- Blitz Dual TT/Boost Gauge install
- Other names for the "snow filter"?
- Is it possible to seperate the unpainted lower from the painted bumper on the rear bumper?
- HRE Wheels from AWE Tuning
- Trading in my B6 on Saturday morning
- I think I've got a coilpack problem... Help/experience needed.
- I've searched and coudn't find it, but I remember someone cleaning the inside of the e-codes because
- Anyone have a Catalytic converter they are willing to part with?
- anyone have single xenon grey housings available?
- anyone have any repair info (bentley?) on rear driver side window regulator?--desperate
- Where can I get replacement city light bulbs for my Ecodes?
- I thought you guys may like those....
- Has anyone replaced the antenna booster thing above the back window?
- My car is a f-n enigma. No CEL or any other warning lights and yet 1st gear feels like 3rd...
- I didn't believe this day would come...
- So i STFA, trying to figure out my bumper situation after smashing it up..
- 04 B6 3.0 USP - 35k service what do they do ?
- What do you think of VW GTI?
- Yay BiXenons, any ideas for matching fogs?
- Got hosed at the stealership!
- Avant passenger side trunk liner removal? I searched already
- '02 1.8t quattro - Which VAG-Com adapater should I get
- Rear Diff and Front transaxle oil change?
- ECT (engine coolant temp.) sensor location on B6 3.0 V6?
- car recently waxed... wanting to touch up paint
- Warranty up in few weeks?
- Is the car a Sport model (suspension?)
- I think my next Audi will be the A5...any inputs?
- Power distribution of Quattro?
- how much $$$ has everyone in here dumped into there audi
- Where did everyone buy their replacement key fobs from?
- Just received my ECS Aero wiper kit (new arms and a set of Bosch wipers).
- 19x8.5 et35 on 02 A4 stock sport?
- Do the B5 S4 HP2 calipers fit all B6 A4's?
- Update on repairs...
- Coolant Light came on today about 30 seconds after I started the car.....
- Time to sell the Audi - What kind of luck have you had on the private market?
- **in need of a bit of help...
- 05 S line - 40k what is it worth
- Anybody else had a broken rear windshield?
- The Horror Story continues
- Drive line/Axel damaged?
- Where is the fuse compartment in an 2002 a4 1.8t?
- this whole a5 thing has me itching for a pic of the b8 a4. it should be a hot car!
- Convert non FIS car to a FIS car
- Are OEM wipers the only option on B6 A4's?...
- coolant question... very stupid but I need help...
- Anyone know the OEM P/N for the oil drain plug/crush washer for the 3.0?
- Does anyone besides APR have a home programmer?
- A5 revealed tonight! Check Autoblog.com
- Got my new Euro tail lights.....
- Power Steering Pump
- Sirius buys XM.
- ATP 3" test pipe questions?
- Found Xenon bulbs and ballast for $100 new.
- Need help with the eccentric pulley (tensioner pulley)! Cannot understand how it works!! PICS PICS
- So i picked up this part for my car today
- Clutch going?
- Mileage Dropped 5-6 MPG... Where to start?
- Need good paint ship in long beach CA
- Anyone every have these problems...Solid CEL and DTC's...please help (long read)
- B6 A4 License Bracket
- Need a new radiator, 95000km.... should I have them replace the timing belt as well?
- Rear deck speakers project: Pics of the rear interior removed for the curious!
- Installed PBR pads and they sound like a Semi when braking??????
- anyone want to recommend a good set of Stainless Steel Braided Brake Lines?
- might be getting a b6, what are common problems ?
- you guys aren't funny
- 2002 satellite radio install
- Just visited my local AutoZone....
- Where to buy a S-line Steering wheel
- Don't know if anyone saw my sig, but I had this done on Thursday...
- why has there been so much discussion about belly pans?
- This is a long shot, but does anyone have any 17" Flik Justice BLACK wheels for sale?
- Simply Beautiful~
- Milltek exhaust videos
- Can I get the cat and downpipe out from under the car with the O2 sensors still in?
- Wanted: OEM exhaust for B6 1.8t
- Belly Pan...or lackthereof...part 2...
- Removing compartment under seat?
- continued diagnosis of my cooling problem
- Belly Pan problems....
- Belly pans again...anyone try the B5.5 Passat part # 8D0863821S?
