PDA
View Full Version : A6 / S6 (C6 Platform) Discussion
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85
  1. 3.0TDI SWAP
  2. Upper timing chain tensioner replacement tools
  3. Trying to replace valve cover gasket on 2008 a6 avant with 3.2 fsi
  4. ABS ECU Replacement
  5. Replacing Power Steering Hoses
  6. Audi A6 C6 2005
  7. MX: Audi A6 C6 2008 Battery drain after using mmi for +-1 hr
  8. audi a6 c6 mmi update 2006 booatloader bad crc error
  9. 2008 Audi A6 S line?
  10. 07 avant 3.2 quattro muffled popping sound from air box
  11. 2007 Avant 3.2 quattro 2-stroke popping sound?
  12. Valve Cover Question
  13. Lost on what to do next, Misfire on 4
  14. Exhaust recommends for ‘07 4.2 A6
  15. Common seals to save money.
  16. Please Check Navigation DVD
  17. Multiple Codes after Engine swap
  18. 04-07 Headlights on 2010 A6?
  19. NG: Fuel consumption?
  20. Front sway bar links, replace on the ground?
  21. Electrics Shut off while driving. A6 2.7 TDI Quattro
  22. Reliability of c6.5 3.0 09-11?
  23. My Audi A6 Avant 3.0l TDI Quattro (Le Mans) Fix
  24. C6.5 Audi MMI not turning on
  25. 2005 A6 C6 No Accessory, No Start Problem and Fix
  26. no switch and ignition in the car. scanning results
  27. A6 C6 3.2 Vacuum pump implications?
  28. IL: An electric driver's seat does not work after water enters the vehicle?
  29. what is a good Audi scan system?
  30. what is a good Audi scan system?
  31. 2005 audi a6 164k
  32. cranks no starting Avant 06 A6 3.2L
  33. 2006 Audi A6 3.2 Quattro GROUND points
  34. Data Bus Fault - Heating Fans
  35. Oil pressure light question
  36. A6 2006 Avant 3.2L
  37. 2006 A6 V6 3.2 297,000 miles intermittent no start
  38. Please help no heat and mystery short
  39. 3.2 Camshaft Block 93 Values Questions
  40. Audi A6 4F TDI 2009 Fuel Filter/Pump
  41. Transmission fluid,filter,gasket change - 2005 A6/C6 4.2L
  42. 2005 audi a6 3.2 163k NO POWER WINDOWS, NO POWER SUNROOF ect
  43. Long crank on cold start
  44. A6 Allroad ( 2010 ) Air Suspension trouble... ?
  45. 2005 audi a6 3.2L v6 163k
  46. Need an extra inch - rear suspension on 2004 C6 3.2fsi
  47. Audi A6 2009 Canada NAV
  48. FI: wierd electric problem on audi a6 2008 2.0L
  49. C6-Ak74 content
  50. Tail lights on after parking
  51. Spark plug errors.
  52. 2010 Audi A6 3.0T Prestige
  53. Passenger blower runs even with ignition off??
  54. 2010 A6 @133k
  55. 2009 Audi A6 3.0T Leak Help
  56. Breather Hoses KIT
  57. Bose Sound System not working after cold start and speaker crackle noise?
  58. Hood wouldn't close
  59. 2005 Audi a6 3.2L v6 coil overs?
  60. 2009 Audi A6 check engine light
  61. Audi a6 mmi basic plus software update
  62. BACK DOOR WON'T OPEN
  63. 2006 A6 Quattro 3.2l error code P0201, p0202 and p0203
  64. Rear brake suggestion
  65. May I wonder which side is the #10 Telephone control unit J526 Module for RHD A6 C6 p
  66. mileometer & clock Dash lamps on 24/7
  67. 3.2 Running Rough
  68. A6 C6 Petrol 2005 Electric diagram
  69. Problem Phone And Media are not showing on dashboard screen
  70. 2008 A6 AVANT - MMI will not come online
  71. Front light failed
  72. Audi A6 3.0 2009 some errors ESP
  73. Headlight issues and advice about keeping car...
  74. Help to find the part number
  75. UK: A6 C6 wheel alignment spec
  76. 2006 A6 seat heater not working
  77. Scraping sound from engine + oil leaks - 2005 A6 4.2
  78. Green Screen (What can it enable?)
  79. NO:Air suspension Audi a6 allroad 2007 2.7 tdi
  80. Sad Day. Looks like it is time to part ways.
  81. 3.2 V6 Timing Issues
  82. RO: Idle issue a6 c6 2008 2.0L diesel
  83. ABS engages randomly on my 2005 Audi A6 4.2
  84. Component location
  85. Adaptive Headlight Help
  86. 2008 Audi A6 4.2 200k miles - bad idea to buy?
