- Reset service interval
- 2004 Audi A6 2.7t - P2181 - P3081 - Cold start problems...
- Question for 3.0T Owners
- Possible sunroof/shade rattle?
- Replace A6 Seats
- Replace the tire or don't worry about it?
- Tire Pressure?
- FS: Hartmann R8 wheels on ebay
- A6 Rear Window Shade
- 2007 Audi A6 3.2 engine issues (need HELP)
- Probably a stupid idea
- A6 C6 2005 steering wheel swap
- S6 Tire help /advice needed
- Question of navigation antenna for 2005 Audi A6
- 4.2 v8 timing guide broken - will the new guide last?
- Osram D2S 5000K CBI's
- The look that compliments performance. HRE Wheels for your A6, from AWE Tuning.
- Fault with level control, Allroad C6
- 06 Audi A6 C6 Quattro 4.2 S-Line Front Orange Bumper Marker Wiring Diagram?
- Lubricating Sunroof and other stuff
- 2006 A6 sunroof won't open
- Dipped beam warning!
- Steering wheel control issues / Air suspension / Bluetooth Question
- S6 C6 Camber
- 2008 S6 losing coolant-Help needed please!
- 120K on a 2005 A6
- Here is how I spent my Saturday morning
- "Air Bag" light on dash
- seatbelt fraying, etc.
- Owners Manual
- 155 mph A6 3.0 TDI in action
- Power Steering Pump Leaking
- 2006 A6 plastic under body protector
- Parking sensors, are they interchangeable from other VAGs?
- Power Window Switch Malfunction
- wiper blade replacements for 2010 A6 3.0T Avant
- License Plate Filler 2006 A6 S-Line
- Trying to sell my 09 Avant, any advice?
- 2004 A6 Quattro 3.2l wont start first time
- OEM Brake question
- Wheel fitment assistance requested
- Trunk Light, Fuse, LEDs
- Official A6 (C6) Wheel/Tire Setup Thread!
- These 20's Should fit right?
- 2007 S6 AMI question...
- H&R bushings suck!!
- First Audi! 08 A6 Ibis White
- Help with uncomfortable seat
- 110K mi service
- Park Assist
- S6 A/S tires size 275/35/19- any issue with ABS?
- Steering and key symbol flashing
- ESP and Adaptive Light Errors At Once
- VAG-COM In (or around Zip 10962) Orangeburg, New York
- Tint Advise?
- ESP/ABS Light
- P0346 :: Camshaft position sensor
- Looking to purchase '06 Avant
- Stock up on your detailing gear 1st Day of Spring Special at DD
- No audible sound from park assist
- water in right rear foot well
- A/C stopped working- Help
- '07 4.2 versus '08 4.2
- 2006 A6 Avant Slow to Cold Start
- Question on 2005 A6 3.2L
- 2006 A6 Avant Windshielf Washer Leaking
- 2005 A6 thigh support?
- AC on - heat on driver side - AC on other
- VIN check request
- Power Steering Leak?
- Advise needed 08 with 115k miles on the clock
- Brake job cost and location
- Programing a beeper
- Best Place to buy Passenger Side Mirror
- head rest question
- In Need of Nav Software/DVD
- Just had my A6 3.0TDI 2006 Remap...
- Would KONI FSD help??
- Can we start a VAG COM tips/tricks sticky?
- C6 S6 Intake Manifold Replacement
- In case anyone was looking to do a front S6 conversion
- S6: 20x9 wheel 46mm offset ok?
- Throttle Lag
- How to release parking brakes and put it in neutral with not activated key
- HELP Wanted
- Nav not installed?
- Ridiculous - Audi dealer quoted me $400 for a battery
- 2012 Audi A6 3.0 TDI quattro
- Which MMI Software do I have?
- FS: 2005 Audi A6 4.2 Quattro - Gray/Beige - Sioux Falls, SD
- Bluetooth issue
- Timing belt or chains?
- Question on positive terminal for 2005 Audi A6
- Parking Brake - making screeching noise?
- Battery Issue Help!
- Question on adaptive headlamp in 2005 Audi A6
- ESP/ABS Lights on
- Adaptive lights question on 2005 Audi A6
- 2006 A6 Avant Adaptive suspension
- Rear Brakes Without VAG-COM? Yes, It's possible!
- 3G MMI iPhone Question
- Replace parking brake cable.
- Question on changing idling RPM
- FS: 2011 Audi A6 3.0T Prestige - Black/Black - Chicago, IL
- Add a 2nd AMI system?
- Vacuum Exhaust Valve on S6 exhaust?
- iphone Cable Help
- SPERATIC ROUGH IDLE ISSUES
- Last Day to Pre Order the Griots 6 inch Orbital Polisher Kit at Intro Price
- cup holder removal possible ?
- CR video review on current A6
- Bridgestone Potenza RE970AS Pole Position Tires
- A6 Avant and Q7 side-by-side
- Info on Fuel Tips-just passing along
- the return of the hazard safety triangle in the trunk
- Weird wheel/brake noise?
- VAG-COM NO LINK.. How to scan without IGN?
- Price for Immobilizer Control Unit?
- 100,000 mile club
- Car wont start - access/start control unit...
- Cheapest way to connect iPod w/o fm transmitter.
