PDA
View Full Version : A6 / S6 (C6 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85
  1. Engine to Transmission Bolts
  2. Can wrong battery programming cause MMI failure?
  3. 05 A6 Quattro Transmission Problem
  4. 2005 A6
  5. 2006 Audi A3 SD music format
  6. Blown Variable Intake Vacuum Actuator
  7. C6: Possible to replace timing chain tensioner with out removing engine S6 5.2 V10?
  8. Creaking noise on front end when hard breaking.
  9. Hard Start When Cold
  10. audi a6
  11. N80 for 3.0T?
  12. LED DRL?
  13. Steering axle control unit - help please
  14. How common are the timing chain tensioner failures on the 3.2?
  15. Simple Oil Change... DIY?
  16. 2007 A6 power issue
  17. Audi a6 c6 saloon trunk problem
  18. DIS SERVICE RESET
  19. Wiper Arm Coding
  20. New S6 owner with transmission question
  21. Rear passenger door won't open 2003 A6
  22. Adaptive Cruise radar sensor heater replaceable?
  23. 2009 Audi A6 backup camera installation
  24. 09 Audi a6 mods Help.
  25. What sensor is attached to coolant overflow tank?
  26. Merry X-Mas To All!!
  27. SMS.. I gotta ask
  28. Fog light error code
  29. How aftermarket lights afect your car
  30. C6 A6: Dreaded Oil Leak
  31. No Sirius Band, C6 A6
  32. Audi A6 Wagon, worth it?
  33. I got lucky!
  34. Are aftermarket service contracts worth while?
  35. CEL > No CEL = Issues
  36. T C tensioners replaced, quieter. blank in block 93
  37. Getting conflicting info on buy or not to buy
  38. HELP - Cam PLUG, Not Seal '06 A6 C6 3.2L
  39. Alloys size for 2005 a6
  40. Need Info for Audio System From a 'Santa'
  41. S6 V10 - gaskets
  42. Engine Sound and Headlights Washers (Video) + Timing Questions
  43. Water on drivers side floor
  44. Compatibility of VW Webasto ThermoTop C in Audi
  45. 2009 A6 3.0t timing chain issues
  46. Varying street values?
  47. ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - January 1st - 7th, 2017***
  48. Intake Valve flap stuck open/closed 08 S6
  49. 2010 Audi A6 3.0T Prestige Buzzing when turning.
  50. 2013 Audi A6 3.0t exhaust seems rough
  51. MMI Screen resolution PROBLEM !!!
  52. Quick advice please - Coolant Warning
  53. Need help regarding rear quarter panel
  54. Audi A6 S line Navigation Help
  55. What stereo is in a 2006 base model?
  56. Something doesn't feel right! Help
  57. Audi A6 2010 SLOW UP SHIFT ON "D" MODE
  58. Heated seats turning off after few mins
  59. $250 left to spend at VW dealer. What can I buy for my car?
  60. A few questions about a base A6
  61. battery issues
  62. 2005 A6 C6 to 2012 C7 front end conversion?
  63. Where can I find a 14 pin to 10 pin headlight adapter
  64. Audi a6 lights only work when warm.
  65. Audi MMI button are not bright :(
  66. A6/C6/quattro rear discs/rotors - must carrier be removed?
  67. Low coolant no leak detected
  68. Low coolant no leak detected
  69. Does my car have a reverse camera module?
  70. measuring blocks group 93 a6 c6 3.2 .... not right..???
  71. Proclip Phone mounts 20% discount
  72. Car Cover
  73. 2013 Audi A6 2.0T Premium Plus - Audi novice warranty and purchase questions
  74. Audi A6 C6 problem
  75. !AUDI ONLINE PARTS WINTER RAFFLE!
  76. Blown engine?? Help!
  77. Cooling fan on all the time
  78. Uninstall fog lights Audi A6 2009
  79. 08 A6 Avant - Cold mornings on startup, Whining Noise When Turning Wheel
  80. Mystery part!
  81. Noisy exhaust leak...drivers side flex pipe
  82. 05 a6 3.2 Need battery module wiring picture
  83. WHAT DO YOU WANT TO SEE FROM A PARTS DEALER?
  84. 2005 Audi A6 C6 Sunroof Headliner Springs, Hooks replacement - Sunglass Removal, more
  85. power steering flush question
  86. Bluetooth module starting to fail
  87. MMI and NAV version?
  88. PDC not working after flashing
  89. 3.2 Severe Front Engine Oil Leak - Crankcase Breather Gasket?
