PDA
View Full Version : A6 / S6 (C6 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85
  1. Oil drain plug
  2. Worst (i.e. most expensive) repairs encountered?
  3. 2008 a6 4.2L cylinder 2 misfire
  4. New TPMS Senors
  5. 05 A6 MMI Cut out, water under driver seat
  6. Experience with aftermarket windshields?
  7. 2007 S6 Questions
  8. Air Filter O-ring Placement Question
  9. :: ECS Tuning :: NEW!! C6 A6 RS Style Mesh Grilles
  10. Knock when turning wheel.
  11. Iphone 5 not working
  12. MMI dead
  13. **Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - September 1st - 5th, 2014**
  14. Would you come back?
  15. Front sway bar and links
  16. Rear coil spring broken
  17. 2008 A6 AC Compressor Replacement
  18. P2404 code Evap System Issue / LDP
  19. a/c system oil capacity and orifice tube
  20. S6 gearbox issues
  21. RED OIL PRESSURE WARNING LIGHT
  22. In need of the detailed Service Checklists for conducting services.
  23. Audi A6L Pickup Truck in China
  24. TCM recode.
  25. [Sticky] Link to 55k Service Thread
  26. wtb: H&R drop springs, Audi C6
  27. 08 A6S Timing Chain Tensioner(s) - How Long Until D-Day?
  28. Transmission Lock
  29. Headlight Help!!
  30. Maintenance Due Reminder
  31. Damaged Speaker Replacement
  32. ESP+ABS+Parking Brake Lights All At Once
  33. A/C not working, please help...
  34. Maintenance Reminder Question
  35. audi s6 VCDS label redirection failed
  36. Help my 2006 A6 4.2 S-Line is having trouble starting!
  37. 2001 A6 2.8. misfires and runs hard at low RPMS and fine at freeway speeds.Help?
  38. Parking brake/ABS harness replacement
  39. Ross-Tech VCDS Mobile opinions?
  40. Blaque Diamond Wheels | New BD-1 pictures released
  41. Audi A6 3.0TFSI MMI update needed.
  42. Go for low with H&R. 10% off all H&R Springs, at AWE Tuning.
  43. EPB not releasing
  44. wnat to try VCDS lite with audi s6 2007 what cable to use??
  45. 2008 A6 Avant 3.2 suspension woes
  46. Mirrors possessed
  47. Radio turning itself on
  48. AWE Exhaust near NYC/Hoboken NJ area anyone?
  49. Got Exhaust???
  50. Every fuse is burnt?!?!
  51. Bluetooth Streaming Solution? 05 A6
  52. Waterfest 20 Promo - Stock up on your detailing gear @ Detailer's Domain
  53. 2001 A6 2.7 Quattro gas cap
  54. 190,200 miles and now needs front control arms.
  55. Misfires
  56. Front Brakes
  57. Hello from Bay Area
  58. Using Rainx in your washer tank?
  59. Random misfires and cylinder voltage
  60. Sunlight photo sensor?
  61. Weird Electrical issues
  62. MMI changing passenger temp control on its own
  63. Great deal on paint chip repair w/ Dr ColorChip - good before July 25
  64. :: ECS Tuning :: C6 A6 Quattro ST Performance Coilovers
  65. **Don Nguyen | Light Smoke/Tint on Tail Lights - White Audi Q5 SUV**
  66. My 2005 A6 4.2
  67. P0021 code- camshaft position?
  68. Blue is Back. 10% off Bilstein at AWE Tuning.
  69. How much motor oil for oil change 2008 A6 3.2
  70. **Don Nguyen | 3M Di-noc Matte Carbon Fiber - White CRZ Hood**
  71. MMI DOA --Has anyone seen this failure mode?
  72. Advice on buying 2008 A6 3.2 from indy used car dealer
  73. Should I replace spark plugs and coils packs ?
  74. 2008 A6 DRL replacement
  75. question on vehicle ride
  76. Audi RS6 Avant Plus Spied
  77. July 4th Special - Save 15% off and Free Shipping Over $75.00 @ DetailersDomain.com
  78. 3.2 Fsi Quattro frying my brain! HELP!
