- VCDS output P0341
- Advice please
- Rebuild 1 Cam Lobe??
- Transmission Blowing Smoke?
- Service Manual
- Xenon problem
- Suspension advice please
- New battery died, but still was good. Recode? Oh, and a spill..
- Engine noise - what is it?
- S6 Springs vs. RS6 Springs
- 2.7 TDI Rear wiper won't turn off
- Please help, A6 Alarm
- MAP Inlet vs MAP Outlet
- MMI crashing and keeps rebooting
- 03160 trouble code - drivers door production mode active
- 2005 A6 MMI stopped working
- P0431 do spacers work to get rid of that code?
- Tail light taking on water.
- Lock Repair Audi A6 and VAG group.
- Intermittent Overheating issues - anyone else experience this
- MMI 2G update without CD's
- Mnd
- ESP/ABS/Parking error - sign of Alternator?
- Location of remote control module for central locking
- Central locking system
- 2008 a6 3.2 quattro . Both Fans run every minute for 20 - 30 second and shuts off
- 18" wheel Question
- CEL ON. Bad cat please help
- Steering Wheel Controls and Back-up Camera Stopped Woking.
- 05 A6 3.0tdi possible starter issues
- Serpentine belt broke
- boot Actuator solenoid or locking catch
- Help with tail light intermittently acting up
- Need Help Wioth Codes
- Thank you for the timing chain help (with pics)
- Default 2007 A6 Allroad. Engine control module
- UK: 2007 A6 Allroad. Engine control module
- Sport to standard suspension conversion
- parking assist doesn't like to beep but once.
- Did center diff fluid change, anyone need the other 500ml?
- Adjuster codes after timing job
- 3.2 fsi 2007 running with no brain
- C6 Audi S6 v10 DIY Power steering pump replacment
- 2006 A6 3.2 no start, cluster goes on and off
- 2011 A6 Avant AC cutting out when revs are up
- A6 2011 mmi parking plus display intermittent
- 2006 A6 3.2L - No Sound
- Audi S6 5.2 V10 Coolant Expansion Tank DIY
- S6 WHP
- Nav Alternative Route?
- Throttle problem
- Trying to find that video of African guy working on his Audi?
- MMI CD Changer.
- Audi CD Changer please look!
- UK: Bluetooth issue 2011 A6
- Fixing oil in spark plug and other engine oil leaks on the 3.2
- 2007 A6 3.2 Quattro very hot air from driver vent only
- Dipped headlight quandary
- '06 Alternator/Battery Charging issues
- Where does this connector go? HELP
- 2008 Audi A6 3.2 Key not starting car
- UK: Anyone in Cambs with vcds?
- Radio/MMI has no sound
- Replacing 2006 ABS Brake Pump Module tips?
- Newer or older used
- Wireless charging
- Avant outer rear tail LEDs out?
- P0346 Check Engine code, Camshaft Senor Bank 2 - 2008 A6 quattro
- Refinishing Shift Boot Frame
- GB: Allroad suspension problem
- Codes P0492 and P0491 on 2010 A6 3.2t
- UK: trouble with Allroad rear suspension
- Audi A6 c6 dies while driving
- 05 Allroad 2.7T showing P1527 and P1535 codes after CV Axle install
- 2010 A6 3.0 Catalytic Converter replacement cost
- Scrubbed and re-sealed this weekend
- Help! Coolant leak, unknown origin
- Front Coolant Pipe DIY - Mistakes and Learnings
- Fuel pump question
- Looking for A6 Avant Buyer's Advice
- RPM fluctuations after car shifts into 5th
- More noise: 2011 A6 3.0t
- Parking sensor display / woes
- Shudder Jerk
- HELP - Front coolant Pipe - Blown head gasket
- License Plate Fuse....where is it hiding...
- No start . Please help
- Audi A6/S6 brake/wheel question
- Traffic Sign Detection with Camera??
- 2016 S6 Wheels on 2008 A6 3.2 will they fit
- Audi A6 MMI 3G Basic to High
- Exhaust
- 08 Quattro Engine Oil Leak HELP - need help identifying part (with pictures)
- Help 2007 A6 3.2 wont start or roll in neutral steering wheel is unlocked
- Audi S6 C6 gearbox oil change
- '10 A6 Avant Flex Pipe Replacement
- Cannot get into "Car" in the green menu
- a6 3.0 plugs
- Better quality? 2g AMI Bluetooth dongle or Aux/BT kit install (behind cd changer)
- AC/Climatronic
- 3.0t downpipes
- General Questions re: 2008 A6 Avant 3.2 Quattro S-Line
- '08 A6 Avant w/205K Alternator Failure
- Please HELP!!!😣
- New Audi Owner
- Parking Sensor Issues
- 06 Audi A6 Avant Quattro shift interlock solenoid connector/ microswitch replacements
- Audi a6 3.0 TDI Fuel problem and DPF warning
- Can't find 2008 Audi A6 MMI Display part number
- Steering Wheel Buttons
- UK: Lights bot working after MUPPET was changing side light bulb
- Jerky
- GB: 2006 audi a6 2.4L. HELP PLEASE
- can't find the navigation file from Myaudi
- auto switch head ligh not working is it common problem
- Door lock chime stopped working
- 2008 A6 Oil Sensor 'Yellow"
- Looking at Buying - Red Flag on Service?
- Oil catch can
- A6 C6 4F Diffuser HELP!!!!
- Use of Battery Connectors in Hood
- Advice with “TPMS Malfunction” message.
