View Full Version : Audi Original "S" Cars
- Where to buy BBK brake bracket 8A0 615 125A?
- Sadness.
- RS2 High output manifold flow numbers
- The Audi sickness has spread to others...
- relay question
- Andrew WK. If you are not still following my problem please check link
- What is a good price for a tooth belt pulley? 034 105 263A
- 2Bennett Coilover spring rate. What are you guys using for spring rates? They reccomended 380/500.
- Anyone has a spare coil pack cover?
- Update on boost saga.... And I need an OEM waste gate spring. Can anyone assist with that?
- Euro light bulbs
- 034 Motorspot... Any opinions?
- can you tell the new one is thicker?
- Anyone running the 2B camber plate?
- $2k UrS4 in VT w/ stromung, chip, RS2(?) manifold, etc... needs new front axles and has 190k miles.
- 7A exhaust cam if anyone wants it.
- X-Post: So any of you guys near Montreal know this guy selling C4 suspension? Scam Alert!
- Carlisle 08 weekly update.
- Not mine, but found on Auto Trader
- pulling codes/no boost on an AAN converted coupe
- My Apikol 1.8T Coil kit should be here tomorrow and I have a question...
- Where to buy lower door trim, Blauparts NLA !!
- New Ur owner
- Looks like the RIV caught on to the wagon loopholes...
- Hi
- Paging VR_Life... I have a question for you.
- I'm sorry I have to subject you to this Carl.. (FJ40 neglect)
- Just a little update. I've been out of the loop.
- Looking at an S6 and am in need of a little help.
- Looking to buy... a few questions
- Need to buy a few more 1.8T coils. Where's the cheapest place to get them?
- Channel 51 is weird.
- number stamped on the PP is 124006110 (white paint) and a J4 below the number
- Why is diesel gas so much more expensive than regular???
- Boleros strike again
- Flaring rear wheel wells
- got a free chipped ecu.... needs stiffer spring now - should i get 1.9 bar or 2.2
- LuK replacement clutch kits - the correct part number (I hope)
- Found an S6 for sale in my color...
- Anyone have a set of '92 springs to get rid of?
- Anyone have a timing belt cover?
- A litle DIY fun... Restoring an old Rally Quattro...
- Audi really kept this on the DL... Canadian Diesel and Rally content...
- Front wheel bearing R&R, tips or thoughts before I begin?
- Who has custom fabricated turbo heat shields for our cars? Or should I look into something else?
- Thinking of removing the 7A exh. cam... = increased mpg? Thoughts...
- If you're going to own a URS, you should have a 2nd car or another means of transportation. Discuss.
- clutch disaster
- I named my car today. I named her...
- well an S car tune up is cheaper than my bicycle tune up:) allways look on the bright side of life
- Used Oxy-Clean on drivers seat leather today
- Failed emissions again OR Getting desperate OR Anyone got an ECU I can borrow for testing?
- OK ,,,,I've searched,but I can't find out what the Firing order is.
- Link to ordering Audi information, e.g. 1995 S6 owner's manuals.
- guys how easy is it to change the throttle potentiometer
- Couple pictures from this past week..
- were to find the 5 $ coil rubber connector
- anyone want original wheels (non-fuchs) with stud ready winter tires (no studs).
- NEED TO RENT THE CRANK LOCK TOOLS ASAP!
- About to sell my UrS, value opinions appreciated..
- Funny ad (Silver S4 4 sale), they used pros and TAP in the same sentence.
- S4 U boat fixed!!!
- Ok, so I finally got off my butt and got my tranny pulled... now I am very confused!
- Brake Problems
- Is it possible to have an S6 3 spoke steering wheel while maintaining the functionality of the trip
- bad rattle from inside bellhousing, goes away when clutch depressed. ideas?
- I there a Ben from Boston here?
- Is there a troubleshooting procedure for the Cruise Control?
- how does one post an audi pic on this ???
- Anyone have a line on used cosmetic parts? I tried the used parts links, but I never get a reply.
- Revised thinking on an AAN intake tract boost leak pressure test
- S4 U boat
- Looky what I found... (56K NO WAI)
- So the other night I went out to a hot nightspot in the city...
- Lots of problems with A6 QUATTRO NEED HELP PLEASEE HELP
- Has anyone had the owner's manual in pdf?
- mmmm... I've always liked these wheels on our older Audis
- Dave - the "bonus material" on the DVD is pretty cool.
- will the 9" bondhus t-handles be long enough to pull the intake manifold?
- Are '02 996 front brakes the same as a Boxter?
- What if I bought a CQ shell and swapped my driveline and turbo setup into it?
- So anyone know off-hand the typical range of power, uncorrected at the wheels...
- Happy Easter!!!!
