- How do you replace the the retaining clip for the sun visor?
- Found my next few mods..
- whats this hose??
- Hey guys, it's been a while...
- Paging Avanteix.....guru of anything Avant trim related.
- Vibrating shifter
- Funny smell on startup - anyone else had this happen?
- i want an S3!
- The Tool!
- Can anyone give me the part # on the anti-theft horn in the trunk?
- Semi rant: I worked from home today so...
- Ebay body kit
- Anyone have a set of OEM Ultrasport wheels (RS4)? Im looking to buy
- on the H-sport sway bars - are the caps on the grease outlets supposed to be open or closed?
- B7 loaner car (short review)...
- MC Hammered got the pod! wohoo! k, can't find your detailed instructions on how to install it
- Need help from Avant owners.
- If you carry spare coilpacks... how to get the bad ones replaced for free if you are under warranty.
- Ecode City Light Bulbs
- ECS, what has happened to you guys?
- One segment of 3rd brake light out. anyone got bulb # and difficulty (time) to install
- Fuel injector cleaner
- Battery connected hose
- x post from the zine. ECS Stg 4 BBK problems.......
- Has anyone...
- Locked Keys in Trunk....
- Brake light on...will i expect dealer to change back pads and all rotors under warranty?
- Very close to pulling the trigger on a Stoptech 332 brake upgrade...
- Coolant Tank Problem: Part Number or/and Advice
- New S8 wheels...
- B6s in Rochester NY
- Problem fitting Audi Center Caps to HP EVO Wheels - Too Small :S
- I'm popping coilpacks like balloons!
- I forgot who wanted pics of my red Momo shift boot with more interior shown but here they are
- To all with chipped rides. Do you put it in stock mode everytime...
- need replacement caps for RS4 rims
- SPP Special on Neuspeed Short Shifter!
- SPP Neuspeed Exhaust Special!
- Anyone GIAC fxk04 with factory clutch - for awhile?
- Windows won't work with remote anymore after I disconnected the battery.
- PW: I have way more posts then Scott had last year on the B6 forum last year and we still
- Would you be pissed if someone went joy-riding in your car for 4 days...?
- My temperature gauge froze at 79 degrees today....
- anyone know where I can buy a pair of B6 A4 Sparco rails?
- Anyone know about how much travel you have until you hit the bump stops?
- For the weekday crowd that missed my post: "What does my 3.0 look like debadged?". Here you go.
- Look what just arrived!
- Hit big 50 today
- no, I think it's spend $50 to get a semi-decent jack
- Rear Coil Spring Removal
- Paging Diagnosticator -- **update** DV "leak" question
- Anyone running a 245/35 19s set up on 04' A4 Avant 1.8T UltraSport with Stasis Street Suspension?
- x post from AZ GTRS a4 vs. M3....pretty cool vid
- what does it say when fog light bulbs say wattage (draw) 55watt....wattage (output) 130watt
- poll: paint my usp wheels black? yes or no.
- Has this ever happened to you?
- ???Possible intake leak???
- Anyone interested in a Revo SPS2 ?
- Removing Front Ashtray - Help needed
- Blackout Lower Grille DIY Help
- Stock 15s tire size...anyone know off hand?
- Oil Change Help and Reccomendations
- plate options tell me which one looks best...just europlate isn't an option
- <rant>So I decide to finally clean my DV this afternoon, and the POS jack folds!!!
- painting the interior door handle
- Just finished puting in my H&R spings + bilstein shocks now i have a problem
- Suspension help..
- so day after my europlate install...im leaving for my vacation...get 10 min from my house and...
- DIY spring install
- DV question
- Lightweight Full-Sized Spare
- RNS-E and Rival Motorsport
- Anyone have the link for resistor fix on LED tails?..can't find that ****!
- Horn Troubles
- A4AdMan...Grilles question
- Doing brake bleed and clutch hydraulic flush?
- Help! Checklight came on and pulled the fault codes
- blackout grille on a silver car
- Engine misfiring at low RPMS in 1st and 2nd gear
- Ever wonder what my 3.0 would look like debadged? Well wonder no more.
- another pic of the side of my car
- X-Post from AW / Custom Sub box from A4Moda recieved today!!!
- Found a Bentley CD repair manual on Ebay...too bad I already have one. Could be a great deal.
- does the B6 A4 have an after-run pump? If so, then wouldn't that eliminate the need to cool the
- i have a whining sound coming from turbo i think?
- Big, bigger, biggest. Door blade pics for those who responded to the classified.
- HELP! Two episodes of flashing engine light!
- Just finished the H-Sport S4 sway bar install :)))))
- installing milltek non-resonated exhaust on a 3.0 - connector pipes the same?
