PDA
View Full Version : A6 / S6 (C6 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85
  1. Vin
  2. 2008 A6 Rear Sunshade Switch
  3. Fuel injector removal headaches... desperately need help.
  4. Torque specs hard to find
  5. Electronic parking break really loud on 2005 A6
  6. ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - Aug 28th - Sept 4th, 2017***
  7. Source and/or name for random bits on Audi
  8. Trans shutter/ vibration '12 S5 cabriolet 45k
  9. Crank Sensor Location 08 A6
  10. Interesting Link on Air Filters Stock vs Aftermarket
  11. Removing front fender / bumper
  12. Suspension height level sensor
  13. Fuel injector o-rings...
  14. AC Problems
  15. 2006 Audi A6 V8 Coolant drain plug location?
  16. Need a rundown of different MMI versions available, please.
  17. Clearing Error Codes or not?
  18. HID headlight issues
  19. Battery location
  20. Air bag
  21. Transmission problem
  22. What transmission fluid to buy for 2005 Audi A6
  23. H&R Sway Bars
  24. coilpacks
  25. Clockspring help please
  26. 2005 A6 A/C question. Lots of hot air...
  27. Left and Right engine mounts... OEM or Aftermarket?
  28. MMI Software version ok?
  29. VAGcom tool used on EPB, now drains battery!
  30. Blurred side mirror
  31. Looking for torque values
  32. Left Engine Mount Solenoid Valve?
  33. brakes
  34. Air Suspension failure
  35. 2009 C6 3.0 TFSI inlet swirl flap issues
  36. Fuel warning signals
  37. A6 pcv
  38. battery for a6
  39. MMI Power switch
  40. Driving lights on, head lights go off
  41. Gas Tank System Malfunction - Contact Workshop
  42. My Audi Car Stereo
  43. Battery replacement and computer reset
  44. Fuel Lid opens everytime a door is unlocked?
  45. MMI problems
  46. Color code of brown interior
  47. Negative Camber - springs
  48. transmission fluid change
  49. Low Oil Level Light- Faulty Sensor?
  50. Help with vacuum line
  51. Removing the strut tower plastic cover A3 8p sportback.1.4
  52. Removing the strut tower plastic cover
  53. Parking brake malfunction light/ trans popped into neutral.
  54. Rear coil spring removal
  55. generator or vehicle electrical system
  56. How much is standard off MSRP??
  57. Audi A6 2.7 Wheels Size - Need help!
  58. Transmision
  59. 05 4.2L Random Multiple Misfires on all but Cyl 4
  60. OIL AND MISFIRE #2
  61. 2004 A6 3.0 Quattro rear passenger window tilts
  62. Where Can I Find Fog Light Wiring
  63. Brake fluid reservoir filter
  64. ORIGINAL WINDOW STICKER
  65. Bent Valves or worse???
  66. Audi a6 error P1883
  67. after market rear view camera installation guide for Audi A6 2012
  68. Cylinder 3 misfire & ABS issue related?
  69. 2006a6 3.2 won't start after changing chain tensioner
  70. Rear Jack Stands.
  71. Anyone know.
  72. audi a6 3.2 2008 front wheel drive s-line model
  73. electronic park brake
  74. Parking Brake Malfunction
  75. My recent experience with carbon build up for those looking to dive in...
  76. Installing Navigation.. need help
  77. Hybrid TV (DVB-T) Tuner and Video Input for MMI 2G (HIGH)
  78. Heating / AC not working
  79. Sun Visor Light Not Working on Drivers side
  80. Fog Light Wiring Ripped, Any Way To Replace At Home
  81. Resetting My Audi A5 Service Reminder
  82. Does Audi do PPI's and what's the average cost?
  83. Replaced fresh air fan but fan seems under powered
  84. Camshaft bank postion fault
