PDA
View Full Version : TDI Discussion
Pages : 1 [2] 3
  1. 2016 Q5 TDI Lemon Buyback with AofA
  2. Injection pump timing under acceleration
  3. NO: Bleeding fuel system 2.5tdi
  4. Glow Plug Lit Up and No Power
  5. Q5-tdi
  6. 2014 Q5 TDI adblue
  7. A3 2.0 16V 103kW (2010) - Noise when engine is cold
  8. Ever wonder where your bought back TDI went?
  9. Used Q5 TDI with few miles added since 2016?
  10. DPF Clogged
  11. Busted sump 03 1.9 tdi
  12. Audi A3 8p Quattro 140hp Engines?
  13. California Lemon law ?
  14. TDI's being released for sale by VW group
  15. audi 3.0tdi make knocking noise when start driving gold engine
  16. Q5 2.0tdi 2015 Whining noise
  17. p3085
  18. Audi A6 avant 2007 2.0 TDI 136HP
  19. 2.5 tdi 132kw Quattro fuel pump
  20. 2.0 TDI, CAGA, B8 cold start problems
  21. Audi A4 2.0 TDI with unsprung clutch
  22. TDI Settlement question
  23. DPF / No DPF?
  24. Audi A3 8P1 2.0TDI 140hp BMM vibrations and shakes!!!
  25. UK: 2016 a6 tdi manual shuddering after driving for 1 hour
  26. buy a non-fixed TDI?
  27. TDI vs Gas
  28. 2.5 TDI AEL/AAT - set injection timing?
  29. Audi A3 1.6 TDI strange noise ?
  30. Sweden: Starting problem A4 2009 3.0 tdi Quattro
  31. Audi A6 2.5TDI 132kW Quattro coolant volume
  32. Glow Plug System warning light/loss of power
  33. Audi A7 3.0 TDI Questions
  34. Degraded fuel economy on fixed 3.0 liters
  35. Surprising Arrogance and Incompetence From TDI Settlement Office
  36. Audi 3.0 TDI v6 vs. Mercedes V6 Bluetec Diesels
  37. How many Psi (or mBar) is the turbo pressure in 1.9PDTDI motor (AVF)?
  38. How is the 3.0 TDI? I would like to hear from some high mileage people
  39. 1994 80 Avant 1,9TDI missing oil
  40. Audi A4 B8 8K cooling system explanation
  41. p229f code
  42. q7 3.0 tdi 2011 CLATTER
  43. Audi A4 B7 1,9tdi Delay in Start when turning over
  44. A6 diesel: Serpentine belt breaking. Cant find answer
  45. 1996 1.9 TDi (90 bhp) running cool
  46. 2.0 TDI Intake Air Temperature Sensor Location
  47. Audi A6 2.0TDI S-tronic (190PS) turbine problem
  48. Q7 oil mixing with diesel
  49. Gearbox problem(?)
  50. Engine mount bracket
  51. 2.0 TDI rough idle solved
  52. 2003 ake 2.5 tdi cam caps
  53. Glow Plug Light Flashing 1 Week After Cambelt Change?
  54. surprised there isn't a thread just for TDI debacle...
  55. "Strong Demand For TDIs"
