PDA
View Full Version : A6 / S6 (C6 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85
  1. XTool VAG401 scan results
  2. Siren Horn.
  3. Cornering lights
  4. Key not recognized as being in the car
  5. Please help.6hp19 quattro tranny failure
  6. Audi A6 TDI 2014 Catalytic converter
  7. I icked up my "New to Me" 2006 A6 Avant Last Night
  8. Oil leaks a6 3.2 Quattro
  9. aftermarket leds on 08 audi
  10. How many spring clamp types are there and where can I get them?
  11. check engine light won't stay off on 2005 audi 3.2 quattro
  12. Adaptive cruise identifiers
  13. audi a4 b8 2008 mmi 2g swupdate 5570 from 5150
  14. a6 alarm
  15. Carriers.
  16. audi R8 battery registration
  17. Troubleshooting AC problem
  18. trailer wiring - A6 quattro TDI 2014
  19. Newb navigation question
  20. need hardware or not for BT streaming
  21. How to start investigating the dead stereo
  22. A6 G4 computers and computers locations
  23. A6 Allroad suspension fault
  24. Help with 2005 Audi A6 4.2 quattro
  25. Doors constantly locking
  26. Neon green fluid
  27. Replacing park aid control module 2012 a6 3.0 quattro
  28. I am at my wits end
  29. Was told to post about my A5 question here... sorry if this is inappropriate
  30. PRV and PCV question
  31. Advice, please
  32. About a6 c6 facelift tail lights
  33. sat nav
  34. Security code to regenerate dpf?
  35. Heater Control Valve replacement
  36. Intermitent no start- vagcom cant reach modules
  37. Heater / Cooler / AC - Partially working need to know what the problem is
  38. Balance Shaft Timing on 3.2L
  39. Best OEM battery replacement and coding of new battery
  40. Replacing adaptive headlight with cheaper version
  41. NEEds a new engine?!
  42. cutting of engine
  43. Water under the rear seat
  44. 2016 Audi S6 5.2 V10 small oil leak
  45. rear brake job gone wrong. electronic parking brake stuck all the way out
  46. Lift points for car lift
  47. Service Center rip off?
  48. Enable service menu?
  49. ABS/ESP parking brake with three beeps
  50. Production Numbers for 2011 S6
  51. Multiple Issues Today
  52. AMI Cable?
  53. Battery issues AGAIN
  54. 2010 A6 bluetooth phone connectivity problems
  55. replacing Serpentine Belt and pulleys..carrier service??
  56. 2011 fender liner on 2009?
  57. 2005 Audi A6 Quattro: Engine starts 'n' runs, won't move. HELP HELP
  58. How to charge battery on 2008 audi a6
  59. Blower motor wont shut off
  60. Thinking about buying an A6 2010 w/ 100K miles
  61. Audi A6 avant 2006 mmi update
  62. 2006 3.2L BKH motor code confusion.
  63. Temp control sensor replacement
  64. hardware to hold motor underbelly
  65. Transmission changed problem ! Need help! Audi c6 3.0tdi
  66. Sharp Turn Resistance
  67. 2013 Audi A6 3.0 BiTdi Turbo Issue DPF Limp Home mode
  68. MMI 2G High stops working after 2 secs
  69. Audi a6 c6 turbo problem
  70. injector A6 C6 2006 FSI 3.2 quattro
  71. How to connect HDMI to MMI 2G AV Inputs
  72. Can TC covers be removed without removing valve cover?
  73. 2006 audi a6 oil leak
  74. Audio output distortions when temp is under 5° C
  75. A set of tires that changed everything
  76. No audio output when it is cold
  77. Newish Audi owner
  78. no start- vcds doesnt recognise engine control module.
  79. fuel pump question
  80. Help! Set screw on A6 front hub snapped in place
  81. 2008 S6 MAF replacement
  82. 2005 A6 bumper mounting question
  83. How rare is my new car?
  84. C6 S6 winter tires and wheels need a Home
  85. VCDS Help
  86. Excessive Fuel in Oil in Cold Climates C6 A6 3.0T
  87. 'CD Changer not loaded' when it is?
