- Looking for feedback on k-mac front camber kit
- Part number for sline/sport springs?
- Tire Pressure for 2011 A6?
- Leaked 4.0T Power Output
- MY08 C6 A6 Headlamp switch removal...
- 2011 A6 Premium Plus clock runs fast
- Bentley ATF Help...
- Help with choosing Tires
- Anyone know how to remove the driver's side speaker housing?
- Question about VAG com...
- Replacing 08 C6 A6 Mirror Adjustment Knob
- OT weekend car
- 2007 Audi A6 Multitronic 2.0TDi "Misfire" and Brake Light Problem
- Changed both rear Assemblies BREAK SIGNAL LIGHTS ON RIGHT AWAY
- WTB 06 Avant ... ASAP
- Viper Smart Start
- Some little smoke when the kick down
- Whos Audi's current wheels manufacturer?
- Any reputable independant audi mechanics / shops in Orange County ???
- Opinion on Wheels
- Matte Black Vinyl Wrap?
- Enjoy:
- Chicago Winter Storm!
- Heated steering wheel on 2009 A6
- Engine oil
- NITROGEN ON TIRES
- Thinking about new wheel/tire setup
- s6 front bumper
- 2010 A6 3.0T Coolant Leak Water Pump Failure
- Will these look good?
- New A8 What???
- Fix Squeaky Steering on Own: 2 Solutions. Need You Advice. Thanks
- LED lights
- rs6 rims
- ECS 100 (V-Checker Pro) Not Idiot Proof, help!!!
- RS6 Pedal Swap
- simple headlights change to RS6 headlights .need help
- Wiper/Central Locking Problem
- Intermittent rear brake light and turn signal sensor
- Knocking Noise...Help ASAP, pics inside!!
- Light horns as highbeams?
- Some Tips and Tricks Take From " AUDIZNE" by jdaudi
- Having problem replacing xenon bulb right now, help!
- Graphite / gunmetal wheels on black A6
- Parts FS: front bumper, rear valence, fog light, floor mats, front grille, more....
- P2296 Fuel Pressure Regulator 2 Control Circuit High
- OT: RWD BMW saves lives
- C7 Video
- C7 Video
- 2006 audi a6 3.2., ECU Reset
- Lowered suspension: to K-Mac or not to K-Mac
- Is there any reason I need to keep my MMI update discs?
- Wheelwell hardware for bellypan missing. Anyone have pics/PN's?
- Keyless Start not working. Troubleshoot advice?
- Will any of the Porsche caliper / rotors fit directly on a our cars?
- HD radio no sound
- Where do i check Transmission Fluid
- Anyone has experience with these DRLs?
- Frozen in place! (off topic)
- Diesel Engine Sound with Extreme Cold
- MMI Audio Not Function in EXTREME Cold
- Silver/AL dash - wood available?
- Check this out.... Is this a Low Battery or Audi Misteryyyy....
- Parking sensors suggestions?
- Torn
- Digital Speedo.?
- Engine Starter motor replacement?
- 2006 A6 Transmission problem and fluid change??
- Need New Battery
- Engine temperature for A6 4.2
- selling/trading my 2005 A6 4.2
- Anyone have a spare 2011 RNS-E North America they dont want?
- Powder coated 19 BBS <Pics inside>
- IMPOSTER S6
- Looks like APR has 3.0 TFSI A6 software now.
- Another brake pad question
- Seafoam. Not the usual question.
- Bearing Replaced, Dash Looking like a Christmas TREE
- Transmission delay? Normal for Audi?
- Small crash
- Left HID failure. Any suggestions?
- First Drive: Audi quattro Concept
- TUNAP micrologic® PREMIUM 173
- Headlight washers
- Rear seat backrest latch noise
- Beat the Winter Blues wtih Detailer's Domain - 20% off.
- Question on MMI update: how do I know it's correct?
- Window switch replacement simple?
- Brakes screech when cold, but only in reverse...
- Any bmw or mercedes owners switched to Audi here?
- Need Carfax. Please help
- Air Bag Light on 2006 3.2 A6 Sedan
- Good bye certified warranty... gulp
- Flex Coupling Leaking/ Fix ????
- Need advice for buying 2008 A6
- Pink headlight
- Headlight Color Change
- anyone with S6 wheels on their A6?
- Front S6 Badge
- Beck/Arnley Rotors w/ Akebono Pads
- Sunroof wouldn't close
- Installing RS6 Grille on 2008 S6
- Help Needed! RS6 headlight retrofit
- DRL in the headlight
- 2006 A6 P2006 P2007 Error Code
- Car Cover good for snow??
- Anyone Want to sell there Front License Plate Mount?
- cheap vibrating seats! ...or just a rough idle
- '07 4.2 FSI fuel smell
- Aux Cable anywhere?
- Replacing the Entire Right Rear Assembly, Snapped my Knuckle in Half
- Heat/AC Issues blowing opposite out some vents at times
- CEL's, Runs like crap at times and sick of it. Please help
- New wheels!
- 2006 Audi A6 3.2 QUATTRO Opinions NEEDED on my DEAL
- A6 (C6) 2006 - DVD Navigation device Problem
- Parking brake mulfunction annoying sound
- found LED DRL set for internal mounting into Audi headlights, any opinions?
