- P3053 Starter Control & P3088 Starter Relay - No Crank
- Hid bulb
- Question on Mobil 1 Formula M 5W-40
- '15 Audi A6 - Burning Smell
- '15 Audi A6 - Water in Head Lights
- Daytime Running lights flickering
- Empty batt/ windows not work after chage batt
- Level of Sidewall damage (Audi A6)
- how to hedge for timing chain failure
- Purchasing a 2005/2006 Audi A6, preferably the 4.2 V8
- 2006 Audi A6 Not Starting
- Moisture in Side Marker Light on Fender?
- RESEALED TIMING CHAIN COVER BUT STILL LEAKING IN THE AREA
- passenger seat teardown?
- steering gear problem removal.
- Independent Shop in or near Sunnyvale, CA?
- Alarm lights lit up for ABS, ESP, and Parking Brake?
- Audi S6 water leakage
- ABS+ESP+Parking Brake+Adaptive Headlight Failure
- Can Install SAT NAVI on my Allroad 4F
- trouble connecting to Bluetooth
- 2008 A6 TPMS Sensors
- A6 C6 S LINE HID DRL H1 bulb help
- 2008 A6 iphone 6 integration solution?
- Key Fobs will Unlock but will not start car
- 05 Audi A6 3.2 High Beam Bulbs warning
- Audi Mechanic recommendation in San Antonio
- H&R springs
- DIY RESEAL TIMING CHAIN COVERS
- A6 C6 Quattro led rear brake light failure
- '06 A6 Avant Navigation install?
- Akebono Ceramics Anyone?
- 200K mi. Yesterday! CEL/bad start cured!
- aftermarket tail lights
- Fine Grain Ash Natural Brown Wood Inlay
- Throttle Body Failure on 3.2 at 119K miles: Unusual?
- Let the wife drive the car - MMI frozen
- A6 C6 3.0tdi quattro vibration
- Need Help!Changing the climate panel from manual to digital
- Key Stuck In Ignition
- 05 audi a6 need fob 4 digit pin
- Service Sign - X through Circle
- Vin Code
- Help '08 Audi A6...Coolant Temp reading at 50oC only
- Strange Audi C6
- J299 location
- oil and carbon buildup questions
- 2006 Audi A6 shock/strut replacement
- Awaiting delivery 2011 A6 Avant
- New Member about to buy an A6
- Fault Code. What does it mean and how can I fix it?
- Car will not turn over just shudders
- Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - December 12th - 19th 2014
- Question about the AMI
- 2008 A6 3.2L - Judders at low speeds
- 2005 A6 3.2 Intake Flap Actuator Arm disconnecting. need help gurus!
- 2004 A6 Stalls Immediately After Starting?
- 2008 A6 Intermittent Wiper Interval - Too Long
- Another MMI Issue
- Pro Clip cell phone mount Black Friday Deal
- Happy Turkey Day
- correct tire pressure for 225/55/16? (winter)
- 09 S6 - Good DD?
- indy mechanic recommendation, akron ohio area
- Radiator fans running at full speed in 20° F
- AWE Tuning Holiday Pricing starts…. NOW.
- Average running cost per mile
- :: ECS Tuning :: 10th Annual Customer Appreciation Holiday Sale|Save up to 30%!!!!!!!
- Oil change/ 3.2 fsi SAE 5W-30 Acea C3
- Possibly washer fluid damaged Bose amp in my avant?
- Rough startup
- iPhone 5/6 MMI Interface
- Flash Sale @ DetailersDomain.com - 15% off and Free Shipping - ends 11/22/14 mid est
- VAG COM....
- plate filler question
- Great Article About a C6 S6
- Another blower?
- No dashlights, and no ignition
- Adaptive Cruise Control history
- Cannot insert key into doorlock
- 2007 Audi a6 4.2
- Door handle passanger side
- Tranny fluid fill up?
- How do i change power steering fluid
- new owner questions
- How to remove the rear seat bottom on an Avant?
- Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - November 27th - 30th 2014
- Dealership Negligence?
- Vehicle Data Label
- A6 3.2 Engine failure.. What to do :(
- a6 2010 rear blind makes noise while going down
- A6 Allroad heater issue
- a6 c6 4f bumper change
- Right Headlight Probleme
- 2010 Audi A6 3.0T automatic Transmission Problem
- a6 bumper change
- 2005 Audi A6 Quattro EPC, ESP, P2296 need help
- :: ECS Tuning :: C6 A6 Winter Wheel Storage Protection
- Curb bite!
- Audi A6 Fuelling Problems
- 2007 S6 5.2 V10 - Dealer Responsibility for damage
- Momentary power (electricity) cut/reset
- 2008 3.2 FSI Head Gasket Timing Issue HELP!
- Require part # for item indicated.
- HELP! Key won't remove. Car won't start.
- 2006 TPMS antenna location and replacement?
- A6 C6 2005 multimedia upgrade?
- Ever have a DVD drive fail to take or eject a DVD?
- 2008 A6 2.0 TDI Automatic
- Did i just buy a lemon??? 05 A6 3.2
- LED DRL keeps lightning
- Headlight Xenon komplett A6
- A6 C6 2004-2010 Dekra and What Car= Solid Car
- :: ECS Tuning :: C6 A6 KW Coilovers
- Oil Plugs S6
- 2007 A6 can Nav and Sirius be retrofited?
- Replacing lock/latch control module. Dealer recode?
- Newbie Checking in...
- 05 A6 quattro 3.2 major engine issues
- 2005 A6 4.2 headlight washer cover
- Opinions Wanted.. To buy or not to Buy??
