- FI: Audi A6 C6 2.4l V6 rough idle
- Need help getting my 2005 Audi back to life
- AUDI A6 C6 Moding help!
- LT: Is the Quattro system in a6 c6 fully mechanical? (Quattro retrofit on 2.0tdi)
- UK: Power steering?
- loud fan noise after sharp turn
- A6 C6 allroad uspension compressor rebuild
- FR: Coding Corning Light to highbeam
- UK: Lane Assist?
- Any decent duckbill spoilers for Audi A6 C6?
- UK: Audi A6 diesel 2006 starting problem
- JHM cable and lightweight crank pulley for S6 C6
- Help with A6 seats in non Audi
- Anyone recognize this flickering instrument cluster backlight in sleep mode problem?
- Serpentine belt length to bypass AC compressor
- Engine/Trans alignment with driveshaft
- 2011 A6 Allroad — Front right noise over bumps (AUDIO)
- Noise under driver floor board
- Rs6 v10 PCV non-return valves orientation!
- Sputtering sound from engine
- HU: Fwd to quattro?
- 2006 A6 Wagon transmission just stopped working
- Headlights going off and back on
- intermittent KESSY problem on starting...
- Audi a6 c6 3.0tdi won't crank
- The audi continues to sputter after changing the coil
- My car has water entering into the driver's foot area
- Audi A6 C6 2010 MMI Control Issue
- Start Up Smoke/Oil Minimum Warning
- Getting P2187 and P2189 (Bank1 and Bank 2 system too lean at idle)
- Cat fix- muffler delete 2007 A6 C6 4.2l FSI S LINE
- Instruments cluster needles illuminates and blinking after taking out keys
- Audi A6 c6 2010 2.0 TDI reverse lights constantly on
- Ignition switch replacement question
- SD Card not being read correctly for MP3 Music
- Chime when Start engine
- UK: ABS UNIT WOES AFTER "REFURB"
- UK: 3.0 TDI V6 Intake Manifold Fault?
- transmission oil change/add
- Battery keeps draining
- I am looking for an electrical connector for an electrical chair
- HU: Audi a6 c6 2.7 tdi cana 2009
- FI: Cold air 06 C6
- HR: Audi S6 C6 with RS6 4F or RS6 C7 style bumper
- 3.2 Exhaust cam is missing
- UK: AUDI A6 C6 ESTATE, EPS ABS, Parking sensor faults
- Car shaking when its warm
- 2016 - A6 - Premium Plus - Upper Timing Cover?
- Car hesitates and sputters at 80 mph
- What are these for??
- 2005 A6 C6 diesel Transmission not won't drive
- 11 A6 Quattro 3.0T Supercharged Engine Compression Test Specs
- Catastrophic engine failure @ 60,000
- Transmission part (sensor?) ID assist please.
- PDC module change can work?
- S6 2008 avant (rear elec windows fault)
- random ESP error
- Small brake vibration when stopped
- Mr12volt and CD Changer cable help
- 2006 3.2 Avant Fuses and Relays Under hood
- Audi A6 2010 Battery issue
- 2005 Audi A6 4.2 complete bank 1 Mifires cylinders 1-4
- 2010 Avant inner tail lights
- 2011 Audi A6 Platform question
- UK: A6 Throwing up multiple faults
- S6 throttle body issue - PLEASE HELP!
- 2009 A6 3.0T MOLL Battery
- 2011 Audi A6 Owners Manual PDF
- Sort of random but I'm looking for a 2013 A6 w 20 inch wheels for sale
- Passenger Seat Won’t Recline.
- C6.5 Mirrors on a C6.
- exhaust pipe rusted and broke off.
- C6.5 Loud ticking?
- Wiring schematic for 07’ & 08’ Audi A6 wagon S line with adaptive headlight?
- AU: Start problems A6 2011 C6 3.0L diesel
- Buy an A6 4.2 Quattro?
