- Pdc Sensors Codes?
- Castrol 0w40 at walmart
- How I fixed my A6 C6 intermittent tail light brake light issue
- Hello
- Looking for Parking Brake Switch for 4L0 919 609 K
- A6 3.2 Q, best brakes for replacement?
- Anyone have a writeup on how to remove the lower dash?
- audi A6 radio issues
- Audi Experience - Sonoma
- FM signal gone really bad
- How to remove rear door bottom speaker cover?
- 2009 A6 - MMI Dies after 30 seconds
- C7 2.0
- MMI Problems - Acts sluggish and sound cuts out...
- tcm on 2002 a6
- Re-post: 08 S6 experience-Problems, Warranty.....
- europaparts.com
- 3.2 Chains. Waste of a good Sunday.
- Oil pressure
- Adaptive Headlight Defective
- MMI Information
- Oil leak, need help diagnosing
- 2006 A6 - Start engine button
- Engine failure-2010 A6 3.0T-Common problem?
- 2008 4.2L A6 C6 4F MMI 2G HI firmware upgrade
- :: ECS Tuning :: C6 A6 Valeo Front Aero Wiper Blades
- For a limited time Sonax Full Effect Wheel Cleaner 500 ml - $12.95!
- airbag clock spring replacement
- Plant your car this spring. H&R and Bilstein coilovers for lower at AWE Tuning.
- Running Coolant Temperature
- Misfire Flu spreading from my 03 to my 06
- Need suggestions and pics for grill mod
- Greetings - '09 A6 3.0T
- A6 c6 control unit
- Fuel Filter replacement.
- Replacing Wheel Hub/Bearings for 4.2
- changing passenger side corner marker...
- Oil in Spark Plugs change
- Trunk LED replacement
- New member
- Shift Lock Override
- C6 RARE AC PROBLEM?
- AMI Importing Audi files
- 06 Slow to Start
- CD PLAYER JAMMED
- Looking for Engine mounts S6 2008
- 2011 55k service same as on my 2006?
- Dusl Mass Flywheel Replacement??
- noise after replacing serpentine belt
- How Do I Update My Audi MMI Software?
- Totaled A6 C6
- Fuel filter on 2007 A6 4.2
- Spring Therapy @ DetailersDomain.com - 15% off and shipping promos
- 2008 3.2 no start. Cam codes on bank one.
- Finally got the MMI updated in the 2005.
- Need to make a choice
- Brake Pads - Northern NJ
- Looking for front license plate delete
- :: ECS Tuning :: C6 A6 Facelift Grille Assembly
- Looking at an Avant
- Aftermarket LED Foglights
- Brake Pad Sensor
- Problem with navigation unit, Help
- Grill Bolts
- AWE Tuning is welcomes KONI to our performance portfolio, with preferred pricing.
- S6 K&N filters?
- Has anyone replaced a starter on a 3.2?
- 2008 a6 battery/start issue
- Bad Ignition Switch?
- Any way to tell if this was fixed?
- 2008 S6 Cooling Fan
- New shoes!!!!
- Are the HD Brake Caliper Carrier Bolts Single Use?
- MMI Shutdown......Help!!!!!
- C6 A6 MY2006 VAG COM Mods
- Picking up a 2006 Audi A6 3.2
- VAG-COM
- 2006 A6 repair questions
- hitch on '06 A6
- Drivers door won't unlock while all others will, via Advanced Key & standard keyless.
- Where to put the Jack Stand?
- Tire pressure for S6 2008 ????
- 2007 S6 Fuel delivery Shenanigans
- 2008 S6 ABS Module
- 2007 Audi A6 Driver Side Window One Touch Not Working
- :: ECS Tuning :: Billet Aluminum Oil Filter Housing Cap For 4.2 V8 FSI
- serpentine belt/tensioner 3.2
- 2005 A6 ABS replacement question
- Avant Owners: OEM roof bars vs. other options?
- 4.2L Quattro transmittion for sale
- Thermostat and Water Pump
- DIY - A6 3.2 Upper Timing Chain Tensioner Replacement
- Coolant temperature sensor location?
- anyone know if the TTRS BBK will fit my C6 4.2?
- Leak in flex pipe
- All weather deep dish floor mats and cargo liners - Edge Mats
- possibly dumb question - ESP
- 75k mile service
- Oil leak in 2005 Audi A6 C6
- Buying an A6, what to watch for?
- Ballasts
- Staggered wheels - will they fit?
- Battery level stuck at one bar
- prices for 19" peelers?
- Valve Cover Gasket and Timing Chain Rattle?
- Replacement headlight washer cover for 2007 A6
- 3.2L Air Tube / Check Valve problem
- Halogen -> Xenon conversion questions
- 2010 A6Q Interior Light Question
- ABS questions
- Its been so cold....
- Strange issue with starting the car
- Hello, from new member
- Feeling the winter time blues? Here is a 20% off Promo Code to get better.
- Backup Sensor Sound
- AMI IPOD HOOK UP
- NEED 3.2 QUATTRO ENGINE OR REBUILD
- 2011 A6 Quattro 3.0 Upgrades
- Which S6? 2008 with 21K or 2011 with 61K
- Tool Kit needed
- Question on Aftermarket warranty for 2005 A6
- Audi C6 S6 Driver Key lock jammed
- Printed Service Manual
- Need New HID bulb
- Good Bye C6!