- Refinishing Fuchs - input needed
- Anyone ever try the chips from Speedtuning USA or InMotionUSA ?
- Chipped S4's are surprisingly quick.
- hesitation issue
- Pics and stuff (Enjoy)
- is there anyone willing to check out these UrS6 for me?
- so turns out it not the injectors or the o2 sensor when i was checking
- Boost saga continues... (longish)
- clutch job.........disconnect the downpipe or not necessary ?
- 034/Wagner HO RS2 Manifold Price Increase March 24th
- WTF! I need help with this emissions problem.
- Corey YGM
- Can I run my car without the fan clutch?
- drilled & slotted rotors; do they wear down pads too fast?
- Look what I found while cleaning out my storeroom...
- How to tune fuel injection systems (with MAF and MAP info)
- question regarding map sensors
- Looking for a built s4/s6
- haha, i had to put some punk teens in their place on the way home tonight...
- Official I've got a VAGCOM, what can I do to my URS car?
- Anyone looking for an S6+ front bumper?
- Oh, MiniMan!! I've found your fender flares. I think you'll like.
- Bypass / Diverter Valve "flutter," sound. Normal?
- Low Mileage s6 avant on ebay
- if I am a US citizen, can I drive to Canada and ship a set of tires to a Canadian
- Which way does the AAN engine twist (facing engine from bumper) upon accel? CW or CCW?
- Any of you guys live around Cincinnati/ Northern Kentucky?
- Flap motor replacement. Please feel free to kibitz, I'm sure I've missed or forgotten something.
- Any BTDT's on aux coolant pump installs...did you get air bubbles..
- Let's say you have a car that sustained some front end damage....
- The current stable...
- Anybody in the Philly area up for a GTG, Mon March 31/Tue April 1?
- Ups man delivered a little present today, my wagner rs2 manifold finally arrived...
- Procon Ten Commercial
- 255-35-18 Kumho Ecsta SX is a grippy tire eh?
- I KLOZ MAI EYZ.
- does removing the MAF screens really make that big a differance?
- Still in search of a single Avus Rim.
- Took a few minutes to spec out the RS2 caliper brackets before I get them installed.
- VW Eurovan VR6 afterrun coolant temp sender, activates at 93C (198F).
- What's a fair price to offer for a used Boxter kit?
- leak in trunk... anyone have solution
- Boost gauge question(s)
- LED HVAC Display
- Audi Shops around Davenport
- Was someone here looking for this bling. I think its for C5's
- don't see this too often in WV
- Stromung now at Gen #5. for those now in production- corrected URL
- Where can I buy the RS2 caliper carrier bolts, other than 034?
- 255-35-18 Falken FK452 or 245-35-18 BFG KDW2. preferance? vote?
- update on my failed emissions.
- i got Luky today...
- So i drove an S5 the other day, thing was crazy fast. Which is why i'm calling bs on it
- Does anyone know if our alignment specs are the same as for c4 100q/a6q's?
- im stuck on why the car runs sluggish at low rpms..
- Has anyone removed the input shaft seal on the tranny?? searched and couldn't find anything....
- 13.5 Footwell/Defroster Flap, static block code. <<cold feet>>
- v8 rear diff advise please?
- DIY instructions for the Carbon Fibre climate control overlay now available (link inside)
- Anyone interested in my 94 urS4? selling it...
- anyone have a spare key front panel
- So I am down to only having an overboost code. Is there anyway
- 80 MPH engine speed?
- So got my new coil pack harness from 034, it's in fine - now there are new problems....
- Shops in Davenport, IA
- when i close the throttle the car jerks
- 93 S4 207,000miles good condition, ne ideas on a price to sell for?
- I AM LOOKING FOR USE STUFF-rs2 bracket-60 lb injector-
- Any interest in a Group Buy for LLtek's lower valence for the urS4/S6 ?
- woo hoo, rear main leaking and 1st gear just started slippin a bit then you let out the clutch=(
- Scenes from the Initial Post-Purchase Punch List
- Friday 6pm Pearl S6 on HWY 17 Nothbound south of Sidney BC... anyone here
- Interior Colour Codes
- New (for me) 93 S4
- Tpierce, do you think noise is an issue with your KDWs? reviewers all complain about horrific noise
- Can some one give me an interior color code for Platinum ('95.5)??
- How to fix th oil leak from center and rear diff?
- Way OT: I saw some guy driving my old Jeep today (not actual pic, but exact combo / shape I had)..
- Ah, CRAP.
- I checked the FAQ and STFA...Where is the best place to get G4/G28 Sensors? Simple :)
- so concensus is that ECS stage 2 314x30 rotors and big reds are noisey?
- "Daddy, why don't we ever ride in the silver car?"