  88. headlight washer replacement
  89. Considering a fixer '06 A6 Quattro
  90. Brake Caliper Rebuild DIY?
  91. Interesting heating problem
  92. cheapest option for extra key copy?
  93. Imagine my surprise...
  94. Windhield wiper service position coding
  95. 2005 A6 3.0TDI Air suspension issue(calibration)
  96. 2006 A6 3.2 liter cylinder head removal
  97. Hood not releasing
  98. Help with component protection!
  99. 2005 Audi A6 C6 3.2L Serpentine Belt Replacement (Video)
  100. audi a3 3.2 quattro 2004
  101. Couestions about my 3.0TDI
  102. Starting problem ( Electrical )
  103. Need advice from Audi A6 owners
  104. Need advice from Audi A6 owners
  105. Timing chain replacement in a 2006 A6 4.2
  106. 4.2L 2006 A6 Tries to crank, but i don't think it's turning
  107. 2017 S6
  108. TPMS Malfunction Random On and Off
  109. headlight service pictures
  110. 40yrs old and this is my first Automatic...a few basic questions before trans service
  111. 2007 s line 4.2 heat issues
  112. 2011 a6 3.0t durability???
  113. 2008 Audi a6 Airbag just came on.
  114. Bleed coolant
  115. A6/C6 Door handle cover replacement?
  116. Does Removing the Catalyser Can damage 2.0 turbo FSI engine?
  117. Albania: Audi A6 3.0 TDI DPF multitronic 2011 128.000 km worth it ?
  118. Need help with iPod cable integration on '08 S6
  119. 2006 Audi A6 with 3.2 V6 Car will not start
  120. Doesnt start
  121. 3.2fsi - does is sound well?
  122. Got my airbag recall schedule notice!
  123. PRND Lights on the Dash Board
  124. New to me - S6 - trunk indentation??
  125. A6 C6 2006 3.2 quattro repair manual?
  126. 2009 3.0 rear main seal leak
  127. Failing Timing Chain Tensioner
  128. 2008 A6 4.2 V8 serpentine belt replacement
  129. A6 Blower issue and Fault Codes
  130. C6 4.2 Rough Idle Accompanied with Diesel knocking
  131. No power steering for a 2005 a6
  132. 2015 Audi A6 rear seat Climate Control Dial issue
  133. 2012 A6 3.0T Antifreeze
  134. Crankcase ventilation tube replacement
  135. Instrument Cluster
  136. audi a6 2007 quattro
  137. Climatronic
  138. Trade fx35 for a6?
  139. 2006 Audi 3.2 liter camshaft Adjuster
  140. Battery drain issue and no Cruise control
  141. location on suspension compressor
  142. Battery drain issue, dealers are unable to fix
  143. oldest OE battery?
  144. 2008 Audi A6 3.2 issues
  145. Useful Accessory
  146. Losing Coolant
  147. PCV Valve Location on C6 3.2L
  148. Rear wiper arm removal and wiper motor replacement
  149. Help with installing mmi interface cable for iPhone 7 plus
  150. wrong pads! HELP!
  151. 2010 A6 Cooling fan issue
  152. How do I?
  153. Seat rail clips
  154. Optimize fuel consumption
  155. epb problem
  156. Thinking about buying
  157. Proud new S6 owner!
  158. High pitch whistle sound when let gas go
  159. Official C6 A6/S6/RS6 Picture Thread!
  160. C6 S6 driving lights in bumper
  161. A6 2008 airbag warning
  162. 2010 A6 3.0T - Upper Timing Chain Tensioner confusion
  163. MMI 3G Emergency Update Stuck
  164. Audi a6 2008 tail lights
  165. Need help ID'n part
  166. 2006 audi a6 3.21 Oil leak
  167. Rear facing car seat in an Audi A6 - Europe
  168. Engine noise audi a6
  169. Audi a6 le mans rear light acting funny
  170. Independent Audi Shop in Austin TX
  171. Is it possible just to replace the LED in the light bar?
  172. Parking brake malfunction? Really?
  173. I NEED A CAMSHAFT SENSOR
  174. 2007 A6 transmission problems after fluid change-update
  175. What's this?
  176. 2008 Audi a6 front passenger power lock problem.
