- G395 Signal Implausible ‘06 A6 AC INOP.
- Feels like I'm being held back when accelerating
- P1129 & P0430
- Ticking Sound - Engine A6 C6 4.2 2005
- 07 S6, B1S1 and B2S1 Rich/lean code
- A6 C6 - removing annoying warning beep?
- Trynna figure out a way to make my exhaust and supercharger louder
- Audi A6 C6 2.0 TDI Question
- MMI went down!!
- 4.2L Oil cooler o-ring replacement
- question for moderator
- Engine cover rings missing
- 2007 S-Line Front Bumper
- Excessive oil consumption
- 2009 LCI facelift MMI dead, cd changer working no radio, help needed please
- Audi a6 2009 3.0TDI misterious buzzing/grinding sound
- More Transmission Seal Issues
- 3.0T intake issues
- V4.2 A6C6 Replacement Lamp for headlight?
- Center seatbelt stuck
- 2010 A6 Avant mysterious high speed braking issue
- 2008 Audi a6
- 2016 A6 2.0T Premium Plus
- What the best settings for ac to blow the coldest air
- FOB desync problem
- Interpreting tiptronic adaptation values - what is your gearbox telling you?
- V157 fuse help on C6 diesel avant
- Front license plate mount
- Audi A6 - C6 - Door Coding
- Are all A6 C6 front grills the same?
- Original Window Label/Sticker (Monroney Label)
- 4.2 V8 (MPI) with 190A Alternator
- Flex pipe messurments on a6 c6 2.4
- no high pressure on the rail (agian)
- Aftermarket bumper covers, any good?
- Battery not holding charge
- 2007 a6 Bluetooth options
- S6 whistling noise driving me crazy
- Lots of HVAC codes
- 2006 4.2 a6 intermittent starting problem
- Trailer hitch - car breaklights always on
- Code reader/diagnostics
- Window Adaptation
- Remove / Replace side mirror housing?
- Passenger Mirror not responding
- Noise from Front Right Side of Engine
- MMI2 update.. which CD first?
- 2007 S6 AC problem - Hot air!
- New wheel question - possible problems going from ET43 to ET25?
- DPF serious issue and driving in limp mode
- Audi a6 2007 center console switch
- Muffler options?
- 2006 A6 All Road - MMI ruined by leak.
- How to use Air Conditioning?
- 2006 body same as 2011?
- Interior lights
- 2005 A6 3.2 Purchase Opinions
- C6 S6 cooling fan issues + other problems
- 3.0T: A6 OIL BURNING
- Uberlame TSB library offline
- 2005 Audi A6 Carbon Cleaning Attempt (Video)
- Transmission type?
- AC no longer cold. DIY fix or need a pro shop?
- Front speakers keep blowing
- Weird electrical issues
- Stuttering during hard acceleration
- Anyone else just stare at their car...
- 2007 S6 Coolant Leak
- Tranny swapping between 05 n 09
- Audi a6 2006 wont start after checking the fuses HELP
- Aftermarket headlights?
- factory roof rack measurement please
- 2005 Audi A6 3.2
- wondering how those that used atf ford mercon sp doing?
- The sub $5000 A6 Avant S-Line
- Replacing Rear Subframe: 2009 Audi A6 Avant
- 2006 A6 4.2l getting P0171 intermittenly
- Best diagnostic software & key programer
- 2008 A6 4.2 codes P2004 and P2005
- 06 A6 3.2 ltr Cam Follower have a break in period ?
- 2007 A6 c6 body/engine mods
- 2008 A6 Rear Coil Springs... Completely Lost
- Aftermarket Tire Sensors
- Hi everyone help needed
- 2009 A6 2.0TDI Advice
- Fog light cover honeycomb
- Changing serpentine belt in 2008 4.2
- Mysterious disappearing vibrations at 140 km/h - common C6 problem
- C6 Allroad - 06 suspension problems
- OEM grill filler piece vs. New (china) RS6 Style Grill
- Brake Upgrade Recommendations
- Help.....2006 Quattro,3.2 liter, HWD Transmission slipping problem and other code iss
- Daytime running light on my C6
- AC blowing warm air (2008 A6 4.2)
- 2005 Audi A6 Front Strut Replacement (Video)
- Accelerator sticking problem
- Lowering springs
- Found this in driver's footwell
- 2007 Audi A6 3.2l muffler delete check engine light
- Music on mmi2g
- Xtool Vag401 uses?
- Tail light fault
- Merc C320 vs Audi A6
- Audi A6 C6 3.0T Problem
- Audi A6 2009 FL - Replace trunk rear fog bulb
- fold rear seats in Audi A6 2006?
- Steering Rack bolt
- MAF sensor unplugged?
- Tiptronic transmission problem
- DIY painting MMI unit?
- 3.0T: Cold air intake/ heat shield ?
- S6 2007 Car don't move doesn't change gear + water/oil mix in transmission & coolant
- 2005 C6 Power Steering Flush
- Retro fitting Heated seats trouble & coding HVAC
- "ANTENNA" message for Sirius 2007 A6
- transmission stopped working
- where can i find updated MMI software to current version
- Why would Y speed rating cost less than V speed rating?
- Updated Injectors for the 3.2?
- 2007 S6 - stiff power steering
- Headlight
- Anyone used these Brembo brake pads before?
