PDA
View Full Version : A6 / S6 (C6 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85
  1. ESP EPC & Engine Light ON
  2. MMI "DOWNGRADE"
  3. Should I get Snow Tires for my 2006 Audi A6 4.2?
  4. 2007 Audi S6 – Carbon Buildup – Dyno
  5. No Heated Steering wheel??
  6. headlight Adjusting
  7. Any way to reset the check engine light
  8. Need a Navigation Unit
  9. Any problems if MMI version is old one?
  10. Good look for a6?
  11. Water in Trunk, wtf!!!
  12. Water cause MMI to Stop Working??
  13. Rear door removal?
  14. S6 Caliper Picture
  15. Nokian v. Michelin
  16. Considering winter wheels: Any precautions re. tire sensors?
  17. Has anyone paid out of pocket for Amp update?
  18. Bose Surround Sound?
  19. Back Seats of A6 wont come down!!
  20. Current BT streaming audio options
  21. Some unknown buttons in my A6 2006 4.2
  22. Just another night and another problems with my Audis
  23. MMI Problems!!
  24. Manually turn on fog lights.
  25. Oil light on after 3k?
  26. Battery Level Problem
  27. A6 Rim Change Suggestions
  28. 2008 A6 wheel fitment
  29. Show speed on the DIS?
  30. Front Wheel Bearing
  31. Heated Steering Wheel
  32. check this out
  33. New Key .... Ouch
  34. How to check if engine heating system works?
  35. ALLDATAdiy.com Introduces Sponsorship of AudiWorld with a Discount!
  36. how to take the glass OFF the headlight A6 2009?
  37. Does this sound like a good deal?
  38. Minor rear fender ding
  39. Audi A6 Hybrid
  40. ECU/Gearbox problems on A6 Allroad
  41. Exterior door handle
  42. 2006 a6 c6 bumper height adjustment?
  43. Officially official: 2012 Audi A6
  44. 2010 A6 service interval
  45. Transmission 2010 A6
  46. Security System / Immobilizer Question
  47. New Audi A6 (C7)
  48. 2007 A6 BURNING OIL
  49. 2005 A6 3.2 OEM Tires?
  50. S-line (stock) suspension questions
  51. Help car won't start!!
  52. Replace DRL on '08 Audi A6 Someone help?
  53. What kind of headlights do I have?
  54. With service something wrong
  55. Problems with boot lid
  56. A6 4.2 thermostat
  57. Halogen DRL on 2006 changes its intensity?
  58. How to take off the glass/lens from the headlight?
  59. Service light reset help!
  60. MMI doesn't recongize foreign language.Why?
  61. Car has gone wacko
  62. Used A6 Owner : Questions
  63. Does anyone know part no. for rs6 shift knob??
  64. toolkit missing 08 A6 3.2
  65. S6 Grill Replacement
  66. Annoying ear splitting alerts--any solution?
  67. WTB: looking for 2009/2010 nav DVD
  68. New A6 owner (last car was a Passat): General advice?
  69. glitchy MMI question: intermittent silence/disconnect
  70. How to change headlight bulb?
  71. Question about A6 4.2 tires
  72. "Valve decarbonizing"
  73. :: ECS Tuning :: 6TH ANNUAL HOLIDAY GIVEAWAY
  74. 2007 A6 C6 4.2 Cranked But Wouldn't Start
  75. Battery Longevity
  76. Trip computer and block heater
  77. Door Lock Actuator (not working???)
  78. Coding for new battery
  79. So long A6, you will be missed
  80. 300hp 3.0TFSI vs. 333hp 3.0TFSI
  81. What is your MPGs?
  82. Newer than MMI 46.10?
  83. 'worn brake pads' light?
  84. Switching Tire Size
  85. 2005 a6 wheels and tires
  86. NE1 in NOVA have the MMI upgrade disks?
  87. Question about Bluetooth and gearbox
  88. ESP/abs fault
  89. Any Takers?
  90. '06 A6 Avant ESP & Adaptive Air Suspension Lights On After Alignment ??
  91. Is Audi paint soft? Had car detailed and looks like salt was shaken over hood/fenders
  92. Figure this one out, Parking Brake Malfunction
  93. Starting Problem
  94. viseeo Bluetooth any good?
