PDA
View Full Version : A6 / S6 (C6 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85
  1. 55 - Headlight Range adaptation channels
  2. How to fit RS6 headlamps
  3. MMI Won't Turn On / Boot-up Screen
  4. Headlight Questions
  5. 2008 A6 - Intermittent Homelink
  6. Electronic stability / ABS
  7. Trouble removing oil drain bolt on 4.2 A6
  8. Cleaning the headliner - 2008
  9. Can I add Navigation?
  10. 4.2 Radiator Fan Issues
  11. New Audi Battery ,No power
  12. System Lean bank 1 and 2
  13. Adaptive Cruise Control adaptation
  14. part numbers.
  15. Fuel filter and Antifreeze
  16. Chain tensioner R&R
  17. Chain tensioner R&R
  18. Driver door opening no fuel prime?
  19. New oil leak - crank pulley seal
  20. using barsleaks leak seal for my 07 a6?
  21. Taillights
  22. Nothin happens when turning key, no mmi, no instrument screen.
  23. 2013 a6 3.0T Door lock touch sensor
  24. A6 c6 4f 3.0 TDI quattro auto (2006 ) ignition key unit part number
  25. Glovebox Door
  26. A6 C6 Cluster
  27. infotainment control unit
  28. Check Engine light is on, can't find codes
  29. not sure where to go from here??? ECM Voltage decreases to 9.8v !
  30. 2008 Audi s6 v10 P0355 Ignition Coil "E" Primary/ Secondary Circuit
  31. A6 Allroad (C6) Heater Issues
  32. Fuel door, not frozen, emergency mechanism won't even open it.
  33. Coolant leak and oil leak. 2007 A6 3.2 quattro
  34. Once upon a time...
  35. HPFP 'modification' number and its compatibility with current one?
  36. How to check brake disc thicknesses
  37. Help identify the connection on left rear door panel
  38. 06 A6 3.2 Quattro headlight issue
  39. ECU / ABS coding? Help needed.
  40. Esp light
  41. gearbox problem
  42. Audi A6 C6 no rail pressure
  43. 2008 A6 IPC DIC issues / bugs
  44. ami won't charge the iPod
  45. Front coolant pipe replacement.
  46. P0906 Tiptronic Short to Ground How to Test?
  47. 2006 A6 4.2 questions
  48. G247 fuel pressure sensor problems
  49. P Codes: 0171 & 0174
  50. Rear Window Defogger..
  51. 2010 A6 3.0T P0172 and P0175 code randomly
  52. Replacing HID Bulb - Question re Back Cover Removal
  53. Wheel touch up paint color
  54. Engines that reduce idle at stop signs
  55. 3.0 tfsi coolant leak when cold
  56. Replacing Vacuum Line? (Video in description)
  57. LED conversion from HID's
  58. Night vs Day
  59. A6 C6 4F Quattro Wiper Arm
  60. IM REPLACING my nav dvd unit
  61. 2018 A6 parking brake stuck
  62. 2015 Audi A6 just bought Hawk HPS 5.0 Pads
  63. The lights are on but nobody is home.
  64. Left TailLight Question
  65. Help needed ! 2007 3.2 Quattro engine light and car in limp mode
  66. Does not using premium gas cause these issues
  67. 06 Audi A6 No crank, no start
  68. iPhone integration w/ MMI 3G High
  69. 2014 A6 rear end clunk
  70. What is this? Simple question.
  71. Help P2181, P3081
  72. 6HP19A Flange Play
  73. 2009 C6 Avant - Switched, Live connection in front overhead lights
  74. 2008 4.2 A6 potential blown head gasket, need urgent help
  75. vcds fuel injector volume measuring block
  76. Unsynchronise blower
  77. What should be in this space?
  78. AUDI A6 LED LIGHT
  79. Problem with moisture on the led taillights !
  80. Coolant drain valve
  81. 2009.5 Avant 3.0tfsi - 125k Miles - Hesitates During Acceleration and Other Issues...
  82. Camshaft adjustment solenoid buzzing after replacement.
  83. Check Engine Light P2016 "EVAP"
  84. audi a6 c6 blowing only cold air
  85. 2011 A6 facelift 3g MMI hi to 3g + MMI retrofit
  86. Draining Coolant with 4.2 liter V8 - Petcock?
  87. Adaptive Lighting (APS) Disable/Fix
  88. 2007 S6 mystery vacuum line help
  89. How to distinguish headlights
  90. 2007 AUDI A6 Tail Light Help?