- Audi Non-Dealer Service in Norht Miami
- Belly Pan Retainer Alternative
- Trans Cooler line fix?
- A6 3.2 Fsi Quattro - ABS Module Recoding?
- so my car left me...stranded...and no MMI
- Thermostat housing or block leak?
- Problems with replacing the blower motor
- Torque specs for wheel bearing replacement 2006 4.2
- Bentley manual assistance please...
- A-6 3.0 front engine flange
- Extreme oil leak after dealership.
- possible blown speakers
- Navigation Pre-Wiring -- Question Though
- A6 C6 4.2 front wheel bearings
- Oil Filter
- Water drivers footwell! Please help.
- Airbag light on but no codes?
- Very poor Xenon HID Headlights
- OEM connection location
- Hello to all...S6 rear valance P/N?
- Front passenger door wont lock. Any ideas? VAG Fault code attached.
- :: ECS Tuning :: C6 A6 3.2 & 3.0T ECS Billet Oil Filter Housing Cap
- I need Advise/Help with MMI and NAV upgrades!!!!
- Door locking beep question.
- Newbie with 08 A6 from Bham,UK!
- Wheel lock key warning.
- Suspension on special at AWE Tuning
- Rough Idle and slow acceleration
- 2009 Audi A6 3.2l FWD Problems???
- Advice on 05 3.2 A6 Quattro
- Speakers Sizes for '08 Audi A6 (C6)
- Lower A pillar removal
- Warning: 3.0T Thermostat
- Water in foot well
- AMI problem after retro fit. Completely stumped.
- (My) Fix(s) for outside vents blowing how with AC on
- Dealer turned off MMI Protection, but recommends $1700 fix
- Electronic Parking Brake
- Driver's Side Door Panel Removal/ Window Regulator Replacement
- Trade in value... Ouch...
- Any recommendations for independent Audi repair in the MPLS/Maple Grove, MN area?
- Anyone know when the 2015 S6 configurator will go online?
- Good deal on a 2008 S6...
- RPM Surge
- 2008 audi a6 corner markers
- Compete with a CTS-V or Camaro ZL1 which model Audi to build
- Car Fax anyone???
- Mobil1 ESP 5W-40???
- New to Me 05 A6.....Intro and progress
- noise from suspension
- Aventurine Blue Tint
- Cold air intake
- engine coolant sensor
- How rare is leaking head gaskets on 3.2
- Body Kits
- Tire Offset question
- Headlamp issue / Mechanic shop issues
- OBD
- Corner with Confidence. Special pricing on Bilstein and H&R at AWE Tuning
- Will the current model R8 rims fit my '08 S6?
- 2005 c6 a6 ignition switch diy?
- Urgent advise needed !!!
- Update Maps in MMI 2G Satnav
- Misfire after air and fuel filter change
- Intake manifold
- Worth the risk?
- coil Pack concern
- Parking Break problem!!!!!
- Snub Mount Replacement
- this c6 hit 250k miles
- Alternative to Bentley Manual?
- 2007 A6 4.2L Coolant Leak
- 2005 A6 4.2L advice (needs timing chain maintenance)
- Moving Sale - Help us move out - Detailer's Domain
- All lights out on front right side.
- BLAQUE DIAMOND WHEELS | BMW Gran Coupe fitted with 22" BD-1
- Display Interface from a8..?
- Calling all BMK owners!
- Gas Flap Pops Open Upon Unlock
- 2005 Audi A6 Tail light issue
- Crazy estimate
- Fuel Guage question - 05 3.2 sedan
- These two parts were rattling around in my sunroof.
- Are fuel filters, powersteering fluid and coolant not sched maint items?
- P0639 General Error Code
- OEM Manual - Help reading diagrams and Legend
- How to check for rear broken coil spring?
- Control. For less. Special Pricing on H&R Springs and Sway Bars from AWE Tuning
- 08 s6 new front brake pads
- GPS date/time
- Specific rpm range problem
- need help with alarm siren..please help
- Retrofit facelift DRL headlights to A6
- Looking for reputable garage
- Rotary knob not scrolling up or down
- 2014 A6 wheels fit on 2006 A6 avant?
- Fish or cut bait thoughts/opinions on '05 A6 3.2 w/ bad AC Compressor and valve leak
- An introduction, a message from AWE Tuning
- Interesting site for TSBs
- long cranking over time
- 2007 S6 LED's? (Canada)
- New MMI control panel source for 08 a6?
- Monochrome (RED) DIS in 2008?
- My 07 S6
- Yet another oil leak....
- BG44K any use in FSI?
- Vag-Com cable help needed.
- Looking to buy 2009 or later A6 avant
- Cayenne 17Z BBK installed...
- winter wheels question 08 s6
- Replace Stereo / DVD / NAV
- Buying a A6
- 2008 A6 avant humming noise starting?
- Audi Guy Import from Germany...
- One and a half MMI display questions
- A6 3.2 fsi shaking badly
- Coilover for Under is back, at AWE Tuning. Dial in your power stance, right here.
- Thinking about 2010 A6 3.0T
- Unstable idle rpm, A6, 3.2AUK engine, quattro,2005
- Looking to buy 2008 A6 located in Houston -- shop rec for pre-purchase inspection?
- Car died, lost power and steering. :(
- 48 Hr - Summer Sale - Save 20% off at Detailer's Domain.com
- Cam position sensor
- A6 2006 Steering Wheel controls not working and other malfunctions
- 2005 A6 Headlight Failure
- 2005 A6 Rear Sunscreen
- Funny Clicking
- S6 DRL wiring using the aftermarket adapter box
- Adding oil
