PDA
View Full Version : A6 / S6 (C6 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85
  1. A6C6 3.0 ASB fuel in oil
  2. Need Help Vacuum Leak 3.0TFSI
  3. 2011 C6.5 3.0 Coolant Leak
  4. Considering a purchase... 2013 or 2014 S6?
  5. How to test wheel bearings?
  6. S6 battery warning light
  7. Load hissing sound on bank 2 on supercharger case
  8. Got a power steering fluid leak...
  9. EPC light Audi A6 C6 2006
  10. Can you charge locked A6? Can u get into cabin from trunk?
  11. Audi A6 C6 Avant 2010 rear LED tail light issue
  12. A/C and Heat woes... how to diagnose the actual issue?
  13. any one have the SD card to update a '10 3G MMI
  14. '10/'11 A6 Navigation Updates?
  15. Cant start the engine. SAFE on Dashboard
  16. subwoofer upgrade
  17. Headlight Motor Wire Gauge?
  18. Cause of low HPFP reading
  19. 2010 Avant tow hitch suggestions
  20. p0345/6 after fixing P0365
  21. Rpm problem needle jumps around wile accelerate
  22. Radio Tuner K Box - NZ Radio Frequency
  23. Power steering fluid flush
  24. Front Wipe Blade dead
  25. Help PLZ Broken engine audi a6 c6 diesel avant quattro 2007
  26. Confused which sensor this P code is for
  27. Oil Consumption - What have I missed?
  28. 2.7tdi avant wont start. Click under the bonnet
  29. where is the Sirius module in a 2011 A6 sedan ?
  30. High rpm rattle?
  31. Audi a6 2006heating blower relay
  32. '04 A6 3.0 CVT range sensor location?
  33. Engine noise after oil change
  34. radio proble
  35. 2011 a6 3.0T issues?
  36. BE: Where is the turbo situated on an A6 Estate 2010
  37. Cam Chain Tensioner Experts, I need your help
  38. audi a6 c6 4f 4.2 quattro 05
  39. FR: Allroad 2008 C6 Air suspension failure
  40. Front Parking Lights Not Working
  41. Fuel filler flap doesn't lock with doors?
  42. C6 A6: Can someone help me?
  43. how to add relay to close Avant hatch via fob ?
  44. oil change interval
  45. Need help with alternator VR
  46. Hopefully a simple answer for water in trunk
  47. Rattling Noise From Passenger Side is untraceable?
  48. Syvecs (or other standalone) ECU on an C6 S6?
  49. 3.2 FSI Serpentine Belt, Tensioner & Idler Pulleys
  50. Audi A6 C6 Avant
  51. 2008 Audi A6 C6 Air Suspension Failure
  52. 08 A6, start authorization module or dead fob?
  53. Replace reverse lamp bulb 2011 A6 Avant
  54. What do these animations mean?
  55. What resonator should I go with
  56. 2007 A6 Avant - few issues I need help with
  57. 3.2L Cam Follower Is Bad
  58. Where is the engine speed sensor/crankshaft position sensor on a 2008 4.2 A6?
  59. O2 Sensor Errors
  60. Audi S6 C6 strong burnt oil smell at front left
  61. Wheels ?
  62. 2008 A6 C6 - Non Running, Any help?
  63. 2012 A6 RMC navi need
  64. Audi A6 C6 2010 Avant Gearbox problem
  65. $200 + for a rubber strip
  66. 2006 3.2 FSI Coolant Capacity
  67. 2006 A6 C6 Driver Door problems
  68. 2008 A6 4.2 Bank 1: CMP Sensor 3 (G300) / Engine Speed Sens (G28) error
  69. New HPFP and carbon cleaning!
  70. Bulb holder thing confused
  71. GB: need Handbook/manual
  72. Code P0203 Injector circuit open
  73. Flex pipe - weld vs. clamp
  74. Vibration when turning under load.
  75. Better bluetooth alternative to Tune2Air
  76. Replacing inner CV joint Multitronic?
  77. Transmission fluid leak
  78. Replacing front outer CV joint
  79. Help retrofitting folding mirrors, power rear shade
  80. Camshaft position codes
  81. mmi system not working
  82. 2006 Audi A6 3.2 Fuel Problem
  83. Car stumbles, stalls, and won’t start (2008 Audi A6 3.2)
  84. Door lock actuator-no blinking lights, horn, or flashing light now
  85. Misfire I cant seem to fix
  86. led rear light wiring
  87. '10 A6 Avant PS Issues
  88. very tight lock cylinder
  89. Nice Looking 2008 Avant on cargurus
  90. 2016 front end cabin noise.
