- 2006 AUDI A6 3.0 TDI LE MANS SERVICE RESET
- 2011 A6 Brake Rotor Size
- Coolant Temp Sensor Audi A6. How to replace it?
- Any issues with 2010 A6 3.0T?
- Noobie navigation update question
- Audi to Porsche
- Engine Oil Color
- Rust & Corrosion Warranty
- Thinking about these rims, anyone have any input?
- Parts help: looking for the driver door panel for 2007 A6
- Aftermarket headlights for Audi A6, any1 has pic of them after installed?
- A5 steering problem
- A6 C6 navi "navigation data are not enabled"
- Stock up on detailing gear before Memorial Day @ DetailersDomain.com
- Awesome Photoshoot of a Gorgeous A6 | Strasse Forged
- 2007 A6 3.2 common issue? - potential buyer
- 2005 A6 MMI Knob Trim?
- 2007 Audi A6 3.2L Quattro steering knuckle and control arm help
- Battery tender question
- What do you think of this A6?
- Satellite Radio Volume "Currently Unavailable"
- Mechanical difference 06 A6 4.2 vs 06 RS4
- Battery 10%
- Fog light fuse - Location
- Reinstate data
- Koni FSD Installation Question
- Looking at a '07 S6 w/almost 200k in odo
- Engine differences 06/07 3.2???
- Dash is Dead , J518? Access Authorization ?
- A/C not blow cold air
- AWE Tuning presents Volkstreffen.
- Adaptive headlight error----
- 2008 S6 rotors
- Found my Avant, '10 Prestige, Sport
- thoughts on winter tires...nokian hakkapeliitta
- 2007 Audi A6 Strut leak driver side
- 4F0035056B pinout please
- Got my first Audi, Hello ;)
- MMI Noob Questions
- K&N air filter
- Service Light in 2005 A6 3.2l
- How to remove headliner console
- DRL bulb replacement w/LED?
- Tow
- towing help!
- Unlocked MMI Hidden menu, lost clock settings
- Headlight Washers
- Runs so much better after plugs and air filter.
- Tuning an A6/C6
- error 17831 2ndary air intake valve insuff. flow
- 2007 Audi A6 Sway Bar Link Question
- 2014 A6
- This is why you should get Quattro and some good tires too..
- Satellite Radio Not Installed Message
- Worn front motor mount?
- Trans, diff and transfer case fluid change
- '07 4.2 - Getting "EPS Fault" indicator when I try to start
- 01 audi a6
- Electrical gurus - S7 seats in A6
- 2008 S6
- 2005 A5 C6 Engine Hesitates at Idle and Ligth Load
- Led drl for sline bumper pre facelift.
- How long will the A6 C6 last?
- Hit and run question
- :: ECS Tuning :: NEW Color Key Fob Covers!!
- Right rear light problem
- Powdercoated my wheels...
- urgent help electronic park brake
- Little help regarding taillights please
- Cheapest and easiest way to connect iPod to mmi
- Quicker oil change
- Does my 3.2 have variable lift?
- 2006 A6 P2294 fault code and more
- help
- OEM License Plate Frame
- Apple TV, Tech Mods and more in Audi A6
- Twist loose the DRL socket?
- anyone use 45 series 18s instead of 40s?
- 3.2L cams, timing, sensors
- Fuel gauge not working
- Introducing New 360 Forged GT Concave Lineup and Monobloc Concave Forged Wheels
- MIL came on yesterday and car went into limp mode any insight?
- HELP!
- 22' rims for sale
- upgrading my 2008 A6 w/MMI to have nav, Bluetooth, rearview camera, Sat radio
- Electrical battery charger issue, Car Lost power
- Really want to lower my S6
- Brake Service w/o changing parts?
- AC Pressure sensor help
- Bluetooth issues
- 001110 - EVAP System/ P0456 - 006 - Very Small Leak Detected - MIL ON
- Power to numberplate lights
- How long should front brakes last????
- Valve cover DIY?
- Item needed. Lights under mirrors.
- changing ignition coils
- Show N Go License Plate Holder
- Audi A6 3.2 2006 Speaker Replacement?
- AMI Retrofit
- Would anyone rent me their VAG COM?
- Extended Crank?
- Replacing the seats so I can have the thigh rest - HELP
- sport differential upgrade on 2009 A7 Avant 3.0T?
- led tail light questions??
- Blizzard Bonafides
- 2005 A6 4.2 suddenly running rough
- iPhone integration HELP wanted Please!
- ENGINE CODE "P2180"??
- bumper side marker lights
- AMI retrofit parts
- MMI WONT POWER ON!!!!
- Just off topic:Best time to buy used?
- Infotainment MMI problems (after car wash?)
- Audi a6 3G MMI UPDATE (without HDD)
- Headlight washer switch
- Upper Control Arms and Struts
- 2010 BMW 535i xdrive Wagon vs Audi A6 Avant
- AMI install question...
- looks like dead battery, can't jump start, puzzle
- New OEM AUDI A3 A4 A6 TT Black Leather Paddleshift Multifunction Steering Wheel
- rear defroster
- almost convinced about getting a a6 but....
- need opinions plz
- Replacing MMI controller on 2010 A6
- Ijdmtoy Audi Style alA6 Led Drl
- MMI update error
- Anyone have the trunk fuse layout / diagram?
- Considering 2007 S6 with 75k miles - what to look for?
