PDA
View Full Version : A6 / S6 (C6 Platform) Discussion
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85
  1. Pcv problems
  2. 2005 A6 3.2 knock sensor replacement
  3. PT: 3.0TDI EGR OFF - Help
  4. Ruff idle/ missfiring engine
  5. MMI display totally dead
  6. Creaking in 2006 A6 Avant Front-end
  7. Rear tailight Malfunction? (c6.5 a6 Avant)
  8. Audi a6 c6 Tdi PD 140 BRE water ingress
  9. Need advice
  10. Please help! Cannot remove wheel from hub
  11. Upgrading MMI 2G Basic to High to Install an Aftermarket Android Auto Unit
  12. Heck of a time getting Alternator back in Please Help!
  13. For Audi A6 A6L 2006-2012 CarPlay Snapdragon665 Android 13 Car Multimedia IPS Screen
  14. 2006, A6 Carplay
  15. TR: Inexplicable gearbox mystery 2005 3.2 Fsi
  16. 25 codes after huge engine refresh
  17. Rear seatbelts
  18. Headliner PN help
  19. 2009 Audi A6 Quattro Alarm Horn failure
  20. Help Needed: Climate Control Unit Replacement - Heated Seats Not Working After EEPROM
  21. i chaned the timming chain 3 times in 4 years
  22. 2006, A6 3.2 quattro Avant
  23. Help, I can't find a solution: the instrument panel turns off while driving !
  24. Gugyella Róbert
  25. Warning for front and rear corner lights.
  26. Brake Pad/rotor replacement
  27. Q7 steering lock help request
  28. Backup Sensor issue
  29. P0133 Changed 02 sensor now p0132
  30. 2012 A6 Avant Parcel Shelf motor issues
  31. hvac blower not working
  32. LV: diesel car starts to fast?
  33. Rain/Light Sensor question
  34. Add Ski Sack
  35. 2007 audi 4.2 wagon - locked out with flat car battery
  36. Swapped mechatronic now this I wanna sell it
  37. 3.0T Camshaft Adjuster Options
  38. Sachs, Bilstein, KYB, Monroe - which one offers most comfort
  39. 02645 Valve level control system
  40. V6 3.0tdi no power
  41. Greetings from Canada, 08 AUDI A6C6 AVANTE OWNER.
  42. Need help
  43. A6 3.2 Quattro: Random Misfire cyl. 1. Need help
  44. Hello from the Great White North
  45. Turbo Actuator problem
  46. 2007 A6 4.2l No Start
  47. RS: A6 C6 - upper control arms - ball joint replacement?
  48. A few error codes help please
  49. Rough Idle and acceleration
  50. Weird electrical problem
  51. Hard shift from 3rd to 4th
  52. Help with diag device/software choice
  53. MK: Audi A6 C6 4F 2009 3.0T Quattro
  54. Audi a6 c6
  55. Help Needed: Rear Parking Sensor Issue on My 2011 Audi A6 C6 4F Avant
  56. please help me 00456 - Control Module for Access and Start Control (J518)
