- Temp gauge keeps on dropping
- Need help! Strut information
- IS: wheels size and transmission problem
- New audi diesel owner fuel eqonomy?
- AL: A6 diesel advice needed - Car revs on idle and in low RPM
- looking to buy roof racks.
- UK: Diesel shuddering at traffic lights?
- EE: Vcds- Can gateway (ecu faulty coded)
- Transmission issues for 3.0 2009 a6
- IQ: 2006 A6 transmission problem
- Lifted suspension
- 2008 Audi A6 C6 4.2 sedan MMI2G High android auto
- A6 DPF light came on
- HELP AUDI A6 C6 3.2l engine noise, NOT TIMING
- 2011 A6 C6 SideAssist Fault
- Converting Audi S6 v10 to RS6/R8/Lambo v10?
- 2008 Audi A6 C6 4.2 sedan TPMS question
- NL: Power steering issue
- Washer Fluid Level Sensor and Rain X
- '05 A6 Quattro 3.2L Stuck rocker....?
- Audi 3.0tdi vibrations tiptronic
- 2008 A6 Coolstream not being read
- UK: 2006 A6 3.0 Le Mans - Electrical Problem, Battery Discharging Overnight
- IE: Audi A6 C6 - 2010 - 2.0 diesel - Rear Left brake squeak
- 09-11 A6 3.0T Stage 1 Tunes, Opinions/Best of
- UK: C6 diesel DPF
- Crank Position Sensor?
- PE: How can i know which Key should i Buy if i lost all my keys?
- 2007 Audi A6 Makes whirring sound but does not start.
- Oil Minimum light
- 2014 Audi A6 door speakers
- 2006 Audi A6 3.2 quattro won't start
- Lower Track Arm install issues
- C6 Rust holes in doors!
- C6 Diesel Engine Rebuilt Experience and Advice?
- O8 A6 C6 TCM location and then some
- need Monroney label
- Power steering problem
- 3.2 to 4.2 swap
- 3.2L simple mistake blew the engine
- J518 Steering lock module. How many control modules?
- MMI not working
- Battery Fusible Link on Batter size?
- Allroad Air Suspension Fault Following New Tyres - 01437
- Rough idle, what couple be the problem?
- Audi installing power inverter
- Allroad suspension fault
- plastic piece between spark tubes
- Tpms vehicle frequency
- MPH and RPM needle lights staying on
- Topdon Scanner cannot connect to ECU
- Rotor and Brake Kit for 2015 A6 Quattro
- S6 C6 Mysterious Misfire
- Pinch Bolt removal w/2 jaw puller
- PL: Looking for aftermarket good quality steering wheel
- Drawing Revisions. Document control
- My Audi virtual Cockpit Stuck msgs and other faults shown in the OBDeleven
- Audi A6 C6 CD Changer swap
- Wont start - A6 SE FSi Quattro Auto v6 estate 252bhp
- UK: need urgent help with my Audi A6 2005 3.2 petrol
- 2008 A6 starts and dies, already switched immobilizer and MMI
- Bluetooth error
- NO: Audi a6 3.2 4f 2005 lock actuator problem
- Diagnosing suspension noises
- SE: ESP and CEL and misfire on cyl 2
- Head lamp question
- Auto gearbox failure - ECU related?
- How to remove steering column with electronic height adjust
- A6 C6 (2005) Onboard power supply module
- Headlight replacement, Halogen to Bi-xenon
- P0106 - Need to pass Emissions and this is the tall pole
- UK: 2007 Audi A6 (C6) SE 2.0 TDI EGR Cooler Fixings
- 2008 3.2 Quattro
- Turbo Actuator Position Sensor
- A6 C6 4F Allroad Suspension again
- Hard Judder on start up (90 Degrees)
- Clicking/Knocking noise from gearbox
- a new cd player unit install, but not working
- 3.0 crank sensor
- 2006 a6 c6 headlights?
- Crank no start
- What is this?
- Apple carplay
- EG: Adding engine start/stop button feature?
- UK: Which to buy ?