  90. vibration and noise over 15mph`
  91. Dension GW 500s BT & MMI update
  92. What kind of suspension do I have? Recommended to have tiptronic tranny fluid change?
  93. Interior Lights won't turn on, but they do turn on when entering car.
  94. Trunk showing open, is closed, but latch is glitchy
  95. S6 seats (front & rear) in an A6 Avant?
  96. p1883 c6 help me
  97. 05 a6 3.2 lost everything box fuse number 5
  98. Takata airbag update
  99. 2005 Audi A6 C6 Windshield Washing System Maintenance (Pictures)
  100. A6 Packages
  101. Is this the correct VAG COM for my A6
  102. Location of Fuel pump relay on 2005 A6 3.2L?
  103. Stock VAGCOM coding for 2005 A6 4.2 Quattro S-line
  104. Gas gaige rising very slowly on fill ups
  105. Audi C6 instrument cluset Q7 swap
  106. HELP!! Spyder Aftermarket LED Tail Lights
  107. Another rare bird just surfaced in Austin, TX
  108. 2010 A6 Chrome/Aluminum Pedals
  109. Going to buy avant - help!
  110. Battery Regulator issues
  111. 2006 Audi A6 Avant - 3rd Brake Light Replacement
  112. A6 3.0T Tune MPG
  113. mirror replacement
  114. 2005 Audi A6 C6 Taillight Assembly Removal/Repair (Pictures)
  115. MMI inop...
  116. Tensioners....now cam position problem.
  117. Backup Camera install on 2010 A6 Avant Premium Plus?
  118. Need CARGO COVER 2005 - 11 avant in Beige
  119. 06 A6 TUNE UP
  120. Joycon EXC Steering Wheel Interface / C6
  121. Turn Signal Stalk Versions
  122. AUDI S6 2007 5.2 V10 OVERHEATING ENGINE
  123. 2006 Audi A6 Power Side Mirror
  124. Auto boot opening retrofit
  125. Another 3.0T Avant Captured!
  126. Considering high-mileage C6 3.0t purchase
  127. 06 A6 C6 Shifter interlock
  128. code AGM battery
  129. Retrofit AMI on an '06 Audi A6
  130. 2005 3.2 timing failure
  131. right rear window switch
  132. access to the oil drain plug
  133. wheel bearing replacement
  134. another key stuck in ignition
  135. zero/calibrate speedo needle
  136. Navigation problem, keeps saying to insert navigation dvd
  137. Spare key!
  138. RS: Spare key for Audi A6?
  139. Captured: Rare Bird 2011 3.0 Prestige wagon
  140. Rear light bulb out indicator will not turn off
  141. Coolant Warning light and A/C...
  142. headlights
  143. Locking the car from the key buttons stopped working.
  144. Audi A6 2.4 2007 door blades
  145. Audi A6 2.7TDI Quattro TipTronic Shudder when accelerating
  146. SIRIUS SATELLITE TUNER QUESTION & part#?
  147. 2008 A6 3.2 PCV valve location, test, replacement
  148. PSA for high mileage owners
  149. A6 c6 suggestions?
  150. Visual Parking Aid coding issue
  151. Stink bug in headlight!
  152. what happend if change ecu,cluster,key j158
  153. Cannot find MMi Software Version - MMI 2g Basic
  154. no autorization start no can bus comunication
  155. A6 3.2 FSI Throttle Fluttering
  156. parking alert please park position
  157. C6 Bluetooth telephone problem (UK)
  158. 2 S6 Sales Statistics Questions...
  159. seat is not leather
  160. FM Modulator
  161. 2004 A6 2.7t high pitched noise after turning off
  162. Shattered Sunroof Glass
  163. Audi a6 4f 3.0 tdi vibration
  164. 3.2l timing chain replacement avoidable?
  165. Brake Pad Recommendations for my S6
  166. ECS snub mount
  167. 2008 Audi A6 Cylinder Misfire/EPC Light
  168. EPC Codes and multiple errors while also stalling...
  169. :: ECS Tuning :: NEW!! ECS C6 A6/S6 Paddle Shifter Exensions | Upgrade Your Shift!