  177. I was able to fix the power hatch on 2008 Audi A6 avant
  178. Help!! Replacing a gearbox! 4.2
  179. A6 Battery Replacement?
  180. BKH: 2005 A6 engine removal
  181. 2008 Audi A6 Passenger door doesn't lock
  182. Brake light foglight confusion
  183. how to reset my audi a6 2006 3.2 automatic transmission
  184. Does anyone have LED H7 head light bulbs that work?
  185. Engine Coolant crossover Pipe
  186. Engine Coolant crossover Pipe
  187. Headlight removed, found culprit...replacement question
  188. A6 3.0t or a8l?????
  189. HELP! Fault Codes!
  190. 2006 a6 Parking brake motor
  191. Cold climate / idle question
  192. audi a6 2007 3.0 tdi stops acelerating
  193. Headlight lens fogged!! Replace or fix?
  194. Fuel pump and Regulator: Help confirming mech's diag. based on these symptoms
  195. S6 seats: upgrade or factory?
  196. 08 Audi A4 V-6 3.2L Convertible Cylinder numbers
  197. Rattle / Whining Noise on Cold Starts (08 A6)
  198. Rear end work.
  199. I'm getting the RATTLE on cold starts
  200. Is there a Euro City Config - No Hi Beams and Quiet Horn
  201. MMI issues C6 2006 avant 2.0tdi
  202. Trunk won't open!!
  203. UK diesel: Engine cutting out, losing power, spluttering.........help?
  204. Pep Boys sale on Bosch AGM batteries
  205. Front wiper relay for a6 avant 2006
  206. Audi A6 C6 2.0 TDI shaking while starting
  207. Understanding the MMI and adding AMI
  208. 2009 A4 cold weather won't start
  209. 2005 audi a6 front brakes and rotors
  210. 2005 audi a6 front brakes and rotors
  211. 2009 A6 won’t start after battery swap
  212. Maintenance costs - higher mileage A6 Avant
  213. New belly pan for Xmas...mounting question
  214. Brake issue after new tires
  215. oil leak
  216. S6 LED DRL install into Canadian S6
  217. Battery Tests
  218. Display Sreen
  219. This IS the technically best forum that I have ever participated in
  220. Replacing Parts from brake System
  221. central differential
  222. central differential
  223. 2009 A6 Avant vs 2012 A6 3.0T Prestige
  224. Audi A6 Allroad 2008 2,7 tdi air suspension/relay/fuse
  225. LED stop lights problem
  226. Vacuum lines, air box, and P2006 / P2007 codes
  227. DIY replacing Rear Tail, Fog and Lights
  228. Mystery Parts
  229. Cylinder 5 and 6 misfire.
  230. Coolant reservoir
  231. Strange sound on start up when outside temp. is very cold
  232. New A/C Compressor
  233. HD Screen for MMI 2G
  234. Service Due Reset
  235. AMI/MMI port Location - 2008 A6
  236. 3 heating elements not working.... help please!!!
  237. 2005 Audi A6 no start
  238. Is your car truly luxurious without these?
  239. 2005 Audi A6 No power no Crank! HELP
  240. 2008 A6 (C6) 2.4 Brake Warning - electronics cuts out
  241. Qatar: URGENT HELP ON CAR SERVICING
  242. Deciding between 2 CPO 2015 A6 3.0T Premium Plus
  243. Front Euro Licence Plate Holder for Audi 2010 A5
  244. Taillights European vs US
  245. Modified Audi C6 compilation! Check it out!
  246. Oil leak behind engine
  247. Headlights
  248. 2006 Audi A6 S Line w/all kinds of problems
  249. Reinvent Your Floor Mats
  250. Adaptive Headlight Error V318
