- how to tell if tailgate supports (gas shocks) need replacement?
- Navigation has no clue where I am
- Having Air Conditioner Problems...Need Some Help!
- A6 brake pedal switch question - worth trying another?
- Parts number
- 2009 A6 with uncommon TPMS problem
- Help. Need a picture for reference
- Audi A6 2006 3.2 Quattro Transmission Replace
- Strange "rumble" from right rear
- Oil pressure sensor replaced 3 times in a week--EPC Fault intermittent
- About to DYI C6 strut & shock change out
- Say good bye to C6 members
- Purchased 2008 A6Q 3.4L - Basic Questions
- Carista OBD2 app can now do service reset and EPB release
- 5.2 V10 tapping on cold start?
- Audi A6 2006 Avant voice change
- VDCS and fuel issues
- Is this an aftermarket grill 2009 AUDI A6 Prestige?
- Camshaft Sensor/solenoid
- Air suspension problem.
- Metal flakes in oil @84k miles.
- S-Line steeringwheel swap-wiring harness
- Whirring, clicking and whining noise when inserting or removing ignition key (video)
- 3.0T nightmare scare
- ESP, ABS & Parking Brake lights are up!
- Auxiliary Fuse block install
- MPH 2 Speed warning help on 2006 A6 2.7tdi S Line Quattro
- Adaptive Headlight Error Fixed
- Starting to have multiple problems with my 05 3.2 A6, HELP!
- Min Oil Light Dance: Light on & oil topped off
- Wanting to buy an Audi A6 4.2
- 3.2L Engine Speed Sensor Location
- :: ECS Tuning:: FREE SHIPPING ends 6/28 MIDNIGHT
- tranny, torque converter, or both
- 2008 Audi S6, 52k miles.
- Can't bleed ABS pump
- HELP compatibility of 2007 BKH engine
- how to pull apart parking sensors?
- Audi c6 climate control
- AC compressor not engaging
- What is this??
- Summer Start MEGASALE!
- Will a brilliant black front bumper look way off on a Phantom Black car?
- radio and all audio keeps cutting out every 15-20 seconds, what's going on?
- extended warranty
- VCDS: 3.2SFI Bank 2, which side is it?
- Confirmed: MMI 2G High > Add AMI + Tune2Air = Bluetooth Music Goodness
- '06 C6 3.2 coolant level dropping 8-16oz./day.
- Broken hose for windshield washer.
- blower/Climatronic won't work
- :: ECS Tuning :: Time Is Ticking!| Save Up To 15% On ECS Timing Chain Kits!
- MAF - CEL, reoccuring
- bank1 cold start noise n cel codes help
- A6 C6.5 front rotor bigger than rear rotor. Normal?
- 2007 A6 Avant 3.2 cold start shudder/misfire still happening after carbon cleaning
- Avant suspension conversion
- 2005 audi a6 4.2 S line pt 2 update with questions
- a6 2005 a/c problem
- Engine whine noise on low revs when AC is on
- Anyone know what the latest AMI_update .bin file is for 09 A6?
- 2011 Allroad no AMI or bluetooth streaming how do i use my iPod for music?
- Lowest ET wheels on your S6 ?
- Blinking turn signal lights
- :: ECS Tuning :: Audi C6 A6/S6 | ECS Exact-Fit Brake Lines
- License Plate Holder nuts
- Finally saw another 4f55vl (C6.5 Avant) in person
- Battery Reconnect
- 2012 Steering Wheel Removal
- Replaced battery and all heck broke lose
- 2005 audi a6 4.2 S line Troubleshoot questions
- Emergency flashing brake signals
- 2009 A6 3.0T cooling fan
- ABS module part number
- Front Bumper Part Numbers
- Weird Problem
- Back in the Audi!
- S6 V10 milled aluminum valve covers gauge of interest
- What am I missing when upgrading to LED Tail lights
- Rear Left Turn Signal Not working! A6 2006 3.2
- Engine starting problems
- rattle from glovebox
- Intake Hose port/nipple disconnected.
