- A6 4.2fsi 2008 P0018 fault
- SE: Several error codes appeared on my A6 C6 2007, need help!
- Maf sensor location
- AUDI a6 c6 3.0T feels like it can't catch
- Power seats wiring diagram
- JHM Tune & State Inspections?
- FI: Tiptronic automatic transmission won't engage
- Will Q7 aftermarket Android MMI fit an A6?
- Power loss, preglow indicator, P3348 still present after many repairs, 3.0 TDI A6 C6
- UK: A6 C6 Quattro Allroad Air suspension Yellow/Green Fault
- 3.2 FSI Cranks NO Start
- Help with 2010 A6 3.0T
- Lost with limp mode / ESP / EPC please help!!
- BC Racing coilovers for S6 too soft
- Electric Tailgate issue
- car feels weak after alignment\adaptation
- engine overheating. should I change fan, regulator, thermostat?
- Still Misfiring
- 2012 A6 Timing Chain
- Lack of acceleration and recognition from car to shift gears
- Camshaft Position Sensors
- AU: Audi A6 C6 Steering Wheel Change?
- LT: C6 avant 2g high mmi reverse camera retrofit
- LT: AUDI C6 FL HEADLIGHT PROBLEM
- Weird auto transmission fault 2006 A6
- 2008 A6 4.2 P0024
- Intermittent EPC Light
- Audi A6 2010 does not start after turning off the key?
- 08 A6 4.2L Random Misfire After oil flush/ change
- 2016 S6 Transmission
- Boot floor
- AMI unit swap 2007 S6
- Long roof Audis
- The new guy... Are there any workshop manuals floating around?
- Bass on the Bose system stop working on the left side and back
- UK: MMI connection?
- A6 C6 Dash backlight stays on / No Error Code / Drains Battery
- A6 TSFI 2.0 Turbo Nosie while car moving
- UK: Going crazy
- HELP! TCM is not where I'm told it should be
- American message board members.....
- Vapor lock
- 2009 Audi S6 Misfire Issue
- UK: ECU fault Audi A6 C6
- Buzzing Coming From Cigarette Car Charger
- MMI not working.
- SE: A6 C6 Remove ECU?
- Battery drained to 6.67 volts while I was gone for 2 weeks
- A6 2.8 FSI intermittent misfire when warm
- A6 C6 Tail light bad ground, need to find ground (E11?)
- UK: Rusted jack point
- Selling my Audis for cheap and leaving the brand
- Power Supply Relay (terminal 75x) -J694
- AUDI A6 2010 supercharged 3.0 OIL LEAK PLEASE HELP W ANYTHING?
- Need some tips/guidance
- P0234 error and flashing glow plugs
- E415 Ignition & VCDS
- Ride hight 2,7tdi avant quattro. With springs
- Oil pressure sensor
- Intermittent EPC light and other faults
- Audi A6 allroad c6/4f electrical issue. No cluster
- 2007 Audi S6 5.2 V10
- '07 A6 3.2 Engine Clicking? (mp3 attached)
- Let's do a test
- DO NOT Just toss parts at that motor!!!!!
- 2010 A6 3.0 TSFI timing tensioners
- Engine issues
- Key Fobs
- IL: Throttle replacement or cleaning?
- Factory DSP non Bose wiring diagram
- Engine Mount
- Electrical Nightmare
- Greetings from SuperSprint Italy
- 170bhp S-line special edition CAHA
- HELP:a6c6 obd pin definition
- Parking Brake Malfuction
- 2008 a6 3.2 quattro obd problem
- AMI Installation
- MMI 2G High strange behaviour
- Need to know if this means I should get new ones?
- Transmission reset or tuning?
- 2008 Audi A6 timing issue
- MMI Sytem Doesnt want to turn on
- 2007 A6 Allroad – Intermittent Air Suspension Fault Code
- 2006 A6 Avant - MMI Issue - Control Unit
- Audi a6 sline dip beam problem
- Sport / Lowering springs and proper shock setup?