- NO: 2.7 TDI Oil filter housing leak
- A/C Temps
- HR: Audi S6 C6 bits and pieces ;)
- Instruments cluster does not remember to keep Digital Speedo Mode
- Oil Separator Oil Filter Housing Thermostat Torque Specs
- Are exhausts of both banks connected?
- Back cover of driver seat is falling off.
- Massive electrical issues
- Trunk tool kit questions
- Audi C6 A6 3.0 TFSI Cold Air Intake Kit- In Stock!
- Interesting tip?
- Pre-Facelift to Facelift mirror upgrade?
- New 07 a6 2.0 TDI multi owner in need of help
- Audi C6 Wheel Fitment?
- How to disable air suspension DTC again?
- Audi A6 passenger mirror
- PL: 3.2L FSI AUK - very poor gas milage
- BA: What is this red button under steering wheel
- 2006 3.2L Avant Tensioner/Compression Issue?
- 2006 A6 3.2l Avant Compression/Tensioner Issues?
- 2011 Audi A6 Parking Brake Warning
- Unable to determine Fuel Pump Relay Location
- 2011 Audi A6 Get Duplicate Key
- coolant riddle
- How do you turn on the A/C?
- Thermal runaway parking brake!
- Fixing speakers with Flex Seal?
- Adding AUX/Bluetooth to 2008 A6
- How do you lock a car that is left running?
- 2007 A6 - Headlight Replacement
- Side miror replace
- HU: Audi a6 c6 2.7tdi cana
- A6 door locks automatically unlocking
- ECU Versions?
- Power trunk issue
- 2008 A6 - First Problem Ever - The A/C
- Reprogram the dishonest temperature gauge?
- A6 C6 2.0T - Auxiliary heater draining battery non stop
- MMI Quickly Shuts Off / After Replaced Battery
- How many miles can you actually drive once the low gas light comes on?
- Gearbox issue - Puts car in Limp mode
- AUDI A6 MMI Stuck after removal of fuse
- NZ: Leak damage - Electronic Modules & BT Module
- CL: Audi A6 C6 Electronic Parking Brake faults after replacing rear brake pads
- 2008 A6 4.2 misfiring on cylinder 5
- Camshaft positron sensor
- From B4 to C7 via C6
- Split Loom Conduit Connectors-where to find?
- Mr12Volt MMI 2g High integration
- DIY Key Fob Programming?
- Sold the Old A6 for a Unicorn S6 Wagon
- Headlights have AFS?
- Audi 2006 A6 no start. Malfunction read
- C6 A6 3.0TFSI Cold Air Intake Kits ON SALE!!!
- SE: Can’t get into Audi A6 2006
- Puddle causing Christmas tree of lights?
- Check Engine Light Glitch
- Solar and Battery Integration
- Trying to track down minor engine clack
- A6 C6 3.2L quattro 2006 stumped by negative and imbalanced fuel trims
- Short press of stop button keeps car on?
- v10 5.2L P2293 p0087 codes
- 2005 A6 4.2 Water Pump - open hole with oil leaking from it
- UK: A6 3.2l engine failure
- How do you use TPMS to know the tire pressures?
- Increase Audio Quality/Loudness
- Audi a6 3.0T 2013 weird noise
- A6 C6 upper B pillar removal
- BG: 3.0 diesel bmk Tuning?
- Is the highest speed ever driven stored anywhere?
- 2017 Audi S6 DSI Tune
- Error after lowering with Vagcom
- DK: Audi a6 c6 3.0 diesel, oil in coolant overflow tank?
- Horsepower
- Adjusting exhaust for bumper clearance?
- Motor Mount Removal
- Audi a6 crank no start
- DK: Audi a6 diesel crank, no start
- Replacing Gear Selector A6 Le Mans
- RS6 C6 - Injectors
- 2008 A6 4.2 carbon clean
- 2008 Audi A6 4.2 short coolant hoses throttle body
- A6 3.0 Supercharged Check Engine Light?