  57. Water Leak in Audi A6 C6 4F5 (2009) - Need Advice
  58. 2007 Audi A6 - P0366 after multiple replacements
  59. Fluctuation in rpm while coasting downhill at low rpms 1000-2000 (Audi 3.0 c6 2005)
  60. Swapping MMI components from a 2011 to a 2007 A6
  61. Car misfire and odd starting all of a sudden
  62. Weird parasitic draw
  63. Audi wagon in the snow
  64. Steering column adjustment does not work after VCDS basic settings
  65. Feeling like driving on rocks instead of tyres
  66. Wireless Android Auto / Apple CarPlay install
  67. Car won't start P1883 permanent fault code?
  68. Missing Navigation SD Card in Audi A6 C6 2011 Avant – Help Needed!
  69. Noise when cold
  70. UK: Is my oil filter housing cap suppose to look like this or should it be dry?
  71. Need help with suspension parts
  72. Stray hose in engine bay 4.2 V8 A6 C6 2006
  73. Drilling HVAC inspection hole
  74. 2006 Audi A6 ESP/ABS HEADACHE
  75. UK: *HELP* - Major oil leak on my 2011 Audi A6 - 2.0tdi C6
  76. Ratling/clicking noise on 1800 RPM if steering wheel turning right
  77. 2007 S6 C6 5.2 v10 - Bank 2 (left) intake runner sensor pinout
  78. Power tailgate DOESNT open on first button press
  79. One horn tone not sounding
  80. Strange engine sound after oil separator replacement
  81. S6 v10 brakes revitalized
  82. 2010 Audi A6 Quattro Cylinder 6 misfire
  83. Looking for a place in Brooklyn or NYC to duplicate a6 key fob
  84. RS: A6 C6 2.0 TDI BRE - noisy engine
  85. Good Used Parts Sources & Replacing Individual Intake Manifold Parts
  86. Water in trunk.! Solution.
  87. Water in trunk.! Solution.
  88. A6 2008 - 2.0 TDI PD engine (replace with CR)
  89. 2008 Audi a6. Passenger seat won’t recline anymore
  90. How screwed am I? (no pun intended)
  91. wipers not working after removal
  92. 3.0TDI C6 Sensor -40.5º / 551.0ºC
  93. Daytime running light bulb spec
  94. NZ: 2005 A6 3.2 Quattro Transmission issue, no drive
  95. Lost my only key
  96. 2008 C6 Avant 3.0 quattro diesel hood cable
  97. BA: Audi A6 C6 3.0 TDI Weird one time shudder once I press gas pedal or release break
  98. Varta 95AH BEM code help
  99. Finished project C6 Avant pics, and headlight question
  100. Reliable Service in CT?
  101. 2011 audi a6 hood lock mounting bolts
  102. Playing music from USB stick
  103. Forum look changed??
  104. Intake throttle/ EGR calibration? - 3.0TDI
  105. 2008 Audi A6 replacement headlights
  106. UK: A6 J518 emulator repair help
  107. 2008 Audi A6 brake components?
  108. Just wanted to show my new A6
  109. 3.2 swap to 3.0t?
  110. replacing front brake rotors. bracket bolts snapping
  111. MMI 2 problem
  112. my audi is hitting from a dead stop
  113. Wash Polish and Ceramic Coat
  114. Audi A6 3.2 - Oxygen Sensor B2 S1 Replacement
  115. Xenon headlights adjustment motors.
  116. How to program a new key fob?
  117. Currently Available Hitch for S6 C6 (2010)?
  118. Intake manifold
  119. sigh... dun broke a rod
  120. front rototors uneven wear. Do I need to replace guide pins?
  121. Replacing inside hood release bracket
  122. Audi A6 2004. CD changer issues.
  123. Replacing windhshield wiper motor
  124. 2008 A6 C6 with 25K miles (40K km) - any maintenance needed?
  125. 2011 A6 Avant 3.0 quattro sudden overheating
  126. Streaming music through MMI
  127. BLB 2.0 TDI at 175k miles - must have had oil pump fix?
  128. Where is this coming from?
  129. What exhaust is on my S6 5.2L 2008
  130. 2006 interion light upgrade
  131. Side mirrors fold/unfold opposite of one another
  132. 2006 A6 TDI - Turbo Compressor Surge
  133. Trunk and Fuel release are intermittent. CCM or BCM?
  134. Wire Gauge/Size EPB motor
  135. DK: Audi A6 2.0 TFSI 2008 misfire + problems
  136. Rear Bushing
  137. 2008 C6 lower front seat clips
  138. uk: Gearbox code?? C6 2.0TDI
  139. 2008 Audi A6 4dr Sdn 3.2L quattro tail light?
