PDA
View Full Version : A6 / S6 (C6 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85
  1. P/N needed
  2. iso terminal
  3. :: ECS Tuning :: C6 A6 ST Suspensions Rebate Sale!
  4. msds filters
  5. Corner De Mayo: All Suspension on Special Today!
  6. DIY replacing upper tentioners on 3.2 motor
  7. Drivers Side Headlight
  8. audi a6 c6 lights problem
  9. Retrofitting '09 A6 Facelift Turn-Signal Mirrors on Pre-Facelift
  10. New C6.5 guy - Feed me tons of info
  11. ISO Cam Locking Set
  12. recharging 2006 A6 3.2 AC?
  13. 2010 S6 carbon cleaning and CPO coverage
  14. Location of AMI cable/Bluetooth music streaming?
  15. Crossbar on Exhaust split and now eshaust rattles
  16. 2006 A6 4.2
  17. Music on start up
  18. Copper or crush washers for oil drain plugs?
  19. Rear View Mirror Reinstall 2009 A6
  20. Passenger Air bag light - On or off? 2010 A6
  21. DL Turbo Lethal Injection Carbon Killer Vacuum Line Induction?
  22. 00955 - Key 1 Error
  23. Emergency regeneration (particle filter) incomplete
  24. 05 A6, pulling driveshaft, reuse or replace bolts?
  25. 2005 A6 3.2L Quattro Runner Flaps Sticking
  26. What's the best way to manually clean direct injection fuel injectors?
  27. S6 5.2 engine vibrations
  28. A6 fuel consumption
  29. Questions about my Audi A6, from a computer nerd
  30. 2006 A6 3.2 Sedan Headlight Replacement
  31. Last weekends project complete!!!
  32. 2005 A6 Telephone Transceiver (R36) needed...
  33. H&R Street Performance Coilover Install
  34. H&R Springs and Sways Special at AWE Tuning
  35. P008A low fuel pressure question
  36. Castrol Edge Professional OE 5W-40 Motor Oil?
  37. when to replace the air filter?
  38. Parking Brake Problem
  39. Knocking in rear under heavy acceleration
  40. p0391
  41. Controlling the steering wheel
  42. 2008 s6 fuel gauge malfunction
  43. :: ECS Tuning :: C6 A6 3.2L Oil Service Kits
  44. 2007 Audi A6 I need coil springs stock suspension will these work on my car?
  45. Mmi panels some lights and cigarette lighter doesn't work
  46. :: ECS Tuning :: C6 A6 3.0T Oil Service Kits
  47. Fan Runs On
  48. Power steering not working after removing ABS control unit
  49. A6 ABS Error Code 01201 help!
  50. Exhaust options 2010 A6 3.0T Quattro
  51. Humming/Whining Noise 2006 A6 4.2 Quattro
  52. Heating Issue
  53. Side mirror switch removal
  54. Coilover for Under Special is back at AWE Tuning
  55. Engine noise 3.2 fsi
  56. How do I replace the running light bulbs on my C6 S6?
  57. Rear sway bar bushings bracket
  58. A6 MMI 2G Upgrade - Lost features!
  59. BBK Brake upgrade? Lambo, Porsche, Audi S or RS options?
  60. Two codes with '09 S6
  61. Mmi Controls dead
  62. Low rev stutter
  63. Water pump
  64. C6 A6 Suspension removal
  65. 80,000 mile oil change interval, ouch!
  66. First thing to mod on a stock 2005 4.2 liter
  67. C6 coding through a mobile app (now for iOS too!)
  68. Looking to buy an A6 2.0TDI from 2008, Is there any problems I should check it for?
  69. 2007 audi a6 front bumper conversion to an S6 front bumper
  70. Black rear door triangular trim ?
  71. Xenon Headlight. Audi A6. 3.2 fsi
  72. insane s6 v10 sound
  73. H&R Coilover Suspension Savings at AWE Tuning
  74. vomit inside of window gap
  75. Car Randomly Turns off
  76. :: ECS Tuning :: C6 A6 Koni Shocks and Struts Sale!
