- Under seat storage bins
- Error Codes, help with some?
- Ignition module
- AC Blowing Drivers Side Originally
- Running rough after fast acceleration
- Audi A6?
- 2010 Audi A6 Headlight Relay
- p2146 code a6 c6 bvj
- 2010 a6 3.0 overheating
- HVAC malfunctioning / car overheated / Fault codes 006449/P1931..Defective FCU
- 3.0 TDI V6 Clattery when starting off
- MMI2g bluetooth problem
- A6 C6 2.7 TDI Crankshaft Position Sensor Replacement
- Cooling Fan
- How to order wiring connectors/pins
- Removal of Front (inner) parking sensor
- -05 A6 3.0 tdi tiptronic replacing with different code transmission
- Battery Coding Problem.
- Coil choices.
- Glow plug light flashing and limp mode
- So. California MMI Mechanic/Repairman Needed
- Audi S6 C6 5.2 V10 Perfomance Issues
- MMI issues, please help.
- Side-assist problem
- Parking sensor malfunction
- Coolant Leak, bit strange, would like input
- A6 c6 issues?
- NO: vacuum problem
- Music Playback solutions (AMI,TV tuner or other magic)
- Windscreen wipers not moving
- drivers side air bag light is on
- Need help Audi a6 c6 turns but wont start
- UK: A6 no ignition lights
- GB: Audi A6 C6 key fob trauma
- Lot of work done, now misfiring....
- How to remove rear license plate base ?
- Comparable Speaker Replacement for Bose System?
- Headlight Question..
- NO: Engine lamp on when car on idle for too long
- Subwoofer install. Whining noise
- A6 2.7 TDI hallogen to L.E.D. error code (dipped headlight error)
- Tiny Wire Mesh Mystery
- Help with 2008 audi a6 3.2L?
- Audi A6 2.7 tdi manual gearbox replacement
- A6 3.0tdi injector values
- A6 3.2 Transmission issues
- Air-Suspension HELP PLEASE!!!
- Oh rats!!!
- NO: A6 2.0 diesel
- Trailer hitch
- A6 C6 MMI Basic Plus (red monochrome display) Uppdate
- Sedan doors to Avant? urgent
- UK: Audi A6 C6 2007 Lukewarm air from AC on 3 vents out of 4
- G395 Sensor Pressure reading OK but no Temp reading
- Audi A6 C6 2007 Lukewarm air from AC on 3 vents out of 4
- My A6 C6.5 Issues....help needed!
- Supercharger Rattle
- Can't locate AMI Port
- 09 4FH with A5 led license plate lights... error
- 2005 A6 dead battery, faulty charging
- ZF 6HP26A issues - surge/slip?
- Can This Be Upgraded
- Installed lights, got dimmed warning
- Q2 Sales Numbers for A6/S6
- EGR UNIT AUDI A6 2007
- Help me locate VVT Solenoid
- AC regulator valve N280 short to plus
- Center control knob won't spin
- Air conditioning / blown fuses?
- Wierd sound and noise
- 2008 Audi S6 - Value?
- Starter replacement 2008 A6 4.2
- Engine swap
- 2007 A6 Avant Headlights compatibility
- A6 c6 v8 4.2L Help please Fuel trim Manifold repair
- A6 c6 v8 4.2L BVJ intake cam adjuster test, is this normal?
- A6 c6 v8 4.2L bvj Help please Hvac
- Crazy Retrofit idea - Sunroof / Moonlight roof
- Looking at an '06 A6 4.2
- V10 intake manifold help
- ac not working/not charging
- redline 75w90 ok for center diff?
- new member
- New goodies in the pipeline
- 2008 Audi S6 48k miles vs 2008 E55 AMG 35k miles vs 2012 Volvo V60 37k miles vs 2012
- IE: 2.0 diesel problems
- What's it worth?
- MMI 2G No working
- AUDI A6 (57) 2007 - Driver Door Will Not Open With Remote Or key
- Speaker sounds weird whenever I take it to audio or dealership it’s fixed
- LT: oil pressuRe help!!
- Cylinder misfiring
- Center console cup holder rubber
- Speaker BOSE Rattle
- Buying an A6 - questions about rattling
- New Key (Remote Transmitter) question '08 S6
- Driver display and mmi blank
- NICHE M116 MISANO 18" Gunmetal Finish wheels for 2008 A6
- Changing lange change assist module attached to rear bumper
- AUDI A6/C6 2.7TDI CANA/CAMA ENGINE?
- Need help identifying screw bit size for coolant pipe
- Another Reason I love my Audi
- Question about depressurizing fuel system. Any alternatives?
- Can’t find two of the oil solenoids??
- 3.2 Issues
- Intake manifold and intake manifold flap(v157)
- C6 2007 2.8 BDX oil leak
- Audi A6 35 tfsi Navi and Camera
- 3.2 timing chain cover bolts part number request
- Locks but no 'beep/chirp'
- 08 A6 3.2 air conditioning issue
- Stereo system
- Engine question
- compressor was not turning
- Audi a6 c6 dampening adjustment
- Bought an 06 avant- with 126,000 miles and some issues
- Comfort module
- FI: Audi A6 C6 Debate
- Door locked and both handles don’t open
- IL: Adaptive cruise control?
- 05' A6 3.2 Quattro wont start... PLEASE HELP!!!!
