- 2011 nav unit
- Help! Fuel range/mpg reading issue
- Audi navigation install
- Learned something new about my Audi today - DON'T WASH THE ENGINE
- MMI Problem
- Steering Wheel telescoping problem
- 2008 A6 Wheels
- Audi pushes Q3/5/7 too hard?
- Right side headlight no power
- What To Do - A6 On Last Miles
- Question about bushings and control arm replacement
- S6 program advanced key fob?
- Need help in finding a good independent service shop in Orange County, CA
- Updated from 2006 3.2 to 2011 3.0T: Stay with same oil?
- 2006 A6 Occasionally Does Not Start
- Cloudy Headlights Restoration Possible or Lasting?
- Pinch Bolt nightmare, what to do NEXT!
- TPMS help
- vag com need help
- headlight upgrade ?
- xcarlink based bluetoorh setup
- Top-off oil
- low windshield washer fluid indicator???
- 2005-2008 A6 4.2
- Just did rear brakes. No vagcom. Some tips.
- To everyone who has purchased a Blauparts timing belt kit for a 4.2L V8 Audi engine
- help with my 2011 vag mods
- S5 Wheels on 2008 A6 Front Trak
- Volume knob worn
- 2006 audi a6 3.0 tdi quattro s line Le Mans
- Air suspension - compressor not shutting off, error codes
- Suspension change for '11 3.0T to "sport" suspension costly?
- Rear caliper retract. A 3rd method.
- Upgrading Bose Sound Sytem
- Labor Day 2013 Special at DetailersDomain.com
- Battery Regulator Fault Code
- SiriusXM Linking problem finally resolved :-)
- Attempting MMI 4610 Update - "MetaInfo cannot be analysed!"
- Driver power seat
- Rear Bumper Valance/Spoiler Removal?
- A6 gearbox ecu removal help please!
- Wheel Offset Questions.
- 08 S6 stupid question
- Ski sack retrofit
- '05 A6 Steering Column Electronics and Stalk not work
- c7 s6 wheels on c6 a6
- 2001 A6 2.7T CD Player Faults
- Replacing Audi A6 C6 4F sport suspension with a standard one
- Power seats stuck.... Need help!
- EGR & DPF Removal
- carbon buildup warranty extension
- 2008 S6 Warranty
- 06 3.2Q tail light bulb repalcement
- Bulb out monitor
- Deleting limiter
- Tyre pressure sensors malfunction?
- Rear bulbs/harness issue?
- What Resistors ?
- 2006 A6 4.2 - front 'down'
- New to the Audi and off to a rocky start.
- SO what are all the latest MODS
- A6 2005 C6 3.2FSI
- Instrument cluster and central locking problem
- A6 4F Avant - Pop hatch?
- 2006 A6 4.2 Transmission shudder from 3rd to 4th...
- Vossen World Tour - Audi A6 Wrapped | Bagged & Deep Concave
- 2006 Audi a6 MAP sensor
- 2011 A6 Back up camra
- Unit for Bluetooth radio
- please help ASAP..speedometer not working
- 2008 S6 Engine Heat
- 2006 3.2 - Has anyone upgraded the base seats?
- '09-'11 Suspension options
- Need HELP plz about cont. main company.....
- Changing headlight bulb - what a pain!
- Need help on the loose rear piston.
- Ignition Lock Defective
- For Sale: 2008 Audi S6 5.2 V10 Quattro
- Should I get an APR ECU upgrade/chip?
- Audi A6 C6 User Manual
- Maintenance of an S6
- installing a nav
- Winter wheels
- Price?
- Front center console latch?
- Adaptive Cruise Control (acc) in a A6 C6 Allroad
- Sport/ lowering suspension recommendations
- A6 3.2 Quattro - Possible Purchase
- Help finding a part number for compressor
- Rear parking sensors continuous beep
- Bose Amp
- S LIne Bumper
- Question about Unitronic Tuning (2006 A6 4.2)
- 06 Avant power rear hatch problem...
- oolong grey vs quartz grey
- Question on 2005 Audi A6
- replacing ignition switch
- 07-10 4.2 A6 - S-Line Package Differences
- Help with MMI on 2005 A6
- Tiptronic TCM Location?
- Picture. It Happened!
- Audi A6 C6 Air Con Issue
- Looking at a 2008 S6
- First Time Audi Owner
- Power Chip sports mode question
- '05 A6 question
- 2011 A6 3.0T problems
- How to replace center brake light
- MMI Upgrade Clarification
- broken middle back seat belt latch
- $4400 high oil consumption with ticking sound when started
- Transmission problem?
- Pet Cover
- Worried newbie .. CEL P2702
- Paint Color?
- Independent Garages
- New leather in driver seat
- Add a second AMI?
- 2008 S6 Thermostat replacement
- Does my A6 have sport suspension?
- Would you buy an Audi if nearest dealer was 200 miles away?
- :: ECS Tuning :: Alzor Style 621 for Your Audi - 57.1 Fitment!!
- audi a6 diesel 55 plate
- Xenon problem A6 C6
- Avant, dead upper brake light
- p2543 low pressure fuel sensor
- I Love my new 3.0 tfsi but .....
- Audi Service in Tampa / St. Pete?