  91. Load cover floppy
  92. Wheel bearing removal tip
  93. My car is a 2008 Audi A6 C6: Man, I Messed Up - No Start Issue
  94. Windscreen wiper adapter
  95. 06 A6 4.2 new ABS unit install issues
  96. Need Heelppppp
  97. AUDI A6 C6 2011 Radiator Fan Issue
  98. Climate Control issue?
  99. 2012 A6 Premium Plus ISSUES
  100. 2006 Audi A6 3.2Q Codes: P0366 and P0014 Repair
  101. Engine block 93 numbers on a 2008 88k 3.2
  102. TPMS grayed out in MMI
  103. Doors Replaced. Wont lock now.
  104. Audi experts-please help
  105. 06 4.2 NON-FSI BNK Fuel Pressure and major drop in milage.
  106. Audi S6 Vs S8 V10
  107. 2007 A6 4.2l Alternator Removal
  108. Engine Model Code: where to find?
  109. Driver door lock
  110. 2010 Audi A6 C6 AC TURN OFF
  111. UK diesel: chain or belt?
  112. 2005 Audi A6 Throttle Body Maintenance (Video)
  113. Can the A6 C6 2.0TDI engine be changed to a 3.0?
  114. Upper Injector O-ring for the 3.2fsi?
  115. Loss Of power after take off
  116. S6 throwing lights when accelerating
  117. C6 A6 4.2 Engine rebuild. Tips, tricks and suggestions
  118. Parking brake lights are flashing.
  119. 2005 Audi A6 4.2 rough idle at low rpm / sputter near rear top of engine.
  120. Recently Purchased 2016 Audi A6 TDI. Do you have Audi Exclusive Line?
  121. Recently Purchased 2016 Audi A6 TDI. Do you have Audi Exclusive Line?
  122. Multiproblems:vibration/fuelpump indicator
  123. Help identifying part
  124. We need a sticky "Show off your car thread"
  125. Las Vegas vcds help
  126. 2006 A6 Avant JER automatic transmission fluid
  127. 2006, 2007 or 2008 4.2 - which is best
  128. Audi A6 C6 Front Window Regulator Removal
  129. Help! Help!
  130. Serpentine Belt Conundrum 3.2
  131. Fresh powder coat on 19 x 8.5 ET43 Peelers + Continental DWS 06 255/35s
  132. What to check for on a higher mileage 4.2 beyond VCDS scan
  133. P2004 and 00739 CEL after dealer service
  134. Battery drain problems or is it?
  135. engine wont start
  136. ATF equivalents
  137. 3.0 tdi problem
  138. Aircon settings for Australia?
  139. Clutch problems
  140. ESP Failure, idles rough, feels like it will stall when hitting the accelerator
  141. 05 a6 4.2 oil pressure sensor location?
  142. Rear Timing Covers
  143. DIY *VIDEO* Carbon deposit cleaning of valves + Thermostat Replacement
  144. INTRO PRICE / Group Buy: *NEW* LED Fog technology: 1 LED 4 modes: WHITE/YELLOW/STROBE
  145. 2006 A6 C6 3.2 Quattro Error Codes & Symptoms
  146. audi in snow
  147. 07 a6c6 4.2 valve cover gasket
  148. Race Chip in 2013 Audi A6 2.0t
  149. Oil leak after dropping 1k 5 days ago pls see pic
  150. 2007 Audi A6 Quattro
  151. Leaking Coolant Reservoir? (See Pics)
  152. AUS TDI: What's this noise? A6/C6 2008
  153. Driver information Panel dying
  154. Can't identify this hose that broke (see pics)
  155. Shift to P, otherwise your vehicle can roll away
  156. Looking for Latest MMI/NAV for 2010 NAR (US) A6
  157. 2005 Audi A6 quattro p2007 p2006 p2404
  158. Loss of power under hard acceleration
  159. Switching engine from 2.0l - 2.7l
  160. Car wont start...
  161. A6 cuts off when the weather is hot but drives well when its cold.
  162. "Air Bag" light on after having Airbag Recall Completed
  163. Carbon Cleaning Adapter 2.0T, 3.0T, 3.2L, 4.0T, 4.2L, 5.2L, etc
  164. A6 steering column rest question
  165. Brake Job - Failed Caliper?
  166. 3.2L lifespan?
