View Full Version : Audi Original "S" Cars
- The cars beats me on "drinking"!!
- Lowest price spark plug source?
- ATTN: UrS4boy since you seem to be the leader of the Leavenworth Drive...
- Does anyone want a phone just to give an original look to their car (if nothing else)?
- Need Help...
- so I charged the battery with a stand-alone charger, and it started right up
- wonderful surprise as my b-day is coming on saturday....my mirrors stopped working
- Need detailed technical info about turbocharging.
- do the electronics portion of fuel injectors really go bad ?
- WTF? an avant towing a 4x4 in this vid (wait for it) CIalowicz this is for you!!!
- YAAAAR... the cabin of my fine vessel be smellin of coolant when she's at full sail...
- Quick fix to the spring sticking out in front seats??
- Does anyone know a tuner in Chicago?
- Avant question regarding towing......
- Avast ye scallywags! Grab yer ale and a wench, and go for a sail in yer...
- STFA and printed off the diagnosing missing/hesitation. Need some additional input
- Anyone changed seats in urS6?
- Could an ISV fault cause a stall at highway speeds?
- 93 90 CS climate control looks the same as ours, are the connectors the same
- Source for Auxillary Fan .... need to replace the fan....
- Anyone interested in a set of New Front Koni Sports
- 2224 code "overboost" today
- RS Header Progress.
- Replaced leaking heater core, tstat, and back of block coolant fitting over the past week.
- OK, I'm stumped.
- Anyone (in US) interested in having Mihnea custom tune their car ?
- just picked up 5 quarts of Mobil1 0w40 fully syntetic......to thin?
- One week to the Leavenworth Beer and Brats run. Remember....
- What part of the front propshaft CV do I whack to get it apart?
- Interior door handles stick open... Is this just a cable replacement?
- Finally got one
- trying to install new MFTS, i know i need a 29mm socket, but i can't seem to find a deep one anywher
- The wife is thinking about selling her europa blue RS2'd avant, what would be a fair asking price...
- Can someone he lp please? I was helping a friend pressure test his 2001 a4
- car doesn't start....beautyful!
- Anyone have/install the Apikol SSK?
- trying to get some advice on my GF's saturn from the saturn forum and they actually had the balls to
- ugh...i've let Ze Vagon sit for a few weeks and it won't start now. can't even jump it
- Found another boost leak. Tiny hose looks like a T right under the Throttle body.
- Who needs a lift...
- Any shipping company suggestions from Germany to North America?
- Valentine 1 is hardwired and working beautifully... I also improvised...
- My next-door neighbor is hot.
- GT3076R vs. KKK hybrid turbo.
- alright got my boost leak issue resolved, but now i have a coolant leak. upper radiator hose needed
- Anyone see one of these before?
- Can someone confirm that we can use POS part # 4A0 905 351 instead of 4A0 905 351A ?
- Anybody know of any used brake upgrade kits for sale?
- FREE: stock bulbs/projectors anyone? Taken out for HID upgrade.
- Bill the Cat, my hoes have arrived. Money on the way.
- Bummer ! 034 Salt Flats run abandoned
- PSA on getting hoses rebuilt
- What do I need to remove so I can get to my camber plates?
- This may be a hard question to answer, but... Are new transmission mounts worth $150?
- Can someone show me where to tap in to use this Sea Foam stuff
- for those of you who bought P/S pump rebuild kits, where did you get them?
- What is a Samco Michelin Man Hose worth?
- Bosch 0 280 142 102 diverter valve(C408612947)
- OEM Xenons Vs Euro projectors/lenses and H1 Xenons
- PS Pump R&R writeup (edited to add Bill the Cat's input)
- Pulled my codes. 2413.
- How to remove switches from the drivers door panel
- A small success
- Finally back on the road just in time for //SFest.....
- ABS sensor
- Check this out. It is finally on the car. UrS4boy Thanks for wiring information.
- Where to get 10 disk CD magazine
- passenger side wiper
- This thing is large.
- Anyone installed Central Locking & FOB from a later model C4 chassis Audi (e.g. A6)?
- Is the s6 flywheel dual mass?
- VR_life, a few pages back you showed pics of your new LUK flywheel
- I will sell my car for $1000 today!
- turbo whooshes and dumps all it's boost at high rpms - can't hear the bpv at all...
- What wire in the sunroof control area do I use to tap into for the V1 hardwire?
- Steel Crossover pipe... who wants it?
- trip odomometer Help.... when starting the car it displays In . 2 or Ln .2
- Next question: Who uses Black Magic Semi-Gloss Dashboard protectant wipes, Or similar??
- 1992 S4 stock springs on..
- Autohaus Arizona suspension parts
- so, let's say there's mineral oil gushing from the rear of my P.S. pump ... any btdt?