- dedicated wiring for towbar
- Noob
- headlights different colors
- Option Codes
- Quattro Front to Rear tire wear....
- Add satellite radio or hd radio to MMI 2g high?
- Rough day at the shop
- Indie Shop near Pasadena CA
- anyone else having these problems???
- Air suspension deflating
- Fuel gauge stuck on empty when very cold outside
- dealer download ?
- New Wheel Spacers For The Audi A6
- 3.2 and 4.2 Reliability (timing chains)
- Need to change radiator. Some questions.
- Loose / Rocking Driver's Seat - Advice on how or who can fix?
- Disconneting Electrical Connectors- HELP
- Car Randomly Turning Off
- Replacing Front indicator lamps 2007 S6
- Used Winter Rims/Tires for Sale
- Squeaky noise
- Audi Service Plan Savings
- '98 A6 Brake Fluid Flush
- Here's a new cold weather quirk I got to experience this morning.
- idle rpms dropping
- 2008 A avant
- Improve driving comfort- A6 C6 Avant
- Which one would you buy?
- YAW Sensor replacement (combisensor)
- Darn Avant rear hatch washer fluid leak
- Tires Tires Tires
- Audi A6 Audio/Bluetooth Problems
- CD Changer + AMI + XCarLink?
- No start and revs dropping
- WTB A6 w/ACC
- S6, runs rough & EPC and Traction Control lit
- Jerky After Start once Press on Accelerator
- New to Audi, advise needed
- Trip Computer Issues
- Anyone want a wheel?
- 2005 A6 3.2 Stalls on Warm Restart
- Coolant drain plug?
- 05 Bluetooth issue / Sat Radio cutting out..
- tire questions
- A6 steering wheel needs help
- What oil are you using?
- :: ECS Tuning :: Aluminum Oil Filter Housing Cap - Audi 3.0T/3.2L
- TPMS & Brake Pad Warning with Spare Tire
- Steering Rack needs replacement
- Got a radar...now time to hardwire install it
- :: ECS Tuning :: Silicone Remote Key Covers!
- No radio/CD/sound
- Front brakes at 5mm
- Car Broken Into
- 05-08 3.2 liter intake manifold replacement
- Which ATF fluid
- Reset + for 2005 A6 Oil Reset
- HELP!! Park Assist... Audi A6.
- S6 Electric Cooling Fan
- 3.2 Crankshaft Timing Marks
- Loaded '06 Avant, Testing The For Sale Waters
- WTB 1 18" Sline wheel. Anyone?
- Bad C6 day.
- What should I expect to pay for an 05-08?
- Bad gas mileage these past two weeks?
- Interior light problem. video. inside
- a forum for all the WTF car moments mechanics see
- 2013 Navigation Update By AudiNav
- Trans Behavior In Cold Weather. Quirky or sign of impending problem?
- I was on here a while back talking about a future BBK. The future is here.
- Oil leak question in 2005 audi a6 c6
- Cold Weather - no start - some functions working
- Seat control plastic loose
- Convert from adaptive air to coil over
- Can't seem to find 'Stereo AUX IN' via Hidden Menu??
- power steering pump whinny when cold
- Plastic backing on the front seats has come unadhered. Best way to fix?
- CEL and Sea Foam
- Camshaft Position Sensor / Misfire Detected
- K&N E-0778 Air Filter Wanted
- Audi CPO transfer
- Stranded On The Side Of The Highway After 4 Days Of Ownership... What A Way To Start.
- 3.2Liter DTC P2006 Help Needed
- radio/cd/sat radio shuts off
- Purchase pending - Advice needed
- C6 A6: Rear window regulator removal
- third oil leak
- Audi a6 4f CD Changer
- 2005 A6 3.2 FSI Timing Chain Tensioner
- Watching DVD on MMI? 2008
- New Ride And Goodbye To An Old Friend...
- car sensor
- 2008 avant MMI bluetooth question
- DIY Oil Change - Oil porthole
- XCarlink and MMI Control unit for cheap
- 2001 a6 4.2 under dash wiring
- Time to Treat Yourself - 15% off and Free Shipping over $50 - Happy New Year!
- Audi A6 features decoder
- vag com help in Houston area???
- vehicle takes more then five cranks to start
- reading light on top problem
- A6 C6 Front Bumper Upgrade question
- 2007 s6 part out.
- bnk = no carbon
- my 06 3.2 just got totaled
- MMI update cds
- Chain rattle worse on cold days
- Question on shocks in 2005 audi a6
- Passenger Side Running Light Replacement
- Problrms engaging reverse.
- Engine Vacuum pump question please
- Possible C6 purchase, any year I should stay away from?
- 200,000 mile club
- OBD2 Port: where ???
- 2007 A6Q Front Upper and Lower Control Arm Replacement
- Intermittent Loss of Keyless connectivity
- Annoying creaking sound when opening glove box
- Backup camera not working
- front oil leak
- What is the button on the steering column for?
- A6 control arm labor cost
- My new ride
- amp faillure
- would a D3 S8 steering wheel fit a 08 A6?
- optical bus problem
