- GE: p1534 error code 3.2 Fsi
- Do you have to have new tyres 'all round' an Audi Quattro?
- Experience with/longevity of the flex pipe repair?
- using A6 to tow another car?
- TT: C6 cooling fans trying to run to full speed when AC is turn on
- 09 3.0T Flex Pipes
- A6 diesel (C6) Power Delivery Problem - diagnosis assistance pls?
- Car won't start without hard key push
- Adaptive Air Suspension and lack thereof
- Change your fluids!
- Audi a6 c6 switced power 12V (ignition power) location
- TT: 2005 A6 C6 2.4 wont start when engine is hot
- Honeycomb grill parking sensors
- Audi Android Multimedia battery drain problem
- TPMS Antenna location 2007 A6 3.2?
- Anyone want my Red Audi Avant 2006?
- EE: 4F 2005 touring "fog bulb error msg on dashboard" - possible to code it out?
- And the P00106/000262 Price goes to.....
- Ignition coils: Bosch vs Denso vs NGK?
- Air Suspension issue
- UK: C6 diesel Temperature issue
- 2007 a6 3.2 quattro front bumper facelift help
- Audi A6 C6 3.2 FSI Tiptronic Quattro Engine /Timing Chain Sound
- 2.8 Engine in c6
- Park brake problem
- GE: Audi A6 C6 Other Engines?
- NO: Rpm fluctuations 2.0 tdi BRE
- Run car without SC for a while?
- 2005 Audi A6 incredible acceleration (video)
- Getting info for certain states
- is this time for my (third) A6 station wagon?
- Can you upgrade the MMI on a 2009 audi a6?
- Need car wash/detailing place recommendation
- 2005 A6 4.2 pulling left, then right, then left etc sometimes
- Very weird mmi problem
- 2010 A6 Avant- convenience open/close rear hatch chatters
- Ambient light problem
- 2008 Audi A6 3.2 Quattro?
- Auxiliary Fan Fuses
- A6 C6 Facelift
- LV: Oil pressure sensor location 2009 3.0 TDI
- Rear View Camera Not Working
- 3.2 parking brake malfunction
- MMI not working
- 2008 S6 ABS module replacement
- VCDS in San Diego Area
- PT: Audi A6 C6 Avant 2.0 tdi
- Has anyone used "audi a6 c6 better high beam solution"
- Starting problem.steering module?
- 2006 A6 3.2 PART OUT
- Audi A6 C6 Smoke How fix ?
- Q for those with 3G MMI....
- S6 brakes squeak - dealer cant fix ?
- Alarm lock beep noise
- 2008 A6 4.2 Brake Warning Light questions
- Audi 6 problem with coolant having to be refilled at least once a day
- Audi a6 c6 Smoke Problems
- Supercharger Oil?
- CEL - G71 Implausible Reading 000262/P00106
- Temperature gauge not moving but engine is HOT !! Help!
- Strange EPC limp mode
- UK: 3.0 TDI Tiptronic issue.
- How do I change the bulb for the right inner trunk lid brake light?
- AFS question
- Help with Crankcase Breather Hose
- Guess who's back into a silver(ish) newer avant?
- Strong Oil Leak only after driving
- Multi function failure
- GE: Front Light problem
- Brake light issue
- Audi A6 C6 3.2 FSI P0303
- 2006 A6 Rear Subwoofer?
- MAJOR HELP NEEDED GUY MISFIRES AND EPC LIGHT
- How to fix Audi A6 C6 2005?
- Help with 2007 A6 4.2
- "8DY" MMI High? Which version is it?
- C6 3.0T overheating in stop and start traffic
- Cylinder 1 air fuel
- Location Fuel pump module on 05 A6
- p2004 and p2093
- 2006 a6 dirty oil throwing camshaft position sensor error?
- seat bottom not moving up or down....
- Front spring noise
- NZ: Allraod hunting 4.2L
- 165K Fluid Service
- Removing rear view mirror on a 2013 Audi A6 Quattro
- Audi A6 - Serpentine Belt keeps splitting while idle or turning hard
- Audi A6 exhaust suggestions
- 2005 Audi A6 Quattro igniter to ballast wiring
- My first audi a6 ac not working . air intake g89 sensor
- P2006 P2007 problems with starting
- 11 a6 avant hatch/tailgate interior trim?
- A6 just wont start suddenly...
- A6 Air suspension Rear Spring not fitting
- A6 4.2 MPI fart sound (noise) from PCV breather valve.
- AM: Recommended oil spec?
- 06 a6 s6 wing mirror
- P0346 cps bank 2a
- Hood sensor issues
- "Steering column control module" going bad?
- Is there nav map newer than 2018?
- Audi no crank/start, steering lock. Electronics work a6 3.2. j518 module?
- Audi A6 C6 Fuel Pump Replacement Tutorial
- Putting front end in service position
- Retrofit MFSW on a a6 c6
- 2007 MMI 2g High + AMI could play music from an USB 2.0 stick?
- Purchasing S6 Questions/Opinions
- UK: Oil pressure warning light, diesel
- 2010 A6 3.0 TFSI engine noise on cold start
- I was told "You will never stop..."
- Throttle Actuator & ECM intermittent codes limp mode 3.2 engine
- chain tensioner upper guide rail.
- Only half my mmi display works
- Right tailight not working( at all)
- Key Saga - no the lock
- 06 a6 3.2L
- UK: Noise when pressing Brake pad on P/N?
