PDA
View Full Version : Audi Original "S" Cars
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127
  1. Imagine my fun.....
  2. A quick 10 minute, $3.65 bumper fix...
  3. //SFest Swag coming soon
  4. I've driven my car .25 miles in the last 2 months. That is all. 8^(
  5. Does anyone know which brake upgrade kit this is? What source for rotors and pads?
  6. S4Boy, I am thinking of doing a POS Coilpack conversion....
  7. Ned Ritchie's wife's Ur-S4 is FS
  8. I need ideas!
  9. I want to import some autometer guages to the UK where's the cheapest place to try?
  10. Euro A8 rotors, ECS is out of stock
  11. Tomorrow I blow this joint for 3 weeks in Europe. I'll be sure to take pix of any s-cars I see.
  12. Need help with Bilstein HD part numbers...
  13. I need S4 badges for Waterfest...where can I get them by this weekend?
  14. So my brake caliper came off yesterday....
  15. BMW and Audi Motronic ECU connector crossover?
  16. 3" turbo back exhaust
  17. alright, AAN brains -- what sensors control both the wastegate and the a/c?
  18. compression test kit+vacuum brake bleeder+McPhearson spring compressor+disc brake caliper tool set
  19. 4A0 721 401 is the clutch master cyl with the outlet on the side not the bottom, correct?
  20. purchased my lltek bumper!....
  21. Air conditioning recharging...
  22. Link to Bob Myer's FTP site with a VAG 143 AAN Motronic pdf
  23. well, got my CPS today, and probably the POS I bought from Elijah tomorrow
  24. Uneven ride height from left to right
  25. e-brake let go last night, is it just need adjusted or do I need to replace the cables?
  26. boost leak detector?? what diameter pipe ends do i need to buy at home depot?
  27. Crank pulley broken.
  28. how much coolant do i need?
  29. After a tough event at Infineon, STaSIS heads to Miller Motorsports for round 5 of the SPEED WCTC.
  30. S Fest 2006 is Aug 26th Coventry CT
  31. another wounded soldier
  32. Pioneer Sat Nav with BlueTooth connectivity (Forrest this is for you)
  33. heater core box flap question???
  34. FP replacement question;
  35. X-Plug at steering pump still leaking after i just replaced it with a new one with a new gasket
  36. Emergency Brake Repair procedure by Fred Munro of the S-cars list
  37. Paging Matt Litteral...
  38. losing good amounts of oil
  39. how many miles did Ur car had when you started modding it and how many miles does it have now?
  40. do our cars take the same snub mount as the B5 A4 cars???
  41. How many S-car guys are going to Waterfest?
  42. Big Preventative Maintenance Day = Success
  43. New bling and why I drive an Avant
  44. EDITED: Considering an 95 S6 Avant. How different are they compared to
  45. Dammit, can't go to S-Fest AGAIN. You must all think my car is made up.
  46. Question for ppl who have KONI shocks on their cars
  47. Anybody ever move up to a B5 or newer Audi?
  48. anyone have wiring diagram for the factory phone system? I'm debating wiring bluetooth through
  49. This might have been posted before. Turbo maps - KKK & Garrett
  50. Replacement Fuel Pumps and spark plugs???
  51. Are there brake sensors on rear pads?
  52. Dash bulbs replaced. Now I have warning lights!
  53. Finally!
  54. Boost gauge finally installed.
  55. Help!! Does anyone have a spare to sell?
  56. Cruise control diagnostic notes
  57. oh, and a note for those of you replacing your wastegate spring
  58. Will this bish fit?
  59. So whats all this about the new 034 ecu thing....
  60. Went to the drag strip last night.....
  61. so i replaced my WG spring with the 034 1.9 bar one...i had a stock one. boost now cuts at 25psi
  62. Big day for the S4
  63. I still dont get what fails on the X-plug on the steering pump that causes a leak
  64. one step closer...
  65. Seriously weird climate control behavior
  66. headlight bulb question:
  67. Anyone have good trunk center section tail lights? not faded!
  68. Spiralsmurf, YGM!
  69. Gas Mileage
  70. hose questions
  71. Any interest in a Bosch 044 Fuel Pump Group Buy ?
  72. 92~94 S4 owners - Anyone know where exactly the Diff-Lock vacuum line enters the engine bay?
  73. HOSE WOES
  74. Help!!
  75. Anyone help with an A/C question/problem?
  76. Now THIS is an engine. (its the grandfather of our 20vt AAN engine)
  77. Thanks to Darin Nederhoff for the recommendation to use Electro Tech Coatings
  78. DIY FMIC Notes
  79. For anyone else who has their slotted rotors "on backwards" (ATTN: S6 4RiNGS , URS4 Boy, Repeater)
  80. ok got the springs.....what else do i need(beside bilsteins)?