- Telescoping Steering Wheel
- What should I know about C6 air suspension?
- Suspension solution...
- Cant adjust headlight high enough, any suggestions?
- Sun Shade Springs (worth fixing?)
- :: ECS Tuning :: Facelift Grille for your Pre-facelift C6 A6!!
- Question on 2005 Audi A6 3.2 quattro
- anyone want to swap 08 license brackets?
- Engine surging at part throttle on hot days
- Body Shop/Battery/Start Stop Button Problems
- Problem with starting the vehicle
- just me
- Evap Leak Fixed
- S6 front brake caliper removal
- A6 New Front Bumper Thanks to Parking Stop
- Detailer's Domain - July 4th Special
- New Grill
- HVAC not blowing cold air out of any vents
- New owner of A6
- VCDS EPB Control Module Error
- 2006 A6 parktronic speaker location
- Jammed CD player
- Keyless Remote (Advanced Key) entry not working
- C6 Rear Door Panel Removal Help Needed
- Rims for my 2008 A6 Avant
- Advice for ECU upgrade 2007 S6
- Rear Tail Light Help
- Valve Cover Gasket on an A6 2006
- MMI 4140 > 4610 update?
- H&R Springs, 10% off through July 7th at AWE Tuning.
- Audi License plate bracket confusion
- Access to A6 Central Control Unit
- Can a 3.0 supercharger be bolted on to a 3.2
- Creaking noise after installing H&R springs
- Advice/Suggestions needed
- HELP A6 keeps unlocking
- LED fog lights on 2008 A6
- how much to replace struts on 2008 A6
- A6 Sline Mudflaps/MudGaurds
- kriwia
- O2 Sensors
- A6 parking brake ecu
- Brake Rotar and Pad OEM?
- TIRES TIRES TIRES
- Advanced key
- 2012 or 2013 USA Sat Nav Maps
- Is there a way to connect to phone music?
- Hitch options for my 4.2 S Line
- Audi A6 fog light replacement
- Wire Through Firewall
- Rear view back up reverse camera retrofit
- Brake assembly noise - Anyone know what this is?
- Sat Nav as standard
- A6 takes on another A6
- Bi-Xenons full beam keeps turning off
- Audi S6 on Motorweek tonight
- 2005 A6
- Please help with advice or feedback......
- glasspacks vs. resonated tips
- looking for a lead on bumper cover - oyster gray
- keyless start problems...
- Something in the roof
- water leaked into my '06 A6 driver side
- Anyone willing to to trade a standard suspension for a Sport suspension???
- Effect on mileage after muffler delete
- Auto dim side mirror, repair / replace?
- A6 3.0TDI V6 not enough power
- Forgeline Wheels, now available at AWE Tuning.
- Place for cell phone
- Belated photos!
- Audi A6 3.0 TDI Quattro C6 - ESP light >> battery dead??
- LED fog and daytime replacements???
- $80 deductible for CPO service? $40 for loaner?
- a6 c6 wont rev and wont move, help
- Is there an extended warranty/service plan that allows DIY on regular maintenance?
- New vs. old observation
- Issues with aftermarket 19 inch rims
- '08 S6 steering problem - anyone other C6 A6/S6 owners with same?
- Audi Wipers and Washer Reservoir Problems
- Brake - Creaking noise - when moving or standstill
- Poll: Engine grinding/rattle at cold start up
- Steering Wheel Question...
- Hello - I'm new here and some photos
- New A6 Owner Intro
- Does Check Engine Light Auto Reset after a while???
- Lube
- Cup Holder cigarette Plug
- ipod dock question
- Audi A6 C6 Avant sport suspension- help
- Should i buy H&R or Eibach Springs for my AUDI
- Goodbye A6!....or so I thought.
- First time experience | PLASTIDIP - Flat Black
- Help coding Aftermarket LED tail lights on S6/A6 with factory LED taillights
- Wheel Opinon Please
- Severe Alignment Confusion
- Aftermarket rims for 2005 4.2?
- Purchasing an Audi a6
- Radio reception
- Primer color for front bumper?
- Replacing rear shocks HELP needed.
- Where the engine oil goes?
- 2007 Audi A6 3.2L Quattro Front Control Arms Replacement best parts to buy?
- Squeaking from back of 5.2 V10 engine
- heater works when it wants
- 2006 a6 3.2q mic issue
- 2007 Audi A6 3.2L front anti rattle spring proper installation
- VAGCOM to bleed ABS pump
- Memorial Day Special at Detailer's Domain Starts Now - Stock up!
- Muffler or Cat Converter or something else?
- NEW A6 SPIED!!!!
- A6 manual transmission in US
- :: ECS Tuning :: C6 A6 LED Interior Lighting!!
- Please Can tell me what's the name of this ?
- inserts for my wiper blades
- 2006 A6 3.0tdi quatro 2 days after turbocharger change, fault 13128 again
- Avant power liftgate question...
- Seriously. Somebody Help.. Temp Sensor Question
- Rear Diffuser Avant A6 C6
- 2005 A6 4.2 Bluetooth Module location?
- 2002 TTR Rear Panel Removal Instructions Please
- Passenger Seat Control Panel is Loose
