PDA
View Full Version : A6 / S6 (C6 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85
  1. Headlights
  2. 2006 Audi A6 S Line w/all kinds of problems
  3. Reinvent Your Floor Mats
  4. Adaptive Headlight Error V318
  5. Audi A6 2008 Quattro Will Not Stay Running
  6. Audi A6 c6 4.2L with 217,000 km for 7,700
  7. Suspension ? "Clunk"!
  8. Brake pads and Rorots
  9. Oil filter housing seal appear to be leaking badly. '06 C6 3.2
  10. 18082 - Powertrain Data Bus: Implausible Message from Instrument Cluster
  11. battery
  12. Cooling fan
  13. Advice.
  14. Advice.
  15. 2005 a6 3.2 running rough after wash
  16. Audi A6 GSP display
  17. 3.2 liter Timing chain tensioner information
  18. Rust Proofing: Wax or Oil based?
  19. Dead Battery Manual Door Lock Doesn't Work?
  20. 2006 Audi A6, 2.0 tdi 140 hp
  21. Camshaft Position Sensor Malfunction. P0011 P0021 & P0340 P0345
  22. Morimoto D2S longevity
  23. A6 C6 MMI 2G - Intermittent Issues Fixed
  24. 2008 A6 Avant rear power hatch does not close all the way.
  25. Funny issue with Parking Sensors/Display this morning
  26. Funny issue with Parking Sensors/Display this morning
  27. battery levels
  28. Replacing drivers side door lock actuator
  29. audi brake pads
  30. Best way for Mirrorlink Android to OEM Display
  31. A6 C4 MMI problems - solved
  32. Looking to buy a 2012 A6 3.0
  33. BCM and Windshield wiper motor
  34. 2012 a6 3.0t camshaft position sensor location
  35. Help with key
  36. - Europrice.us | Black Friday | Big Discounts | New Product Lines | Holiday Sales -
  37. cant link iphone with A6 Allroad
  38. 07 A6 4.2 with rough running and fuel coming out of exhaust
  39. lights warning, but lights ok
  40. Weird no start issue
  41. Fault finding.
  42. 2009 A6 Avant - Mild Front End Noise/Vibration
  43. Ticking noise
  44. Having issues with rear lights please help..
  45. A6 TPMS
  46. Limp mode after accelerating to pass
  47. MMI Update Issues
  48. TRANSMISSION OIL CHANGE
  49. Which Oil Filter for A6 V8 4.2 (2006) ?
  50. 3.2L Harmonic Damper Bolts
  51. Sound problem
  52. Hear ticking in on start sometime.
  53. MMI says "An Installed Component is not valid. Please contact Audi Workshop" - Power?
  54. Burning oil
  55. Noobie A6 Buying Advice
  56. Terrible Gas Mileage Audi S6
  57. 2010 A6 QUATTRO TRANS OIL CHANGE
  58. interior dome lights don't work
  59. Bluetooth question
  60. 2008 A6 Adaptive Light Defective 02626
  61. rear electri caliper
  62. Transmision problem A6-3.2 quatro 2008 C6
  63. battery
  64. A6 C6 Avant, Headlight Warning Code Out
  65. 2007 A6 -- MMI reboots every 2 seconds
  66. WHEEL NUT TORQUE
  67. Bluetooth music streaming to MMI 3G
  68. Please help. My display screen went bad.
  69. Audi a6 c6 4f wagon drainage holes in body
  70. Vibration
  71. Bluetooth music streaming to MMI 3G
  72. Can car dealers sell Audis on this website?
  73. 2003 A6 3.0 high miles
  74. 2006 Audi A6 3.2: no crank
  75. cylinder mis-fires, trying to fix
  76. A6 Facelift LED Headlight Wiring
  77. 2005 A6 BOSE AMP WIRING.
  78. 2008 A6 MMI most recent update and How to?
  79. 2008 A6 MMI most recent update and How to?