  91. Steering Fluid Leak - Rack Doctor
  92. Front crankshaft seal replacement
  93. Looking to buy a 2016 A6
  94. What oil?
  95. Exhaust sound for 2018 S6
  96. Cockpit navigation not working
  97. a6 c6 2006 instrument cluster swap
  98. audi a6 c6 3.2 l fsi
  99. Oil leak, Drivers side
  100. Going to try this RSNAV 2G High unit
  101. Audi A6 TFSI 4F5 C6 2009
  102. unknown source draining battery
  103. Sub woofer does not turn off completely
  104. Green and yellow air suspension lights, no error codes
  105. Weird throttle issue no MIL
  106. Replace navigation unit
  107. 2005 Audi A6 Heated Auto-Dimming Mirror Glass Replacement (Video)
  108. 2008 A6 (C6) 4F Allroad Quattro 3.2ltr 3.2 24v FSI
  109. 2011 A6 Avant 3.0t still having misfire on Cylinder 4
  110. Misfire codes after replacing spark plugs and ignition coils
  111. 2011 A6 3.0T error codes
  112. Windshield visor extension ?
  113. Power Steering high pressure hose
  114. Audi a6 2006 2.4 v6 acceleration problem.
  115. 2006 S6 5.2 V10 Cooling
  116. Third brake light removal
  117. Headlights DOWN grade A6 c6 2007 from Xenos to Halogons..
  118. Luggage cover avant: creaky as hell
  119. Anybody in NYC
  120. Air suspension?
  121. A6 C6 Key fob
  122. What causes a car to jump into "limp mode" when accelerating hard?
  123. IE: 2010 a6 S Line
  124. Phone placement?
  125. A6 MMI 2 G problem ! Radio is not Installed ?!
  126. Anyone know where this plug goes?
  127. MMI problem
  128. List an a very unusual A6 AVANT on Bring a Trailer or e-bay?
  129. List an a very unusual A6 AVANT on Bring a Trailer or e-bay
  130. Door Module/Wiring Errors
  131. Help; '07 A6 C6 won't go into gear (won't engage)
  132. How to Install Sat Radio
  133. 2019 Audi Connect
  134. P2075 and P0345 error codes
  135. Anyone switch oil recently?
  136. Folding Mirror Motor
  137. Power Outlets not functioning
  138. intake manifold flap
  139. HVAC fan big problem
  140. hello, everyone
  141. Starting when hot problem
  142. Need help figuring out a few problems
  143. loses high fuel pressure once engine warms and stalls.
  144. Install Navigation for MMI 2G Basic+
  145. Parking brake malfunction, ABS, Anti-spin problem
  146. CD changer problem
  147. Purchasing C6.5 3.0T A6 Prestige: give me any advice?
  148. Timing chain noise
  149. Going UP!!
  150. stretched chain guides replacement cost?
  151. Fuel door keeps popping open when I stop the car.
  152. 2007 S6 V10 Misfires
  153. MMI 2g problem!
  154. Mini problem
  155. Audi a6 3.2 fsi Help Help!
  156. Audi Turn Signal and High beams controls flipped
  157. Did 55,000 mile service- had some problems
  158. Replacing C6 transmission
  159. Coding tail lights from 7 to 6 pin.
  160. My first big job
  161. Coilovers
  162. Changed fuel filter now can't hear fuel rail pressurize
  163. stretched upper chain?
  164. A6 2007 3.2 Quattro AC Keeps Disconnecting
  165. How to decide when its time to turn in an old Audi?
  166. rear light Assy, circuit board?