  85. magnaflow exhaust
  86. Electric Windows
  87. Suspension Replacement Options
  88. A6 2010 2.0T START SIGNAL...
  89. Level control system module (J197) No Signal
  90. Alternator torque specs
  91. Does it exist a single mass flywheel for this car?
  92. Cylinder #4 cutting out ocassionaly - VCDS
  93. Gear box issues with Audi 6 Quattro 2016
  94. Locked out
  95. Do 2007 ( reg in Dec 07 ) have BLB engines???
  96. Timing chain tensioner covers leaking major!
  97. Audi Q5 wheel bolts
  98. The rad does what??!
  99. What colour to paint the centers
  100. Jack stand points on C6
  101. Putting c7 seats in a c6 sedan
  102. MMI Shutdown
  103. Phone not installed after update to 5570
  104. 3.2L Crank Pulley failure
  105. Hard to change gear
  106. European driving
  107. 2006 A6 Avant > What to lookout for
  108. Drone Captures of my 2005 A6 C6
  109. Vibrations when turning with AC on
  110. Charging battery.. jump points or battery posts?
  111. 3.2 removal thread anywhere?
  112. P2006, P2007 codes Audi A4 Quattro 2008
  113. 3.2 bank 1 exhaust cam adjuster intermittent failure
  114. 1995 a6 condenser replacement
  115. HELP Brake pad replacement turns into nightmare
  116. Is the US-spec Facelifted C6 S-Line bumper exactly the same as the EU-spec?
  117. A Nightmare quest
  118. 2011 A6 engine light
  119. Replacing Front Subframe: 2009 A6 Avant
  120. Need help locating rear Parking Buzzer on Q5 model 2009
  121. Need help locating rear Parking Buzzer on Q5 model 2009
  122. 3.0T motor investigated?
  123. Audi a6 c6 2006 mmi replace with audi a6 c6 2011
  124. Weird noise from driver foot well at idle is it my exaust?
  125. Audi A6
  126. Very high RPM upon startup
  127. 2006 A6 - trick to get at wiper motor?
  128. Audi A4,2.6 V6 Auto cuts out after 5 days
  129. Water on trunk curtain
  130. Battery replacement in 2012 A-6
  131. 2009 A6 CEL: check air intake hoses
  132. Flashing warning lamps
  133. Tires
  134. Climate Control - warm air when set to Low
  135. turbo fault codes
  136. Battery - Load Test failed
  137. Safe mode
  138. A6 3.2.. my AC are not coming up and my radio volume control is on silent mode.
  139. Murray brown
  140. both hot and cold coming out dif vents in hot weather with A/C on
  141. Address 72: Door, Rear Right
  142. 2009 Audi A4 Airbag light
  143. SQUEAKER: 08 Audi A6 Avant
  144. X-Pipe instead of factory resonators
  145. Broken vacuum hose
  146. White Smoke
  147. Cold light throttle mild surging
  148. 2008 S6 Blower Motor Location
  149. Oil leak issue with 2005 Audi A6
  150. 2004 A6 S-Line 2.7t quattro secondary air system
  151. New stem seals or used engine?
  152. ABT rear defuser
  153. Washington DC people here?
  154. TCM Wiring Harness - Terminal Release Tool
  155. Audi A6 (C6) Avant 2.0 TDI Air Con Compressor Replacement Assistance
  156. Bose amp questions
  157. GSZ differential fluid
  158. Wheel paddles on D and S mode
  159. Anybody have a front license plate mount for an 05 for sale?
  160. Recommendation for Exhaust System Please
  161. $200-225 to replace a flex pipe sound right?
  162. A6 C6 trepidation while braking/uneven grip
  163. Mobility Vehicle- Not For Retail Sale
  164. Does 2009 Audi A6 had Mechatronics sealing sleeve or something like that?
  165. Weird throttle movement
  166. how do you safely remove residual gasket?