  87. Should I keep my 2005 A6 4.2?
  88. P0341 cranks but won't start...cam pos sensor fail or timing chain snapped?
  89. 00003 Control Module: No or Incorrect Basic Settings
  90. New high pressure fuel pump, crank no start
  91. Trunk won't open-not valet button
  92. Engine Errors A6 3.0T
  93. HP2 Calipers
  94. puddle of water behind the driver's seat
  95. 2006 A6 Avant Heated Mirror Question
  96. 2007 A6 sport mode not working
  97. 2008 Audi A6 3.2L C6 engine swap
  98. SE: C6 2.0 tfsi -2008 thermostat?
  99. Need some help with interchanging immobilizer system
  100. tried to jump start Audi A6 avant 2007 , now completely dead
  101. Possible to remap??
  102. Engine temperature drops
  103. 2010 A6 3.0L - Engine running hot
  104. getAudiparts.com | Last Minute Holiday Savings Promo Code: HOLIDAY2020
  105. Hybrid turbo on a A6 C6 3.0TDI 2009?
  106. TX, USA: Why I shouldn't buy a 2011 A6 3.0T?
  107. S6 v10 5,2 2006 - Lots of P-faults
  108. 2007 Audi A6 3.2 FSI
  109. Bad fuel pump?
  110. Need tips on how to get the hanger/carrier off an Allroad (lower 18mm bolt)
  111. 2005 Audi A6 245/40/r18 vs. 235/45/r18
  112. Please help
  113. No pressure on cylinder #4, but it seems to be in time... what could it be?
  114. passenger brake caliper moved?????? can't put on my winter wheel
  115. 2006 Audi A6 avant retractable cargo cover
  116. coolant leak on 2008 s6 (pics below)
  117. A6 C6 Avant Steering Wheel Column Actuator Issue
  118. A6 3.2 Quattro Front Subframe
  119. A6 3.2 Intake Manifold Position Sensor Plug
  120. 2008 A6 Avant locking issue
  121. Timing Issue, Need Help.
  122. Getting P2187 and P2189, system too lean at idle on 2008 4.2
  123. Wiring Pinouts for Seat Heater Wiring
  124. deAutoLED Black Friday and Cyber Monday sales are LIVE NOW! Best prices of the year!!
  125. Shift to P, otherwise vehicle can roll away. Doors do not lock if lever is not to P
  126. Heated Seats
  127. Fault 00288-Steering Column Lock Actuator (N360)
  128. Ambience led lights problem
  129. Air suspension problems + some more..
  130. 2015 A6 TDI Prestige front camera issue
  131. Wiring Pinouts for Seat Heater Wiring
  132. Valve Cover Gasket bolts - how to replace?
  133. I have a 2006 A6, Sirius XM not working.
  134. A6 front camera stopped working
  135. Power steering hose o ring question
  136. steering column module. Solve the problem temporarily with a simple scanner?
  137. Ambience lights turning off randomly
  138. AM/FM works, Satellite inop.
  139. Alvadi parts - Warning
  140. Enabling A2DP in Engineering Menu
  141. carbon buildup prevention
  142. Need help removing transmission pump
  143. A6 2007 glovebox motor
  144. Parking System Visual Display
  145. Isnt the 3.0T engine 213kw?
  146. JP: 2008 A6 Quattro Glove Box Soft Opener?
  147. IL: Replacing a battery without REGISTERING with the ECU?
  148. 2009 a6 3.0 cylinder misfire?
  149. 2011 a6 Valve cover gasket/breather hose
  150. 2008 A6 4.2 oil leak from above alternator
  151. Passanger Front Door Doesn't lock from the inside
  152. VCDS adjustments in AUDI A6
  153. C6 3.0T Oil Catch Can Install
  154. Smoke inside cabin, can't find problem
  155. 2006 a6 rear timing chain cover leak
  156. Audi A6 - MMI problem
  157. Audi A6 C6 Brake RESERVOIR
  158. Heat is weak at low RPMs
  159. Out of the frying pan...
  160. Audi A6 Avant MMI not working
  161. 2006 Audi A6 Does not Crank/Start
  162. Mating 4.2L Radiator to 3.2L Rad support&cooling fans
  163. turn signals wipers and radio don’t work, any suggestions?