- UK: 2006 c6 A6 2.7 diesel V6 S Line TCU location?
- 2006 A6 Avant dead
- Wiper arm rest position
- No AC controls in display after MMI unit replacement
- SI: Audi A6 diesel 2008
- both front seats won't move back or forwards
- 3.0 tdi BMK shaking on idle
- HPFP Cam Lobes Dimensions?
- Change air suspension spring without 4 post bridge
- 2008 A6 Avant s-line EBS issue
- IT: Gearbox malfunction?
- 2005 A6 c6 MMI System Not Functioning
- Compression Braking Smoke
- No cold air from AC
- C6.5: Anyone can do it definitive guide to boosting your heated seats
- Help! Bad cat??
- 2005 A6 C6 to C7 front end conversion?
- AMI is stuck at initializing
- A6 may not be long for this world...!
- Audi A6 2015 - will key lock in car
- Audi a6 c6 2005 3.0tdi battery voltage drop with rpm
- audistream2air.com/ Audi Stream to Air - Do Not buy anything from these scammers
- Car won’t lock from key fob (immobiliser swap?)
- 2005 A6 3.2 Throttle Body replacement
- Exhaust for a 2008 Audi A6 3.2 Quattro?
- Front fog light trouble
- Headlight adjustment??
- DIY Suspension
- EPC Light on
- EPC Light on
- Airbag code 01217
- '10 A6 Avant Single Owner
- 09 A6 3.0 battery will not hold charge
- Car overheating when idle
- Lost all keys
- 2006 audi a6 c6 quattro 3.2 cranks but doesnt run?
- MMI Issues
- License plate lights
- Fault code P0782
- Add Bluetooth input to DVD Navigation and SD card Unit?
- ABS Module gone bad....
- 08 4.2 cam cover
- Oil level light
- Alarm only beeps?
- IL: Water noises in the rear doors area.
- Help! Brake problems
- 2010 3.0 tdi PCV Valve
- 2007 A6: No power steering
- What gas is the better choice for my A6?
- MMI control knob/wheel
- Dead Battery and boot wont open.
- Upgrade Halogen Bulbs To LED
- Audi A6 2014 Lane Assist - steering not working
- Weird noise, I'm getting preoccupied
- Wheel offset
- 2010 A6 Key Stuck, Battery Dead, Dash Lights On
- Audi 2008 A6 Coolant!
- Inner door scraper
- C6 3.0TFSI and refueling problem
- Engine rattling
- Is this sound normal??
- UK: A6 4F 2.0 diesel electricsl issues
- Adding visual parking aid in the MMI
- Key stuck and no pinhole in the ignition
- COVID: car is sitting for the past 4 weeks
- Replacing rear parking sensor harness?
- MMI 2G WORKING BUT NO SOUND FROME THE SPEAKERS.
- audi a6 2007
- A6 C6 Retrofit Backcamera
- A6 c6 2009 programme issue
- Transmission and differential fluid
- A6 c6 2009 computer issue
- Timing Chain Tensioners - "Italian tune-up"?
- Kit to rebuild valeo alternator ?
- Supercharger in Audi A6 2006 4.2?
- Front air struts replacement info
- CD changer
- Need help identify part
- 2007 A6 S-Line - Fuel Issue?
- Audi A6. No Playable Medium Inserted
- Possible broken timing chain tensioner
- UK: S6 C6 noise under acceleration
- Damping
- Audi A6 Exhaust
- Audi A6 C6 Avant wheel question
- C6 A6 led fog lights
- 2009 Audi A6 C6 2.0TDI 125KW engine CAHA fuel pump relay
- well crap, is my car totaled? [repair quote]
- Camshaft solenoid broke in half. Now stuck. HELP!
- 08 A6 4.2 pinging?
- A6 3.2 FSI Engine vibration HELP
- How to repair windows switch
- Audi A6 2.0 Tdi 2010 - Serpentine Belt Tensioner Replacement
- SSR AUTOBODY ♖ | SoCal's #1 Source for Quality European Collision Repair!
- PREGNANCY SEAT BELT
- 2006 a6 4.2 crankshaft alignment
- 06 quattro 3.2 TCM
- 3D printed engine cover rings
- How to Change Automatic shift Audi A6 C6
- Only rear speakers working
- Wheel bearing replacement question
- 2008 A6/S6 repair manual ?
- 3.2 Solenoids?
- Rearlight warning problem
- Need newer Navigation cd for 2006 A6
- reverse parking sensors
- Interior red button backlight don`t work
- ES: Audi S6 C6 Avant test drive. What to look for when buying?
- 2006 A6 red battery warning light
- 2005 A4 1.8t Cabriolet antenna wire
- Steering Wheel Buttons not work audi a6
- Boost heated seats in VCDS?
- crank but no start after car wash
- Sat nav disc eject button locked
- recoding VAG Address 61: Battery Regul.
- Soundproofing part 2 car audio.
- Issues With Adding Bluetooth Music
- Purchasing and installing a6 c6 camera?
- ABS Module 4F0614517L - faulting
- AC blower not working (Special Situation)
- Looking to buy A6 C6- Noise from timing chain?
- HU: A6 C6 daylight running light error
- Mmi navi optical error
- O2 Sensors - i need advices
- Knock sensors
- No lights on front left
- TN: missing Tunisia map in Nav. syst.
- What is this sound?
- Please advise!