- TPMS tolerance question
- blue smoke after a long engine braking / p2070 fault
- Audi a6 c6 front bumper swap to lift version
- PL: 20" inch wheels on a A6 C6 (2004)?
- UK: diesel fault codes; 00473, 01826, 01206, 00003, 02382, 02433, 01087 and 02432
- How do I fix fault codes; 00473, 01206, 00003
- Throttle body interchangeability?
- audi a6 nav update
- buy VCDS or OBD cheap
- A6 C6 Quattro 4.2 V8 adaptive air suspension Problem
- Inboard High Beams not working.
- BCM/CCM
- MMI Replacement and Trunk Latch Replacement
- Rear fog light
- Transmission fluid fill plug location
- Source for new or replacement headlight housings for 2009 A6 Avant?
- Swapping BCM/CCM
- Headlamp size question - Audi A6 TDI 2.7 V6
- [THe only mod on my car]: rear whiper rest
- BCM/CCM REMOVAL AND INSPECTION?
- Adaptive Headlight Defective (left arrow) error
- Swap break's from Audi S6 c6 5.2 to Audi A6 c6 ALLROAD
- 2008 3.2
- Facelift vs Pre-facelift grill?
- Dynamic 4 wheel steering
- Low beams and fog lights
- IL: Automatic light beeping \ extraior lightning has been deleted from mmi
- Stolen S6 2010, was gone for 3 years.
- HK: A6 rear right brake light and reverse light
- Auto box not changing up gears in d mode
- Android Head Unit 8.8" but with generic dashboard/interface
- Philips X-tremeUltinon gen2 LED H7
- BG: A6 TFSI 2.0 Errors and going into limping mode
- New turbocharger with controller, but car has safe mode
- AUDI A6 STOPS WHEN IDLE AND AT TRAFFIC LIGHTS.
- Goes in to limp mode at 3500 rpm
- '08 A6 Sline Avant Mirror interchangeability?
- Parts needed For my 07 Audi a6
- 2008 A6
- Tail light faults
- 2007 Audi A6 Battery Replacement w/OBD11 ?
- UK: Audi A6 c6 2005 engine relay,fuse and ecu box lh plenum?
- 2008 Audi A6 Reverse Camera Gridlines Gone
- 07 s6 sprint blue value?
- A6 allroad 3.0 tdi cranks but wont start
- P216A Audi Fuel Injector Group E Supply Voltage Circuit/Open
- ESP and Brake lights on when ignition on A6 C6 4.2 Quattro 2006
- SE: 2.0 TDI, strange behavior. EGR Valve?
- Front Lower Control Arm Bushings DIY
- 3.0T Long Crank?
- Best repair manual for 05 Audi A6(C6) ?
- LT: Add more electronic to my c6?
- 2006 A6 Avant (AC) Rear Cabin Heating.
- ESP LIGHT ON AUDI A6 4.2 QUATTRO V8 TNG PROBLEM
- AUDI A6 C6 4.2 QUATTRO V8 OIL PRESSURE SENSOR
- Car locks itself with running engine and kids people inside
- Is coding needed for new Injectors after 5000KMs?
- PT: Audi A6 avant '09 correct part number. Help
- AUDI A6 C6 4.2 QUATTRO V8 OIL PRESSURE SENSOR?
- A6 2005 often not starting in cold (One click when turning ignition)
- Coolant level sensor disable or spoof?
- S6 Odd Electrical Problems
- A6 led headlights on an s6
- P0106 - Do I just have a bad MAP Sensor?
- A6 C6 4.2FSI coolant temperature question. And intermittent code P0087
- Best A6 engine?
- Experience with aftermarket injectors?
- C6 engine swap
- Engine running cold
- What Part(s) am I Missing to my air filter (see pictures)
- Strange coolant leak
- Audi A6 allroad 3.0 Tdi cranks but wont start
- Hello
- 07 A6 CV Axle Nut Removal
- 09 a6 avant forsale
- BA: Audi a6 4f 2005 DATE PROBLEM
- HELP a6 no start. what to scan with ross-tech
- ESP/ASR
- First post: starter fuse?