- LT: Collor code
- A6/C6 136bhp error - DPF, resources
- MMI not displaying software version. Any ideas?
- A6 C6 performance exhausts????
- Need help solving GPS mystery!
- Headlight Self-leveling
- O-ring size help for coolant supply hose
- After (new) autoradio installation, ABS/EPS/Parking problems.
- RS6 - VCDS Security Access Codes & Coding
- Front seat removal/heater problems
- UK: 2007 Audi A6 (C6 F4) SE 2.0 diesel (BRE) Not Starting
- Potential timing issue or maybe coincidence?!
- Audi A6 key fob problem
- 2006 Audi A6 Avant Not Starting
- Glow plugs/engine management light
- Updating maps on 2016 S6
- FOLDING MIRRORS
- Ecu woes 3.2-4.2 swap 2008 avant
- ABS BLEED WITH VCDS
- P164B - Oil pressure switch Malfunction Upper limit exceeded
- WHAT VERSION IS MY A6?
- FIRST SCAN
- chip my Audi?
- 3.0 tdi 225hp vs 232hp
- Removing Lower Dash Knee Panel Cover
- Need an MAP?
- EPB info required
- Radiator fan problem
- Mysterious S6 V10 Fault
- City lights - Dim DRL Ideas
- ECU Location ?
- Rear tire tread wear
- Audi A6 4.2 motor
- O2 Sensor Fault Codes P0136 & P0156
- RS6 - leaking HPFP or injectors?
- parasitic draw 2008 A6 C6
- ZA: diesel Engine mounts?
- FI: Mmi not working, a6 c6
- Speedometer bounce
- Coolant Confirmation/Mixing
- Water Leaking onto Front Driver Floor
- Balljoint tool size
- UK: Audi A6 - power control module?
- A6 3.2 quattro 2008 1 owner
- Unknown Info Sheet
- SE: 2.0 TDIe injector problems?
- Front Cigarette Lighter Troubleshooting
- oil leak C6 A6 V6
- A6 2.0 TDIe part name
- S6 v10 2010
- Intermittent squeakiness, probably power steering
- A6 Facelift sound upgrade
- UK: Audi A6 C6 Allroad misfire
- Odd driver door lock problem
- Daytime Running Lights
- High beam not functional even replacing bixenon bulb
- MMI Basic monochrome display schema
- UK: 3.0 tdi egr issue
- EG: What is that?
- Air suspension PROBLEM
- 2008 audi a6 c6 BT music?
- Climate controls not shown on MMI
- PT: 2.0 tdi glow plug errors
- 2011 Quattro Prestige MMI
- 07 S6 Shifting habits
- Cooling fan issue
- bigger brakes on Audi A6 avant?
- ECU Question
- Help !!! Any Body know how to Fix it....
- Trouble with TPMS warning
- random brake warnings
- Coolant pipe end cap??
- Ok, my worst fears.....
- Pumped (suction) oil change
- RS6 - issues with intake runner flaps
- MMI system not working
- A6 C6 Front End Repair
- Sand on engine block?
- radio help
- 3.0tdi intake manifold/bridge swap
- ES: TCU tune worth the money???
- Replacement car for the C6 Audi?
- 2005 3.2 Quattro AC Compressor Pulley Bypass?
- ZA: PASSENGER SEAT DEAD
- SE: Replace control unit for the handbrake Audi A6 allroad 2010?
- C6 A6: Electronics died while driving, engine won't turn off, key stuck in ignition
- 2011 Audi A6 3.0T Repair Manual
- BG: Audi A6 C6 ACC retrofit problem
- Any advice on how to reattach the swirl flap push rod?
- UK: Audi A6 3.2 (2005) ESP unit?
- Help me diagnose smoke in parking lights, after engine off (2008 3.2)