  167. Oil leaks, undershield and foam absorb?
  168. Steering column
  169. [Pics] Coolant leak from auxiliary water/coolant pump, passenger side bottom.
  170. 2009 C6 Air Conditioning
  171. Audi a6 headlight wire diagram for DRL install
  172. Anybody have any idea what this is?
  173. TDI: audi a6 c6 check engine light
  174. Error coded p0391 and p0024
  175. 01225 fault code driver's door won't lock or unlock with remote
  176. Throwing serpentine belt monthly
  177. 2006 A6 Avant, retrofitting stock bluetooth, and some other issues
  178. Transmission or throttle position sensor?
  179. 2007 a6 4.2 - no ac - need help
  180. Restoring headlights.
  181. Steering wheel hose audi c6 2010 2.0 tdi
  182. My first CEL - Code 08852
  183. DRLs & side lights out after car wash
  184. Possible to just replace just Cam Lobe?
  185. New here. Steering column actuator fault. 2005 A6 not starting
  186. 2009 A6 facelift MMI dead, have a same year, can I switch parts?
  187. Gearbox Problem - 2008 2.0 TDI S line Automatic
  188. PCV Valve? Breather Hose? Something else?
  189. No front or rear sensors
  190. Tail lights for 2007 a6 3.2l
  191. Cylinder bank 2... it is the left side?
  192. Are these RS6 style wheels?
  193. Seeking Guidance
  194. P03BB Fault Code
  195. 2008 Audi s6 issues with codes p2007 and P3298
  196. AC Compressor Question
  197. MMI Programing
  198. Aftermarket tail light source for my A6 C6 3.0T
  199. HeadLight Replacement
  200. Newb Needs Assistance A6 lighting
  201. Better power steering when revved to 3k RPM?
  202. TCM canbus pins? RS Q7
  203. Question about my 2007 Audi S6
  204. A6 C5 Climate control unit
  205. Intake box question?
  206. 08 Audi S6 Bank 2 lean
  207. Brakes-how many miles?
  208. Navigation update?
  209. Aftermarket lights and fuses
  210. Parking System is not working
  211. Start stop button
  212. 2008 audi a6 front passenger door wont lock
  213. Post-facelift bumper question
  214. 2014 Audi Q7 TDI AC not working
  215. Front Seats back covers, falling off Audi A6 2007
  216. Number plate lights
  217. Adaptive cruise control slow down uphill
  218. Fault code P0104. Help!
  219. TPMS disable and other things to do?
  220. Code P0068 and P307A
  221. 2008 audi a6 codes check engine
  222. swapping S6 seats into 2008 A6 C6?
  223. Fuel Pump Issues
  224. A6 3.2l suspension
  225. SE: A6 2.0 TFSI
  226. Epc and esp fault on, rough idle and limited throttle
  227. 2008 S6 trunk lid remote buttons stopped working
  228. How to add BT/iPhone connection?
  229. 2007 Audi A6 drivers seat rail release broken.
  230. 2005 Audi A6 ABS ESP Unit Replacement (Video)
  231. MMI Control Panel lights randomly flashing
  232. Stereo input?
  233. Ami location?
  234. What year A6, and engine ?
  235. Roof Rack Recommendation
  236. Roof Rack Recommendations
  237. Any info would help
  238. 2011 C6.5 Custom Sub
  239. MMI 3g with unresponsive buttons question
  240. Rear Swaybar on A6 Avant?
  241. MMI update nonsence again.
  242. 2005 Audi A6 Valve Cover Gaskets Replacement (Video)
  243. 2008 Audi A6 3.2 Fuel Pressure issues.
  244. 2006 A6 3.2FSI to 2.7T swap
  245. AU: Injector Readings - A6 3.0Tdi 2008 Quattro
  246. HELP! Faulty ignition lock, access module and comfort module
  247. G395 Signal Implausible ‘06 A6 AC INOP.
  248. Feels like I'm being held back when accelerating
  249. P1129 & P0430
  250. Ticking Sound - Engine A6 C6 4.2 2005