- Radio MMI problem
- USB STICK EMPTY FOLDERS
- NL: 3.0 TDI reliability?
- P0403 EGR valve N18 malfunction intermittent
- mmi 3g high firmware update
- Problem with DPF 2.0 BRE
- Strange Heating Issue
- New Purchase Audi A6 Avant 2.8 FSI + Help With Some ISSUES
- Coolant temperature fluctuating
- C6 A6 Sport Package - How to find Sport Seats
- PL: Audi TT MK2 wheels fit on A6 C6 (2004)?
- PL: Third stop light repair
- Supply Voltage for Right Parking Brake Motor (V283)
- UK: Audi a6 c6 2010 2.0L diesel
- Transmission Longevity on a 2010 Audi A6 3.0T?
- A6 e-tron... Will they make a wagon?
- UK: A6 caha 2.0 tdi coolant problems.
- UK: Audi a6 2.0 tdi caha
- 2007 A6 Seat Wiring
- UK: Help with A6 Avant (C6 2.0 TFSI) EML/fault codes
- 2010 3.0 Avant extreme oil consumption...HELP !
- A6, 4.2l; replacing torque converter, what else should I replace?
- Mmi boots then shuts down. Vcds shows all errors
- UK: P3348 Turbo Actuator doesn't move, new turbo and actuator installed too!!!
- Horn not sounding when alarm is set
- Audi a6 2007 won't start, got codes
- Turbo actuator won't work, even with new unit installed
- 2005 Audi A6 short serpentine belt A/C bypass
- 2007 Audi S6 parking lights/inspection fail.
- 2006 A6 C6 Avant rear opening height
- S6 c6 missfire
- Help: no codes, shaking at idle when warm
- Battery disconnecting question
- 2008 s6 up-badging?
- 2012 A6 cooling fan, MMI issues..need advice
- 2008 Audi A6 3.2L
- A6 C6 4F Allroad jacking mode will not turn off
- UK: Heavy steering after fluid change.
- Help - Driver's Side Ballast
- Need Help! 05 Audi A6 3.2 L won’t start!!
- [A6 Avant] Rear gate strut length
- [less important rant] passanger airbag off
- SE: Front door fbu issues
- A6 C6 Parking Brake Switch Faults?
- 2009 A6 Reliability?
- UK: All Red Warnings
- Throttle wont respond sometimes
- OBDELEVEN Battery Replacement
- Radiator replacement on 2008 A6 4.2
- P-0391 and P-0346 Codes (08 A6 3.2L)
- MMI Nav Display Screen 2014 A6
- Inner Tie Rod Nut Size?
- Changed spark plugs /coils engine still shaking at idle
- Aftermarket intake suggestions
- 2012 Audi A6 Quattro Error Code P275300 ($15k quote for repair??)
- Audi A6 C6 Avant retrofit 2g to 3g
- MK: Help/suggestion for Android Multimedia
- Audi A6 C6 3.2 Quattro Light Problems
- UK: A6 diesel Quattro Auto 2006 - ABS woes
- installing aftermarket backup proximity sensors?
- Reverse camera stay on after back from reverse
- 2008 s6 p0741
- Audio only on left hand side
- Big Oil consumption
- New owner with a headight question
- UK: Air con 4F0260805AE
- 2008 A6 Avant rough ride.
- Experience with aftermarket door lock?
- MK: Help with headlight adjustment
- No crank steering unlocked!
- Should I TipChip ( TCU Upgrade ) my 6-SPD Tiptronic On my Audi A6 C6 4.2 Quattro 2005
- Signal Wire for Tiptronic Implausible
- Does anyone in here know the front shock/strut length of a later A6?
- P0087 with no misfires.
- 06 A6 quattro 4.2 massive oil leak
- Supercharger pulley kit compatibility??
- SOS! Just bought an A6 V6 3.0L (I need to swap)
- size of the winter tires.
- New A6 Wagon Owner here
- Sat Nav Please insert DVD... why?
- Manual climate control and MMI
- Climate control temperature issue
