- considering selling 2008 Avant Sline w RS Rims
- Withdraw ignition key radio stays on
- dirty valves ??
- AMI help
- New to Audi! Can someone help me decipher the Ipod integration options?
- 2011 A6 looking for VAG code for seatbelt chime?
- MMI Reinstallation??
- My APR tuned A6 3.0T Review
- Anyone know error code 00470?
- HELP!!! just got 2006 A6 with OEM HIDs, but also want LED's... How can i retrofit???
- De Carbonize Cost Or Minor Questions
- Need Part number?
- Thermostat recall notice
- S4 Avus 17 x 7.5 on an '08 avant
- 2011 A6 oil change interval reminder reset
- Pondering an '06 4.2 S-Line purchase
- Used ABS Control Module
- Car still cranks after ignition on cold starts
- XM /Sirius module swap
- tranny issue?
- Thermostat recall
- C6 S6 EVOMSit ECU Tune - Anyone try it?
- DIY upper control arms?
- Headlight housing removal instructions:
- Bluetooth connected but Audi Telephone.....
- How to select correct MMI
- s line bumper
- Advice on 2005 Audi A6 purchase?
- Audi A6/S6 Auto Lease Programs - April 2011
- s line bumper
- 92k 07 a6, 3.2 advice needed before purchase,
- Anyone have MMI update CD's they wanna loan me? I'll pay shipping back and forth. =)
- G12 Coolant a bit above MAX is that ok?
- Cold Start S/W Update.
- Car Won't Start
- Wheel Upgrade
- VCDS VAG-COM port interface location for C6 (pic)
- The new M5
- How to pull ECU?
- Audi Extended Warranty Group Purchase Discount! See Inside For Details.
- Scratches in Wood Inlays
- Buying a used C6 - Which model?
- Crash!!!
- SOS Car Stuck in Parking
- MMI issues need help
- removing rear sway bar
- P2404 Check Engine Light
- Need info on Front Rotors
- '04 A6 2.7T Sline Quattro - new to us
- A6 Avant Tailgate trying to kill me
- is this all I need to allow video playback via the MMI...
- Fine screen pre-air filter
- AMI and cd changer questions
- S6 Engine Light - Injector Problem
- Please I need a picture! or Information..
- does anyone have a spare S6 grille?
- Good MA Inspection Station?
- c6 s6 O2 sensor replacement - lower the engine?
- Advice on potential 2008 A6 3.2 Quattro Sedan purchase?
- Considering brake pad "upgrade" to Akebono; PN?
- what is the best way to attach a license plate frame to the RS6 grille?
- Sway Bar Upgrade or else
- 2006 A6
- A6 3.0T Custom Exhaust
- Adblue - Reductant - What is it?
- 2008 4.2 blk/w Amaretto 56K @wholesale...
- Exhaust Tips!
- 19" OE RS6, 19x8.5 et48 Wheels only -4 Sale
- Navigation heading indicator in VCDS
- Can I use cables for Sat radio for Nav?
- No sound from MMI
- Fixed a problem myself and saved a fortune
- RS6 grille
- Need advice on exhaust tip change.
- headlight question
- Blacked out C6's <Pics>
- High pitched whien at cold startup normal secondary air pump function?
- LED bulb replacement
- MMI update went wrong???
- a6 hartmann rs6 wheels
- anyone running 275/35/19 in 19x9 on an sline avant
- About front lights and tire size change
- xenon conversion problem
- My one-touch windows are acting up
- Aero Wiper Conversion?
- FS: Audi Maintenance Items
- Does S6 Mirrors will fit to my S3?
- Hub Rings
- C FIBER dash kit
- 2005 A6 Received Satellite: 0
- sline fit standard model
- RS style mesh grille for cheap.
- Hub rings
- Double checking dealer on overall low mileage and cold start issues
- Looking to put larger tire on
- Im at it Again: Check out these DRL Devil Eyes for 05-08
- How to replace Parking Brake Wiring Harnesses?
- Auto lock - walk away?
- Spark Plug Replacement
- Need Help to understand my situation!
- A6 Blackout Complete w LEDs
- Problems w/ removing front bolts when lowering a6 4.2???
- MMI Update while car is running???
- Disable orange markers in the bumper?
- Need help finding a link.
- Where is cylinder 9?
- Just sold 2005 3.2 Quattro - good deal ?
- voice command phone possible on '06 ?
- 08 3.2Q and Carbon Issues
- TPMS sensors
- Newer A6 engines have Timing belt or chain?
- Re-alignment needed when moving from 17" to 18" wheels?
- 255/35/19 or 235/35/19
- Max miles on used c6
- Anyone instlled these?
- FYI: Hesitation
- Voice Command Button Stopped Working (Worked Previously)
- Battery Maintenance Recommendation!
- MMI 2G Update to EU or not?
- 9.5" rim on a 2006 A6?
- Cup Holder Adaptor
- Anyone here installed a custom exhaust/ intake on a A6 C6 3.2L Engine?
