- Anyone got a link to a write-up on replacing INNER CV boots? I see outer but never did an inner
- PLEASE HELP!! NEW battery problems!!
- Video of my car. Stage 3+ with TP and Neuspeed exhaust.
- Headlight Condensation
- what is the charge for scuffed rims on a lease return?
- Flywheel, clutch, rear main crankshaft seal...5 hours...
- Wheel fitment question for B6 Avant owners
- power steering groan
- non A4 help needed. A8 not starting up after trying to help a friend....
- Wheel bearing procedure? B6 same as B5 Tech article?
- radiator leak...how much is a new one??
- Rotors/pads changed, now getting auto level error?
- VAG-COM DRL Fogs Question
- Intermittent low battery voltage - seat heater problem?
- Any of you guys considering Stage 1+ chip upgrade, there's a set of new TT injectors in the ad sect.
- navigation DVD problem
- Need to change spark plugs
- So I changed my driver door control module tonight... (someone please help me!!!)
- I never wanted to see my Avant in this condition
- Thanksgiving Sale - 10% off all products at or over $995!
- headlight problem - please help
- Anybody running VMR 18" RS4 Replicas with BBK?
- Check Engine light on
- With all the problems, are people still chipping cvt's? I searched and haven't seen much talk about
- Comments on Bentley manuals?
- Wow, I was cutting it close. Snow today.
- To all B6 drivers who celebrate the day.... Happy Thanksgiving!!!
- Center vent boost gauge... ECS or AWE?
- Heated mirror activation?
- Achtuning APR Winter Sale Special!
- Probably already answered but - Is APR's Turbo the same as a GT28RS or is it some "special blend t"
- In terms of getting girls...
- my baby got jacked and joy rided
- Swain Tech vs Jet Hot thermal coatings
- Hit 50k today 02 a4 1.8t
- ECS TUNING........you should have a holiday sale as well. I need a few things.
- 245mm vs 255mm rear rotors; same pads?
- Got some questions about the difference btwn B6 & B5 suspension
- Happy Thanksgiving from the staff of A.W.E. Tuning.
- 3.0 Cat Replacement stats?
- PSA: For those that use the B7 A4 brakes, please note that these OEM 16" wheels clear them.
- So when its time to replace the battery, what brand are you guys going with?
- Please read and help me out here...
- Poll: Those with snow tires, did you have them Road Force balanced or just just done on a regular...
- Wheels with most clearance?
- As always i received top notch service from Avalon Motorsports today.
- Winter mode :-(((
- how much is a used k04 and tt injectors worth?
- We are proud to announce the release of the Apikol Snub Mount...
- X-post from wheel & tire forum - help identifying wear pattern on tires
- Help! - Anyone know what this warning symbol means?
- Milltek or APR Stealth
- Audi 2003 A4 won't start ..... clicking noise when I turn the ignition...help?
- Holiday Coupon Codes!
- Audi Certified Warrenty Expiration
- Free Audi!
- Buying A4 2005
- Motor Mounts for 02A41.8T QT?
- my sunroof is possessed...
- Does bumper cover have to come off to pull headlamp assembly?
- Does the B5 and B6 platforms use the same control arms? Check this out...
- Some B6 model year questions...
- Looking for 17 or 18 inch wheels anyone have anything?
- Is there a B6 FAQ and DIY list somewhere, like the B5 board has? Thanks-
- Vibration and low-frequency noise help
- Does anyone know which way the cylinders are counted on the 3.0....
- Significant vibration when revving - 2002 3.0 Quattro Manual
- I have a TT and am looking at an 2002-2005 A4. Anything to watch out for?
- Does anyone know the plug or where I can get it?NAVI- CD version
- anyone else pumped about the return of the turbo to the s4?
- how do i loosen and install the wire harness boot between the door and car
- anyone tap into the preamp inputs that run into the trunk amp
- UPDATE SPEAKER ISSUES
- The numbers are in...
- Setting the 'correct' Coilover ride Height
- Affordable replacement battery that fits properly?
- paging "Bronze" in the Detroit area. Fire me an email. I'm @ GMTC also.
- Replacement Aero Blades
- Part numbers for one-use clips for door panels?
- How does $1,000 sound for parts + install for Koni Sport Shocks?
- Take a look at this A4!!!
- HID Kit Install
- APR ECU upgrade
- cylinder position
- 18" USP Wheel & Center Cap part number
- For guys who have done RNS-E installs recently...
- Oil question -- i have 2 qts of castrol syntec 5W-40 left, OK to mix with M1 0W-40?
- Anyone know a shop in MD that will do scheduled maintenance for less than the dealer?
