- Problem with my a6
- 2008 A6 Sline question about fluids
- Audi A6 C6 4F 2.4 V6 - Camshaft Adjustment Solenoid Valves Question
- Component Protection - 02084 & 02095
- adaptation
- 07 A6 Air Filter Box Part ID
- Audi A6 C6 MMI 2G Custom Touch Screen Entertainment System
- 2008 A6 S line brake question
- 2006 A6 radio quit then steady high pitch tone.
- 2010 CAN gateway problem
- Audi A6 C6 Power Loss
- Rear Strut Replacement - Advise needed
- Ordering 2018 A6
- AFS and flashing
- Airbag sensor replaced and skid plate question
- Misfire problem on cylinder 2 help.
- Audi God's PLEASE HELP! Simple timing questions
- 2008 audi a6 3.2 s line.
- Just gained access to green menu
- parking brake not working
- Issues after Lowering A6 C6 with B12 Pro Kit
- Please help before I burn the dam thing, cutting out at 1/4 tank
- 2007 a3
- A6 c6 2006 right tail light not working
- DIY front spoiler
- Headlight going out?
- Going on a long road trip...feeling worried
- Audi S4 Avant conversion
- Figured out why the car kills batteries.. help!
- Wiper fix
- audi a6 3.2 timing problem
- Lost Steering Wheel Controls After Bootloader Update
- Audi A6 Quattro 2008 wiper relay and location?
- audi a6 Quattro 2008
- "dash" Low break pad warning light.
- Q5 Rear Wiper Malfunction
- Widdling down the possibilities...
- Issues buying parts online from Amazon
- Help identifying this part...
- CD Changer Question
- New Front Air Struts for '06-'11 Audi Feature Custom-Tuned Shocks
- FSI 3.2 engine compatibility
- ABS module repair
- 2007 Audi A6 AUX
- Missing Rear CV Boot Clamps
- The basics... care to share?
- Audi a6 c6 transmission update
- Oil Cooler Leak
- 05 A6 3.2 leaky injector on cylinder one...
- Thoughts on Remanufactured wheel for spare?
- ever have this particular A/C problem ?
- There is a chance that Audi of America will bring next version of Avant RS6 to US
- 2008 Q7 blowing hot air in front, cold in back
- Got tired of the OLD MAN WOOD look
- 09 A6 prestige tail lights
- VCDS alternative?
- Going to buy used 2008 A6
- Audi 2007 S6 Reader Module Failure
- Shift modes
- audi a6 gear ratio error
- Good shops around PA
- 11 A6 TDI - loss of power, engine mgt & emmission control system lights
- Locking wheel nut (Please Help)
- D2 SERPANTINE BELT REPLACEMENT
- Newish C6 V6 diesel owner hoping to solve some issues
- windshield hair crack
- Re Tard timing blowing oil pan seal
- Proper torque for VC's on 3.2?
- How to install 5 wire Universal WideBand O2 Sensor precat
- bluetooth
- Rear sping replacement A6 C6
- Advice for 2014 A6
- Indy mechanic in Sacramento area?
- Audi throwing codes, need some help (vw enthusiast)
- Wheel/Tire Questions
- ECS poly snub mount pics and airbag light/code question
- A6 TDI 2014 Diesel
- number plate light working sometimes
- Dr. Tranny for torque converter shuddering?
- 2005 Audi A6 4.2 help
- AMI
- 2004 A6 2.7t
- Location of the fuel pressure regulator
- Update Maps from SD Card
- New guy here
- New 2008 A6 owner here, getting a feel here.
- Gearbox Failure Please Help
- 2005 A6 - Bluetooth module replacement
- A6 c6 hid with projectors giving poor light.
- Question on Brakes
- UP Grading 2009 Audi A8 Headlights to LED
- First Audi, wooo!
- Best way to run a wire through the firewall?
- navigation install
- curious tt lover
- 2006 A6 Circle with a straight line through it on dash
- Grief & Loss...
- 2006 A6 C6 - Key Safe Mode Nearly Daily!
- 05 Audi A6 MMI
- 2005 A6 - Fuel gauge goes up - how many fuel level sensors?
- '11 A6/3L/130K on hold. Advice needed.
- Audi Code help
- audi a4 tdi b5 station wagon 1998
- Rust in lower quarter panel ?
- Has any one else have bent valve on their C6 3.2?
- clicking noise when press brake in park
- Removed AFS inside headlight and module on outside
- A6 C6 ignition switch E415
- Is it possible to make DRL stay on while headlights are on?
- A6 4.2 error code reads maf sensor even after it was replaced
- Question/issues with heater ac fan
- Antenna for HD radio??
- How to remove dead pedal
- New ride and steering wheel replacement
- New to Audi, Avant liftgate question
- Audi s6 v10 oil leak
- Battery died, now MMI does not turn on
- 3.2 or 4.2
- Climate Control Question
- 2007 Audi A6 check engine light
- C6 S6 with 100k miles + reliability
- Replace ignition switch
- Adaptive Headlights- All 2005 A6 (C^ Platforms)? Parts recommendations?
- heater fan
- 2005 A6 Rain Leak
- New C6 Avant owner (longtime B5 owner) with a few ?'s
- Replacing 2017 A6 xenon headlights with full LED
- Looking at a 2005 A6 4.2 S line- advice?