- 245-35-18 BFG KDW2 or Toyo T1R? & anybody got Emry's email? what size BFG did he go?
- Wagner Engineering/Tuning now has a T3 version of their new RS2 EVO EM
- Rear diff oil seal.......how to stabilize rear diff
- Anyone tried goodyear F1 all season,sound a great tyre.
- How much boost are you pushing?
- can i assume that my key fob is busted? by key fob i mean remote
- Pulled head. Interesting find....
- The "cornerstone" for the Avants Bosectomy (Bosectomy is a Kday tm)
- PSA: Aftermarket Cam Position Sensor CYHME301 replaced with BBHME301
- grrrr
- Pass or fail? I like them but I'm not sure I love them. Rack's Sport Edition D3's
- Who is this person and what have you done with him?
- Free to good home: 15" steel wheels, with worn out snows.
- Best tires for stock 225/50-16 rims?
- Variable nozzle turbos are so much more fun than fixed housing
- No headgasket walkthroughs?..tips... ricks...wisdom? Going down that slippery slope tomorrow a.m.
- Classic... What power steering fluid to use? Read On Please!
- lifting wiper at speed resolved with new wiper arm...
- So, are you guys saving the "economy stimulus" check or spending on UR "S" stuff?
- VVME hid help.PLEASE
- spotted: pearl s4 in barrie near kozlov centre... lookin' good!
- For those who have tested their OE Beru coils, what were the readings, e.g. 30 kV? 45 kV?
- Keep the faith!
- i just ordered my clutch ....
- New Front Bumper...
- do the lower bolsters come off of the seats?
- hello potential:
- Any leads on an RS2 or RS4 Tranny ?
- back to the tire debate, 245-35-18 recomendation?
- Sweet manifold, but prolly won't last (cross post from 12v dev)
- Dave, I wuz thinkin' 'bout your K WGFV.
- Just totalled up all (repair) receipts for the car since new. Anyone want to take a guess?
- While inspecting my timming marks i noticed my timming seems to be one tooth retarded
- Please tell me how this ebahn things works... I installed but cant access any thing.
- PSA: don't go to radio shack for your 386 key batteries
- ECU wont perform output tests...
- Take the PLUNGE?
- little update
- Oh yeah, good bye spare tire!
- Concensus on running an 044 fuel pump on stock injectors/ECU
- Stupid e-Bentley question.
- Full black interior coming on the market soon.
- well, ordered 2 VVME HIDs on the 11, and they are in Kentucky right now, be in my hands
- Any in PA (or near by) have timing belt tools : 3256 and 2079(optional) ? Need 4 this weekend.
- come to the 5th annual Carlisle PA Audi gathering!!!!
- Ok, not an S-car, but I thought you guys might enjoy one last photo before we head to the dyno...
- Yet another flywheel option for you guys now, lightweight steel flywheels availible!
- Has anyone heard these Morel 5.25's?
- Interesting junkyard find today....
- Audi RS2 clutch disc+pressure plate
- ELF Excellium LDX 5W40 no longer available. Total Quartz 5W40=same??
- oh snap, are these A8 wheels?
- preferred source for front control arms, tie rod ends, and rear caliper
- Gas Mileage?
- Cheap, clean and rather MacGyver like DIY ipod integration and charging for the S6
- squeeeky steering wheel. sounds like a dry rubber bushing that needs lube... any temp
- Guys got squicky rear drivers side koni sport,can i lube it somehow??
- Found this on Craigslist. Parts car?
- My emissions story: HC and CO both just barely over the limit.
- ISTFA - FMIC Pipe
- fast car video
- Speaking of steering rack issues...
- Wide-band oxygen sensor installation question for kday.
- Small enigne Fan
- best place to buy POS sensors? i assume dealer - anywhere else?
- High HC--Failed emissions.
- Right. Got married last week.
- any tips on a clutch kit?
- My suspension work is done, the rattling persists, steering rack suspected, advice?
- I finally got to the timing belt and,,,
- Clutch Adjustment Proceedure?
- BBK users, what is your brake pedal feel from initial press?
- broken ECS caliper bracket
- Ahh... but does Hap have one of these?
- Koni adjustable shocks...
- I need a MAF to Turbo hose if someone has a spare lying around.
- Just got a black '93 S4
- Wanted: Sure-fire, non-damaging, method of removing 93 black plastic HVAC trim.
- S4 is off the road. My CQ passed emissions testing this morning. I expected a fail really...
- does ECS warranty their stage 2 caliper brackets? or if not is there another bracket
- Hey, Dave, URS4boy, I have a few hours to spare, where did you buy your ..
- tap chip
- 28cm in 24 hours
- Hello everyone! new initiate into the audi URS fold here
- Looking for threaded piece for front tie rod end. Left side. Anyone?