- 2011 A6 Intercooler
- Audi 2.7TDI BPP HPFP bracket problem
- Erorr codes on my Audi C6 2005 3.0 tdi
- Can't get my electric parking break to release
- Would be greatdull if anybody could help
- The car is not crank and not start
- No power to sensor in engine bay please help
- esp fault, brake fault, parking brake malfunction headlight range control defective,
- A6 C6 2.0 2006 avant cvt DMF
- Stripped fill plug on front differential A6 4.2
- SE: Does my A6 have A/C?
- UK: A6 C6 strange sound after gear change
- Center support bearing, driveshaft noise
- LT: Audi a6 c6 plastic seat cover
- A6 no ignition when key turned on
- A6 2008 Not Cranking, not Starting suddenly. CANNOT READ CODES.
- How to auto decarb a V10 intake valve
- Is mmi 2g basic suitable with ami interface?
- BG: Does the S6 C6 V10 have active exhaust valves?
- 2004 A6 2.7 Turbo Random Shut Down (Secondary Exhaust Failure??)
- Several Codes - Can you give me part numbers for new sensors for my 2008 A6 quattro?
- MMI 2g basic upgrade option
- Aftermarket Headunit Installation
- ESP/ABS System function test
- EVAP Fuel Vapor Temperature Sensor
- 2006 A6 Avant 3.2L A/C problem
- A6 coolant
- Both keys can't lock, but can unlock
- Parking brake malfunction
- S6 C6 wiring diagrams needed
- FI: Audi A6 2.4 (2005)
- ES: ESP/ABS PROBLEM HELP !!! AUDI A6 4F C6 3.0TDI
- 2013 A6 3.0T getting P2006 & P2007 code
- 2009 A6 3.0 TFSI died under power
- Heater blower inoperative. Blower good. Resistor good
- audi a6 avant front airsuspension down.
- to s6 owners
- Programming out the manual mode
- Wheel/drive bearing issues
- 2008 A6 Crankcase Vent replacement?
- 2005 A6 4.2 BNK cooling fan keeps running with car off
- Emissions System fault code
- Potential Oil Leak Fix for Cam Girdle Joint
- IE: A6 2.0 diesel battery light
- Need help with a no crank/no start
- UK: Audi a6 front wheels jumping
- MMI Issue
- Intermittent ticking from engine
- 08 A6 3.2 with 190K miles, camshaft position sensor
- a6 4.2 v8 low compression problem
- 2008 A6 3.2 water pump replacement
- 2006 Audi A6 quattro missfire
- Fuel Injector Seals (Help)
- 2005 A6 4.2 bad cats? What are my options?
- 2008 Audi a6 died in me in traffic
- what year parts are compatible with an 08 a6 quattro?
- VAGCOM codes
- UK: Realiability?
- PL: Audi A6 C6 3.0 TDI gray menu ;(
- Retrofitlab headlight upgrade kit
- engine dies
- intake manifold flaps - life span? S6 C6
- A6 C6 Avant / Steering issue
- 2011 Audi A6 Avant 3.0 Prestige Driver information screen is blank
- Injector retaing clips Replace them or Nah???
- metal dragging sound when driving
- 2010 A6 No Audio Volume for Radio, Nav, Bluetooth
- Where to get J271 - Motronic engine control module (ECM) power supply relay?
- Exhaust question about A6 C6 3.0T
- A6 Avant - 12v Socket surround loose in centre console,
- Mr G Hurley C6 A6 Avant
- Anyone know of a Sprint Blue S6 for sale?
- AL: Audi a6 c6 Facelift Headlight Upgrade?
- To make a new key
- G85 sensor wont calibrate
- 2010 S6 Intake Actuator Failure
- Coolant missing and engine fan running
- UK: Audi a6 c6 2006 emergency release trunk?