- Original Window Sticker?
- Need some help on 2005 Audi A6
- Dim xenon headlights/fuzzy cutoffs?
- Sports Seats / Sports Package
- If you were to replace your A6 Avant, what wagon will you choose ??
- DVD playing
- Give me your opinion on these rims....
- Carbon
- Philips DayLight 8 LED DRL - Anyone install this onto their A6?
- Does the dealer really flush?
- Junking C5 and buying C6 keyless go?
- 01590 Ignitor for Battery disonnect @006 C6 A6
- Revitalize the front headlamps...?
- Help Coding
- Need Help and Pictures
- Avant power tailgate problems
- Good Deal/ Bad Deal 05 A6 4.2
- need two sensors. help
- B7 A4 avant vs C6 A6 Avant
- akebono pads for 4.2L
- Please help with center display info......
- Audi A6 Adaptive Xenon Headlights Help!
- NGK PFR7W-T spark plugs for sale
- Will these 18 inch OEM 2008 Audi A6 rims fit on my 2006 A6 Quattro?
- Cargo Net Hooks @ side liner NOT anchors
- Need Help with part number...
- Looking at a used S6. Anything to look for?
- S6 back from dealer for 25k servive now shifting is different
- Rhythmic groaning
- New member Advise / Information
- What is needed for Ipod Touch?
- 2008 A6 4.2
- 2005+ A6 Brake pads Rear
- Synthetic Oil - which to buy for A6 4.2
- CD player -- snap, crackle, pop
- Confused about all Audi fluid changes
- How to remove scratches from wood trim?
- S 6 Reliability
- I need some advice
- NAV - not finding a logical route...
- Need some advise on the next car
- 2006 A6 3.2 repeatedly gives codes P0391 & P0024
- VAG-COM, Name Directory, and custom software
- Car selling advice
- FS: 2005 Audi A6 3.2 Quattro - Granada Hills, CA
- Sporadic Dash Alarm
- Any with auto folding side mirror ever have one suddenly not work?
- A6 Battery Replacement
- Leak Detected! Please advise
- VAG-COM Codes for S6 vichele modes
- Modification Questions
- Need Advice for Retro-fitting Steering Wheel
- Does anyone know what this is in my coolant?
- Battery problem HELP!!!
- Overhead Wiring Diagram
- Options on car
- Castrol Trnsmx Imprt Multi-Vehicle ATF=Lifeguard 6
- v1 tap the Console?
- Dealer trade in phone calls?
- Complete Brake Job this weekend
- Cost of 75,000 service for 2006-2008 A6 ???
- MMI Malfunction no display no sound periodic hiss
- Advices needed on changing trans fluid
- parking /auxiliary heater (Flame Out)
- Anyone successfully turn off Cold Diagnostics?
- Siri and MMI
- Driver Info Screen works intermittently?
- Need some help finding rims and a rear door
- ECU Upgrade on C6 4.2L
- Steering Oil empty
- Would you put max performance summer tires on an Avant?
- Best Way to Lower Audi 3.2
- 06 Avant question
- Need tires & feedback
- A6 upgrade to S6 DRLs/bumper
- Pentofrost ++ or SF for 3.2 FSI
- Beautiful Red Hot A6 2005 on Ebay.
- Advice about heated steering wheel
- FS: 2006 Audi A6 4.2 Quattro S-Line - 59,000 Miles
- Buy a VAGCOM or not? Pro's? Con's?
- MMI randomly and intermittently switching over to CD
- Oil level on dipstick
- Cosmetic upgrades on the S
- Battery replacement simple? Need "Audi" battery?
- Replacement unbelly/splash shield
- Thinking of 2006 Audi A6 4.2
- Low Trams Fluid
- C6 A6 Driveline noise clicking.
- Coolant Leak
- Passenger Tail Light Problem - Replaced bulbs but still not working
- Problems, engine related!
- iPhone 4s
- Should I keep my A6?
- Hello New S6 owner
- New member, Few questions comparing models
- S6 Help: Driveline Noise/Rumble
- A6 questions
- MMI Upgrade advice
- About to buy: C6 S6, high miles
- Fluids and Capacities
- H7 bulbs
- New Battery
- do we have an expert in camshaft driving chain sprocket in the house?
- Anyone have a grille filler piece w/o plate ?
- Will 2011 A6 grill fit 2006 A6?
- New to me 2008 S6
- Transmission Codes
- Car doesn't think it's in park after shutdown
- Advanced key
- Fuel filter TDI
- A6 Avant for sale in LA
- Rebuild rear caliper?
- the great Avant hunt...
- A6 (all models) who moved up to S6
- Aligning Adaptive Headlights
- 2009 A6 3.0T / prestige package
- Coolant tester
- Someone drove A6 Avant to Hunter mtn today. Are you here?
- Anyone have PN for taillight?
- Would the trunk cover for a Q7 work in an 08 Avant?
- Rear Seat Belt Latch Lost in Retractor
- ENJOY
- 2006 A6 4.2L Temp Gauge stopped working?
- Side mirror question...
- How to Replace 2008 A6 4.2 Headlight Bulbs
- Finally got some snow
- Introducing SuperSprint's S6 cat-back system
- just bought Bentley Repair Manual CD
- 4.2 Owners Who moved to S6