  167. Should I by a 2005 A6 with 98k Miles?
  168. 20bhp Upgrade
  169. A6 C6_air con not working
  170. Skid plate group buy (long shot)
  171. How to Un-mute radio
  172. MMI and console lights stopped working
  173. Another blower fan question/issue..
  174. [HELP!] Cooling Fan Stays On After Start Up.
  175. what is the serial number of the new battery
  176. p2404 engine turns off when driving&start up need help
  177. MMI panel and Soy Sauce !
  178. 4.2 Electric Cooling Fans
  179. performance chipping 04 2.7T Q auto
  180. Tuner in Michigan?
  181. 2008 s6 5.2l v10 is getting a tick in the intake manifold.
  182. Recommendation for mechanic near Stamford, CT please
  183. headlight rubber around headlights
  184. 3 Ring spark Plug Gasket
  185. 2005 A6 Transmission Issues - how hard is a Tip trans swap?
  186. 2007 a6 timing belts ?
  187. Newb Question
  188. Water pump/Thermostat
  189. which ignition coil to buy?
  190. Ran out of gas...now it won't start
  191. ESP Fault, P3028 error code
  192. ESP Fault, P3028 error code
  193. A6 4F C6 Long coding problem
  194. Passenger side rear turn signal intermittently working
  195. 12V Switched Power
  196. Parking brake malfunction with esp/abs on
  197. Thinking about Upgrades for Summer
  198. Bank 1 "P0014-008" code intermittent
  199. Questions about selling a car
  200. 2007 A6 3.2 stalls when pushing gas
  201. Adventure to get my new 2007 A6 Avant
  202. Front Bumper
  203. Getting a 2008 A4 S-Line Convertible for FREE!
  204. Test Vehicle needed!
  205. Avant Windshield Washer Pump
  206. Here I go again looking at a 2006 A6 Avant!
  207. Ignition switched conneciton in the trunk?
  208. Oil pan gasket?
  209. Front driver-side lights won't turn on after minor collision
  210. 3.2 Magnetic crankcase drain plug size
  211. Over voltage / ABS ESP Audi A6 2006
  212. middle brake light works, other 2 do not!
  213. 2006 Audi A6 Parasitic draws
  214. Oil Consumption in 2009 Audi A6 (2017)
  215. N00b here with a new-to-me A6 Avant 3.0T
  216. which cd type do i use
  217. Aftermarket Bluetooth via FM Mod (iSimple Product)
  218. What sensor is this
  219. Bringing drivers side back in proper time?
  220. USA - 2010 A6 Prestige Sedan 3g High MMI help needed. No sound!
  221. 2006 Audi A6 Quattro...battery is good...car won't turn over & is locked in park..
  222. 2006 A6 Slugish
  223. Poly snub mount effects?
  224. P0106 code
  225. A6 3.2 Intake Cam 31 degrees!
  226. 2010 Avant - checking for NAV cable in C pillar
  227. A8L 2010
  228. tiptronic problem...help
  229. Front Control Arm Replacement Kits
  230. New here ..
  231. 3rd brake light
  232. A6 4F MMI 2G High update?
  233. Fixed Nav, at least I thought I did...
  234. 2005 Audi A6 3.2 TFSI
  235. Weird Factory Nav Problem: Main Map Frozen
  236. 2011 AUDI A6- steering column failure car automatically applies parking breaks
  237. 4F0.863.822A Under Car Shield
  238. 2008 Audi A6 DRL
  239. '02 A6 Quattro 2.7t need to get rid of
  240. 2007 A6 3.2 oil leak test suggestions
  241. Aftermarket wheel offset and size question
  242. parking brake malfunction error
  243. Remove back seat to do fuel system cleaning?
  244. Balance shaft oil seals
  245. 2009 led trunk light?
  246. Need Help with Fault codes.
  247. Audi A6, what is included with monthly maintenance?
  248. What is involved in swap 3.2 engine for 4.2 a6 c6
  249. reasonability check 2008 A6 repairs
  250. Torque converter disconnection from engine?