- will these TT rims fit a 04' A4 sport
- Can we put this rear bumper on our b6s??
- Those with Rieger rear...where can i get more of the grill / screen that comes with it?
- Paging Fokai....
- Windshield wipers for A4 B6 2002
- Good deal? 2004 1.8T, CPO, 44k Miles
- Exaust Question
- Coilpacks - Stick with the B6 rev 'R' or try the Beru the B5A4 guys use?
- rear brakes
- Followup: "The rattle is gone!!!!!" I found the source and took a picture..
- installing a new ko4 tomarow any tips thanks
- Want your opinions. If I tint my tails should I go with....
- Can I use H-Sport S4 sways on my B6 or do I need the A4 application?
- Blitzsafe adaptor sub par performance
- K04 & Forge 007 - Yellow or Blue spring?
- So no resolution after all......more problems today.....
- Does ET43 work on our cars? To lazy to STFA
- Question about H-Sport S4 sway bars
- Anyone have an idea of what a Ross-Tech Key-USB VAG Cable is worth (besides tree fiddy)?
- Do i need shock absorbers or anythign else to install an S4 bumper?
- engine problem, blown turbo--> the cause is......
- I picked up my car yesterday...
- So I went into AWE today...
- Cool I just got a package from my parents... Audi Sport polo, Audi golf towel, and...
- don't miss the big WMS GTG/party this Sunday Aug 27th !! those in need of BBKs
- Exhaust Resonance (Somebody please help!!!!!)
- Trying to convince a friend to buy a B6 instead of a G35, please post pics of your nice modded B6's!
- Eurocode vs. ER testpipe
- 2 friends invited me to go to an AutoX with them this weekend....
- why do i have to wake up and see that someone hit my front bumper?
- WTF is a 'shooting brake'?.............
- Can these be bought at Pep Boys or Autozone etc?
- Which big break kit to upgrade on front A4 1.8T Quattro APR-Stage I?
- just about to leave for my vacation and realized my belly pan is hangin in the part...
- Does anyone know where to get 7.5X14.5 braided stainless steel fuel hose?
- K04 users - what boost levels are you seeing?
- Weighed the Avant at a truck stop this evening...
- So I fell in love today. To bad I am still married to my current love.
- MC Hammered YGM
- Left Front Turn Signal Out...(advice needed) TIA!
- 5G ballasts into Bixenon Housings - anyone have Jen's dremel pics?
- Extended warranty after 50,000 miles, worth it?
- anyone want to buy a nuespeed short shift kit i bought it for my b7 and they sent the wrong one ill
- post year and mileage and rough amount of $$ invested in mods (not maintanence) 2002 1.8t 60kmi $5k
- As Promised...(sorry for soft pics)
- anyone know how to join europrojectz?? whats the requirements?
- Just got the call, car is ready to go after 50k service...
- Engine Light
- question. right front passenger armrest, bottom of it, what is the hole for?
- Question regarding installation of rear bump stops...
- 02 1.8T Sport - Clunk if too fast over speed bump? Time for new suspension?
- What would you do? Dealership woes...
- Tennis Ball method for finding boost leaks - 1.8T
- DIY instructions for removing/installing a K03/K04 turbo
- question...
- Dealership told me USA put the cup holders in the car, cause Germany doesn't have them??
- Engine running rough
- thinking about an 02 1.8t 5 speed to 03 3.0 6 speed switch...can't decide
- i'm in a loaner for the day, the B7 A4 2.0t (my thoughts).........
- X-Post Pic Request: Phatbox installed in B6/B7 sedan.
- Anyone in/or around Toronto going to the ALMS/Speed Touring Car Sep 1-3 at Mosport?
- DIY BT: How much of a PITA is it to replace the in dash cup holder and the trunk power plug.
- my latest timeslip
- Need help finding a shop...some fool just hit my car >-O
- so which is more accurate in determining car's value - NADA or KBB?
- 51k DIY service and CPO
- APR K04 installed, first impressions and pinging issues
- Does anyone else get air out the defrost ducts (windshield) during Auto Mode on the Climate control
- ordered some new "mystery mods" for my baby...and just got done detailing it for 4hrs...
- Front Left Turn Signal Out...
- those of you with video ipods how do the black ones wear?? gonna buy one and i like the look of the
- Paging heateris: What were you doin' in my 'hood and ya didn't stop by?
- Car says SERVICE! when no service is due? Anyone else?
- EPC and ESP light came on while using cruise control and car went into limp mode...
- FYI: Wurth Silver & Merc 744 for stock wheels
- 2004 A4 3.0 Ultrasport with 45k miles... how much is it worth?
- GIAC FX Users and Potentials
- Video of the new R8 tested in the U.S.