  81. Kday can you hit me up about what ecs did for with your brake situation
  82. Eibach Pro Kit delivered........to wrong adress :(
  83. has anyone purchased the high-performance 034 coilpacks?
  84. Spark Plug suggestion for UR S6? Blaufernugen suggests Boshe Platinum, Local shop hates them! NGK?
  85. Does anyone have a procedure for removing all of the wood trim and steering wheel?
  86. If you miss your first 20vT, say ay
  87. Hit 160k today...
  88. I've often wondered after buying the cr dropping head gasket from 034 if...
  89. Ordered the 3 spoke steering wheel conversion today.
  90. I've got a few straightfoward questions that i can't seem to find answers to in the archives...
  91. Gabriel, about those VR6 aux water pumps.....
  92. AAN airflow diagram for reference in discussion of boost leaks, etc.
  93. Oh man, oh man! If only 1995 + 15 = 2006. (see URL)
  94. failed smog...O2 sensor?
  95. Ahh gude times
  96. So many s-cars stuck behind some bunk TT
  97. Is 400 whp possible with the 3071gt?
  98. what are the labor hours for steering rack?
  99. Hap YGM regarding ECU tuning
  100. Eibach Group Buy
  101. heater core box sealing tape...
  102. Ronal 17" Wheel Sale
  103. Anyone on here have an M3 spoiler on their car?
  104. engine starting problems
  105. Will be gone for 3 weeks, should I disconnect the battery?
  106. apparently jegs.com sells the eibach pro kit for our UrS cars...
  107. Looking for a "shotgun spread" of ideas - Electrical problems causing Fueling spikes
  108. The boost is back! (hesitation on boost @3k RPM) *long*
  109. Gabe, what was the pic in your earlier caption contest?...
  110. Where can I find a new throttle body gasket?
  111. Is it easy to damage the O2 sensor?
  112. The S6 ebay garge sale continues...
  113. Caption contest
  114. Is there a part number for the X-Plug on the top of the power steering pump?
  115. Engine stalled 3 times this past week at red light
  116. Clutch Kit NEEDED ASAP , CANADA
  117. Can't get this car out of my head...
  118. Can somebody run carfax for WAULD64B44N036702 ? Thanks a lot!
  119. Finally found a good use for the armrest!
  120. vibration damper & Tensioner
  121. dash beep driving me crazy-long
  122. The Crispy ChikAAN saga continues
  123. Starting problem, need some suggestions from the experts:)
  124. replaced t-stat and guage reads normal again, but channel 51 is reading 70c while cruising
  125. adriano, can you email me the specs that HAP gave you for revalving the bilsteins?
  126. Caption Contest
  127. Applying Leather Conditioner Question...
  128. Hollah!
  129. Question / problem on Bilstein / 2B mounts....
  130. big brakes pads
  131. Has anyone used 034's RS2 replica injectors yet?
  132. Rear alignment question...
  133. Crazy things done to C4 X-post
  134. Any Opinions on Sythetic Oils?
  135. s6 oil cooler mod done
  136. Recommendations for cheap, dependable auto transport from CA to IL?
  137. K26/gt3071 turbo questions?
  138. ETKA online is now hiding the p/n's
  139. A fair price
  140. Viscous Coupling or Shaft any reasonable source to buy from?
  141. so what would be the symptoms of a broken wastegate spring?
  142. ok...my coolant is green. I'm about to flush the system and change the t-stat.(Q inside)
  143. Is installing the 3 spoke sport wheel a PITA?
  144. t-stat replaced and radiator drained without lifting car off the ground:)
  145. End of a 1.8t coil pack conversion "science project"
  146. Strange boost lag?
  147. where can i find the best price for MTM chips?
  148. My fun earlier this week...
  149. boost building issues
  150. How do I remove the X-plug on the power steering pump?
  151. Does anyone know for sure if the Euro S4 bumper fits over my Apikol FMIC
  152. Thinking of buying a S6 that has problems.... (need input please)
  153. Strange Electrical Problems
  154. A question for broken clutch master people...
  155. Alternative to G002000 (Pentosin CHF11S), Fuchs Titan ZH 4300 B, both are VW TL 52146
  156. Do you need the 3-Bar sensor with the Tap Stage 1 chip set?
  157. Audi Avants
  158. Mileage roll call- I'm at 162,300
  159. T-stat?
  160. Allroad delete & BBK complete :-D
  161. Will I burn in hell for leaving the protective rubber boot off the shock body ?
  162. Engine kind of loud at idle?
  163. MTM 1+ finally installed...
  164. Audi Expo 2006 Photos
  165. Drivers School
  166. |skolnick likey
  167. Radio code missing
  168. Goodbye my K24
  169. It lives
  170. Do BBS RC wheels (17x8) clear big red's?
  171. Come on guys, somone has to have a 10 disc changer laying around...
  172. Can you hook up a Blitzsafe adapter to the stock cd changer cord
  173. ECU with TAP stage1 on Ebay
  174. Sheite... my clutch pedal went to the floor today. Had to get the S towed home.
  175. stock '93 968 Porsche v my UrS6 stage II chip how will I fair?