- Quick update on my trimming and cutting my car doors to save weight...
- Ok, not a noob post, I promise. Need some DV/BPV mechanics info.
- So I decided to torture myself today and looked at an '05 B6 S4.
- ross tech key usb vag com cable in the classifieds. or email me if interested.
- After driving an IS350 today my question to Audi is why can't you put a 300+HP V6 in an A4?
- Follow-up trouble posting in same thread
- HELP. SOMONE BUMPED INTO ME
- HELP NEEDED in finding the proper belt to run without AC...
- PLEASE HELP ME...
- Short Shift Kit Q...spfc Stratmosphere...
- On the way home just now heard metal screaching rubbing and grinding noise from front pass wheel...
- Hear-Yee, Hear-Yee...New TT Drawing...(Dallas Area)
- Take a look at my rotors. I'm not sure if it's a problem or not...
- Bleed cooling system, is there a writeup?
- $300 CVT Trans Oil Filter???????
- Nexen tires
- Increasing maximum boost levels with VAG tool
- Will it rub? 245/40/18's on OEM RS4's with 10mm spacers - Sport suspension
- Hard to shift into 2nd with trans oil cold on a 30f day?
- Thinking of adding a used Allroad to the fleet. Which model is considered the best?
- 17inch wheels best size winter tyres
- CV Boots keep ripping
- Anybody have the service checklist for 2002? About to do my 50k service.
- Oil in intake manifold and intake hose??? is that normal???
- Post your "A4 on a flatbed" photos!!
- TORONTO AREA MEET TONIGHT
- Best place to by an alternator?? Cheap but quality
- GIAC question.
- radiator only took 1.5 hours to replace, but i lost the bleed screw on the top pipe... doh
- MIL light on, not making temp... Thermostat?
- Look after my posts \/ \/ \/ \/ I'm off to watch "I was a Celeb get me in"
- Road noise - can it be just the tyres?
- I want to set my desk top Pic as a Dolphin A4 - who has the best pic?
- i was away on vacation and was not able to get on aw. is audi serious about that
- Control Arm Kits
- Can anyone ID this 6-speed short shifter for me? TIA
- Tires
- Combing the Ad's looking for B6 A4tqm's...
- Clutch upgrade coming soon, any seals and misc. stuff I can change while it's all taken apart?
- Retagging
- I have an extra head unit for the Audi B7 models. Any takers???
- Losing boost
- Anyone know online places were I can order an axle assembly?
- anyone want a sport 02 rear sway bar in ATL? going in trash this weekend
- Searching for old threads posted
- Stock sway bar bushing upgrades? Endlink upgrades?
- Is this maroon a Stock color?
- ECM Relay says 219? J271? Anyone know the model number?????
- another question about my headlights
- (FAULT CODE) P0688 ECM/PCM Power Relay Sense Circuit ???????
- G83 Coolant Temp Sensor
- Service intervals and prices
- Noob here, need help with CVT problem
- New optima, makes charge when running 13+ volts, once off,battery drained after 24hr..?? what to do?
- EPL Dyno Day Dec 8th : Spots are filling up fast!!! - 2 Spots left.
- Replacing boost hose clamps with t-bolts; anyone make a kit?
- B6 A4 reliability
- What kind of fastener holds the air filter box to the side of the car.
- Pic request - 17" BBS CH 's - Anyone running these?
- Replacing gas hood strut (the one that holds the hood up!!) - Little Help?
- anyone know what a stock front lower valence costs? (the unpainted grey plastic)
- ok.. somebody buy my AMS 6 speed Short Shifter ..!
- hard shifting into reverse
- Please comment on my log, more specifically the lambda values.
- paging "diagnosticator1" please pick up the red courtesy phone, or look inside:
- Sprint.....
- QuattroFan02, AllWheelDriver, Southsong, and any other NY/NJ/CT people...GTG information
- B7 Sport Suspension into B6 HELP!!!
- does anybody have one of the new Eclipse double din NAV units in their car?
- Help!!!
- Why won't my rotors come off?
- Preparing for 80K self service, looking for info...
- What do you guys recommend for black bumper paint? Someone mentioned European Bl. Bumper paint
- No heat, what could it be?
- wohooo! time to be a stuntman
- Swapping ECU's
- Spark plug recommendation for 130K mile A4
- Stratmosphere - Hyperboost in stock and ready to ship!
- installed a set of 8mm spacers this past weekend- how do I know if they're hubcentric?
- Did I make the right diagnosis?
- What is the diverter valve to buy? APR? Forge? Bailey?
- Ok - APR called me back - not thrilled with their answer. Please give your feedback....