- 3.2 Camshaft Position Sensor/Intake Manifold Tuning Valve Malfunctions
- Towing with '09 Avant
- 2008 S-Line Question
- C6 parking brake control module location
- MMI restarts after 5 min
- Intermittent headlamp fault
- Still Having A/C Problems
- DRL bulb replacement tool
- HID headlights
- EPB issue
- Creaking Sound
- headlight help
- Whining noise even when engine is off
- Help p3028 code ???!
- FREE SHIPPING through Memorial Day!
- '05 Audi A6 3.2 P1158 and P0068 codes
- Less than 24 hours away from launch!
- How do I defeat TPMS in VCDS ('06 C6)
- Unstable tachometer
- Accident - Side mirror, turn signal, windshield
- steps for cracked breather hose
- Wiper Blade Options
- Can INDYs flash ECM?
- Blue Smoke - 2008 A6 3.2 - 188K Km
- Anybody used this cable for their iPhone 5S through 6S?
- 2008 A6 C6 - LED Plate lights coding?
- 2008 S6 V10 5.2 Milltek Exhaust Review (Videos)
- 2016 A6 USB phone charging very slow
- 3rd key fob won't work
- C6 Avant Ownership (Long)
- Glow light blinking (EGR?)
- New directories not recognized on thumb drive
- Upgraded my 06 Avant to an 08 Avant
- driver door control problem with mirrors and lock/unlock via remote
- 2005 audi a6 with mmi basic
- Peoper operation of 2006 A6 Avant lift gate?
- Black all weather floor mat on beige interior (Pictures)
- Audi A6 C6 Rear Brake Pads replacement (Pictures)
- Audi A6 C6 Front Brake Pads Replacement (Pictures)
- Audi A6 C6 Rear Bumpstop Replacement (Pictures)
- Driver Door Jamb Socket p/n?
- A6 Bose Speakers not working on Drivers side
- MMI Problem
- Intake Manifold bank1 flap stuck open/closed
- 2007 Audi A6 Ignition Lock Warning Light - Key Stuck in Ignition
- What the hell is this vacuum line!
- 2006 Audi A6
- Is there such a thing as a decent third party warranty?
- Has anyone taken an upper tensioner apart?
- Air suspenion problems 2006 A6 Quattro 4.2
- Hard downshifts into 3rd gear
- A5 wheels on C6 = rubbing
- MMI Optical Bus Diagnostic Result Help
- Steering column adjustable does not work - VCDS Basic Setting
- AutoPreme Prices (2 Weeks Away from Launch!)
- Will a 2009 A6 Front Bumper Cover Fit On a 2008 Avant?
- Exterior door handle removal/install instructions
- Engine Fault Codes should i be concerned?
- 3.0 AVK Motor Swap
- VCDS coding for enable 2011 A6 C6 Audi Driver Select
- Update on car
- 06 A6 Avant 3.2 engine failure ...
- sirius question
- Phone Book Contact Names Not Populating in MMI via Bluetooth
- Successfully converted a AFS to Non-AFS
- C6 A6 diesel, glow plug issue, 2007 plate
- Are 2006 OEM (Sachs) C6 shocks gas-filled?
- 2006 A6 C6 4.2 - Found water in the driver side rear footwell, unique problem
- Sirius issues
- Audi A6 2007 - Audio Input question
- air suspension to coils conversion
- Whees questions
- Adjustable suspension
- VCDS HELP
- Finally finished the initial "couple of weeks" work
- FREE AutoPreme Floor Mats!?
- torque converter 3.0 TDI
- Documentation for changing serpentine belt?
- Cheapest wayto reset service due message?w
- Sun visor hard to move up and down
- Turn signals playing tricks on me
- Car won't stay running...
- Sunroof will not close due to sun shade.
- I broke one rear upper damper mount bolt. Torque specs and tools please
- 2005 3.2L Quattro Transmission Problem?
- 07 a6 3.2l 160km. crank no start. please helpp!!!