  176. Need help tonight with fuel pump!!!!!!!!!
  177. Tired and frustrated.......
  178. Two recent S-car sightings...one Pearl and one Dark Green
  179. Heys guys just thought I'd say hello and introduce my new little friend.
  180. leak>>>> what could it be coming from???? passenger side
  181. Cruise Control wont engage - how to troubleshoot
  182. best price for POS units?
  183. Anyone have a working stock early 95 radio for sale?
  184. out of curiosity, those of us with lowered cars
  185. Eibach Pro Kit
  186. can anyone identify these for me please?
  187. just had my handbrake replaced, did not realise what a big job it is; - Audi dealer cost me $600!
  188. I believe someone was looking for Borbet Type E wheels
  189. AMD S4 (BWW and 10UW)
  190. Fiberforge CF car parts.
  191. Will these rotors fit stock everything?
  192. Rotors
  193. GM Top Engine Cleaner
  194. Paging ChefBob...
  195. Finally drove the car today!
  196. SUSPENSION FUN FROM ADDICT MOTORSPORT DESIGN
  197. HRSB Rear sway bar on ebay
  198. Eibach Prokit 1529.140
  199. hap, where is fiber images getting the mold for the CF hoods?
  200. OK, convince me not to do it.
  201. Should I trade my A4 w/56k on it for a Urs6 w/ 76k really nice
  202. Is there a write up or...
  203. 94 S4, where is the flasher/hazard relay? thx!
  204. Black wheel bolts?
  205. Odd surging sputtering in 4th 5th 6th under full load also ...
  206. oil cooler bits are on the way
  207. Updated!! S6 the car smoke out...
  208. please post close up pics of your tints at edge's of window where the glass is dotted and
  209. Anyone have a stock 10 disc cd changer for sale or borrow?
  210. BLACHAWK FARMS 2006 REGISTRATION IS OPEN!
  211. A6 and S6 hood (95-97) plug and play?
  212. Crispy ChikAAN Ballar
  213. Carbon Fibre Hood GB...
  214. "her" name was Maximus....gotta read this....enjoy!(nothing to do with Audi but touching)
  215. Sweet.
  216. Moisture trapping...
  217. Bad Harmonic Balancer?
  218. What should I treat my Lloyd's mats with before putting them in my car.
  219. Adriano and/or anyone else, need the part # for the black coolant fitting/o-ring at the back of
  220. "Antilock Brake Off" light is lit/rear diff lock button not working? Fuse for dash lights not workin
  221. I think I'm leaking.... boost.
  222. ok, i have to ask, whats the deal with these people saying their cars are faster at half throttle??
  223. Where to get a new Power Steering pump
  224. Thanks VR_life re:sunroof thread/anyone know serp bearing part #/anyone have extra coolant T?
  225. Best in show es2, crispy chikaan on 18" chromes, qpilot and skollie
  226. I want a tow hitch.
  227. getting tinted tomarrow, wonder whats the best percent to go with a black car?
  228. my drivers door handle is getting a bit sticky and clunky, both inside and outside
  229. is it bad to mix 10w40 synthetic and 10w30 synthetic if less than a quart?
  230. Can somebody lookup part numbers for me?
  231. Turbo to MAF hose
  232. Need quick diagnosis...what spark plug can use from FAP?
  233. thanks to a good friend and some greens my car is no longer an allroad.
  234. Where is the best price for the OEM oxygen sensor?
  235. X-post and slightly off topic...
  236. Are the bumper shocks one time use only or can they pulled out and reset?
  237. Weird brake pedal vibration on startup only, lasts ~20-30 secs, then normal. Any ideas? TIA!
  238. normally,is there a lot of oil can stick on the intercooler?
  239. when does the rad fan come on?
  240. Need help finding this pic: 1991 200 20v Brochure
  241. Any suggestions on HID upgrades
  242. anyone else have a really stiff ignition cylinder? should i just spray WD on the key and stic it in?
  243. electric gremlins caught up front!
  244. any issues with switching to synthetic oil at 140k miles?
  245. so i replaced my brakepads...first time doing the rears. is my brake pedal supposed to feel mushy at
  246. $35 afterrun pumps...
  247. for a 100hp gain, would a chip and intercooler do it?
  248. Replaced afterrun coolant pump and T connector..
  249. Front suspension troubleshooting
  250. HI guys!!!!! (kinda long)
