- opinions: Koni FSD vs Koni Sports shocks
- Rear Exterior Lights
- Sheepskin seat covers
- Clear bra..
- Current BMW Owner - switching to Audi A6 (avant)?
- Audi A6/S6 Auto Lease Programs - April 2010
- Telephone package call won't end!
- Wife's A6 makes a clunk under light braking
- Anyone with a chipped 3.0T?
- Pothole Problem
- Add Shock Sensor to Alarm?
- 2005 A6 4.2 with battery drain - tried everything
- Tires for the S6
- A6 Headlights
- my headlights are pointing a little too high.
- What are the latest proper MMI update procedures?
- Brake calipers
- How to change DRLs on S6?
- Bentley Publishers Manual
- Removal of 3.2 Tip Shifter?
- D2 S8 to C6 S6?
- Eibach vs HR Springs
- Hi, I´m from Spain, and I need help with MMI 2G and the upgrade of MMI
- New To Audi - Exhaust Question
- Disconnect Bluetooth
- I'm looking for a left headlight assembly
- 22's!!
- This is going to soo take the Mini down
- Celebrity A6 Avant with blacked out rims
- 2010 5-series @ NY Auto Show
- 2005 A6 Brochure?
- MMI shut down
- Vibration on A6 at high speed
- Exhaust piping
- instrument cluster trip monitor problem?
- April 2010 Lease Rates? Anyone?
- Is there an easy way to copy Audi Nav DVD?
- Dealer is offering to buy the car back rather than resolve the vibration... Advice?
- Suspension question and Hello
- MMI Firmware update for IPOD
- Wheel Bearing
- Aftermarket Sway Bar Links
- Tranny fluid, 2005, A6 4.2
- New member, questions about MMI update
- Entertainment systems...
- Strange Thud when releasing gas.
- Just changed my front brakes
- Factory Alarm Volume
- A6 Avant 2.0 TDI
- Oil Selection
- Is there a write up for how to change Transmission Filter and Fluid?
- Anyone running these wheels...
- Noisy Engine - Test Drove 2010 3.2
- Can I turn the climate control OFF?
- Suspension Setups
- Front sway bar or rear? which way to go first?
- Are these sports package wheels? 19"
- What happens if you put a Europe NAV DVD into a US Audi?
- Issue with OEM part seller
- What is this part?
- C6 chassis differences?
- Looking for a part for 2007 A6 Sedan
- Control arm bushings
- Alignment - Any advantage to using the dealer?
- Long Cranks in the morning
- My Magnaflow experience
- Lots of rain, now car is surging....
- Thinking of doing something like this with my A6...
- Our new 2010 A6 Avant Prestige
- Sirius to XM swap
- Thinking about upgrading my 16"s
- how rare is the A6 avant in the US?
- Anyone have their LED DRLs fail?
- 2011 Audi A6 available, prices, changes...
- C6 S6 K&N Filter
- Urgent Suggestion: A6 3.2 or 3.0 Quattro?
- Need help with Bluetooth!
- So my recently-purchased 07 A6 is vibrating at high speeds...
- S Line wheel
- Thinking of these performance mods........
- One project down , three to go
- Audi in China
- Any news on the C7 A6?
- Would any other tire sizes fit on stock 17" rims?
- Adding spacers to ET45 A8 wheels on A6
- Which Rim.....need your thoughts on this
- $25.5k a fair price for certified 07 3.2 with approx. 47k, nav, convenience pkg...
- Reverse sensor not working - silent
- Looking to buy 2007 A6 3.2 Quattro need advice
- Thoughts on upgrading 18" to 19"s...
- Frame Around MMI - Anyone seen this before?
- Moving up to 19 inch rims from 18 with stock sport suspension
- Anyone upgrade their A6 3.0T with Stasis ECU SW?
- Link to car for sale...I'd love some Audi veterans opinions, etc
- ESP fault 18265 - Load Signal: Error Message from ECU
- 2005 4.2L A6 Rims offset?
- S6 Trailer hitch?
- What gas to use for '04 A6
- How to reset Next service stuff?
- Cup holder door issue
- 2001 A6 4.2L with ECM problems?
- Help! Dome Lights Won't Turn Off.
- Brand new to AudiWorld and I have a question...
- Good-bye A6... I hardly knew you...
- Finally A6 DRLs Installed
- Automatic Transmission Fluid (ZFLifegaurd6=Ford Mercon SP)
- Where is the music amp in the a6?
- A6 named by JD Power as the most reliable midsize premium sedan
- Service hours for a front/rear brake pad replacement
- Tired of my rims....
- S6 LED DRL's
- Hello, new around here! Considering 05 A6
- Can gas quality affect mileage?
- My 2010 A6 3.0T
- Intake Valve Carbon Deposits
- Before, Before & After
- anyone seen this and or tried it yet?
- POSSIBLE 2007 S6 PURCHASE
- Ouch, hit some tire shrapnel...help!
- DIY Rear Brake Pad Replacement
- Brake pads
- 2007 S6 with 33k miles for $39,995...
- A6 Avant Radar Detector Hardwire Install?