- 2004 Audi A6S 2.7 Quattro - Exhuast Question
- A6 C6 Avant - full option dash
- S6 V10 engine misfires - low cost solution
- Bad readings? Timing chain
- Audi A6 2007 RS6 Grill
- Rear bottoms out after some hours
- Instrumental cluster
- cup holder replacement
- 08 A6 crank but won’t start
- Stuck tow hitch
- A/C Schrader Valve - How do you replace?
- audi a6 crank but doesn't start
- 2013 a6 prestige with no paddles?
- Should I change my transmission fluid? 2005 3.2 with 206k miles
- Audi a6 heater control valve problem.
- 02646 air suspension problem
- No crank
- 2008 A6 4.2 Camshaft position sensor connector
- MMI
- Interior lights don't work when ignition on... but they work with the doors open
- Remote key transponder problem
- Headlights
- VCDS Modules cannot be reached, many errors
- A6 4.2 auto bucking in 1st
- LED tail lamp dim
- Non genuine parking sensors
- vag com
- UK: V6 tdi 2.7 smoking. Advice please!
- 2008 Audi A6/C6 4.2: P0014 and P000B
- sometimes car won't start
- adding RVC to a Dension 500 06 A6
- Wiring
- 2003 A4 3.0 loss of power
- Bluetooth issue
- Engine misfires when cold
- Shopping for Audi, any way to know which cars have what features?
- control module??
- Fog light
- Bluetooth Pairing Problem
- Best All-Season tires ?
- P0300 & P1129
- No crank after timing tensioner fix
- Another Audi AMI Bluetooth option
- Thoughts on if I should buy this 2008 Audi A6 S line or not..
- 2010 A6 quatro MAP sensor location?
- Hitch
- Which mode fastest with tiptronic
- Just bought a 2016 Audi A6 3.0TDI with 28,000 miles - Is something wrong with it?
- Front bumper
- “Pinch bolt” Best remedies for MN car
- A6 2008 front wheel bearings
- Rear Wiper Quattro vs Wagon
- RS: ESP Fault!!! See owners manual!
- Should I buy a used 2006 A6 with 120k miles?
- 3.2 Head gasket replacement Help
- Triple Whammy?
- Adding navigation?
- Engine doesn't start
- Audi S6 C6 esp failure
- Question on Siren Module 2005 Audi A6
- Headlight replacement LED 2010 A6 Avant
- HVAC codes
- WTH is the Head gasket Arcs
- Coolant pump/serpentine belt HELP!
- Control arm replacement - best brand choice 08 A6 4.2
- What exactly does this resonator do?
- P2006 Error code/Black soot buildup
- Replacing Steering Wheel-need VAGCOM?
- Intake manifold runner stuck closed c6 s6
- A6 4f 2.0TDi BRE engine - random not starting on first attempt
- 2008 FWD Audi A6 MMI Nav and AUX
- 2006 A6 Avant key stuck in ignition
- New A6/C6 Quattro owner with question
- 3.0TDI Oil Issues?
- Audi A6 C6 error code P0172 P0175 P2006 P2007
- Tiptronic coding VCDS
- Installed honeycomb grill
- Newly (self) painted door blades
- Sunroof part
- 2010 Audi A6 Wagon
- 2005 Audi A6 Sound Static Fix (Video)
- Prospects on Higher Mileage 3.0T
- 2018 Audi 3.0T Sport
- Color DIS startup screen
- a bunch of warnings, left side? [2008 A6]
- 2005 Audi A6 Vacuum Pump Maintenance (Video)
- Audi 3.2 FSI Common Vacuum Line Failure Fix (Video)
- 2005 Audi A6 LED Tail Light Replacement (Video)
- Moving to C7 forum
- Air suspension fix/conversion
- 2006 4.2 hose ??
- Sounds like a horse galloping in my vents
- Audi Dealer using BG Products
- Headlight / Tail Light C6.5 retro to C6 knowledge
- wheel offset question
- 2005 Audi A6 CV Boot Replacement (Video)
- Supercharger oil change
- Uncommon vibration during breaking.
- Dealer Timing chain and tensioner replacement in 2018 ?
- Cylinder 3 Contribution/Balance P0269 and Misfire P0303
- Pedal AT for C6 2005
- AMI Issues
- No Vrooom Vrooommm from my 06 A6 4.2 - Crosspost from Audizine
- Possible Brake Booster 2008 Audi A6 Quattro
- Cracked Hose / Vacuum Line CEL
- Paddle Shifter spring bent - options to replace? '08 A6 S-Line
- Which tranny fluid do I use?
- Engine Air Filter
- MMI 2G High - iOS 12 - Phonebook
- AMI - always compatible with MMI 2G High?
- 4.2 fsi, new motor-now cooling fans turn on randomly with vehicle off
- 2009 A6 passenger door latch, and water pump at 75k mile service
- 2007 S6 driver door latch failing
- Under Body/Under Tray/Baffle/Belly Pan...
- How to keep coil connections tight
- A6 C6 - lights on after opening the car?
- 2006 Audi A6 3.2 Quattro (u.s) MMI SCREEN ISSUE
- Parking Brake Not Working
- Third brake light not working
- Grill replacement
- A6 2009 C6 3.0 Transmission Swap KKT vs KKT-4K
- 4F0616013 location
- p0341 and p0366 2008 Audi A6 3.2quattro
- Best Tires for Daily Use
- Help!!!!
- Running odd / rough - PCV or PRV issue?
- 2006 A6 no start