- Front Suspension R&R
- is this the same part???? links inside
- Who here uses their Valentine 1 on the dash instead of the windshield?
- So... reusing 12-year-old exhaust hardware looks to be impossible.
- sometimes i miss having my old car :(
- *** Hartford, CT GTG, Wendesday, 9/27; Over 40 participants....are you joining us?
- Civic Killzzzz....
- Would the dealer do this?
- Anyone have a 10 disk CD changer bracket?
- Avant owners please read......
- Gear box question/issue:
- rear suspension problem?
- $2300 for a 56k mi 6 spd b5 trans OR $3300 for a stasis built c4 5 spd(cryo, 4.10 diff) hmmm
- Seafoam, yea!...? [edit]
- Hap, please email me offlist about the hood.
- OCT 9-10 : 2-day ACNA track event @ Willow Springs (not Streets). Who's going?
- If you really had to put a floor jack under the front of the car to jack both sides up at once...
- Alternative Proceedure to test your POS
- Replacing rear calipers. Link included with a quick question
- torque wrench(lpf ft) for AAN needed
- NOStradamus revealed...
- S car trivia- How long is the stock intake tract between the turbo & throttle body?
- found my pshhh pshhh source.....j hose....auch!
- woot! ICE COLD AC!
- Never follow
- What do you guys think my front seats are worth???
- K24 Surging?!?!?!
- S6 is now running 034 Stage IIC full time! :)
- Finally got my kit from ECS
- i'm sure some of you guys have porsches...or at least know more than me...
- Anyone know if you can use H1 100w bulbs for the crappy headlights?
- Just orderd the GT3076R mit .63 A/R.
- 1995 Silver S6 Avant parked next to my black 2002 S6 Avant last night in PA. Anyone here?
- Part number for wgfv?
- whats the best way to remove the carbon fiber inserts on the door cards?
- nice black S6 w/Borelo's at the lobsta place on county line road in denver.
- i had to post this.....look at the smoke.....this guy is burning rubber...i can't stop laughing ;)
- C4 Nav+ update (long)
- Looking for AAN Serp Belt Tensioner part #
- All improvements are in, but the car is still acting extremely sluggish at low rpm. Questions:
- Quick Question
- this just in rs2 injectors will not support anywhere near 400 whp
- Wow, you d00ds post a lot! And a WARNING...
- My photos from Poland... if anyone's interested.
- anyone familiar with this car?
- 486 CPU aluminum heatsink + custom watercooling + 1.8T coil = good idea?
- Camping with the S4
- RE: Anyone have a spare working coil. # 5 coil is shot. Please e-mail off line to arrange shipping.
- Test drove an Alpina B10 biturbo - long with some UrS content
- Rattling or Rubbing when shifting through first and second???
- need answer ASAP: where is the expansion valve? Thanks
- Look what I just found.....
- Anyone know of a factory driving/fog light for the S6+ bumper?
- How many crankshaft positions sensors are in the 20V?
- Well she's gone. She went off to a Audi/BMW couple.
- Can anyone suggest where to get rid of body parts, brake rotors, etc?
- pulling e-brake up one click disables electronic functions like speed limiter on
- Anyone in New England with a '92 want to swap suspension?
- 377 miles, idiot light came on. at 382 now, debating on going to 400 before
- strange but lovable
- Diagnosing 1.8t coil pack failures
- AntiLock Strangeness
- so last night my windows decided not to work any more...
- Xpost from B5 forum (I5 Video inside)
- Update on '95 Avant w/54K...............
- Is this an Audi part or a Mr. Lube special?
- Fuel level sender... repairable?
- The Green Monstah went on a house call,,,
- pressure test done, leak confirmed. anyone have a spare stock or samco turbo to x-over hose?
- Stuttering start has stranded me.
- Engine Problem -- What does this sound like it might be?
- Did Crapple sell his S6 Avant or not?
- anyone know about this guy?
- when pressure testing to find the boost leak, should i put the adapter right onto the turbo inlet?
- 95.5 S6 Avant Fuel Line Recall - Gave dealer VIN# and they said "must have been done already."
- So you think you have trouble passing people in the rain. Try this! *Mosport WCTC spoiler*
- Fuel Pump Relay (J17) Function - Even more than I thought. (Updated)
- u think i should wash it?
- 93 S4 steering wheel. I am not a huge fan of it. Show me pics of OEM steering wheel swaps.
- speed-related squeaking from right front corner...wheel bearing?
- Farking turbo finally blew on my car.
- To those discussing the fuel line recall - I just scheduled mine Friday. They still had it going.
- Turbo Timer installment?