- Issue with Navigation with 2005 A6
- Very strange sound question!
- Need headlight cover. Anyone?
- TCM 4B0 927 156 FE help.. Rusted
- How to remove Sirius radio?
- MMI update problem. Logs inside
- A6 4F 4x4 does not work on my 3.0 TDI !!!
- Audi still new to me: Carbon build-up concerns? Should I Sea Foam?
- Adjusable Control Arms
- How to remove reverse light bulb?
- Sat Nav to SDHC
- Missing fasteneres on front fender liners Why?
- help me choose vag com
- Two noob questions...
- S6 on a diet?
- News about 2012 S6
- Help with these Vag Codes
- 2009+ (post-facelift) rear valance? Help!!!
- Small scratches removal advice.
- Hello Audiworld
- Audi RS6 claims ice record over Bentley
- dvd playable files on 3G mmi?
- S6 Summer tires
- No Sales Tax For Military
- Angel EYES Headlights
- A good deal?
- How dangerous is driving with broken coolant fan control module?
- 19" S4 Wheels will work, right?
- 0 Satellite
- S6 and RS2 photos
- Lowering the a6
- halogen headlights change to bixenon with drl.
- HID lighting project
- Battery replacement Coding?
- any one used the repair kit from Audi to...
- spacers suggestion for 2008 A6
- OEM Sports Springs with Standard Shocks
- Akebono Pad Review
- 2010 Stasis A6
- Emission control system warning indicator on
- tire pressure monitoring grayed out in mmi
- Oil Charged Filter????
- What's 05 A6 Q Rear Brake Pad Size?
- a3 concept
- What's with MADAudi.com??
- Stock offset is 42mm, correct?
- driving in mountains on ice
- Audi Build Sheet Option Codes - MODS: Please sticky in "Resources" section
- Looks like Genuineaudiparts is no more...
- Rocker Panel Repair Question
- Need Info about my new car...
- FAULT CODES/ almost all related to voltage issue.... any ideas please
- Help: Trim around MMI display rattles/vibrates
- APR or Stasis 3.0t ECU bump
- Anyone needs load resistors for LED bulbs?
- 2011 A6 P+, Radio Presets
- About engine oil level and different tires on the car
- Can 18" wheels replace 19" on 2011 A6 Avant's
- Finally, new wheels on
- Automatic Car Wash: Is it bad?
- SOS!! Guys, need your help.
- Audi TT rims on s6?
- Help. Defroster vent rattle
- Front grill plate
- Battery Level in MMI
- Headlight glass polishing
- End Of Lease ... what to do ?
- High pitched noise from radio
- VAG-COM Purchase / Rent
- Intermittent Whining noise from front
- Details on 2012 S6 / S8...
- Reset service reminder without VAG?
- Rear brake light and indicator showing faulty on ipack but bulbs OK??
- My new S6 Avant
- Help with offset
- 2012 A6 autospies Video
- Looking to buy an '08 A6 - question about Carfax reports
- Euro plates anyone?
- Another Brake Question
- vagcom
- parking graphics won't display in mmi .
- FS: CHEAP 18" OEM RS6 Wheels w/tires (off 2008)
- Due for 55K service but only 39K miles
- Parking sensor Graphic Display in MMI HELP !
- Rear bumper removal help.
- 2012 A6 First Drive...
- 2005 A6 not starting
- I'm selling my 19" A8 12 Spoke(turbine) Wheels
- DrivTech | VMR Wheels 19” V701, V708, V709, V710, V713, V713 w/Pirelli Tires Special
- Aftermarket upgrade for A6
- OEM Oil for 2010 A6 3.0T
- Rims for 2006 A6 Avant
- Part numbers for Airbox Retaining Clips on 05 3.2?
- I'm Finally Back in an Audi
- Some questions about A6 2005
- Another wheel fitment question
- Remote function
- eBay remotes / programming
- Headlight Range Malfunction (For the archives.)
- are the fog light grille covers the same for the S-line as
- Center Console Repair (now Heated Seat does not feel as hot?)
- Which extended warranty or service contract?
- Hmmmmm. What to do? Wheel = Check, Tires = ?
- LED's
- VAG-COM help
- Air Intake
- 2011 A6 Prestige wheels question
- Chicago Auto Show
- Oil level question
- 2010 A6 3.0 water pump.
- Muh new riiiiiide! : )
- Really stupid question, but how does one open the steering fluid reservoir??
- 2006 A6 Avant ?'s
- My new baby!
- 08 3.2 avant residual heat?
- Too much ATF?
- Wrinkles
- heated steering wheel
- OIL Recomm
- Driver's side front door alignment?
- Please help a soon to be A6 owner.
- Audi A6/S6 Auto Lease Programs - February 2011
- Front side markers don't work???
- 2008 A6 Avant 3.2 vs 2009 A6 Avant 3.0T
- Residual Air in the Summer??
- Photo of Conti DWS 245/40-18 mounted on flat 5-spoke stock rims?
- is this offset to aggressive? pics inside