  164. Audi A6 NAVI and Telephone issue
  165. Audi A6 2009 Canada Version
  166. IL: Vehicle problems after battery runs out
  167. Rear Armrest Cupholder
  168. LT: 2005 a6 c6 phase positions?
  169. Passenger side headlight not working
  170. S6 oil in spark plug wells
  171. Bi-xenon headlights pattern issue
  172. Audi A6 Q7 Access Start Authorization Steering Lock J518 Module
  173. Key stuck / shifter stuck in park - power question
  174. UK: a6 c6 diesel cuts off by self
  175. 2008 Audi A6 Avant passenger headlight is turning pink/orange
  176. HU: A6 C6 sunroof opens automatically?
  177. Question on installation of refurbished ECM
  178. Doors replacement with lower trim, will it work?
  179. C6: TPMS malfunction?
  180. LY: Multitronic CVT fluid?
  181. New Owner/ Member looking for opinions on S6 V10 Intake
  182. Brake Light Switch Location
  183. Rear facing third row seats
  184. ZA: Shifter stuck in park position with epc light on
  185. Flex pipe leak
  186. VCDS group 61 - throttle valve angle
  187. Anyone had their heater core out?
  188. Coolant flush?
  189. 2010 A6 2l tdi le mans heating issues
  190. 2010 A6 2l tdi le mans heating issues
  191. A/C blowing constantly, Controls aren't working.
  192. Audi A6 C6 Avant wrong door display
  193. 2006 Audi c6 mmi problems
  194. TT: Transmission problems
  195. AMI MOST install,remove 6 disc CD changer having issues
  196. E brake stuck. Is this the actuator?
  197. Offset change
  198. MMI 3g high camera angle
  199. 2006 a6 3.2 Avant ECU location
  200. Tiptronic hkg To kjc
  201. Help with valve cover gasket please
  202. UK: C6 diesel gearbox issues
  203. Check engine light - p0068 2011 Audi A6 3.0T
  204. A diy on moving the lock carrier to service position
  205. DIY Brake Change Query
  206. UK: Keys in boot....Doh! (A6 C6 2.0ltr saloon)
  207. 2005 A6 leak detection pump testing question
  208. 2006 Audi A6 Wagon Heater Control Valve Replaced, Now What
  209. 2008 A6 C6 Drivers Front Window Regulator Sliding Shoe
  210. Installing aux or Bluetooth.
  211. Screechy Parking Brake
  212. Pcv valve help.
  213. 06 Audi A6: TBS Issue
  214. Need opinions on new emblem placement
  215. Ignition key lock
  216. Turbo has been changed and now I have to hold the ignition key on to turn on the car
  217. Performance chip 2005 Audi A6 3.2T
  218. stuck at work, no crank
  219. NO: Outside temp probe?
  220. Value of 2007 A6Q (3.2L) - Engine is misfiring
  221. Belt Brand for main serpentine belt
  222. MMI Problem
  223. Serious vibration
  224. Monster 2005 A6 Plan
  225. S6 Daily Driver
  226. 005495 & 000036 error codes
  227. I can’t tell if this noise on cold start is coming from my engine or my secondary air
  228. 2011 A6 Timing Chains Replacement Costs?- P0018
  229. 🔴 Won't start and parking brake blinking!
  230. FR: A6 2.0 TDI problem
  231. No codes but no start
  232. how to re-sync key for 2010 A6?
  233. 01152 error code, questions? Where is fuse
  234. PLEASE HELP!! strange noise coming from engine on cold start
  235. Fuel Filter Bracket bolt size
  236. Tiptronic transmission oil fill procedure (6HP19A)?
  237. AW: '06 Audi A6 Avant
  238. NO: Air Suspension/A6 Avant 2006
  239. 3.0 TFSI Triptronic Quattro chiptining/OBD
  240. MMI trouble / 2006 A6 Quattro 2,7 TDI (LHD)
  241. '08 A6 Avant Hatch Problems
  242. AC Doesn't work, radiator two front fans don't spin?
  243. Battery Replacement
  244. 2011 A6 CarPlay Retrofit?
  245. 2007 Audi A6 wiper Control module issue
  246. EPC and TPMS msg after 6 minutes at Idle. Fixed after shut down and restart
  247. Headliner removal/instal
  248. audi a6 2005 transmission problem??
  249. 3.2 Engine. Is it interchangeable?
  250. MMI died and other electrical problems