- for those who have not seen....B8 S4 with supercharged 3.0 is highly likely
- TIPTRONIC vs CVT
- "OEM" Conversion to Xenon? What is involved?
- Thinking of going APR Stage 1+
- Ay guys, Maybe you can help me out (GT28RS WG Problem)
- New to the forum and VAG COM in Washington DC
- Going in for first oil change
- Just got my car back from svc. Svc dept says torn bushing links in F upper Susp?
- 500 miles later and my OFE HD is broken in, it still catches nearly at the floor but
- **Need Instructions to Change Front Turb Bulb, 02 A4 1.8TQ**
- Just noticed this when changing over to winters
- timing belt done at 54k...
- Hey, Carson @ Riverside Audi, you guys should rent out tools.....like TB kits, etc etc.
- Rear Sway Bar Advice
- Any last minute suggestions before the car goes into the shop...
- New (soon to be) owner of a B6... US to Can Conversion Q's
- On cold days how long do you wait before you stomp on the throttle? I wait until...
- Coolant replenishment?
- Driver door wiring harness replacement write-up (lots of pics)
- Anyone experienced GIAC chip on 3.0 manual?.
- Quiz, Can you identify this electrical plug?
- Installed the HJS Tuning HFC this morning....
- a4 3.0 quattro shopping - known issues (70k + miles)?
- 1.8T Avant + kids=???
- How do I install my APR shift knob...
- Has anyone done a comparison with the GT28rs to the GT71?
- visitor (from B5 forum) with headache will a 250 ohm 1watt resistor cancel the low beam out warning
- digital rpm gauge
- 1.8T BHP question
- Was this anyones car here.
- How Much Would these Mods Cost for a 1.8T Manual?
- How do I open the LED tails?
- Has anybody has this problem with there lights 05' (B6)
- Electrical gremlin? Car's brake lights turning on by themselves when the car is off
- Things To Look For before Buying B6
- IS SPORT PACKAGE A MUST- HAVE ??
- 2002 B6: Which is More Sporty Fun : 1.8T or 3.0
- Those with Tiptronic transmissions, particulary 3.0's....
- Seriously considering trading my 03 1.8t Q Tip for 04 1.8t Fwd CVT UltraSport..comments/suggestions?
- Quickie Wheel Poll: Better 1, or Better 2? TIA
- If anyone has, or can take, pics of xenon beam pattern on a garage door for me.
- Since I can't drive my car right now I might was well picwhore it out to make me feel better
- Props to Mobil 1
- Help - Wheel Needed
- A new member of the B6 family :)
- Door open warning chime and display not working... Any suggestions?
- water in my headlights :(
- RA4 Clutch / Boston Area Shops
- how much more work does the B6 require to be in sevice mode, i need to do a radiator job
- so is this a terrible idea?
- 2003 A4 @105k - Change CVT Fluid?
- Master cylinder 2002 A4
- matte black mirrors on a Dolphin USP avant - should I do it?
- A few issues.. any ideas??
- X-post from the B5 forum "Secrets of Speed - Audi quattro"...
- x-post from AZ, which is a x-post from gmmodernmuscle.. if you haven't seen it yet..
- Changing front pads tomorrow - too lazy to STFA, so anything I need to know?
- Wow....APR exhaust leak. Found CRACKS today on and before the resonator. Disappointing....
- Ya know, the "stages" for our cars needs to be revised I think
- Gas Mileage - What do you get? (B6 A4 1.8QT, Manual, Stage 1+)
- Am I a traitor? I just set a M.B. C300 Sport as my desktop background =P
- Lost my Petrol Cap - Now A4 throughing codes... (P0411, P0455)
- Red Interior Lights around Light switch are out- how are they replaced or epaired? Does the switch
- A clicking sound
- A truly pathetic story from Roadfly. He has been bashed on the board.
- ECON Mode stuck ON
- What the.....
- 2003 Audi A4 Avant - where is the block heater plug?! Thanks.
- bulb question
- 02 Avant Right Rear Brake Light
- How long before this self destructs
- So somehow I managed to run over some type of spring and it got lodged in my tire...
- Brakes...what are good, drilled and slotted rotors and ceramic pads for under $350???
- Hartmann Winter specials up on Achtuning.com!
- Help with Radio Reception!!
- PLEASE HELP----->
- Sneak peek at what is coming soon from STaSIS!
- looks like my oil level sensor light is caused by a broken blue(i think) wire by the oil pan
- Dealer trying to rip me off?? Extended warranty question??
- Stupid question....why does my brake bulb out warning some on only after I shift out of P??