  170. 2005 Audi A6 C6 Door Panel removal (Pictures)
  171. A/c turns off and on
  172. Squeaking/creaking coming from front end?
  173. 2006 A6 4.2 blue/white smoke from exhaust
  174. couple odd things with my S6.....
  175. '11 S6 Advice Requested
  176. Just learned the hard way to use quality parts
  177. Wheel Bearing/Rear Axle Torque Spec
  178. Amplifier Help!
  179. !NEW AUDIWORLD EXCLUSIVE PROMO!
  180. HELP WITH MY A6
  181. C6 stock seats totally suck! Options?
  182. 2006 A6 4.2 shaft driven power steering pump.
  183. Vendor for ABS module rebuild
  184. 2005 A6 3.2L - Bent Valves
  185. ABS control module intermittent fault
  186. 09 A6 3.0tfsi rear main
  187. Instrument panel lights not turning on when lights set to "Auto"
  188. A6 4.2 quattro uneven running/transmission issues
  189. 2006 AUDI A6 3.2 quattro replace the transmission
  190. Tiptronic steering wheel Retrofit.
  191. Sunroof stuck in vent position
  192. Playing Music through iPhone Through MMI 2G
  193. 06 A6 Quattro 3.2L won't start, NEW STARTER.
  194. 3.2l Timing chain tensioner failure
  195. Is the shell rotella T6 5W-40 that everyone uses the one that says heavy duty
  196. A6 with Airsuspension
  197. 2007 Audi A6 help please.. music
  198. Control Arm Kit GH vs Meyle
  199. P2004 & P2006
  200. Need a new RS6 style grille. What's the best option out there besides OEM?
  201. Need some help understanding measuring block 93
  202. 2008 A6 6 disc cd changer problem
  203. Audi A6 3.0TDI turbo problem
  204. Thinking of purchasing first Audi
  205. Trailer Hitch Wiring - 2007 A6 Avant
  206. Audi c6 knocking stearing wheel
  207. cam adjusters jumping forward
  208. navigation update
  209. Brake calipers
  210. My steering wheel isn't tilting after a jump start? b
  211. Audi S6 2008
  212. 3.2 FSI [BKH] P2295 Fuel Pressure Regulator 2 Control Circuit Low
  213. Dash cam and Radar Mount
  214. Pass High-Beam suddenly stopped working.
  215. Exterior Power Mirror Question
  216. A Pillar
  217. Build Sticker w/ Paint Code for Avant
  218. Need Help - 2009 S6 Over Heating Problem
  219. MMI 3G Plus joystick
  220. Do I have a dual mass flywheel?
  221. Anyone use Febi (bilstein) transmission fluids, instead of zf?
  222. '08 4.2 timing chain or belt?
  223. 2005 a6 burning tiny quantity of coolant
  224. 2005 A6 3.2L Stalling Randomly
  225. 2006 Audi A6 3.2 Quattro A/C temperature changes
  226. Light warnings but lights ok ?
  227. Rear trailer light & Side running light failure
  228. A/C problems with cabin blower
  229. Leaks, leaks, more leaks and finally dry as bone!
  230. A6 Premium Plus vs Prestige... Thoughts?
  231. DVD/NAV ?
  232. Seat Control Short HELP!!
  233. Takata Airbag Recall, Some Audi's have them.
  234. MMI
  235. new wheels?
  236. V10 Engine overheat - Dealer Service Mistake
  237. Audi A6/C6 2005 3.2 quattro torque converter removal
  238. 3.0t belt routing diagram
  239. Lucas Stop Oil Leak
  240. Need help with a car in Fairfax Station, Virginia
  241. Should I get new tires for my 2008 A6?
  242. torque converter going bad?
  243. water in footwell, car wont start, no crank. help!
  244. 2005 a6 4.2 intake interchange question
  245. Alas Farewell
  246. BIRTHDAY SALE!
  247. how to tell if tailgate supports (gas shocks) need replacement?
  248. Navigation has no clue where I am
  249. Having Air Conditioner Problems...Need Some Help!
  250. A6 brake pedal switch question - worth trying another?
