View Full Version : Audi Original "S" Cars
- Paging Weldo aka Stroker//S4 - YGM
- FYI: Limerock Park AW event feeler:
- I'm going to be following these instructions for the HVAC blower r&r...
- 996 Caliper Pin Q.
- URS6 Motorola Blue Tooth Integration?
- It appears as though my IR key's cool dip in the pool...
- If you have a problem, if no one else can help, and if you can find them, maybe you can hire...
- What's the deal with the sunshade bar? It's *barely* long enough to catch the cradles at either end
- anyone with money?
- Anyone else pressure washed their engine bay ?
- Okay, who bought the Casa White S6A off S-cars classifieds?? You officially suck!
- Pearl 93(?) spotted in MN - hwy 110 at Dodd Rd (Mendota hts)
- Just found pistons for our cars 539 bucks from wiseco DAM thats cheap!
- Anyone have any good urS4/S6 rear calipers they want to get rid of?
- Where's Weldo ? (Engine received - thanks !)
- Paging Trent (TRTW)
- Incase you were interested in the '93 S4 from Ann Arbor MI on AudiFans
- update on heater core replacement
- is there a write up on installing the group buy CPS? can't find in the FAQ
- so i just got accepted into UTI and my g-friend finally said YES to me
- 20v Phenolic intake manifold spacer kits now availible!
- Chicago Area Peeps: Anyone willing to help out with a blower motor R&R?
- Can't really beat this for bolt-on power vs price. These guys in a way are lucky!
- Anyone got pics of a UrS on these?
- 034motorsport faulty hotside? What should I do, these are pretty good guys to deal w/ but...
- Got Tricks?
- S6=1, Boxster S=0
- I'm always the only "UR". 8^(
- Is this where everyone gets there stroker engine rebuild kits from?
- Intermitent Coil Pack... How to tell which one is failing???
- Funny how a RS2 turbo is only @$650 american using 1.35219 as a conversion rate.
- How many foot lbs of torque do the cv bolts require to attach to the transmission ?
- Paging scott12v@pghaudi
- Nice place for an Exhaust!
- Those funky euro headrests...pre-'95
- Backup light portion of the tailights are foggy, anyone ever able to polish out?
- Followup: What are the chances a new pilot bearing could cause the clutch not to disengage?
- I need the replace my EM gasket. Any BTDT?
- Ripe for the picking! Now if only I could find someone that could sell me a Turbo/Mani package ..
- Hi guys. Anyone has a link for the heater core replacement with photos?
- PSA: Singing to yourself without a working radio sucks :)
- Anyone with a spare POS in Vancouver?
- Took the car out after fixing the bucking problem, after a few hard pulls I feel hot water on my
- I want to get my headliner redone...anyone know of a good shop in or around Boulder, co
- Power mirror module 1994 UrS4
- oh snap! just got my fan clutch, it's made by Meyle. anyone running this clutch?
- Eibach Springs ... and Boge Turbo gas? anyone done it?
- Can the amount of "Servotronic" assistance be modified instead of just disabled?
- Poll: Which state has the largest UrS population?
- Hesitation, Running extremely rich
- Can a trunk lock be fixed?
- Indicators of a failing rack? (and yes, I know "sagging" is atop the list) ;^)
- So who's car is at C&S in Mamaroneck today?
- street/track tires
- what is the cost in labor only for rebuilding the bottom end?
- Coil caps
- OT: If you have a 30 amp appliance, what amperage fuse would you use?
- Stock Boost Gauge
- Some questions on the urs6
- Clutch won't disengage. Good pressure, good pedal feel. Ideas?
- almost!
- Just in case anyone's doing a turbo this summer like me...
- Can't these be braced so they aren't so prone to cracking?
- Anyone know the part # for the p.s. X-plug?
- Paging VRLIFE, Brian Weldon is trying to get ahold of you, YGM!!!!
- 5mm spacer thickness with new 45mm lugs.
- Alternator or Voltage Regulator?
- OT: Chicago Peeps.... i'd like to invite you ...
- 1994 S4 MRC Stage II chipping... is it good?
- Anti Lock switch pin out?
- S4 took a dump.....any insights?
- Hey, don't throw Daddy's key into...
- Carbon coilpack cover on ebay.
- Website updated - Headlight lense replacement and cleaning
- Caption contest...
- A small gathering of the faithful.
- psa
- Searched for huge bucking sudden loss of power at WOT and I really don't know where to start.
- No headlights, power windows, temperature controls or temp readings, but...