- Any wheels that look striking on silver with unpainted lowers.
- Oil all over spark plugs!!!!
- New ECU, but dealership forgot to turn cruise control on...
- Brake pads BT: What are people liking for pad replacements?
- 2003 a4 avant rear bumper cover
- Speed channel euro gtg here...
- dipstick plastic cracked and pieces are in engine?
- diagnosticator....do you still like the Akebono brake pads you're running?
- Updated shots of my compleated front end lift, BWW
- Best Aftermarket Stereo for an A4?
- Off Topic, but interesting
- what do these symbols mean on my dash the mph one beeps
- what else could cause slight "clunk-age" underneath the car?
- could use some help with identifying a "clunk" noise coming from the rear suspension area
- Impromptu NorCal Audi Club Lunch in Santa Clara on FRIDAY (8/25/06)
- (Repost) a solution to keep your B6 look up to date or an Ultimate RS4 Wanabee Kit?
- In a twisted moment of irony, my car decided to die on me yesterday
- moving to SF/bay area; few questions
- Hit 40k today still on original front pads and rotors
- Whoever was interested in the Quattro plate frame please email again. I lost the original email
- Pics of my pedals as requested by quattrothatcould and MB...
- Anyone else have APR stage 1+ pinging issues?
- So a stock 1.8T dyno's about 110hp, right?
- My ECODE rant...
- Help with my Audi A4 1.8T
- I just ran a carfax on my car(more)
- Tgr_the_CLW how are you liking the k04?
- Aim head lights Q-
- Help with iPOD integration IPOD2Car in Trunk ...
- is the k&n drop in worth the money?
- evo or awe frontmount?
- What do you guys think US-spec S4 xenon housings are worth?
- Neuspeed Short Shifter....
- Cheap mods, VAG-com question
- MChammered...any chance you could post more pics of your momo knob &shift boot?
- Argh, ye scurvy center console
- The V.2 Carbonio intake doesn't work with S4 bixenosn right? because the housing is too big??!!?
- Help me find a good home for my baby...
- UPDATED:dealership did not disclose accident at sale - do i have any ground for claim?
- My prepared letter to AudiRoadside...opinions? suggestions?
- Most recent pics of my car from below, black out grills on the way, let me know what ou think so far
- ok so i picked up plastic epoxy and GE silicone II clear window and door silicone...which one is
- 2002 1.8T Injector choice
- Performance Driving Pedals
- Which ECU flash "chip" should i go with to just run stock everything in Orlando, FL
- Window wont close. Is this a common issue?
- Too chicken s$it to do the following while moving. Are these ok to do?
- Another extended warranty thread...yeah yeah :p Maybe it'll interest some...some help
- My cup holder is busted--any quasi-useful mods I can do instead of simply replacing it?
- STaSIS Motorsports Runs Strong at Road America *race results inside*
- Looking to buy 18" B7 RS4 rims for USP, need pics and advice please
- strange hissing noise...
- what is reasonable labor time for a shop to charge for snub mount install?
- flutter (baseball card) noise under load
- OT: I think we need to start a site like this..i had a few laughs.
- test drove a 2006 S4...like the car but can't convince myself to spend the money (more)
- 50k service on Thursday...anything I should have them check?
- What pads you guys running now?
- 2003 A4 - Does it Have Xenons (by VIN#)
- Question for Diagnosticator1
- Mini POL Insurance costs ......
- last cc mod q...what kinda silicone...just any..like GE window and door clear?
- How do I know if I have a Sport package?
- I need a blackout ultrasport lower grille ASAP...who has one to sell me?
- how do you get to the horns on an 02?
- driver seat height adjustment handle peeling-anyone else have this?
- Audi Roadside rant (wheel damage during tow)...what would you do?
- Engine Error code? looks like this (O)
- Anyone know a good mechanic in the SF/bay area
- City light help: driver-side bulb keeps burning out!
- Parts is parts, rimz is rimz, and they're in teh classifieds
- My 2002 OEM Headlights FS on Ebay w/CC
- Repost for the weekday crew, please help.
- SPEC Clutch Audi A4 Product Release
- 300mm Rear Brake Upgrade now available
- quick question from my shop... is there any tsb's or related materials with amb heads for 02 1.8tq
- OT for sure (someone sent me this) but... Can anyone guess what this is?
- Annoying vibration at 55-62 mph...lug nuts tight..may have to get wheels rebalanced..
- Did photoshoot last evening..here is one of them...
- Out of warranty - CD Error 3. Any fix beyond taking apart Symphony II unit myself?
- Where can I buy stealth bulbs?
- Advice for new A4 2.0 TDI Sport owner?
- A4 USP 3.0 any idea on how many they made ?