- 20" Wheels for Sale MINT CONDITION
- Vag-Com Scan
- Interchangable parts for the 2005 a6 4.2l engine? Doing custom head work.
- O2 sensor help plz!!
- ABS Module Removal Help
- best source for TPMS sensors ?
- Terra clean and motor vac
- MSDS Air filters - S6
- Owners with Sports Suspension
- 2008 S6 Ipod/iPhone integration mObridge
- Remove Headlight Assembly
- OEM Carpet Floor Mats
- C6 A6 4.2Q Performance Air Filter
- Brake Light Switch, First Stuck now won't come on!
- Need Help
- What is the biggest set of tires I can fit on a 2006 A6 Avant?
- A6, 4.2L V8 Engine Air filter replacement
- finally took some pics
- Birmingham to Fort Worth and back----- 70 mph + ---- 28.7 mpg verified by calcul
- Just Bought a 2006 A6 Avant!
- Electrical Diagram
- What's your mileage on 2005-2008 A6 ? Up to how many miles will you keep it ? 150K+?
- Selling Mint Condition 20" OEM double spoke wheels and tires from A7
- Power Steering Suction Hose
- Fog Light Question
- 2007 Audi A6 tire psi recommendation help
- Leaking exhaust
- THANKS
- Bluetooth Audio Stopped Working. Still connects, but no sound.
- :: ECS Tuning :: Alzor Wheels Style 628 for Audi!!
- Brand New oem a6 18" tires and rims for sale
- Brake advice needed.
- lock carrier service position
- 3.0T vs 4.2???
- SIRIUS Radio GONE!!
- Poor Fuel Economy
- OIL & SPARK PLUGS CHANGE
- Anyone selling any OEM 18" Sline wheels.
- Lube points
- Low Battery After Cold
- A6 limited seat adjustment (or spouse too short for A6)?
- Why won't this exhaust work on the 2008?
- If you have a blinking CEL don't ignore it, might be a lot worse than you think
- Please Help with Codes !!!
- MMI update for my A6?
- 235/45 R18 will fit on Audi A6 C6 2007 ?
- Advanced key working???
- Daylight Driving Light
- Rain in NY, same problem once again
- Audi A6 C6 - Front Window Regulator Repair Clips
- DTC P2433 ??
- Where to tap Ignition-switched 12V source in engine bay?
- 2008 S6 OEM wheel centerbore measurement
- considering 2008 s6
- Anyone use Ravenol ATF?
- Timing Chain Reliability/General Reliability of Audi A6 2005 4.2
- FS: OEM Nav Discs
- 2009 3.2 coolant leak - help plz
- MMI hidden menu
- steering noise
- Tire Recommendations
- Avant Cross Bars For Sale
- Mechanic in Fairfield County, CT?
- Loaner car questions
- MMI Startup Screen
- the snow that Audi couldn't tackle... :)
- If you have sat radio but no nav it's very easy to retrofit navigation
- size of rear rotors on my 06 4.2? looking to change pads as well
- S6 2007
- EPC, Check Engine and traction control light on at the same time
- No Current to Spark Plug
- changing differential oils
- 2011 A6 Aftermarket navi?
- looking at Koni Sport/H&R or Bilstein/Eibach combo
- Lane Change Assist Module
- Sound Amplifier Basic - Swapping
- broken headlight tabs...
- Anyone looking to change there tranny fluid? ZF Lifeguard8
- Should i buy a 2007 a6 at 108k miles
- Battery Level Meter
- TPMS problem persists after all sensors replaced
- Damn.....ABS Control Module is failing
- Sirius Satellite Radio Compatibility
- What MMI do I have ? ASAP
- Looking for RS6 Headlights
- please help a6 quatrro 1998
- AC problem with 06 V8 4.2 A6
- Seat belt buckle
- New owner with a couple questions
- Does anyone know have to replace the MMI knob?
- Audi a6 extra packages
- Question: If you swap the A6 Steering Wheel, will you need a new airbag ?
- OEM Valve Cover Gaskets - $25
- 2010 Audi A6 - does it have Navigation? How can you tell: MMI with Nav vs No Nav?
- 2006 Audi A6 4.2 tire pressure sensor
- Air suspension problems
- A6 2009 2.0T
- Brake light & turn signal intermittently fail
- Nav + MPH display in cluster
- Is this a good car?
- Suspension for S6
- Confused with vag com
- Brand New Parts for 06 A6 Avant 3.2
- 'Green' tranny fluid isn't actually green
- It's Possible to Upgrade your NON-LED headlamps to LED headlamps
- President's Day Sale at www.DetailersDomain.com
- MMI Update cost
- antenna amplifier removal and VAG 00856 repair
- 2006 A6 4.2 Quattro Steering Malfunction
- 2006 A6 (Quattro) Headlights
- Had my infant car seat checked. Need your opinions please...
- wheel well screws holding rear bumper - need part #
- MMI 2G high cd text
- Relocating iPhone adapter, 2008 S6
- Battery Drain from MMI - Temp Fix
- Had MMI update ??
- Tachometer moves up and down up aprox. 100 RPM in morning
- WTB oem roof rack for sedan or recommendation for best place to buy...
- Draining windscreen washer fluid
- Glacier White or Quartz Grey for S6
- I need some info on a 2006 A6
- A6 C6 18"" Wheel centre Caps AE0 601 165 A