  80. 2005 Audi A6 C6 Brake Discs Replacement (Pictures)
  81. Steering Column Battery Draw
  82. Printing a build your Audi
  83. 2008 A6 Center Screen Glitch
  84. Broken Rear window regulator
  85. 2017 AUDI A6 COMPETITION
  86. replacement coil pack suggestions?
  87. torque specs for camshaft retainers
  88. 2008 A6 Avant Trunk Spoiler Replace
  89. weird starting problem
  90. 04 a6 question
  91. Transmission leak
  92. Connecting Phone to S6
  93. 05 A6 3.2 Stalling Issues
  94. 5 digit code?
  95. Burning robber smell
  96. Mods for C6 Generation S6
  97. airbag recall and crash sensor
  98. 3.2 error codes p0278,2070,2006,2007,2069
  99. EPC and ESP
  100. 2010 A6 Avant QUestions
  101. New motor mounts after only 30,000 miles?
  102. 2008 audi a6 sline
  103. Will it pass?
  104. 2000 Audi A6 2.7t coolant leak
  105. A6 C6 2G MMI doesn't work - probably controls?
  106. 2005 A6 4.2 Cold Air Intake with Airbox removal? Help?
  107. Advice on A6 3L TDI 2009 facelift model
  108. Numerous A6 issues
  109. can TPMS be deleted with VAG COM in '08 A6 ?
  110. A6: Cold start shift problem!
  111. New wheels for 2011 Avant
  112. What is a Sig?
  113. Gearbox.
  114. Audi A6 2006 tailights
  115. 55,000 mile maintenance
  116. 2006 3.2 A6 engine problem?
  117. 2008 A6 Avant near side Brake Light bulb replacement
  118. Speedo and rev counter stopped working
  119. AC/blower going on and off
  120. Canuck - Avant Wagon Build Thread
  121. 2006 A6 Quattro Wagon / Gas Pedal Question
  122. Interior Lights Only Work When Car is Off
  123. Where to find engine info?
  124. 2008 S8 door cards/shifter surround compatible with 2010 A6 Avant?
  125. Audi A6 2006 headlights
  126. Interior Lights Only Work When Car is Off
  127. 2015 Audi A6 2.0 TDI
  128. I bought the car last year and the mmi is not working
  129. Oops... wrong(?) transmission fluid
  130. how to turn off airbag warning light?
  131. MMI issues
  132. Battery Drain 2010 A6 3.0T - Noise
  133. 2005 A6 4.2 Cylinder 1, 2, 3 misfires
  134. AUDI A6 C6 BUMPER TO FACELIFT
  135. Can someone tell where this connector is supposed to be connected to?
  136. My A6 Avant project
  137. Audi A6 reverse lights on all the time and parking sensors
  138. ***WannabeRacer.com | Boston and New Jersey Vinyl Wrapping Tour***
  139. Audi ECM part number
  140. Distance Graphic on button
  141. 2015 a5 radio screen with white lines in it
  142. A6 MMI Alternative way to access phone menu?
  143. C6 Grill differences
  144. front passenger door will not lock with FOB
  145. 2010 A6 Avant Thermostat Failing - Recall? TSB? RUV?
  146. 05 a6, MMI upgrade.