  95. New Member :)
  96. What's different with S line?
  97. ross-tech VAG-COM with HEX-USB+CAN Interface
  98. AC control panel removal
  99. Problem shifting gears
  100. Trunk light not working – Need help
  101. Can a stock A6 successfully hop onto/off of a street curb without scraping anything?
  102. Triangle doesnt switches off
  103. Check engine warning at 1,600 miles...
  104. Rear sway
  105. Did r1racer do his trannie?
  106. S-line v. N-line avants
  107. Sunroof issue, help!
  108. Loose rear calipers
  109. About Audi MMI and navigation
  110. Where do you put a dog in avant
  111. AudiUSAparts.com?? Any info?
  112. After Market Auxiliary
  113. POWDERCOAT OR PAINT?
  114. Buying an 07/08 S6 - Things to watch for
  115. 9.5 inch rear
  116. suspension questions
  117. SDHC cards
  118. S6 Wheels for sale
  119. What do you think of this Control Arm Kit with Lifetime Gaurantee?
  120. Factory Recalls
  121. Which should I buy, A6 or A8?
  122. LED Interior Kit... (Video)
  123. Loss of responsiveness after rear brake job.
  124. Oil Pressure light
  125. Disconnect the Battery Question.
  126. Maintenance Costs
  127. 2008 A6 Avant 3.2 FSI Carbon Deposit Update
  128. Local VAG-COM available in Portland/Vancouver area?
  129. Cost of OEM sport springs for 2010 A6
  130. Hankook Ventus V4 ES H105
  131. Problem with iPod AMI
  132. Audi A6/S6 Auto Lease Programs - November 2010
  133. Battery - Special Deal
  134. Brake light help
  135. how to turn light off after car is locked
  136. Audi Side Assist
  137. Winter tires - to do or not to do?
  138. What Communications Pack
  139. Needle Sweep
  140. New solution for A6 headlights retrofit
  141. 2006 A6 3.2 Quattro Air Conditioning & Hesitation Questions
  142. Degraded oil filter
  143. S6 units sold
  144. 2007 S6 Transmission Surge Update
  145. How do you remove plastic cover underneath
  146. Detailer's Domain: SEMA / PRE BLACK FRIDAY SALE! 20% Plus!
  147. Front rotors $377 installed a reasonable price?
  148. brake wear warning light came on....
  149. Yokohamo AVID ENVIgors or Michelin Pilot Sport A/S - which ones are best for my A6?
  150. black grill frame + roof rails
  151. Brakes without VAG
  152. Tire question- can I replace just two tires on my quattro?
  153. TCM location on 2002 A6 2.7T
  154. Milltek for S6 - Resonated or non-resonated?
  155. Driod X and Driod 2
  156. Dealer finally cleaning carbon deposits on intake valves, after 1 year of visits...
  157. Question about A6 4.2 (2005)
  158. Bluetooth issue, I can hear, they can't hear me
  159. Navigation Help
  160. Happy Pumpkin Day Audi Fans!!
  161. Wind Noise
  162. Help... Tech/key ESP issue
  163. How do you negotiate on a special order?
  164. Help with 2011 A6 Avant Pricing
  165. WTB: 2009+ Navigation Disc
  166. Will tuned A6 3.0Ts see high 12s in the quarter?
  167. 3.2 Driveline Lash
  168. Winter tires R17 225/55
  169. Replacing P/S fluid, A/T fluid?
  170. Tire size change 2008 A6
  171. Ipod battery exhausted when left in MMI???
  172. Any experience with Cartronics.com hdtv device
  173. Trunk Liner
  174. Battery Life?
  175. 2011 A6 buying/engine questions
  176. brake light warning but no LEDs out...is there a fix?
  177. 2"+ of water in footwell front and rear
  178. 07 A6 upgrade to RS6 kit
  179. 3.2 issues + questions on the new 3.0T
  180. A6 TDI.. .Any plans for the US?
  181. pics 2010 A6,STASIS signature series
  182. RS6 headlights revisited
  183. Cant Decide Between the '11 A5 or A6
  184. Cliffs of Insanity Audi Cruise vid
  185. Standard life for shocks?
  186. Does the Nav learn?
  187. New A6? Photos from Texas
  188. Trunk trim loose
  189. Winter tire/wheel question
  190. Black Beauties: 535xi vs. M37x vs. A6 3.0T
  191. Dumb to buy new A6?
  192. A6 1996 water in engine
  193. Best 3.0T Suspension/Wheels to Limit Road Noise?
  194. Tire change for 08 A6 Avant
  195. help with navigation 2006 A6 avant
  196. Hit a Deer, Great Bday present
  197. 2010 STASIS A6
  198. S6 Steering Whine
  199. Sprint Booster on S6?
  200. NE1 tried the Clek Oobr booster in A6?
  201. 3.2L tuning
  202. completed the S6 conversion... and have lots of parts left
  203. Wheel balance / Rim issues
  204. Code busting
  205. Side Marker (Under Side Mirror) Bulb Replacement
  206. 3.0T Steering
  207. Sunroof parts disintigrated
  208. 4.2 Spark Plug
  209. Detailed impressions of our 2011 A6 Avant
  210. Engine Smoking
  211. A6 Completely Disabled
  212. A6 Daytime Running Lights
  213. 2010 A6 3.0T Fail!!
  214. Newbie Question about 2006 A6 Navigation
  215. Need help disabling or changing yellow air bag light
  216. Electric Exhaust Cutouts
  217. Getting Playlists on SD Card in MMI v3 working with iTunes on Mac
  218. Turbo/Supercharge A6 4.2 ????
  219. Passenger Airbag light--annoying!
  220. Headlight aiming problems
  221. 2009 rs6 wheels
  222. 2012 A6 Spy Photos
  223. Sluggish Tranny
  224. Rear Brake Vag-Com
  225. Seatbelt Question
  226. Mix function on Hard Drive
  227. Heated Seats and the Climate Control
  228. A Cheap AMI solution - Group buy
  229. kind of a stupid question
  230. Experience Audi Tradition 1901 – 1990
  231. 3.2 engine valve cover gasket replacement
  232. Towbar
  233. dvd/navi help
  234. Replicas vs OEM RS wheels
  235. New tire type for '08 A6 3.2 Avant
  236. LG 501 Cell and Audi A6 2005 3.2
  237. Climate Control temperature/blower Issue?
  238. I need plugs/grommets, and front plate delete...
  239. A6 3.0T or S6 - performance
  240. Weekend Drive: Audi V10 S6 and Supercharged V6 A6
  241. Who do their own oil change here? 0W-40 vs 5W-30???
  242. Oil Change
  243. NH / MA installers for HID's
  244. Adding Homelink
  245. AMI Cheap Cables????
  246. Vag-Com and Adaptive Brake Light?
  247. New Car.. Kinda
  248. 2005 A6 cable in trunk???? for What??
  249. MMI upgrage 5150
  250. Blower Motor Replacement DIY? Or Dealer?