  56. jerking when slowing down to a stop
  57. Brisk Sales of Modified 2015 VW TDIs
  58. Audi Q5
  59. Did any VW owners do buybacks on cars with electronic issues?
  60. Any Q7 owners returned under buyback yet?
  61. 2014 Q7 TDI w/55K miles
  62. AUDI A5 1.8 error code help
  63. Beware The Approved TDI Modification
  64. Do It Yourself AD Blue DEF Refilling
  65. VWAG TDI Buy-Backs Eligible For Sales Tax Refund In Texas
  66. 1.9 TDI B6 Jerking then eventually limp mode
  67. audi a4 b5 1.9 tdi
  68. Bosch 2.0 TDI Settlement Announced
  69. OBDLink usable gauges (including DEF tank gauge?)
  70. Bosch Settlement
  71. Allroad Injector Pump Coding / Adaptation & the Immo III SKC
  72. 3.0 Liter TDI Update
  73. how to tell if 150 kw or 180 kw
  74. White smoke problem
  75. Stripping TDI Buybacks
  76. FUEL READING
  77. A3 1.6TDI 2016 COOLANT WATER LOSS
  78. What is this part called? Audi Q5 tdi 3.0
  79. PROBLEMS!!
  80. 5 Reasons to Choose the TDI Version
  81. 14' Q5 3.0 TDI
  82. 2012 A6 ECU troubles
  83. Buy a 2014 A6 TDI?
  84. 2.5 TDI allroad 2002 AKE (tiptronic) slow acceleration, ppor power
  85. A4 - Oil Leak
  86. 2.5 TDI allroad 2002 AKE glow plugs curve
  87. Bad 3.2 engine replacement with TDI?
  88. OBDLink "Catalyst temp" as a proxy for EGT?
  89. Audi a4 b7 2,0 tdi 140
  90. TDI - The fraud that was and still is...
  91. Audi A4 B8 O2 Sensor Signal P2196 Rich Bank1 Sensor 1 Too Rich
  92. Q7 starting issue
  93. 2T oil as an add to TDI with Common Rail
  94. Pressure Sensor/ Upper Intercooler Hose Help
  95. 2011 Q7 TDI Particulate Filter Replacement
  96. RPM Problem
  97. Q 7 injectors nightmare
  98. solve this.. trends and obs for slow start 3.0 TDI
  99. 3.0 TDI Ultra V6 - Where is Boost Pressure Sensor
  100. Increased exhaust noise and unsteady revs at constant throttle
  101. 15k Service....
  102. Analysts Reverse Engineer VW TDI Engine Module
  103. 3.0L TDI now added to the EPA investigation
  104. Engine problems
  105. What does these really mean and do I care?
  106. TDI Horse Power, UK vs USA
  107. My a3 is struggling to start from cold
  108. A6 c6 TDI Avant - high pitched squeak
  109. Flat battery
  110. Audi 2.5 TDI valve seals replacement / hydraulic lifter / camshaft replacing / cylind
  111. Audi A6 2002 1,9 TDI 130 bhp
  112. Audi q7 radiator fan runs all the Time ....?
  113. Overheated brake smell
  114. Audi have successfully made diesel fuel from carbon dioxide and water
  115. Audi A4 Avant 2011 2.0 TDI, vibration on speed 40kph
  116. n00bert tdi q's (I know,sorry)
  117. Engine temperature
  118. does Anyone know falut code on q7 tdi?
  119. 2009 audi q7 tdi check engine on
  120. adblue refill light / quantity
  121. 2008 Audi A6 estate 2.0 TDI Engine issues ?