- Need Help with coding battery
- FR: A6 C6 Air suspension drop during maneuver
- A6 Airbag module reset help needed
- Audi A6 C6 2.7 V6 TDi clock spring help
- Exact Location of Locking Wheel nut in rear side panel
- 2013 Audi S6 Parts
- 2008 Audi S6: I NEED HELP
- 2016 S6 bose amp replacement coding process
- Automatic Headlights
- ME: A6 C6 door sound insulation advice
- All my interior don’t work
- Brake Light Warning ... but why?
- Parking Brake warning light constantly on, even though it not mechanically engaged
- Light Sensor Issue?
- Low oil pressure warning light on dash
- 2007 A6 3.2 Catalytic Converter Replacement
- EPC? FUEL RAIL? Which one is it?
- Rough idle and misfires on 3.2
- 2007 A6 3.2 Flex Pipe Replacement
- First Time Poster MMI Assistance
- 3.0T Engines, Oil Dilution, HPFP & Rod Bearing Failures
- IE: Swirl motor not actuating, bank 1, diesel
- Spinning sound after shutoff
- 2006 A6 3.2 Avant
- Brake Disc help info
- HU: Very bad misfires started after a short trip
- 3.0 tdi power surge
- Service Manual / Repair Manual
- Coolant Leak after front bumper replacement????
- HELP!!! CANT FIND THE RIGHT PART
- 3.0TDI rough idle after few minutes
- Misfire and slow in 1st gear - please help 🙏
- Component Protection for Driver Seat Controller
- Brake Pad Warning Light
- 005715 - Please check DTC Memory of ABS Controller
- Engine Data Block 93 - Camshaft Acceptable Deviation Limit at Idle
- PL: A6 C6 3.2 FSI Engine won't start and chokes
- alternator , battery module and esp
- Rear Backup Sensor speaker Location ?
- A6 Egr problem?
- My 2007 Audi S6 has rough idle and suppressed drive on a cold engine.
- Major hesitation on highway/minor hesitation in the city
- 01273 Fresh Air Blower Findings
- TCM Removal
- Passenger (right) side door outside handle acting up
- Rear lift gate not raising on 08' A6 Avant
- A8 D3 round steering wheel on A6 C6
- gearbox malfunction mesg. Limited drivability
- 2008 Audi A6 fuel pump relay?
- CL: Audi A6 C6 Fuel Pump still having malfunctions
- Air bag light on / sensor location
- Would a 2008 front bumper cover fit a 2011?
- 2011 3.0T Whining on Engine Start Cold
- 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
- BE: 3.0tdi facelift mods for more power
- 2010 S6 Seat Fuse Location
- Vacuum/Air Pump - Odd experience.
- HU: A6 2010 2.0 TFSI | Insane rough idle
- LT: Audi A6 C6 engine stops when switching to reverse
- s6 c6 v10 wheel alignment factory specs?
- 2007 S6 V10 5.2 liter major oil leak
- A6 3.0t oil leak only long trip at 80+ mph
- EE: A6 c6 3.0 tdi injectors problem
- IL: car chokes with whistle sound from the dashboard
- 05 Audi a6 aftermarket headlight options
- I need tabs at bottom of seat back
- Ambient Retrofit Problems
- 2006 A6 3.2 being parted out
- Battery Changed, MMI now dead
- Advanced key - sync after battery replacement
- Potential Purchase Help - 09 3.0t Quattro
- Fuel Trims
- 2010 2.0 TDI Intake Manifold problems
- Traded old Cummins truck for 2010 C6 quattro
- Kid didn’t help me out
- Audi s6 2003 avant- Quattro
- Whatsup with this shizz bruh?
- Convert the Lock-confirm beep to a different tone / sound GUIDE
- Lock-confirm beep sounds
- Alarm keeps going off
- FI: 2.4L V6 multitronic reversing lights sometimes not coming on, P0706
- Audi S6 V10 intake manifold flaps