- phone setup
- Where to buy eyelids for '08 A6?
- Need Some Advice
- Cant find some positions in MMI
- Audi A6/S6 Auto Lease Programs - January 2011
- Rear wiper motor very cheap easy fix !!!
- Front brakes wear out in 20k miles?
- S6 vibration
- Funny..Yet Very Serious Problem
- Another s6 carbon problem...
- How to get a wire from the hood into cabin?
- 2011 A6
- 4.2Q Light Engine Vibration at 1,200~1,400rpm
- Anybody have the 19 inch 5 TriSpoke RS6 Like Wheel from the TT-S on their S6?
- Tail lamp assy "assembly"
- Is there such a thing as Michelin Primacy HP All Season?
- part # for rear pass pillar vent
- Rear Seat Entertainment on S6
- sway bar and tint
- Anyone in CT with VAG Com?
- Transmission Fuild Change: Now shifting 'strange'
- Anyone know if a VagCom can enable Beep Sound when Locking?
- Help with wiring DRL modue box.
- Damaged Bluetooth Module; will my '05 A6 still function if I remove it?
- Strange help, needed
- Some unknow buttons
- Immobilizer fix?
- Would you buy this or not? 07 S6 for $30K
- reverse bulb replacement
- DEALER DRIVING THE CAR WHILE FOR REPAIR!!!!!!!!
- 2010 A6 Front License Plate Holder
- Radioproblems
- About MMI and yellow liquid
- folding side mirrors
- VNS AMI BT
- 2006 A6 Avant Cylinder Head/Cam Shaft Problem
- BKS Tuning
- Happy New Year to all of my AW friends
- Passat Seems Nicer than the A6
- Strange behavior - Parking brake engaging/disengaging - from Reverse to Park -
- Happy New Year!
- Coolant Change Procedure ?
- Low groan from engine when off/on gas
- More questions about winter wheels
- is this the type of engine coolant we should be using for the 4.2 engine?
- Badge Removal
- Tailgate interior trim removal
- Ignition coils recall is on, check your dealer
- Add VISUAL parktronic via vagcom (for A6 with equipped parktronic)
- RS6 Grill Replacement - HELP!
- 2005 A6 - what do I need to watch out for?
- NEW BATTERY SOLVED FEW PROBLEMS
- Audi A6 Alignment
- Warranty
- Tim Myatt
- VIN Check
- Foglight bulb
- Can anyone interpret this fault code?
- snowchins?
- Electrical problems.. Tail lights failing!
- 2012 A6
- Check Engine light came on - now what?!
- Snow in Brooklyn
- Another wheel thread...omg!
- Both SIdes, SIgnal / Break LED's acting upp
- HELP!! VNS AMI trouble
- 2005 A6 3.2 Sirius Linking Issues
- Unusual problem-question
- Rector Audi order: website security certificate problem
- Help! Car won't go into gear
- Windscreen wipers
- Electronic Parking Brake Auto Release?
- Can Electronic Parking Brake Freeze?
- wheel damage by tire shop, advice?
- 2006 A6 C6 oil leak in the rear of engine... should i add some snakeoil?
- Audi Key quick question?
- Brake Pads: Red Stuff vs. StopTech Streets vs. Hawk Ceramics
- New problem, my car vibrates as gears change
- 2006 A6 3.2 ATF Change Interval
- 2005 A6 3.2 (BKH engine)
- Center Color Display Dead
- Are these sway bars the same?
- MPG IS TERRIBLE 55k Maintenance no help!
- Something wrong with key/ignition
- What SD card?
- Losing Power Steering Liquid
- C6 A6 Avant power tailgate, issues while closing
- heated steering wheel
- Avg. MPG before service 20, after 15.
- Driving without key
- Child Lock Window Stuck
- Anyone ever replace seat control module?
- Sisius radio "LINKING" when raining
- S Drive Question
- Camber issues after lowering car
- Custom Speaker Box DIY
- What if the GRINCH drove an AUDI?
- 2011 Leather
- coolant
- 3M Headlight Restoration ???
- Is this the wheel bearing-caused slow speed clicking?
- Vin serch
- Brakes replaced, Now problems!!!!!!!
- Anyone Else Ready for Some Fun???
- 4.2 owners, what oil are you running?
- Replacement key needed, how much?
- Dim OEM xenons - worn bulbs??
- Power tailgate not/partially openingon first button press
- RS6 headlights
- B & O stereo which Audi's have this option?
- My 2005 A6 4.2 Quattro
- strange cold weather noises and other issues
- Leather Seat Issue
- About to hit 100K... what to have dealer look for
- HOW TO ADD PIC IN PROFILE ???
- Update MMI basic plus?
- 2011 A6
- Will these rims fit my '08 A6 S-Line?
- Misfire - next steps?
- S6 V10..APR, H&R, Msds, custom exhaust videos..
- Has anyone used these aftermarket tail lights (pic inside)
- Frozen Car doors! what to do??
- S6 vs R8 - why the power differences??
- MMI Dead, how do I check the bluetooth module?
- 55K Miles Service
- Aftermarket wheels
- Battery charger setting during MMI update?
- MMI Upddates Available??
- Problem with radio-cd sound
- Caliper Cover Replacement
- Hinging piece under front end?
- Audi A6/S6 Auto Lease Programs - December 2010