- 2005-A6 4.2, Pre Purchase questions. New to Audi (former Volvo)
- Newbie user seeking help/advice !
- ZA: Air suspension leak from where?
- 2011 A6 Avant Prestige Parking Assist No Warning Sound
- Subwoofer and amplifier instalation
- A6 C6. MMI system restarting (rebooting) every few seconds.
- Thoughts on the 2.0 vs 3.0?
- TCM location
- Buying question
- C6 A6 passes floodded BMWs
- 2011 A6 Air Intake Question
- New A6!
- New Grill
- Need help
- Mark B
- Debating taking a gamble on an S6 - Advice appreciated
- upper intake gasket 2006 A6 4.2
- J model 3.2L saloon Two issues MMI and The dreaded.
- Pre-facelift to facelift rear conversion
- New Ride! What should I do first?
- A6 - FSi vs TDi engines
- Thinking about buying
- 2g Hi AMI issues with power
- 2008 Audi A6 Upper Timing Cover Sealant
- Replaced Rotors and Pads on All 4 Wheels Last Night, Now Pedal Feels Soft?
- 3.2 Cam girdle torque specs?
- Where is Cam position sensor B
- Erratic HVAC
- help!
- Help with a C6
- lost the metal clip on a side marker
- Good Deal?
- Audi TT 2011 spoiler brake lights have just gone off altogether
- Avant rear washer hose broke (even with the recall retrofit)
- fuel pump
- Climate controls died. What fuse position powers it.
- audi a6 TDI
- Next A6 Iterati
- What is this in the air filter housing
- Audi A6 3.0T PP Quattro wheel offset
- 2016 A6 - First CEL, now seatbelt indicator
- 2006 Audi A6 3.2 Quattro transmission fluid change
- I did 130mph (Video). What was your max?
- Winter 2017
- Another A6 gone
- A6 3.2 purchase questions
- Audi A5 convertible rear sensor H15 buzzer location
- Static and crackling noise
- Audi A6 BRE 2008 tdi camshaft position sensor - help!
- TPMS monitor fault (on a C6)
- 2011 A6 C6 - lights around gear shifter & MMI not active
- Bosch Quietcast Brakes
- Album Art from Spotify in my 2012 Audi A6
- Mid-winter maintenance & Plans
- Mid-head gasket?
- Future of Advanced Driver Safety Systems
- 2010 Audi A5 with clutch won't start
- Paint Color?
- NOW OFF TDC - A6 timing chain tensioner replacement
- 2011 A6/Navigation system not available
- please help 2005 A6 won't start and transmission stuck in park
- Trunk won't open from any electrical source--sometimes 2005 A6
- Audi 2006 V10 inlet manifold issue.
- Bluetooth phone doesn't work
- Wheel size question
- 40V OR 32V 4.2 V8 ENGINE (UK)
- Upper timing chain cover 2005 A6 C6
- Best year model for A6
- Interior Color Durability/Preference
- Avant tailgate soft-close issue...
- Oil Leak
- 2006 A6 wiper fluid no sensor?
- Moisture in Headlight / New Owner C6
- 05 AUDI A6 Quadro S-Line trouble shooting
- Change paint color on C6 A6
- Daytime running Lights issue
- Oil leaks! Arg!!
- 2005 audi a6 3.2 sedan radio/mmi not working
- Upgrade to 20" on my S6?
- UK: Audi C6- No Dash Lights
- Battery drain.
- High Beam Assist retrofit
- Music from my iPhone 7
- Am I driving a C6?
- Upgrading wheels on 03 S6 Avant
- 2005 audi A6 3.2 sedan does a forward jerk movement when coming to a stop
- 2008 3.2_Oil pooling in 1 Torx well on top of head cover?
- 3.2 to 4.2 swap?
- A6 q 2005 3,2 bad cold start .....RPM drops ???
- Remote Starter For My '16 A6 (Diesel)
- Center Display burned out
- Audi A6 C6 4F Gas Tank shield
- D2S to LED headlight bulb conversion?
- Intake Manifold Runner (Bank 2)
- HYR Transmission
- 3.2L FSI knocking noise
- 2005 A3 2.0 L4 engine needs replacing
- Steering Column transponder
- 2007 A6 Timing Chain Tensioner
- audi navi plus RNS-E navigation button
- Center display starts after few minutes when cold
- What's the cheapest source for C6 wiper blades?
- 06 3.2 a6 powersteering fluid and air susp?
- Oil pressure light only when turning right slowly
- 2006 Audi A6 Quattro 3.2 L
- A6 C6 HVAC not working
- NEW D1s/2s/3s Xenon Bulbs | Front Turns | Error Free Reverse LEDs | Interior LEDs!
- checked esp fuse/amp on drivers side and now anti-slip light stays on
- A6 C6 2005: Please take load off steering wheel - cannot start car
- Paring a 2008 Audi TT with a rolling garage door opener
- Oil Leak Revisited
- Yet another 6 speed Tiptronic (9L type) issue
- 2010 A6 headlights on 2005?
- New to A6 Diesel: Opinions wanted
- A6 C6 Rotors
- Engine lift points?
- Needle sweep
- dip stick levels
- Audi guard protection kit
- PPI results
