- 06 3.2 cold starts question
- TV Tuner ( 4F0919129D) Vagcom coding
- Audi Parts
- AMI issues
- Any one know the part number for this?
- 2006 A6 driver side mirror removal
- Heats up
- Noisy tires.
- Oil Consumption
- Help with part name & Number
- quattro stuck in sand
- 06 audi a6 stalled and epc light on
- VAG COM and Headlight Questions
- Need help with nav in houston
- Thinking about a 2011 A6 3.0t
- New owner, new problems.
- Long shot - does anyone know if the 18"x8" C5 RS6 wheels will fit on the C6 A6?
- engine trouble a6 2,8 fsi 2008 help !!!
- 2005 A6 3.2L Torque Converter
- Help With My 2009 S6
- interior lights die randomly
- wiper blades flicker
- 05 A6 3.2 surging idle
- Which model best fr use as works "van"
- Backup Camera - Installation/Retrofit 07 A6 Avant
- Need advice from those that have pulled the 4.2L engine
- Programming key fobs 2001 a6 allroad
- 2006 A6 3.2 Quattro towing wiring
- Battery issues
- LED Taillights - Opinions?
- Need HELP to understand what is going on.
- brake master cylinder
- :: ECS Tuning :: GEOMET® Coated Brake Rotors | Audi C6 A6 3.2L
- Intake Manifold Runner Actuator failure...
- 3G MMI still functions, but no sound
- oil leak/ timing chains
- Transmission code HYR versus JER
- Audi 3.2FSI VCDS Block 93
- Audi a6 quattro wont start
- 2008 4.2L A6 coolant in oil
- License plate light bulbs replacement (Pictures)
- Snow screen removal and cleaning (Pictures)
- Help! Where can I find a side mirror bracket???
- 2005 A6 4.2 Quattro, P0300 multiple misfire code, severe vibrations on idle
- Valve/Cylinder Head Cover Gasket
- Help 2006 A6 wont start,or shift,brakes locked
- Has anyone ever experienced this before???
- starting problem
- "Radio not installed" after failed MMI update!
- AUDI A6/C6 3.0 TDi Quattro Le Mans Auto 2006
- parking brake failure
- Does anyone knows how to do the new key fob programming
- Expected repairs for 2007 A6 after 150,000 miles
- Timing issue 08' 4.2l
- Let's play stump the forum - darn sound deadening piece for Avant
- Supported AMI music formats?
- Phone BT no worky after Dension 500S BT install
- oil leak
- Tyre pressure monitoring system 7K7/7K8 retrofit
- A6 c6 front passenger c/l
- Stereo Cutting Out (Head Unit)
- Headlight Swap
- 3.2 fsi .fault codes
- Transferring "rear view camera setup . 07' to 06'
- 2004 Audi A6 Qua 3.0 TCM Question
- Transmission Park Selector Switch (F305)
- anyone done R&R of curve light motor in head lt ?
- entertainment system (MMI) question
- Fuel pump relay assignment for '06 A6 Quattro
- 55K Complete Service. One issue: Fuel filter removal
- Can i update my MMI?
- Audi A6 2.0 tdi 170bhp white smoke at idle
- another snowstorm in NY. Another oportunity to show off Audi quattro on the road
- What to look for, buying a 2005-6 A6 4.2
- Someone local selling 2006 A6 4.2 with issues curious on your thoughts?
- General questions - thermostat, coolant tank, serp belt
- Possible to turn off cold diagnostics for LED's on Audis?
- :: ECS Tuning :: ECS Carbon Fiber Mirror Caps | Audi C6 A6
- 4L0907357B headlamp range control
- Brake pulsation again - same as C5 - Is it me or the roads? What gives?
- My 2005 Audi A6 C6 3.2 quattro
- How to manually open A6 2004 bonnet?
- Wheel Bearing Failure Poll...
- michelin pilot sport a/s 3...garbage in light snow
- New to the C6 realm!! Intro and one question!!
- Considering a 2008 A6 4.2 w/ 110k miles what do look out for?
- Need some help for choosing one of them!
- 07 A6 4.2 P0016
- Anyone know what the part number is for this?
- Park Brake Module help
- Please help me to verify this S6!
- PS fluid topping off
- Remote / Key Fob Issues
- MMI not working after water damage - 2006 A6 3.2
- Microbead Car Covers
- Audi A6 C6 2004 faulty camshaft sensor?
- Will these Akebono rear brake pads fit my vehicle?
- coolant leak
- Audi A6 2005 ESP Fault & P2296
- 75k Service
- Which clutch pedal switch will fit my car? (VCDS help)
- Replaced both right and left side stabilizer bar end links last week.
- Intermittent tailight problem - 2005 A6 sedan
- Review of deAuto LED complete interior LED kit
- TPMS question...again
- largest tire size (profile or outer diameter) that will fit on a 2010 A6
- Audi A6/S6/RS6 A7/S7/RS7 Club Hong Kong
- 2008 oil sensor 4.2L
- Raj99
- P2294 and P2070
- Spare key fob
- Change front diff and transfer case fluids
- headlight range warning light...
- Two A/C Condensate drains?
- NEED YOUR HELP
- New to me 2011 a6 avant... What now?
- Rough idle a6 3.2 fsi quattro
- Double phone book entries - can't get rid of duplicates
- Battery test?
- A6 3.2 FSI HPFP noise
- How to remove brake reservoir screen filter?