  122. 2,5Tdi v6 issue
  123. A4 2.0 tdi information please
  124. newbie - advice on Audi A6
  125. Help HELP: Audi A6 2.0 TDI 2007 Model, slow kick down, black smoke DPF removal Remap
  126. Biodiesel - still an issue?
  127. Where are the glow plugs on the 2.5 tdi ?
  128. Advices with 2.5 V6 TDI
  129. 2013 Q7 TDI won't start in cold - help a rookie
  130. If someone need I have for sale Audi swirl flaps 2.7TDI or 3.0TDI
  131. anyone remove a DPF
  132. Starter motor help ASAP
  133. Advices / Experiencies with the V6 3.0 TDi engine !
  134. Hard Steering when hard brake
  135. 3.0L TDI in a 2008 A6 Avant
  136. Glow Plugs Maintenance
  137. cams and timing
  138. A6 2,7 tdi - turbo fault? (actuator)
  139. adjusting vnt on a 99 2,5 tdi afb
  140. chip tuning 2,5 tdi v6
  141. 2014 Audi A6, A7 and Q5 TDI diesel models
  142. Audi Tdi Help in NJ
  143. G28 sensor position on 2.0TDI
  144. Info on Q7 V12 TDI
  145. Please Help on Error Code P2108
  146. 3.0 assembly origin
  147. engine change
  148. AD BLU OR BLUE DEF-DIFFERENT?
  149. Coolant leak
  150. 2.5 L v6 oil breather
  151. engine knocking
  152. Nuw to Turbo, Diesel and Audi--Got driving suggestions, etc.?
  153. Oil Warning Light Mystery
  154. 2.5 timing issue
  155. 2.5 tdi camshafts question
  156. Looking to buy
  157. many problems with 2.5 tdi afb
  158. 2002 Passat 1.9TDI
  159. Problems with high revs
  160. fuel filter
  161. Warning Light Question - Glow Plug/Loss of Power
  162. Losing power during acceleration
  163. Cold TDI constantly changing down when cold?
  164. TDI engine drops out on starting
  165. APTuning Garage Sale - Low Miles Engines, Trans, Seats and Misc parts!!!
  166. Allroad 2.5 tdi camshaft broken at 64,000 miles - why?
  167. starting issue
  168. Oil buying site
  169. what mileage has your 2.0 diesel BLB engine done
  170. C6 Avant Allroad diesel seen in OH
  171. New Audi diesels for U.S.
  172. shaking on very hot day when try moving
  173. So Cal TDI Roll Call
  174. Audi Q7 3.0 TDI & AdBlue
  175. VSS (vehicle speed sensor)
  176. AdBlue Additions
  177. A6 TDi Hesitation
  178. Oil pump wrecks my engine
  179. BMW Diesel MisFueling Protection Bypass Adapter
  180. AdBlue Discussion
  181. Temperature
  182. Adblue Question
  183. Q7 TDI Oil
  184. Engine Diagram Audi A4 2.0TDI 2005
  185. Clutch noise.... i think!
  186. AdBlue Distance or Consumption
  187. Knocking engine
  188. When will AoA expand the TDI offering
  189. wanted V12 TDI engine
  190. DIY AdBlue... Adapting reduciing agent tank...
  191. nobody home
  192. 2011 Audi a4 TDI probable if not in 2012
  193. October US intro date for A3 TDI?
  194. Audi A4 Black smoke
  195. 2.5 TDI Fails to start
  196. Engine issues A4 tdi -98
  197. Clean Diesel televison Ad spots -Sunday AM shows, etc
  198. MY10 A3 TDI rollout date
  199. Audi A3 TDI specific reviews, FAQ, and buying checklist
  200. Q5 3.0 TDI
  201. A4 Diesel
  202. Average MPG from TDI engine
  203. Bump?
  204. Does anyone have TB tools I can borrow?
  205. Diesel to be lower than gasoline by April
  206. Diesel prices keep falling ...
  207. A3 TDi for North America :)
  208. Any news on A5 TDI?
  209. Crazy thought. But this "Clean Diesel etc etc"
  210. Audi 1.9TDI 4 cylinder
  211. Introducing BMW Advanced Diesel.
  212. Diesel Quality
  213. A3 2.0 TDI hard starting when hot
  214. BP Ultimate Diesel Live Forum
  215. 2009 A4 Avant 2.0 TDI in New Jersey
  216. http://www.audimileagemarathon.com/
  217. spotted an A6 3.0TDI in Ardmore, PA today
  218. TDI real world mpg
  219. what do peoples revs read on idle?
  220. A4 3.0TDI versus S4
  221. Basic seting for turbo charger
  222. 170 HP/125 KW 2.0 TDI
  223. 225000+ miles....anybody else?
  224. ECU tuning for 06 Jetta TDI?
  225. I'm sure you've seen this but just in case...
  226. '93 Eurovan 5sp TDi conversion possibilities
  227. I drove a 2.0 Jetta Tdi Yesterday
  228. Diesel $5.09 in Stamford
  229. When will the tdi s be state side and which models will be offered with this offering
  230. 4.0 TDI: Black smoke on acceleration.
  231. TDI convoy in LA
  232. Anyone running a chippped 180bhp 2.5tdi? worth it or not?
  233. Anyone have an idea on support for B100 in Audi's new TDIs?
  234. Diesel now $4.59 here in CT, up 30 cents overnight
  235. The 4K TD is rolling again after a winter's contemplation slumbering in the shop
  236. Great article on A3 TDI vs. Prius.
  237. Mercedes may sue Audi over Bluetec
  238. Estimated price of B8 A4 TDI?
  239. Frustration
  240. TT TDI
  241. TDI in the US
  242. price jump overnight- $3.77 to $4.17
  243. Questions for the TDI gurus....
  244. Its getting closer
  245. Sporty TDI?
  246. TDI In Massachusetts
  247. 4.2 TDI startup and engine idle
  248. 3.0 TDI Startup and engine idle
  249. 3.0 V6 Tdi Opinions/Info Request
  250. Listen to sweet sound of that 3.0 TDI (pity about music)
