- Strange Traction control light abs light and brake light flashing wtf?
- :: ECS Tuning :: USP Grilles 30 dollars off with free shipping!!
- DrivTech | VMR Wheels – NCAA/NFL Football Kickoff Sale - V710
- Stung by the ABS control module
- Battery Swap
- PROBLEMS WITH COOLING FANS - HELP!!!
- Need help deciding on whether to change the timing belt or not.
- steering wheel swap ?
- Sporadic Headlight
- Installed HID kit, plagued with dash display problems
- How much would you pay...
- shokan saved me a bundle
- Brake Pad Wear Indicator
- :: ECS Tuning :: 30 dollars off RS4 sway bars and w/free shipping
- A/C Blows Hot
- AC issue
- A strange one involving timing belt and 02 avant...
- Boost problem or something like that Audi A4 1.8T quattro -04
- Jerky Feeling... transmission...?
- APR stage 1+ injectors
- S4 2004 Need quick advices.
- What do you think of the 3.0l V6
- In the market for A4 Avant, have questions.
- G12 Coolant question?
- Drivers Door Speaker Intermittent
- Avant Cargo Cover
- I received my new comfort module...now what?
- Just went to Valvoline....need some advice
- Need some real input here
- Speed Sensor Repair in Two Parts
- Rear O2 on a 3.0
- Sluggish A4 Avant after new tires?
- Gears flashing / CVT/ 2004 A-4 1.8
- VMR | Wheels - Labor Day Sale!!
- Diesel behaviour after timing belt change
- A4 wheels and tires for sale
- Turn signals
- Trunk light out
- Trunk light out
- Trunk light out
- 0w-30??? Feed back please.
- B6 Bentley anyone?
- Signs of serpentine wear? Lots of repairs
- A4 USP Help
- Can I get a VIN off of the engine?
- Cooling system purge
- Driving home tonight..........
- Has anyone replaced xenons/HIDs with Halogen lights?
- Key Blade
- Labor Day Special at Detailer's Domain
- A4 3.0 vs 325i
- .:EuroCode Tuning:. OEM Audi (Bosch) TT225 Injectors, $71.75 each shipped!!!!
- Torque converter won't slide off of transmission
- 2004 Audi A4 Cabriolet 1.8T, Stock Radio Replacement Options
- Car Won't Start After Installing New Stereo
- Control arms on a B6
- VMR | Wheels - V701 Straight Spoke Wheels IN STOCK!
- ::ECS Tuning :: Aluminum RS4 Pedal Sets – 47% OFF with Free Shipping!!
- not starting
- Audi Anarchy 2010 Writeup
- If i turn on A/C, my dashboard is gone~
- CEL will come on and then go off a few days later...then come on a few weeks later...
- :: ECS T uning :: B6 A4 Aero Windshield Wiper Conversion - 30% OFF
- More problems, Ready to set it on fire
- VMR | Wheels - Back To School Promotion!
- Exhaust leak 3.0 B6
- Mann Oil Filter different part ?
- Coding Key
- Replacing clutch master cylinder
- Completed my first timing belt job on 3.0 and....
- EVERYDAY SOMETHING BREAKS ON THIS POS!!!
- Child seat ISO-fix latch bars
- Opinions on buying this beautiful '04 A4
- B6 A4 1.8t putting into VW advice?
- Boot Lid replacement
- What are you doing this weekend? How about Audi Anarchy 2010?
- Enkei RP03
- Damage at full counterclockwise rotation?
- DrivTech | License Plate LED Set – In Stock
- Tiptronic hard to move shifter
- Oil Filters
- Urgent HELP CEL on engine making knocking noise
- B6 Bra
- All season Performance tire?
- Painted lowers and trunk trim help
- Loss Coolant: I think I found it
- What tools is a MUST for this job?
- Front turn signal light bulb
- interior parts
- DrivTech | VMR V708 Sale - 18"-19"
- a/c
- 2.0 tranny sway
- Misfired When Cold Engine, Help, Running Out Of Ideal
- 2005 Audi A4 with only 51K miles
- Need help with a cleanse
- Control arm replacement - Broken bolt
- B6 2002-2004 purchase advice needed
- OEM vs aftermarket windshield glass make any difference?
- My adventures getting my STASIS suspension installed
- A4/S4 iPod cable for Nav System
- VMR | Wheels - V701 Matte Black Promotion!
- Gotta noise..
- Screws used for license plate lights
- 1.8T AWT is this that bad ?
- Best rims for 03 A4?
- 2005 a4 (b6) owners manual in pdf?
- Please help my A4
- how can i get my b6 tuned
- Need Recommendatioin on Indie Garage
- Torque setings
- Fog light question
- VMR | Wheels - V708 18" and 19" IN STOCK!
- name that wheel
- DrivTech | VMR Wheels Introductory Offer Sale – V701, V708, V710, V718
- Security screws on ECU
- Thump when downshifting, RPM's at 3500
- Need Audi Technician's help with CVT
- PLEASE HELP!!!! Motor keeps overheating n warping head
- High mileage advice needed
- Need help removing B6 engine cover!!!
- 2002 A4 with a CVT transmission and code 18185 / P1777
- : ECS Tuning :: B6/B7 S4 Door Blades - 36% OFF - Free Shipping
- More trouble: little smoke at turbo
- current oil recommendations for 1.8t?
- Some weird fault codes.. Bank 2 o2 on a 2002 1.8T? Quantity Adjuster? N320 valve..?