  167. Audi A6 c6 steering system
  168. Question on headroom?
  169. 3.2 Oil leak from sensor
  170. rear bumper cover removal 2009
  171. Radio Tuner
  172. Made it to 200k!
  173. '10 A6 Avant Satellite Radio Receiver
  174. 130mph from outside. V6 sound
  175. 2006 Audi A6 MMI problems
  176. Crap!..DTC P0305
  177. Start/Electrical Issues
  178. Dead battery - no warning
  179. Serpentine Belt Question
  180. My weekend (valve covers seals and broken coolant hoses)
  181. Just bought 1st Audi
  182. any aftermarket place to get a right CV axle for a 2007 S6?
  183. A6C6 Brake Pads and Rotors
  184. climate control not working
  185. Misfire
  186. Help! Transmission!
  187. Beeping
  188. SE: Some problems with my A6
  189. ignition
  190. 2009 3.0 TFSI - Engine Lifetime Expectations?
  191. Ignition Coil for A6 4.2
  192. MMI 2g Intermittent
  193. Audi A6 3.2 Multiple Shorts/ No connection
  194. All warning lights on , car wont start
  195. Audi MMI 2G improvements
  196. Hi everyone.i need help with something that I don't understand
  197. 2008 S6 5.2L First Time Buyer
  198. trunk sensor?
  199. Rim Interchangiability
  200. d2 no heat in windshield defroster
  201. Service interval - oil change after 5k km?
  202. 2010 Audi A6 3.2 Premium Plus
  203. specs for 2014 audi a5 daytime driving bulb
  204. P302 Misfire Intermittent - Frustrating!!!!!!
  205. RS 6 V10 Twin Turbo 2008
  206. Why am I getting better mpg now my temp sensor/gauge is not working?
  207. 130mph steady (legal). How it feels from inside.
  208. No grease in control arm rubber boots
  209. aux bluetooth adapter mmi 2g question
  210. C6.5 3.0T Cooling Fan Assembly
  211. Excess Engine movement
  212. 2005 Audi A6 C6 Air Filter Replacement (Video)
  213. Spark Plugs
  214. can DRL function be turned off with VAG-COM ?
  215. Ignition Issues
  216. Installed Satellite Radio but not working
  217. 2009 A6 4WD Wagon Winter Tyres
  218. MMI 2G no sound
  219. adding aux module
  220. WINTER SETUP FOR SALE $1,500
  221. Headlight issues 2007 A6
  222. Oil problem? Maybe?
  223. Differently sized front tires?
  224. steering knock / loss of fluid(2008 2.7 le mans a6)
  225. What Is This Plug Go To?
  226. 3.0t overheating!
  227. Relay for secondary air injection pump
  228. How do I remove the fog light grilles on facelift C6?
  229. Another oil leak thread...
  230. High Mileage 2013 Audi S6 reliability???
  231. Adaptive Air Suspension drops when engine off
  232. Audi A6 C6 2.7 TDI 179 ps, MY 2007, sometimes doesn`t start(very random)
  233. whats involved in headlight R&R ?
  234. Has anyone turbo'd a C6 with a 4.2L?
  235. Need help ASAP !!! 2007 A6 Quattro headlight switch removal?
  236. 2009 A6 Starter Removal
  237. 2006 A6 dead battery issues
  238. Costco Sale - Mobil 1 Advanced Full Synthetic Motor Oil 0W-40 (European Car Formula)
  239. 2005 Audi A6 Upper Radiator Hose Replacement (Video)
  240. how often does tranny needs service?
  241. 2005 Audi A6 Cowl Drains Maintenance
  242. Hi I own a Uk 2009 Avant radio not working
  243. 2008 Audi A6 P0346 code
  244. Retrofit pdc button
  245. 2009 lane change assist Control Module 2
  246. 94-96 S6 avant or sedan
  247. Replacing g419 accelerameter esp sensor
  248. Audi A6 memory seats
  249. driver door errors, need help.
  250. The amazing saga of a misfiring 2005 audi a6 quattro. Fuel supply
