopped..
- can someone photoshop fat fives on pearl white
- Finally got to install and experience Stromung Generation 5..
- Fuel pump replacement question
- Coolant wont fully drain??
- Colorado folks : still any good skiing going on over there ? I heard it just snowed again
- Ok guys whats the best power retaining battery to fit under our back seat??
- Canadian Owners, you need to add yourselves to the Frapper Map
- deephouse, YGM, pics
- Supposed 1288 hp S2 on a track. Some amusing moments.
- Friend is looking for a replacement wheel for his 1995 S6 wagon, is this a reputable place?
- OK, how many TDS-1/TDS-X owners are there?
- Anybody w/ CARFAX available? WAUHP54A9NN129313 , please.
- Mirror replacement
- Ebay Find.....looks like a good deal so far....
- Follow-Up Gamma No Workie.
- cell phone antenna
- Paging Chefbob, give me a call when you get a chance thnx =D
- The guy with the Black interior...
- Tired of STFA... What is the diameter of the turbo outlet? Throttle Body (?2.75?)?
- Here I am picking up my new R8 in Stockholm. Only 1,475,500 sek
- Debate: Installing aero wiper blades (with the wing). Wing up or wing down? Discuss with reasons.
- Audi Expo - June 28th
- It's finally time to chip the car, I'm thinking MRC 91 octane tune but I'm suffering info overload
- who has their exhaust custom made? what muffler did you use and do you have a sound file of it?
- chevy Nova what?
- Dream come true (for me)
- Looking at Buying an S4
- Looking for factory ur-S4/S6 Gamma CD changer setup....
- How do I remove that screen thingy in the brake fluid reservoir??
- Paging UrS4boy: i can't get the clips off of the fuel pump/ cant find them
- Wasn't looking forward to making this post...
- Wow!
- Found this on the interweb for all you wheel weight seekers..
- Ladies and Gentlemen, Riverside Audi's Online Parts Website, AudiPartsDepot.com is now live!
- I need new front pads: are these acceptable?
- Very, very serious TDS-1 problem!
- Audi window regulators...
- anyone see that new ACNA article where they claim the Ur has 49/51 weight distrubtion?
- Crank pully confusion
- If the ECU is fried, will VAG-com still connect?
- Finally got around to try to install the S6 3-Spoke steering wheel again...
- Weird lock issues on my new S6
- Front suspension noise
- One cool dog!
- Know anything about this S6 sedan in PA?
- Can you buy Samco hoses Locally? (I'm in Vancouver)
- Just averaged a little over 24mpg on my last tank
- Just signed up to volunteer for the North Nevada Rally.
- '94 S4 (Black/ecru) for sale in Maine... 4000 bucks.
- Is this the EVAP purge valve?
- STFA and got the write ups for the fuel pump DIY already - however
- Who would have though it would be cheaper to run my car on milk? 93 was 4.09 this morning =(
- flame trap.How many of you use it?
- Installing the HRSB this week on my Avant. I seem to remember talk of extra parts needed.
- Sorry in advance, STFAed, no joy....
- So two weeks ago I adjusted my fuel pressure down, in an attempt to pass emissions...
- Saw sneak preview of "Iron Man". Great flick, and R8, S5, and Q7 were all very visibly placed.