  77. TPMS Battery while tire is not on car. Is it being used?
  78. '08 S6 Daytime Running Lights
  79. Bought a 2007 S6 V10 today-Pic
  80. Rear Differential Insides
  81. homelink
  82. Coolant Fans Constantly running
  83. Faulty Throttle Actuator? P2100
  84. change engine at 107k mi
  85. Is XCarLink still the best way to add Video/Miracast to our MMI?
  86. Navigation retrofit odd issue
  87. Battery Replacement Headache
  88. Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - March, Monday 25th - Sunday 29th
  89. Other owners of A6 C6 opinions regarding exhaust setup
  90. Brake sensor
  91. Recognize this part-front brake area
  92. Maybe buying a 2007 S6
  93. 2008 3.2 questions
  94. fault code. Check engine light" A6 3.2 fsi. 2005
  95. Saw a 2006 a6 avant with front damage on craigslist
  96. CARBON fiber tape
  97. power steering pump
  98. Default Driver's rear corner dropped an additional 1.5" after being on lift? normal?
  99. Peeling Carbon Fiber
  100. MMI Import Help
  101. Pre facelift license plate delete
  102. Bilstein Suspension Savings at AWE Tuning
  103. 2008 A6 3.2 quattro Intake Manifold
  104. :: ECS Tuning :: C6 A6 Ziza D3S Xenon Bulbs
  105. Will 2008 RS4 bumper fit my A6 2006
  106. Advice on upgrading a6 cvt to a6 4.2
  107. Audi A6 2010 -Sports mode etc?
  108. CEL P2626
  109. Right headlight out
  110. 2007 A6 digital instrument cluster
  111. driver mirror folding problem
  112. 2005 a6 weird problems when it is cold?
  113. :: ECS Tuning :: C6 A6 Ziza LED Lighting Kits
  114. Installing Navigation CD Reader
  115. Slow shifting on 2009 S6
  116. Can't find front grill for my leds...
  117. Audi S6 Tires
  118. Airbag
  119. S6 drive shaft question
  120. I did it, bought an A6 Avant...
  121. Home coming light
  122. 2005 replacement headlights - recommendation?
  123. Suggestions on new purchase - C6 S6 or C7 A6
  124. Battery replacment
  125. ABS module failure??
  126. Whine sound under the rear of the engine/trans area.
  127. 2014 A6 TDI Premium plus front seat
  128. oil leak in vacuum pump in 2005 audi a6
  129. Service Interval
  130. MIL Light on 2011 A6 3.0T P2007 OBDII Code
  131. MIL Light on 2011 A6 3.0T P2007 OBDII Code
  132. 3D MAPS FOR MMI 2G HIGH NORTH AMERICAN
  133. Looking to get 3.0t, any major problems?
  134. A6 (A3, A8) doors not unlocking.
  135. Low Compression on One Cylinder
  136. Smaller Wheels
  137. Strange wheel noise, can`t handle the stress..
  138. Need advice buying a 3.0tdi quattro s-line ABT-chip
  139. Battery issues
  140. code P0346
  141. 06 Avant, Noob issues/ questions...
  142. Free Shipping on suspension at AWE Tuning
  143. Front oil leak in 2005 audi a6 3.2Quattro
  144. Your new Performance Specialist, a message from AWE Tuning
  145. 2006 A6 won't start, cannot get it out of park
  146. Hey guys need some input on your mpg?
  147. 2005 Audi A6 3.2L Quattro Major Problem
  148. Door Blades
  149. DRL Error
  150. Windshield Wiper Clearance to Hood?
  151. 4.2 highway stutter
  152. '07 A6 won't start
  153. MMI Voice from US English to UK English
  154. 2007 A6 3.2 Quattro ECU performance upgrade
  155. 2005 A6 3.2 FSI Quattro Issues
  156. A6 2.0 TDI Oil pump failure
  157. :: ECS Tuning :: !!10% Off Exclusively Through ECS On ST Coilovers 2/5 - 2/15!!
  158. Satellite radio problems on 2010 A6 Avant
  159. Audi a6 3.2 vs 4.2?
  160. 2005 A6 3.2L engine control module?
  161. New C6 owner and questions
  162. 4.2 intake / injector removal HELP please!