- Audi A6/S6 Auto Lease Programs - March 2010
- Installed Bilstein shocks and H&R springs over the weekend...
- Audiworld CLASSIFIEDS need to be Updated Listing RIMS and PARTS that have been Sold
- Thinking about selling my 2007 S6..
- VAG CAN COMM
- Does anybody have wiring diagrams for C6?
- Carbon buildup CEL TSB Update
- 2005 A6 C6 Running lights.
- Front inside tire wear
- LED DRL'S
- A6 3.2 AVANT - 321mm or 347mm front rotors?
- Anyone knows the OEM S6 wheel specification ?
- I didn't get a bill this month?
- Headlight Removal
- wondering about this rare combo
- Anyone with a Bilstein + H&R setup?
- Is Audi resposible for my blown engine? HELP!
- Airbag Warning Light
- Side repeater removal
- OE Springs for C6 S6:
- Re-Enable speakers after a protection fault
- S-Line vs standard car. What is the difference?
- Dension 500
- '06 - '08 A6 3.2 Q - A reliable car or NOT?
- Bought my H&R springs....
- Ipod integration for 2007 a6
- Anyone need MMI update discs?
- Back seat Squeak! ERRR!
- Converting US MMI Nav to Euro...
- 245/40/18 on rimms 8Jx18 which ET?
- Laser interceptor
- Need new tires
- Forsale Bilstein Sport shocks a6 05
- Sirius problems
- A6 bumper splitters and where to find any?
- S6 Avant? Paddle shifter on S6 sedan?
- Need to replace sub woofer on front passenger side
- HVAC Fan Noise Help Needed.
- MIL light came on mysteriously
- Does anyone know where to get....
- CEL light TSB- carbon build-up
- MMI Update
- Paddle Shift Retrofit
- Grrrr. Chinese parts!
- Fog Lamp Assembly
- Audi schedule maintenance
- Replacing Side Door Mirror Assembly??
- MMI sceen is completely out again this am.
- Suspension DIY?
- Vellano VSY 21''
- replacing rear tail light assembly ?
- Install Manual Rear Sunshade?
- Cargo Mat
- Koni FSD
- Strut Rubber mounts
- MMI DEAD?
- Bolt size?
- New Sway Bar Links = New Car = Happy Owner
- Gas Cap replacement options
- Is Audi still using Spies Hecker paint?
- Paint Code
- Fuel Door Locking Pin
- Binding sound in rear end, at dealer now...
- The S6 AVANT Valance search goes on...Dual Tip Mod
- V1 Hardwire Question?
- A5/S5 Wheels
- Best polish/wax for scratches? Best PC to buy?
- Question on window for 2005 Audi A6
- audio cutout 05 A6
- Control arm question
- Front brakes squeaking
- S6 and S8 have same front pads/rotors?
- How do you guys feel when A6 owners rice their cars?
- Onstar and Audi
- Would anyone here bring their car in for a hand wash for 18.95. 15 min wait?
- "Issue with K&N filter"
- Transmission Troubles?
- Entire Driver Side Tail Light Problem
- MMI Upgrade and Nav versions
- A/T fluid for my 2005 Audi A6
- Umnitza Angel Eyes?
- CD Changer
- How to Retrofit MMI Navigation to MMI Enabled Audi
- Few qustions about front damage in accident
- Really bad trip to the supermarket....
- Question about RS6 Bumper Install on A6 (C6) Body
- On Hard Accel, my Sirius loses signal.
- '09 A6 3.0t gremlin???
- Question on engine oil for 2005 A6
- Dealer says I might need new pads soon. I am gettig...
- Question for 20" wheel owners:
- DVD Nav disk question
- Slipping multitronic
- Anyone have access to etka or bentley manual?
- VMR | Wheels - V718 Signature Mesh!
- Engine warning light on 2010 A6 3.0T
- Price opinion on 06 A6 4.2
- Multiple Random Misfires (TSB update)
- Fuel Filter
- A6 3.0 STaSIS exhaust in stock
- Best FM Transmitter?
- My baby is gone...
- Power loss while accelerating
- Climate Control settings missing from MMI after upgrade
- Belly pan possibly damaged
- HELP!!!! how to remove front yellow marker light
- Weird things happened before she just died on me
- light bulb sensor is on, but all lights are working..please help
- MMI disks available for anyone that want's them in NC
- Can't get the air box out....
- "please check Navigation DVD"
- Redesigned A6 for 2011
- Audi A6 4F - Electrical Rear Lid - Comfort module coding help !
- anyone know how to fix my sirius...
- 2010 A6 Interior Trim Question
- 2006 Audi A6 4.2L under CPO - Both Keys Do Not Work
- Dark ring on New Rotors on New 2010 A6? What does this mean?
- Sporty Wagons Coming Soon?
- XM receiver compatiable?
- Audi A6/S6 Auto Lease Rates - February 2010
- I am very lucky
- Good Dealer in MA or NH? - Having dealer troubles.. :(
- Tire / Wheel Noise - What To Check Next
- C6 RS6 - North America
- 05 C6 A6 MMI Crashed - Some Questions
- How are KWv3 Coilovers on the S6?