- Yet another hole in Flex pipe.
- 1st Gear not working
- Selling my 06 a6
- Torque spec for timing chain covers?
- MMI update
- "Chirping" sound from heating fan
- no start, no crank. help please.
- XTOOL question
- #8 Cylinder "open Circuit"
- How to delete Audi A6 Avant Wagon 3.2L with Adaptive Light defective error on dash?
- Sorry to rehash MMI update but...
- HELP !!!!!!
- Miessler remanufactured OEM front air strut - any experience?
- Esoteric Sirius question
- Will R8 20” x 11” wide wheels fit?
- Rear brakes done - Phonebook will not load
- GB: C6 A6 2007 diesel gremlins
- fuel/trim/o2 sensor issues - rough idle, choking, hesitations - safe to drive?
- Merry Christmas, C6 style (pics)
- Speaker upgrade MMI 3G - Sound System Standard
- Audi 2007 4.2 bvj
- 2006 A6 4.2 bad oil leak
- Brake discs / rotors warped again - why?
- Heat but no blower speed
- Where is the Oil Pressure Sending Unit 3.2
- wiper toggle switch
- missing options on MMI service menu
- Finding MPG
- hard cold starting
- P2177/P0171 System Too Lean off Idle
- rear wheel/fender gap seems low
- 2004 Audi A6 2.7T
- Question about rearview camera
- 2005 Audi A6 3.2L FSI Carbon Cleaning Success (Video)
- BG: Audi S6 330mm rear discs on A6
- Just got A6 2011 got questions
- Air springs: genuine vs. Dunlop vs. Arnott
- 2010 Audi A6 4.2L: DESPERATELY NEED HELP
- User manual with electrical diagrams
- Intermittent starting issue? '05 A6
- Evap 2404 implausible signal
- the sale continues! do not miss out
- "Report on Boom!" 3G MMI message balloon??
- Door issue
- 2008 engine in 2006 A6. 3.2?
- audi a6 4.2 engine swap?
- Intro/ Add me :)
- Will these wheels fit
- Central Convenience Module
- 06 a6 all warning sign on headlight blinking
- A6 front Bumper came off
- 2006 A6 4.2 coolant leak
- C6 air suspension prob locked out
- ZA: Mercedes C320 Cdi comparo?
- Advice on buying a 12 year old S6
- LT: Audi A6 C6 diesel fault codes
- button on the driver's door
- S6 maintenance schedule and details.
- 2010 Audi A6 Quatro 3.0T Steering rack questions.
- Dead battery/low voltages
- SPC or K-Mac Front Camber Adjustment?
- intake flap rod arm
- Intermittent Air Suspension problem
- 2010 A6 3.0T Misfire
- Miles to kilometeres
- Headlights provide low visibility
- getAudiparts.com | Black Friday/Cyber Monday FREE SHIPPING + Promo Code!!!
- newbie - is camber adjustable in the rear on a A6 Quattro?
- 2008 A6 4.2 losing coolant
- scratching my head??
- Quattro torque split on 2008 A6
- Should I consider a rebuilt Audi A6 2011?
- 2005 audi A6
- Exhaust help - resonator delete?
- 2008 3.2 No Start, Maybe Timing issue?
- Audi c6 2.0 2010 missing coolant rube
- Crankshaft Seal Replacement
- Rear Sway Bar End Link Replacement
- UK: Question for those of deep knowledge and experience! Rogue Oil Pressure Warning
- Newbie - got burned
- Rear spoiler options.
- MMI updates
- Dash Cam installation 2010 A6
- Champion AGM Battery from Pepboys
- 07 A6 Avant ECM replacement problem ECU 54k
- 3.2 camshaft position sensor and systems rich
- Btpj
- 2010 A6 steering knuckles
- 2004 audi a6 quattro s line 2.7l transmission problems
- VAG-COM ABS Pump Bleed Procedure
- My 06 A6 avant passed 200K milestone. Yey
- lost dab and want to add reverse camera
- car not starting/turning help
- Station stored incorrectly
- A6 Steering Wheel Swap
- Bluetooth connection with motorola audi phone
- are the 3G MMI panels Component Protected ?
- Spare Key Help
- [2008 A6] oil puking from valve cover gasket, diy?
- You start the vehicle and the radio automatically blasts at full volume
- Audi A6 C6 2005 Software Upgrade
- fuel door unlocks each time I get into the car!
- Left Headlight Troubleshoot- 2008 A6 Quattro
- Spark plug wire T25 Screws
- In desperate need of help with issue in 4.2 (2005 c6 A6)
- 2007 A6 Quattro Glove Box
- 2008 Audi A6 Reliability?
- 08 Audi A6 intermittent starting issues
- PSA: Low-Cost Option for Replacing ECM
- Misfiring on All Cylinders
- CODE P0784
- Melbourne mechanic recommendations
- Someone take a looksee
- Warning light still on after rear pad change
- 2005 Audi A6 3.2L FSI Intake Runner Flap Fix (Video)
- Hood lock sensor..
- 2007 Audi A6 3.2L (what is this part) TOP of motor hose
- 2006 Audi A6 facelift
- doors won't unlocked
- Vibration at 85+ Mph
- Foozy's Audi A6 C6 Build Sheet
- Caliper replacement
- Power steering loss belt kicked off tensioner replaced belt help
- ECM/ECU Help
- high pressure fuel pump replacement on 3.2
- Has anyone put a roof rack on their Avant?
- Help with minor(?) items in VCDS Scan
- 2006 c6 3.3