- How to Protect your Floor Mats (A Revolutionary Solution) - AutoPreme Update
- DIY Oil Change on 2011 A6 3.0
- BRAND NEW - new style ignition start/stop switch
- Goodbye and thank you all
- A6 3.2 racing with BMW 540i
- Audi A6 2.7TDI w. fault code: EGR System - Insufficient Flow - Intermittent
- Want to buy 2007-2011 Audi S6
- ***Don Nguyen | WannabeRacer.com | Vehicle Wrap - Tint - Plastidip - Custom Decals***
- Cam Tensioner Seals (half moon) - 3.0T - Dealer only?
- HELP! ESP, Parking Brake, ABS lights all on
- What part is this?
- What's the "expected" ignition coil pack life?
- What is better to stream bluetooth 2007 Audi A6
- Engine compartment sounds like a jet taking off when heat is on!!!???
- APR ECU Tunning
- cd charger mp3
- Trip Computer Mileage does not Go Up, and Fuel Gauge Faulty
- 2007 A6 3.0 TDI Le Mans - iPod
- What kind of pwr steering fluid?
- Replace 2009 A6 headlight switch
- passenger seat diagnostic
- A6 C6 Emergency Flasher wiring?
- Backup Sensor Not audible w/Backup Camera?
- So hard to find parts...!!
- Little help needed
- mmi 2g issue
- Suggestions for dip lights
- Anyone have a steering rack fail suddenly?
- A6 Aircon question
- Did 1st oil change, found cam tensioner covers leaking
- How does the C6 TPMS System Work?
- Power seat fuse
- Audi A6 2006 3.2 PRND light on
- HELP! P0411 Secondary Air Injection System Issue
- Front Bumper Cover Removal
- Interior LED Kit + License Plate LEDs-Error Free-Lifetime Warranty-Free shipping
- Front Sway Bar Links Removal (Pictures)
- Ok I need opinions!!
- Why does the A8 accelerate faster than the A6 with the same engine?
- Replacing thermostat - broken tabs missing in block?
- Need Instructions How To Replace Thermostat & Water Pump in 2010 A6 Quattro 3.0T
- Help replacing front door lock actuators
- Timing chain noise
- Hesitation/jerk under hard acceleration 3.0T
- :: ECS Tuning :: Save Up To 30% On ECS Assembled Kits | Limited Time Only!
- A6 C6 2005 3.0 TDI QUATTRO
- Heating and AC issues
- 2005 A6 3.2 V6 Headlight in premium model
- 2005 A6 v.8 4.2, Is it ok in Gas or too much?
- Xenon Headlight Beam bounce
- Lowering Spring DYI Help
- MY09 A6 Emission Light Issue
- Well that was short lived. 😡
- Audi Newbie - 06 a6 Steering Wheel Audio Functions Not Functioning
- Oxygen sensor replacement B1S1
- Major Engine Oil leak : 07 A6 C6
- Coolant Temp Sender or Fan Control Module
- Big Leak, Big Problem
- Question on motor mounts on 2005 A6 quattro
- Newbie to Audi
- Leaky PS Hose Clamps
- 2006 a6 automatic trans fluid
- 5.2 V10 into 3.2 - Tranny Question...
- Car says not in Park so doors wont lock
- Instrument cluster avoid CP
- Trunk struts/shocks
- TPM Sensors
- HELP! Tire is touching wheel well after hitting crub
- Cam Position Sensor G163 error
- Headlight troubles and more. [Bi-Xenon, pre to post facelift]
- Will someone with a 2010 A6 post their VCDS scan for the Sirius Radio and Airbag
- Time for new brakes
- :: ECS Tuning :: Want Milltek Exhaust? CALL US! Promo Ends 3/5/16
- Just bought my c6 what is this?
- 2008 A6 4.2 Looking for advice
- Audi A6 2.0 TDI 2007 big problem P1883
- Need help on what kind of grill this is
- Considering trading for an A6
- S6 or RS6 exhaust to an A6
- Please help me find a post