  163. Difference between a6 s-line and non s-line?
  164. Installed a pair of Sylvania Zevo LED bulbs...
  165. Fair price to offer?
  166. Spark plugs question
  167. :: ECS Tuning :: C6 A6 3.0T Engine Oil Dipstick
  168. the v10 s6 project
  169. 2.0 TDI vs 2.7 TDI vs 3.0 TDI
  170. Enabling Adaptive Brake Light with VCDS
  171. Special tool, need or not?
  172. HELP audi 3.0l misfire
  173. A6 after market Air Suspension help
  174. How to attach accessory positive wire?
  175. Rear differential seal leak question
  176. Wiring question
  177. 2005 A6 3.2L Quattro Accelerating and Starting Problems
  178. Left headlight fuse 32 blows
  179. 2008 A6 quattro jerky downshift issue
  180. Anyone use Europa Parts?
  181. S6 vs. A6 -Question for S6 owners
  182. Please help!!!! I'm trowing glow plugs to trash :(
  183. 2005 A6 3.2 174k oil change question
  184. great 60 mins carbon cleaning video
  185. Custom Plate Idea
  186. Heated steering wheel and Thule roof rack
  187. Suggestions about buying a 2008 A6 3.2 wagon or 2009
  188. :: ECS Tuning :: C6 A6 3.0T Ignition Service Kit
  189. Un-connected wiring harness in the trunk?
  190. Leaking washer fluid reservoir
  191. 2005 A6 3.2 Quattro Tranny oil change old tan vs new software with blue oil
  192. 2010 A6 Avant in Portland
  193. DFW Audi has 2010 A6 Avant for sale
  194. '04 A6 Quattro 4.2L serpentine belt change
  195. DTC 01274 air flow flap positioning motor (v71)
  196. Looking for an A6 C6 3.2 quattro guru for help
  197. 2005 a6 3.2 quattro engine oil
  198. 2005 A6 3.2 Quattro tranny cold problem
  199. Help with driver side seat switch 2005 A6
  200. Oil or Coolant Leak?
  201. D3 S8 owner dropping into S6 land looking for help
  202. 2007 A6 3.2L Stop Lamp Switch
  203. Turn signal/brake light fix?
  204. Light Sensor Defective
  205. 2008 A6 w/AMI, but no Aux as choice for source
  206. Help on seat switch on 2005 A6
  207. VagCom Scan Sirius Radio Issues
  208. Hi/Low Beam Switch
  209. Locked out of my 06 A6 Avant???!!!
  210. 16836 P0452 VAP Emission Contr.Sys.Press.Sensor Low Input
  211. Suspension on special at AWE Tuning
  212. Replacing Centre Brake Light
  213. Replacing Centre Brake Light
  214. New Audio System
  215. 2007 A6 3.2 quattro, when cold sometimes no heat at idle?
  216. Backup Camera Retrofit
  217. Armrest Stuck!
  218. :: ECS Tuning :: C6 A6 3.2L Ignition Service Kit
  219. New Tires
  220. 'system faiure' light even w/ new TPMS sensors
  221. 2006 A6 problems when its cold out
  222. Sound module issues
  223. Anyone good at wiring diagrams?
  224. Exhaust tuning
  225. 2007 5.2 S6 misfire Saga
  226. Which alternator for my vehicle
  227. DSG Reviews?
  228. HELP...where is G410 w/ pics
  229. AMI Retrofit
  230. Low speed transmission clunking
  231. Replacement tail light assembly
  232. Problems with the air suspension
  233. buy used or rebuilt engine a6 4.2l
  234. Still working MMI diagnosis
  235. Rear view camera A6 C6 2007
  236. did the 95k service and found this
  237. a6 4f 2009 external amp + subwoofer
  238. rear defog
  239. DRUNKS!
  240. 3.0/3.2 Engine Timing Belts
  241. MMI 2G Software Update
  242. Code 0341 and 0011 A6 3.2 Q
  243. Need an electric expert
  244. OIL LEAK UNDER ENGINE **w/ pics** HELP
  245. Need advice on power steering pump
  246. digital speedometer a6 2006
  247. Question on ATF fluid change in 2005 A6 3.2 Quattro
  248. Anyone have an unlimited Carfax account and want to run a VIN for me?
  249. Headlight Replacement Question
  250. New to C6, headlight question