  140. 2005 C6 A6 Curiosity
  141. New to me 2010 A6 Avant!
  142. Multiple Faults
  143. Is this tail light out of production?
  144. EU A6 C6 sedan
  145. Camshaft p;osition sensor G301 implausable. Which one is G301?
  146. Start proplem a6
  147. LOCATION PLEASE 2012 AUDI A6 2.0t VVT intake side
  148. 2009 Audi A6 Quattro randomly won't start
  149. 01J VL300 CVT Gearbox issue
  150. Quick P2019 Code Gone, Cold Start Procedures Not Running
  151. Condensation through air vents after turning A/C off and no water puddle underneath
  152. 2007 A6: Central Conv module
  153. UK: Flashing Coil on 2.0TDI
  154. Forgive a probably dumb question: Bluetooth in C6 cars?
  155. CH: O2-Sensor related issues - Please help me
  156. 2.8 fsi reliability
  157. Engine sound, normal?
  158. Facelift or Pre Facelift
  159. Audi Q5 2018 water pump failure
  160. Oil in intake hose
  161. Different issues on new car
  162. Xenon headlight assembly replacment
  163. UK: CVT 7 speed Audi A6C6 2007 2.0 TDI
  164. Android head unit for Audi A6 / S6 / RS6 2006-2012
  165. IE: A6 3Litre bitdi - oil burner?
  166. Perking sensors problem
  167. New rear callipers
  168. Headlight thoughts
  169. Marks on MMI3G screen
  170. Aw man, crank pulley broke
  171. Adding Navigation
  172. Rain Sensor Replacement
  173. Can't roll up windows with key, no driver side buttons Please Help!
  174. 06 audi a6 3.2 fsi timing chain replacement
  175. C6.5 3.0t cam phase range
  176. A6 C6 V6 2.4 problem: 01201 - ABS Pump Supply Voltage
  177. Wireless charging pad
  178. Lots of issues after cam girdle / chain tensioner fix
  179. Battery Drain Issue Fixed
  180. Buying advice
  181. Random misfires and lean at idle FIXED!!!!
  182. S6 - Bilstein B8s
  183. Stripped Engine Plug on 3.2 RepairingUpper Timing Chain Tensioners & Cam Girdle Seals
  184. Cannot unlock and open car (2006 A6 Quattro Avant), even with physical key
  185. UK: Air Blower Motor Issue on A6 C6 4F2
  186. C6 MMI shuts off then flashes
  187. 2008 S6 ECM replacement/coding help
  188. Headlight replacement
  189. PL: Wheel fitment query AUDI C6 A6 3.2 FSI Quattro sedan
  190. Collant leak
  191. P2296 - Fuel Pressure Regulator 2 Control Circuit High (Have tried everything) HELP!
  192. Low coolant temperature on A6 C6 avant 2.7 tdi CANA
  193. J518
  194. C6 A6 brakes: I’m afraid that I really messed up
  195. UK: Audi a6 c6 2005 tail light swap?
  196. Putting air suspension on
  197. Conversion MIB sat nav maps to 2G High possible?
  198. Transmission fault
  199. PT: No Air Con A/C
  200. Audi A6 C6 parking sensors not working
  201. RO: A6 3.0 quattro 2005 unconnected pipes
  202. P3348 replaced new actuator and still problems
  203. Service Help
  204. Does anyone know the part number for this part
  205. Vibration while in drive at traffic light
  206. A6 C6 2.0TDI avant gearbox model number
  207. Part number ID request
  208. OBD II Throttle Actuator Control Module Performance
  209. S6 C6 exhaust
  210. AFS not working, THE MODULE DOES NOT RESPOND
  211. Rear springs OD and thickness?
  212. Alternator Cable Getting Hot
  213. HVAC button replacement
  214. 2009 A6 Passenger Side Exhaust Downpipe
  215. A6 TCM not communication
  216. Is your high mileage engine burning oil? Try this!
  217. UK: Air con broken
  218. Security lockout
  219. Footwell lighting
  220. Coolant Flush extras
  221. Rattling noise from cockpit only any idea what could be?
  222. Oil burning-any luck with stop leak/burning products??
  223. '10 A6 Wheel Fitment?
  224. No brake pedal after ABS module replacement
  225. Interior Help
  226. Coolant Leak 5.2l S6
  227. Service Manuals? 2006 A6
  228. EE: A6 C6 2.0tdi servotronic solenoid replacement
  229. S6 Exhaust recommendations
  230. Looking to get another Audi but its been a while
  231. Total Power Failure?
  232. Cam adjusters
  233. 2016 A6 Quattro 2.0 Thermostat Engine Light
  234. Avant- end gate tried to kill me
  235. 2008 Audi A6 - P2402 Evap
  236. New to me 2011 S6
  237. Good things come in large boxes
  238. A6 2009 3.0T P0018
  239. Intake Manifold Tuning Valve Stuck Open
  240. Oil pressure warning when engine lukewarm
  241. Help please. Tail gate light nearside
  242. supercharger side fill?
  243. Valve stem seals or ...?
  244. Air suspension woes… or not?
  245. IE: Audi a6 2.0 diesel Shuts off while driving
  246. Audi A6 C6 2011 electrical issues J519
  247. 2006 Audi A6 - Dead MMI - Changing Radio?
  248. Wheel bearing recommendations?
  249. Suspension tie rods and PM recommendations
  250. CZ: Audi A6 4f C6 2.0 tfsi 125kw BPJ