- The grand pappy of all 20vT's, I rode to get breakfast in a Sport quattro today.
- Well, I sea foamed my car today, and the idle misfire has subsided*knocks on wood*...
- Went out to the car to check plug torque and found one of the plug boots is stuck to the plug...
- LED bulb replacement for temp display?
- Thanks UrSoccer_mobile for the bulb prophylactics!
- get it while it's still available
- Pulling codes on the 20V???
- How does one go about removing these switches?
- Delta radio removal...
- Door Lock Fix - Easy match with good help
- Got the Concert Radio and CD Changer today...
- I miss driving my S4
- is re-installation any more difficult for the S6plus bumper than it is for the US bumper?
- Check your cv clamps!
- Raritat...
- Interior Dash Lights
- Shine her up for the show - Carlisle
- Changing my headlight lenses, found a big metal wall blocking the light, wondering if it's normal...
- Drivers side door lock worn out, won't open with key anymore
- Vancouver/Nanoose Bay/Seattle area listers (VLAC)
- Cleared the fault codes, this is what I got..
- hey guys can anyone tell me if theres a write up for the clutch/slave master?
- Think I fried my radio :( ....
- I'm moving to Tampa, just thought I'd let you all know.
- Had my Avus rims restored...
- Today for the first time ever I checked my spark plug torque. I hope Dave approves. :-)
- So there are REALLY the best CPS replacements???
- 3 more questions from Noob that just purchased a 95 S6
- Misfire saga continues..pulled blink codes, got 2111...rpm sensor...
- Man I wish I had a lift.....I'd do everything myself. So tired of half ass work......
- So, How u guys getting the Optima "Red Top" to fit??
- Where's Weldo?? Is he making another trek to CT? If anyone see's him......
- One more leftover, Avant specific European taillights...
- Anyone have a spare POS they'd be willing to give up?
- When you hear a scraping metalic ticking noise, don't immediately PANIC because...
- just installed MRC Stage II ECU
- Red UrS4/S6 on I-84 near Poughkeepsie NY on Wednesday heading east bound
- RS6 brake system
- slightly OT... Dear Mr. Nys Guy... thanks for sending me your family album... Kate is a cutie. ;)
- I got my one freeby (POS rewire)
- urS4 still sick, flooding on startup, and cutting out??
- Does it need longer lugs for 5mm wheel spacer?
- What sort of sealant should I use when replacing headlight lenses. TIA
- Trying to Decide between UrS4 and 91 200tq 20v - need advice!
- PSA Concert I retrofit update.
- I want to buy an S4/S6 with a dead/no motor
- Light Switches, From S4 to S6 Pinout
- note to the forum running over tumbling metal object = ive been hammered for the past couple days
- *if* I was going to buy an RS4, it would have to be this one...
- if i had the money...
- Occasionally when I start my car I hear an....um...gurgling coming from the back end. I think.
- Lol at small blacks.
- Anybody need a spare?
- DAYTONA
- anyone running AT Italia S5s?
- Why is it when an S-car is advertised for sale...
- well, looks like i blew my motor....
- Someone send me an email when it's over.
- What is a POS?
- Anyone from here?
- SPEC Clutches...
- thinking about running 18x8 Ronal RTs?
- Just purchaced a '95 S6...couple newbie q's
- Bumper removal --> EASY; Bumper re-assembly --> NOT EASY
- you guys are funee
- Guess who is driving.
- Enjoy
- Mike Cialowicz for president.
- Dave Forgie for President
- I talked to big BP today. The Burien meet will not be in June and it will not be in Burien.
- It doesn't matter if you're black or white.
- Do I really have to say this again? STFU.
- Diagram of front bumper mounting points available?
- Bosch Tri-Electrode spark plugs from 034...
- Sources for brake accumulator aka BOMB? tia!
- What happened to the FAQ? It dissapeared. (It's my Bible, you know)
- Any UrS owners going?
- How do I search this forum... I cant seem to find it in the list.
- IC red bulb cover.. a.k.a. red condom
- I cleaned and conditioned my leather for the first time today
- Xenon light question? My Proxenon Ballast burnt up twice in the last year. Question for those of y
- I just tried to get my cabin air filter out and failed. Is my car different?
- putted H&R 29828 in yesterday..
- Brake light on and pedal to floor under heavy braking (found when seating new pads to new rotors)
- Got to love a clean //s-car ;-P
- Poll: Has the price dropped out for our //s-cars, or will the value continue to fall?
- Looking into a 1992 UrS4...and some advice please...