  79. Hardwiring a radar detector
  80. 3.2L USP intake
  81. A6 DRIVER HOW OLD ARE YOU???
  82. Question on Brakes
  83. Radio turning on by itself
  84. Cpo. Are the rear shocks covered?
  85. Blaque Diamond Wheels || Audi A7 with 20" BD-6
  86. minor upgrade
  87. Audi radio problem
  88. 2G > 3G
  89. LED Headlights
  90. Software Update
  91. Windows with Key Fob
  92. 3.2 to 4.2 swap
  93. I presume TPMS can be turned off w/VAG-COM?
  94. Sports Package
  95. :: ECS Tuning :: C6 A6 3.2/3.0T Aluminum Oil Filter Housing
  96. HD Radio through Dension 500?
  97. Needle Sweep
  98. First Scan Need Help Reading
  99. What is this missing part of my car called?
  100. 2007 C6 A6 Sedan 3.2 CVT MMI Problem
  101. Just a few Quick Questions about the 3.2
  102. Carbon cleaning
  103. Speedometer 2 mph higher than actual speed
  104. How long the original battery last for 2008 A6?
  105. 2007 A6 Quattro original tire replacement suggestions
  106. 4.2 Spark Plug options
  107. S6 5.2V10 engine problem twitching
  108. H&R, handled. Special pricing on the entire H&R Catalog, at AWE Tuning.
  109. Vendor for ABS Module rebuild
  110. DRL bulbs OK, getting an error
  111. Arnott Introduces Reman Front Air Struts for 2006-2011 C6 Chassis
  112. Fitting Audi "Swivel" Towbar to 2008 A6 Avant
  113. Audi A6 Project lowering and plasti dip dippin
  114. Left Parking Brake Motor malfunction
  115. Audi A6 4F AMI and Android
  116. Rear Parking Sensor Source or Interchange?
  117. headlights with LEDs ?
  118. BLAQUE DIAMOND WHEELS || 2012 A7 on BD-4s
  119. 24 hour Father's Day Special Save 20% off and more and Detailer's Domain
  120. Most common problems for 3.2 fsi Q
  121. passenger seat doesn't recline
  122. High Octane Gas
  123. Full Service and Maintenance History
  124. Rear parcel shelf
  125. BLAQUE DIAMOND WHEELS || 2013 BMW 535i on BD-4's
  126. A6 C6 2005 Parking sensors FR and REAR
  127. A6 C6 2.7 diesel 2005 - oil filter
  128. 2006 3.2 Avant electrical
  129. VCDS - Worth it?
  130. Bluetooth not pairing
  131. 2005 Audi A6 (3.2) Head Light Assembly
  132. :: ECS Tuning :: C6 A6 Quattro Airlift Suspension Kits
  133. Can I upgrade the MMI to get traffic info on my 2010?
  134. cell ligt on panel. converter? 3.2fsi
  135. Removing driver side lower dash
  136. anyone tell me what front bumper is on my car?
  137. Oil leak front driver side
  138. Will they fit?
  139. Rumble/Vibration from rear differential
  140. Problem installing Dension Gateway
  141. BLAQUE DIAMOND WHEELS || 2008 Lamborghini Gallardo on BD-4's
  142. Random difficult start, rough idle, misfire, poor acceleration
  143. Extracting oil with vacuum pump.
  144. Electronic Parking Brake Connector
  145. Memorial Day Special @ Detailer's Domain - Stock up on your detailing gear!
  146. Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - June 16th - 20th 2014
  147. Cam Position sensor, Incorrect correlation, Multiple cyl misfire codes et al
  148. DIY - Adpative Headlight Failure Repair
  149. home link issues!
  150. Will any AUDI 16 in. Wheels work on '06 A6 Avant
  151. Watch out for the new Droid KitKat upgrade
  152. :: ECS Tuning :: C6 A6 3.0T & 4.2L Geomet® Brake Rotors
  153. Almost had an Avant
  154. Motul 8100 Xcess
  155. Black interior leather finish - how matte/glossy?
  156. Going to buy a6 3.2 with 180,000 miles
  157. 06 4.2 Quattro A/C issues please help
  158. 2010 Audi A6 Quattro installment
  159. C6 Coolant Replacement
  160. Coilover for Under. Special pricing on Bilstein, H&R, and KONI coilovers.
  161. 2008 Audi A6 4.2 Telephone module keeps resetting back to zero's
  162. Replacement tail lights deal
  163. '06 Avant Sirius Linking Problem
  164. Gear box failure
  165. mmi 2g question
  166. Engine vibration at idle
  167. 2007 A6 4.2L (BVJ) Cam Adjuster to Camshaft Bolt Torque
  168. Just bought 2008 s6. 80k miles. Should I invest in
  169. 3.2 oil filter housing socket size - Is it 36mm?