- The big 2-0-0
- Anybody know where I can find a see-through view of a C4 S-car? In the e//S2....
- The fundamentals of installing a trip computer in a '93-'94 S4
- Interesting article on SPEED TV's website about Chip Herr and STaSIS Motorsports
- Inside of front tire is worn funny
- Maybe you may have seen this already.............
- TabulaRasa - The S3 will be running around in your neighborhood this weekend.
- I like this photo
- PSA: use Redline Water Wetter...it really works
- HEY SPOOLIN S6 HAVE YOU UPGRADED YOUR FUEL LINES YET?
- S4/C4 hood and a V8 Torsen rear diff needed...
- paging repeater, what are the proper values for working O2 sensor
- x-plug problem...
- spoolin//s6, the battery is a group 48 in case you haven't purchased yet.
- Need help with S6 steering wheel conversion
- es2 question. intercooler location>>>>
- Did I sta-sta-sta-stutter?
- when my car builds boost it feels like it's slower than at partial throttle.
- RR outer tail light housing... anyone got a spare they need to unload?
- Poll: How many people park their cars IN gear? (PLEASE POST A RESPONSE!)
- Didn't pass emissions. HC's at idle too high. Any suggestions?
- 2nd Annual Leavenworth Beer and Brats Run: Sunday Sept 24th.- Details
- Fuel line recall done?
- Driving Impressions... LONG
- WinOLS for blowing up your engine.
- Rear engine block coolant fitting and O-ring
- Preparing to put the //S back on the road. A few ??'s
- clutch pedal is getting stiff ... time to replace pressure plate, master cylinder, or both? (more)
- PSA... Make sure things like rolls of coins aren't in the right side door....
- maybe a repost, but this one help me go to sleep [i'm bored...]
- What's a '95 S6 Avant w/54K worth? Good cond. Dealer serviced........
- When i turn sharp to the right at slow speeds I hear a thud on the right front side...
- Transient check engine light while driving no rhyme or reason
- Old vs New
- What do you guys think? Y/N
- Where does the other end of this wire go?
- For all the guys who wanted the BOV
- Any recommendations to buy Hella clear corners? ECS tuning has them...
- Spiralsmurf and other San Fernando Valley/Los Angeles peeps: New repair shop
- Need new LF strut mount!!! How easy to DIY???
- Vr_Life, look what just arrived today!!
- can someone help locate...
- AMD GREEN MONSTER JUST DID 400HP/415LB-FT TO WHEELS ON PUMP GAS - ADDED VIDEO!!
- Anyone thinking of selling their S?
- installed the HU, but one question theres a pop when switiching stations
- where's the best place to buy driving lights
- For Sale: NEW H&R S6+ and Bilstein Sports
- JasonC, you around????.......
- I think my heater core is failing.
- pos cooling mod
- Trouble finding Euro A8 rotors for Big Red upgrade...
- car stalls after being on expressway for any amount of time...
- Hmmm, interesting.
- x-post, I don't think this would last another 5 minutes
- let's me post again K24,'EM glowing red when hard driving..
- part number request- 93 serpentine belt tensioner. Anyone have ETKA access or this number? Thanks
- My shock boot is ripped in half, should I replace it?
- Boost Saga Ends
- A Wet World Challenge at Mosport Makes for Exciting Racing *RACE RESULTS INSIDE*
- Nostradamus Quatrain...
- Oppinions are welcome;
- Meet at Annacis McDonald's at 8:30am for the Leavenworth Drive?
- chef bob is a toucher that is all
- I am getting the IAT code off and on. Time to replace? Cheap sources?
- Nic Bode. I tried to reply but my email was rejected. There is an article on s-cars.org regarding
- AAN Crankcase Ventilation System Diagram and Function
- First step to e//S2
- Anyone have $35K burning a hole in their pocket?
- I had a boost leak under intake manifold, a t-shapped rubber hose in the breather lines
- is there a second xplug? on the bottom of the ps pump. tia
- x-post: anyone want a 5-spd 1995 A6?
- Canadian distributor for aftermarket pressure plates? LWFWs?
- Is my explanation of turbocharging correct? And what should I add to my website?
- Teach the newbie - Intercoolers and Radiators everywhere!
- ***Hartford, CT GTG - Wednesday, September 27th ***
- Anybody got a power steering pump?
- How do you remove the wire pins from the plastic connector without destrying it?
- HU install
- Koni shock dimension needed???
- Question on 034 RS2 replica parts
- Will 7A crank lock tool work for AAN? Preparing to do timing belt before winter...
- Advice Needed
- Power Output Stage wiring plug question? Can someone look at their car to verify this for me?
- Driver's window problem fixed.
- Girls just LOVE the "S"!!! :D
- Mea Culpa (my bad) #2