- Where is the Transm. Multifunction Range Switch
- Fuse for reverse lights?
- Anyone in Denver Area with a Vag-Com?
- Have car trouble I need advice on
- '02 a4 rims question
- In-line Check Valve for B6 1.8T
- X-Post: Group Buy on AWE intercoolers!!
- What else to replace with timing belt tomorrow?
- Need Help please read
- Bad Window Regulator or Motor?
- Front and Rear turning signal bulbs LED
- Battery was removed, now remote unlocker/locker won't work
- Mirror install help!!!
- Could low oil throw CEL?
- Independent shop in fairfield County, CT? & average mileage for timing belt?
- LEFT PASSENGER FENDER WANTED
- replacing the power steering pump??
- Something is wrong with my stock Car Alarm (please help)
- Finding Coolant Sensor in 2003 A4 3.0 L
- A4, BMW 3 or MB C?
- My car caught up on fire at the track.......[o_o]
- Gears? What Gears?
- P0411 Code?
- *** PUBLIC SERVICE ADVISORY, stay away from Do Werk Garage of Rhode Island!***
- New tires?
- Hood Open Display Error
- Tail Light bulbs
- Know anything about ProJ and Sonar lights from Ebay?
- Stern B6/B7 Rear Sway Bar Links
- Surging under acceleration
- passat 6sp auto for CVT.
- looking at 04/ 05s to buy. does the paint peel off all buttons?
- missfire rough idle!? Help please out of ideas!
- S4 black leather Recaro set on ebay
- Need new "material" roof
- how do you seafoam a 2002 audi 3.0???
- ECS steering column gauge pod install help!
- FYI if you're looking for some new tie rod ends
- Where is EGR
- Fading Clutch - 2003 A4 3.0 q
- Brakes chirp when driving over small bumps?
- 2005 Audi A4 1.8t front-trak downpipe/midpipe dilemma
- Shakes or Wobbles problem
- Is my alternator going out? Got a reading of 13.79 volts across the battery
- Broken seat height handle
- Major Transmission Trouble!!
- FMIC Who's In
- I need HELP on making a Discussion on buying this car!!!!!!!!!
- 20% off Waterfest Special 7/20/2010 at Detailer's Domain!!!!
- S4 recaros in the classifieds
- 2005 Audi A4 Front-trak 1.8t crankcase breather
- new car issue..
- 5x100 rims on 5x112 hub?
- Replacing coils for A4 1.
- Adding some cargo space on A4 convertible
- Introduction
- Oil change and filters?
- no neautral or park indicator when warm
- window initalization?
- Seat alternatives (AKA, I hate my stock seats)
- Oil level warning on A4 3.0?
- K03s
- PARTING OUT 04 AUDI A4 (B6) 1.8 GARRETT TURBO
- Temp gauge always at middle
- The severe vibration from the floor board and seats in 03 Audi A4
- tips on how to check the mileage of your car
- 2005 A4 3.0 USP..... On sale :( :(
- Coolant Leak Location 2004 1.8T
- Modd costs - A4 Avant?
- B6 cab with B7 upgrade for 10.00 Front grille
- Will this A3 Radio Fit
- Fuel tank back pressure and misfire
- Fuel Pump? Thoughts?
- 2002 a4 3.0l 02 sensors or cats ?
- OK so my whipes go slow then eventually stop, WTF??
- VMR | Wheels - V708 RS4 Style PRE-ORDER
- A4 Avant - Reg. or USP?
- INTALLING CONVERTIBLE ROOF
- Ac blown out hot air and system has frion
- R&R the steering pump on the 3.0
- passenger dipped headlight
- Replacement Battery
- help please! TCU gremlins
- trim levels
- VMR | Wheels - July 4th Pre-order Specials!
- Poll-- Best Car/Crossover for Advertising?
- Vibration When Making U-Turns..
- Almost stranded in my '04 1.8
- Shifter is shifting out of gear while driving
- Craftsman Swivel Jaw Hose Plier. 4 the price I'd says they are worth it.
- 2005 A4 1.8T Heated seats not working
- Cruise control not working
- EPC Light and Stalling
- Bad Alternator? / Overheating
- '05 3.0 temporary power loss during cruise
- Interior Wear - Is There a Fix?
- VMR | Wheels - Photoshoot 19x10 All Around
- Sub Install 05 A4 tips
- 2002 A4 Passenger seat question
- b6 3.0 help
- HELP needed regarding OEM Headlights / Part Numbers etc
- Replaced battery in 2002, 3.0Q.....
- TRANSMISSION ISSUE
- 2002 A4 BLOWOUT SALE!!
- O2 Sensors
- help pls my audi has died
- Acceleration Issue
- Missing Sensor?
- What would a used USP wheel set with newer tires fetch?
- what engine block and head is the same as avj
- Tail lights stay on
- Missing Dash Panel Under and Right of Headlight Switch
- ABS wheel speed sensor fault / G47 00283
- VMR | Wheels - V713 Split Spoke Design IN STOCK!
- 1.8T turbo issue
- 2002 Audi b6 1.8t_Rough Idle & CEL even after coil pack & MAF replacement
- need pin audi 2007 from damp plz
- Looking for Front Bumper Skirt
- Driveshaft help immediately please!
- :: ECS Tuning :: B6 A4 Floor Mats 78% to 88% OFF
- Dealer Doc Fee 269??
- Liberty Mutual vs State Farm
- 05- Loud humming when turning right- Please Help