  170. How to disable TPMS?
  171. Head rebuild gone bad. Need help!!!
  172. Engine runs rough on startup
  173. 2008 S6 Front License Plate Bracket
  174. How badly am I screwed? P0021
  175. PRNDS Lights on Solid
  176. P0455&56 MIL codes
  177. problem opening 06 Avant tailgate...
  178. Drive A Super Car On A Racetrack In The Dallas/Fort. Worth Area May 31st & June 1st!
  179. Radio goes off
  180. audi a6 2004 2.7 quattro overheating and vibrating
  181. Tail light upgrade
  182. C6 S6 to C7 A6 - crosspost
  183. Possibly purchasing 2008 A6
  184. BLAQUE DIAMOND WHEELS || Audi A7 with BD-5
  185. 2006 Avant; What Do I Wanna Check? (1st Audi)
  186. Replacing engine or selling A6 2006?
  187. ignition on or off when doing rear brakes
  188. Some paint correction
  189. S6 rear suspension very stiff and bumpy
  190. TRW Control Arms
  191. BLAQUE DIAMOND WHEELS || 2013 A5 on BD-4's
  192. two questions on rear brakes
  193. Leaving the A6 forums
  194. 2006 A6 quattro 4.2 - Water in ECU plenum box
  195. Check engine light: Camshaft Position Sensor (G301) P039
  196. Newbie
  197. P0087
  198. Possible reasons for an inability to connect to a phone via bluetooth.
  199. Bluetooth audio (ad2p) with MMI 3G and no (visible) AMI plug
  200. MMI software upgrade question...
  201. Corner with confidence. Special pricing on H&R Sway Bars from AWE Tuning.
  202. Convert adaptive air suspension to coil over
  203. Adaptive air suspension: 01437 - Control Position not Learned 005
  204. akebono EUR1348 or EUR1018 2007 3.2
  205. Intermittent Shutter & Steering Pull 06 A6 3.2Q
  206. My wife's 06 A6 3.2q smells like burned oil
  207. SERIOUS MMI Issues '06 A6 Avant
  208. Offset question
  209. Advice Needed on 2005 A6 3.2
  210. ABS module bad? Would like second opinion.
  211. those who have used Mercon SP
  212. BLAQUE DIAMOND WHEELS || New 2014 Collection
  213. 4f Allroad Problems...
  214. Static when using Bluetooth phone module
  215. **Don Nguyen | Gloss Black Vinyl Roof Installed - White Audi RS7 Sedan**
  216. jukebox drive
  217. window washer fluid warning light
  218. Manheim Pricing
  219. **Don Nguyen | 3M Dinoc Matte Carbon Fiber - Wrapped Interior Trim**
  220. Adaptive Lights - auto-leveling sensors problem
  221. Bluetooth module replacement
  222. Late Afternoon Headlight Restoration
  223. Back up camera
  224. 2006 A6 navigation
  225. ABS Module to MM now No Power Steering, No Speedometer & CEL, normal?
  226. ESP button don't work
  227. Help with diagnostic - 3 short 1 long signal
  228. CAM Shaft Position sensor question (after search completed)
  229. New a new Radiator?!?!?
  230. Carbon buildup possible solution? Video attached.
  231. 2005 a6 3.2L timing walk-thru needed!
  232. Is this guy a scam??
  233. Front brake question.
  234. 20 inch wheel question
  235. AC Compressor electric source
  236. Front brake wear uneven question
  237. Pics Of My Ride
  238. Cam position/cam timing marks???
  239. Rear arm rest squeaking
  240. Brilliant Black Touch Up
  241. 3.0T Water Pumps?
  242. Let's get low with H&R. Spring Fling starts now, at AWE Tuning.
  243. Intermittent taillight failure on 2011--same issue as '06?
  244. Brake Rotors
  245. 2 Unidentified problems - surging & stalling
  246. RS6 Grille
  247. 05 and door blades warping pretty bad
  248. 2005 4.2l engine advice needed
  249. new avant - needs a little tlc
  250. RPM flactuates on cold start ups, hissing sound (with video)