- A topic that hasn't been discussed lately... Is this truly cheating? Or just an alternative?
- where do you guys get your EM studs from? 034 or FLAPS?
- Could bad motor/trans mounts cause a highway vibration similar in effect to that of a bent wheel lip
- What is the best way to remove the turbo coolant line that wraps around the head?
- Has anyone just upgraded the Rotors with larger ones and keep the stock Calipers?
- So I want to run no front plate.
- Why don't you all just STFU.
- PAGING - UrScubed, I just bought this...
- Strut mount issue...
- Help!
- New MRC chip - Installed
- Beware the big spring...
- I wish eibach made pro-street coilovers for the UrS4, they are amazing!
- Concert I into UrS pre-95.5 update...
- Run in with a E39 M5 - again
- i've been busy today....racing an R32
- Clunk when pulling away from stop or coming to a stop.
- 95 S6 transmission
- Euro licence plate bracket
- Quattros on the Dragon
- Chris, Julian, and Nick were reping the S-car community at Primer '07 @ Yarrowsport in Providence RI
- How do i remove master window switchs, i need to replace one switch in master
- BBK update, leaky left rear brake line
- Help with Studder/Hesitation (Long)
- paging AUDIDOIT, your email address keeps bouncing
- Does anyone know the top speed capability of a "stage 1" (ECU/exhaust) UrS?
- hello everyone
- stuck hood
- Three brave ur-S cars attended the Maplewood Porsche/Mercedes-Benz car show today.
- Challenge: I say "400 hp" and "I am on a budget" is oxymoronic. Prove me wrong.
- Wonder if my oil cooler is working "too" well.........
- C5 A6 sports seats in C4 UrS4 - Do they fit ? Can they fit ? Anyone made them fit ? ;-)
- Brembo Caliper Part Reading Key
- Ran in to a snag on my RS2'ing. I planned on using Adam's 95 head but I discovered that it has
- If i wanted a bigger turbo on my current RS2 setup what would you guys go with and
- info on busings for Hap bar
- Now this is an engine. Finding parts might be a tad difficult.
- One way to spend a Saturday, good bye G60's
- urS4 intemittent cutout and starting prblem ????
- Update 2 for no start. Flywheel pin is there. read on
- Anyone got a set of nice grey sport seats they want to sell?
- Turbo inlet hose / low pressure side / Accordian hose.
- Marvel Mystery Oil did some good.
- Need help reinstalling the sunroof accordian flaps
- Viper brakes
- When 034 machines a 7A head to UrS spec (with water manifold) how do they deal with the CPS issue?
- How much thread is enough for my wheel bolts?
- I've STFA w/o much luck. What is everyone doing w/ their pre-turbo plumbing when going 3" at turbo?
- Connecting VAG-COM help
- Stock wheel center cap question
- Anyone looking to get rid of their stromung?
- Finally.
- has anybody ever heard of this problem?
- Spotted Champagne? urS6? southbound on US-31
- no fuel
- Only-Emre and Germantoy are GENIUSES!!!!!!
- Feeler...All for sale... talk me out of this though...ok?
- I STFA's, any idea of a stock S6 exhaust (DP and all w/ good cats) is worth?
- Sporadic fault.
- Why oh why did I wait so long to put my Stromung on????? My windows may never go up again!
- Super Rare Emerald S6 Avant FS (OK, so maybe only rare on ebay), but read on!
- Is this a fair price for a used RS2 EM?
- another question
- question
- Pointers on removing ECU and swapping chips
- PIMP MY RIDE 1994 S4
- too lazy to search, just Yes/No. Is a press required to R&R the inner control arm bushings?
- Skollie, set up our registration. Its S-Fest West time! =)
- skolnick YGM
- front stock struts
- Skollie, what's the date for S-Fest West? I gotta put in my request early!
- Paging UrS4boy... Send me an email! I've got an offer that may be of interest to you.
- e/S2 3B engine ECU problems...HELP!!!!1
- I screwed down the WG spring to seven turns, previously was set to six.
- (UPDATED) these are pricey, but are they car specific or will they work with HRSB?
- Hmm, OK now I'm sort of confused.
- RS2 set-up question...
- My new wheels are here! :-D
- Spark plugs
- Still looking for 7A cams - am I retarded or just looking under the wrong rocks ... ?
- looking for part number for S6 headlight lenses, I STFA'd
- is this a good price for the following?
- So, I am going to try this Miracle Mystery Oil stuff...
- Any one see this header?