- AU: 2008 - A6 Allroad C6 Suspension collapse
- Looking for mechanic in NYC-area
- A6 hood cable
- Door hinge A6 C6
- Dash repair
- A6 allroad 2007 few questions
- 2008 A6 Avant flashing reverse lights
- camshaft sprocket position.
- Broke the valve breather hose.
- My A6 has a few annoying problems...
- 2006 audi a6 p0346 code but sensor is fine
- 2006 A6 Avant - Suspension Question
- Winter Tire size recommended
- 05 A6 S-Line Bumper bolt on to 09??
- Group 93 numers?
- Parking Brake Adaptation Options
- Replacing dashboard Bose center speaker
- Coolant fan stays on.
- Third brake light stops working when i put in reverse
- Help Heater
- Change Cylinder head cover gasket and injectors
- Transmission slip
- Replacing Ignition Switch
- Bluetooth Module replacement
- 2010 A6 3.0 oil burning
- Broke hood latch
- Rear timing covers need to be resealed.
- Selector lever malfunction
- Vacuum issue
- Maintenance on used 2011 A6 4.2l
- Advanced Key - Help me understand....
- Rear Window Regulators
- SI: diesel, white smoke, oil completely gone
- Air condition control: basic vs plus? (question about Euro spec)
- Android on mmi 2g high
- Audi a6 C6 after market dsp install
- Strong coolant smell after warmed up
- Spare key problem
- 3.2L FSI N/A, Looking for an opinion based on experience.
- 3.2 FSI known oil pump or rod bearing issues?
- Oil leak
- LED turn signal
- Help Needed: Oil Leak, Noticeable loss of power, P0341
- A6 C6 2010 S-Line Air Suspension to Coil Over conversion
- Need help disconnecting upper radiator hose
- Updating my basic MMI
- Ampire AMPIRE Smartphone-Integration Audi MMI 2G High
- 2008 A6
- Steering Rack R&R question
- Brake Light Switch-Repair Procedure Correction
- Ticking sound from back of engine
- 2011 Avant Boot Open but it's not
- Door lock acutator
- Help--Rattle after replacing upper chain tensioners and removing camshaft girdles
- P0018 temp circuit sensor 1 too high
- Your opinion is needed- dealer vs. independent Audi specialist?
- Daytime running light warning on dash
- Temp gauge not working, both fans come on at start
- Accidentally opened A/C lines on radiator
- Possible causes of P0492 DTC- insufficient air flow in 2ry air injection system Bank2
- Fuel/Trunk Button Intermittent
- Unable to crank engine after camshaft guide removal
- Help needed to remove stuck camshaft adjustnment valves
- My 1st Audi
- Camshaft girdle bolt reuse vs replacement
- 2008 A6 3.2
- 2011 Audi A6 Quattro Help!
- DTC 2070 Intake Manifold Tuning Valve stuck- solution?
- my next station wagon?
- *Starter* or *Ignition* troubleshooting
- Driver seat stuck
- Time problem on cluster
- Folding mirror issue
- Audi A6 2006 - computer connection without the ignition
- 2008 Audi A6 3.2 Quattro s line CODE U0002 any ideas where I should I start?
- 2007 Avant.. Walking/wandering steering!?
- How to change reading lights, help!
- Green menu
- fender/wheel well liner
- Recent Brake Job
- Best way to drain coolant for 2007 S6?
- Engine ticking at idle
- A6 vs Allroad for ride quality and quiet cabin
- Help - key broke off in ignition switch
- 2009 A6 3.0T Heater Core Question
- A6 C6 allroad suspension
- Audi a6 2011 headlight
- LT: 2.0 multitronic to 2.7fwd?
- What bumper fits on 2005 model?
- Front windows not working
- Audi wont get contact with ECU, nothing happens when turn key.
- P0455 - 2008 A6 4.2
- Headlight Washer Cover
- UK: A6 C6 , MMI LCD = dead , upgraded to Android, still dead, help me, obi wan!
- A6 C6 , MMI LCD = dead , upgraded to Android, still dead, help me obi wan!
- 2008 A6 4.2 shifting issue, slamming into gears
- A6 06/ 3.2L quattro serious Headlight issusues
- 2006 A6 Avant Manual door Key inop
- Using a smoke test machine to find a vacuum leak
- How-To: Audi Lock Carrier Service Tool #3369
- Rear wiper problem
- Gearbox related electrical problems?
- My fault codes - A6 C6 can you please advise what's important?
- Marketplace Question
- 2008 A6 Quattro Auto filter
- part out coming
- How-To: Audi A6 C6 Steering Column Removal with Actuator/Module Fix
- A6 C6 wiper blade question
- BXA Engine left bank valve-cover sealing
- 2007 Audi a6 MMI not working after dead battery
- Engine noise - 3.2
- Camshaft Holder Tool when replacing upper timing chain tensioners
- I feel like the little boy in the dike...
- 2007 Audi A6 Manual mode
- 2008 A6 4.2 random misfires
- Question about modules Audi A6 4f ?
- Can’t change instrument panel settings
- 2007 A6 Allroad J523 location
- Front Bumper
- Audi A6 Allroad 2007 Air Suspension Problem
- Temp creeps up
- C6 Brake light switch?
- 2006 C6 MMI
- Can’t pump fuel into tank.
- Key stuck in ignition help
- S6 With V10 Lamborgini engine
- 2007 Avant hitch install.. Wire colors??
- PL: Is my engine finished?
- Oil leak repair soon. Question for the forum