- 08 A6 AMI MMI cable confusion
- Blower motor at low speed sounds like there are crickets. Advice needed.
- is it worth replacing timing chain on high milage 2006 A6 4.2 Sline?
- Back to my 1998 A4
- WHAT ON EARTH JUST HAPPENED?!?!?!?
- Engine sensors and electronics help
- Multiple error codes P2004, 2006 and P0300, 01...
- Intake manifold removal video
- What is the cheapest method to reset oil service indicator/message?
- Torque spec for alternator belt tensioner 2006 4.2 ?
- Block Heater
- Very high mile '06 Avant
- DIESEL GURUS 2,0TDI (BRE) 16v new PD injectors, running like crap
- Horrible MPG's... less than 10mpgs, few questions???
- New C6 Owner... Need help with P2404 please
- Need help with A6 C6 headlights
- rough idle cold start
- Wind Noise from Sunroof no water leaks
- How to protect car floors (Revolutionary Solutions)
- Modifying the Heater Control Valve Unit. Crazy??
- Any Way Track A Car from Arrival in Houston Online To Destination?
- Exhaust options
- Update on no start sittuation + theory
- CAn't find Radio fuse location
- Transmission Fluid Change & Filter Hard Downshift 5th to 4th only???
- Where to find parts???
- Have a luggage rail system? Can you measure something for me?
- airbag module
- MMI randomly switches audio to CD.
- Audi a6 4f2 3.2 fsi quattro auto engine rebuild
- Heating/Cooling Problem...
- HVAC Drain Line
- :: ECS Tuning :: 50% OFF CYBER MONDAY ONLY! Audi Ziza Master LED Kits
- Heater tied to engine coolant level?
- Radio works, CD works, No sound. MOST Bus?
- Anyone know if Europaparts is doing discounts for parts right now?
- P0302 Misfiring
- ESP light!
- Just bought VAG COM
- tiptronic gearbox 2.7TDI/3.0 TDI
- Black Friday/ Cyber Monday deals from Car Parts Discount
- 07 S6 - VERY rough cold start idle. Misfires under load. Need help.
- 2005 Audi A6 C6 AC recharge
- :: ECS Tuning :: 11th Annual Customer Appreciation Sale|Save up to 25%!!!!!!!
- I know these will be a tight fit, but what do you all think?
- New A6 Owner :(
- Best time to order my 2017 S6
- 2016 Prestige cost
- 2005 Audi A6 3.2 Quattro.. Can someone tell me the name or part# of this part
- Passing Hesitation
- P2006 & P2007
- '07 A6 Avant won't lock w/remote or key!
- Fuel injector
- 2011 A6 (C6) steering question
- crackling sounds on r sided loudspeaker
- AMI help
- Stealership Report - North Atlanta
- 2008 Audi A6 MMI not working
- Location of the intake manifold?
- sealing center brake light in avant
- Considering 2007 Audi S6 Quattro
- Is this a Ross Tech clone?
- Intermittent Right Rear Turn Signal
- VAG COM
- AIRBAG LIGHT..
- A6 and S6 parking sensors the same???
- Rear passenger door handle removal
- I was recently reminded just how well my A6 holds its own.
- "headlight range' warning light question
- Huge Audi A6 2.0 TDI 2007 malfunction
- WTB: ROSS TECH HEX-CAN USB
- Windscreen ventilation does not work properly
- Seat control panel removal
- Noise at 40+mph when turning right
- CENTER CONSOLE REMOVAL
- Terrible Maintenance Story
- Audi A6 3.2 FSI Write Up's and HOW TO's List
- front seats
- Parking control module 4f0910283B
- Deleting saved Routes from SatNav?
- Lets get upgrading- Interior/ Multimedia first!
- Long startup, P2294 Fuel Pressure Regulator Code, 1 inch puddle of oil
- Brake light switch replacement
- Need help finding part number
- "Access Port" look alike for A6?
- Manuals
- Last Day With A6
- Continued check engine light 2005 Audi A6 3.2 Quattro BKH
- 05 A6 radio replacement
- Check engine light
- What is this part?
- 2006 A6 quattro MMI problems
- Picked up an 09 A6 Friday - AMI question
- I need Help First time audi owner
- 2004 A6 3.0 Quattro Check engine light
- My 1st AUDI
- Special promotion for Audi World Forum members
- 2008 A6 Avant about to hit 80K. I feel every bump in the road like it's a pot hole...
- modules
- Instruction to replace Side Light / Daytime Running Light
- GEAR SHIFTER STUCK
- computer
- Oil soaked coil 3.2L help!, ideas?
- BiXenon stuck on High Beam
- Adaptive Headlight Question
- Coding Rear View Camera
- Car has thrown some codes scanned with VCDS
- Forum group buy with Car Parts Discount
- 2016 Audi S6
- What resistor
- Need to Program Key - vagcom in Jersey?
- Replace my Xenon HID?
- 3.2 FSI limp mode after ECU change
- Blower motor problems
- MMI freezing during Bluetooth phone call
- Strut failure cause Brakes to squeak??
- Trunk "Chrome trim" ?
- Tire Pressure Monitoring
- 2010 A6 Avant 3.0T (reliability? weak points?)
- Towbar wiring - Convenience system - Pin 19 cable colour conformation
- how to check third brake light
- 3.2 cold misfire cylinder 6
- Block Heaters
- Snub mount replacement for 3.2
- 20x9 tire size
- Quick Question on MMi Amp
- headliner
- catch can
- Parking Brake nightmare