  147. 2014 A6 Premium Plus Quattro - Side Mirrors
  148. 2014 Audi A6 tune APR or Piggyback
  149. Problem with engine
  150. Owners manual/cd
  151. Paging Denver Metro folks!!
  152. Audi smartphone interface greyed out
  153. MMI failure
  154. Cracked Interior Door Trim A6
  155. 2006 Audi A6 song selector button
  156. 2006 A6 quattro 3.2 Rear Wheel Bearing replacement
  157. A6 2007 2.7 TDI K&N filter
  158. Gearbox and MMI - 2008, A6 C6 Quattro 3 TDi
  159. 2006 A6 4.2 Crankshaft Position Sensor
  160. Tips for replacing headlight Xenon bulbs
  161. P0020 Actionneur A de position de l'arbre à cameA - circuit ouvert (ligne 2)
  162. Black smoke and power, swift diesel 2008
  163. Xenon Bulb about to go?
  164. Camshaft posion sensor help!!
  165. adaptive air suspension
  166. audi a3
  167. audi a3
  168. P1138 & P0263 after carbon cleaning, did I damage injector?
  169. Audi a6 2006 - subwoofer
  170. 06 A6 3.2 Liter Coolant system problem
  171. A6 3.0t Avant. Possible oil leaks?
  172. REAR upper control arm replacement? A6 C6 Quattro
  173. Hated my wheels. Painted them. Now, I love them!
  174. Fumoto oil drain plug / valve
  175. A6 Remote Central Locking intermittent problem causing battery drain
  176. 2009 3.0T Crossover Pipe Leak
  177. 2005 A6 3.2 ABS Control Module question
  178. can i install navigation in non NAV audi a6 2016
  179. Brake caliper dress up
  180. know nothing about tires
  181. Smoking A6 3.2L
  182. 2007 A6 3.2
  183. When the car looks dead ... tips from "russian hackers"
  184. HID Bulb Replacement
  185. 06 Audi A6 3.2L V6 Saga... Rough Idle, Missfires, Plugs and Coils Replaced
  186. S6 Transmission Fluid Change - removing the pan
  187. Replacing Thermostat 3.0 T - Read the threads - Last minute wisdom?
  188. A6 C6 2006 - Infamous steering column module problem
  189. Need help finding a new door panel
  190. 2006 A6 Quattro 3.2L Won't Start
  191. OEM Trailer Hitch Stuck
  192. Passenger Front Tire Issue
  193. Likely an upper tensioner problem.
  194. MMI turns on after battery is connected
  195. Tune2Air not being recognized
  196. NOT TO BEAT A DEAD HORSE.....But REPAIRED MMI N/W
  197. A6 3.2 Quattro.
  198. ABS and EPS Fail
  199. What part do I need
  200. Rubbing sound while braking
  201. AC intermittent stop
  202. 1995 A6 Wagon Will Not Go Forward
  203. Ear crimp clamp source
  204. TPMS Grey in Car Menu?
  205. Intermittent A/C Problem
  206. Valve Cover Gasket Replacement Question
  207. Audi a6 brake lights
  208. s4 wheels on a6
  209. How do I remove the connector
  210. Car almost stalling when the purge valve engage
  211. Error code 4417
  212. Surging when driving at a constant speed
  213. Siezed injector
  214. parking brake malfunction
  215. GPS Not Receiving Satellites
  216. New to Audi and MMI
  217. 2008 S6 with high mileage (200.000 km)
  218. Please I need urgent help
  219. A6 electrical problems help please
  220. All season tires for 2011 A6 Quattro
  221. OEM windshield interfering with EzPass Transponder
  222. 2007 S6 5.2 V10 Oil Leak
  223. 2008 S6 MMI DISPLAY
  224. Stalling once right after startup
  225. Rear cigarette lighter not working
  226. Carbon deposits in PLASTIC UPPER INTAKE MANIFOLD [06E 133 210 P].
  227. 2005 4.2 cold start
  228. Audi A6 Jump Start
  229. G2 MMI DVD/NAV
  230. Audi A6 3.2 v6 2008
  231. Adaptive air suspension problems
  232. takata airbag interim fix
  233. Update NavSystem
  234. Sonax Profiline Ceramic Coating CC36
  235. Where is the HVAC electromagnetic heater control on a Q7
  236. pedal booster
  237. A6 Charging issue?
  238. 2007 A4 audi
  239. nokian Hak R2
  240. Audi A6 Quattro 2005 Fuse front lighter
  241. cant find the hvac heater unit
  242. 2005 4.2 Oxygen Sensors?
  243. Audi Q7 2007 wont start at all
  244. 2006 audi a6 c6 after market tail lights for cars with factory leds
  245. Fog Light Wiring Help
  246. 2009 A6 oil consumption
  247. Please help
  248. Moving to the B9 Forum
  249. Mating torque converter to engine?
  250. This ones a doozy, need the gurus!