- Does anyone sell wiring harness extensions for ecodes?
- Yesterday was a good day...
- Anyone else also ride two wheels if so post your ride
- It seems belly pans are the subject of today...
- Busted belly pan. Found #8E0 863 821AL, can anyone confirm? Also is there a different part shown..
- wow...search button helped me!!!!
- Anyone purchased a VIS carbon fiber trunk?
- How are people hooking up aftermarket systems (amps & subs) to a stock deck if at all possible?
- Anyone use any fuel additives on a regular basis?
- Oil Quality Standards VW 502 00 and VW 505 01 - Approved Oils
- fun fun fun
- Anyone here have the finish on the headlight dial peel off?
- Dyno results with GIAC FX...
- Anyone selling MY02 sport springs?
- Washer Pump Fix...Real Easy..
- A4 or A6
- Paging A4Rye .... fitting RS4 rear sway bar
- Oil Sludge Question
- Anyone hook up Sirius directly to the stock radio?
- Quick question on offset . . .
- Does anyone have the USP door blade part numbers? Search turned up only S4 blades.
- Correct Strut Mounts??
- coolant system bleeding
- The small "tt" to the right of each post
- This may have been posted before.. but what does everyones Gf's/Wives feel...
- window regulator dead (driver rear).. any DIY guides available?
- Have to ask....who has had a failed O2 sensor and at what mileage?
- 3 weeks and this has to be on the truck to Sebring ready to race.
- O2 Sensor, VAG-COM and Bentley questions
- Learnt something cool about the Audi R10 today...
- Selling 2002 A4 3.0Q - what's a good price?
- First time I've been stuck for more than a few minutes!
- Will these wheels fit my A4?
- Hey MB The Body: Your 3.0 is in March issue of eurotuner in the Reader's Rides section.
- Where is the pictureposter?
- How do you get the wires in this part? 1J0 973 722
- audi navigaion
- blowoff valve
- Whoa! som1 lend me $68888!
- Washer fluid not coming out?
- is PES tuning still around? do they still make wheels?
- Calling on Avon M550 owners...how many miles have you got on them?
- Where would u put jack stands in the front of the car?
- A little wheel help, if you please!
- Routine Service Confusion
- Purchase 2004-5 A4, questions
- NYC Snow + Bad drivers in SUV = broken A4 (front grille)
- Suspension offerings available from A.W.E. Tuning
- 2nd coil pack failure in 2 months..arghh...
- replacing a burnt out xenon bulb
- Most kms or miles on an A4
- Blown Left Headlight 2002 A4
- Can't catch a damn break with this car! On my way home after finally getting it fixed and WHAM! A
- When's the Rival Motorsport site going to be operational?
- Last weekend for presale pricing on Testpipes!
- can an O2 sensor be cleaned? do they ever need to be?
- Big difference between OEM Synthethic Transmission fluid vs Motul?
- I like the snow but this frozen snow SUCKS...
- Found a new spot to get some grill material OTHER than HomeDepot
- My windshield wiper doesn't sit flush with the windshield anymore...
- What's it called when a technician flushes out the oil?
- When you have jerky shifts, how much damage on drivetrain?
- comp reset
- WTF: Car won't start. I turn the key and it is completely dead. No clicking or anything.
- I wanna sell my 02 1.8t, What's a fair price?
- Boxster or HP2 calipers
- Lame 0-100 kmh video of 1.8T A4.
- Wrecked A4
- Who's got stock door blades?
- German Engineering
- Neuspeed power pully with belt has anyone ran it
- Very near to sealing the deal on an 04 1.8T Quattro Auto Sedan for $16,750.00
- Project Decal Complete (well almost)
- 02 1.8t fwd
- Auto Sensing wipers 2004 B6?
- this is tempting, S6 avant for 26K....
- Will the B5 S4 OEM wheels fit B6? Are B6 and B5 S4 OEM wheels the same (design and size)?
- fair price for my car? $11,000? 80k miles
- Question on the most common way parts fail on these cars
- I saw these wheels on an A4 about a week ago..
- so I'm tempted to jump to a B6 S4 avant...
- Yay, aero wipers shipped to my door in 24hrs for $90
- Anyone East of the Missippi selling under 70k miles 1.8TQM
- So I dyno'ed the car last Friday. Click for teh results...
- SNOW DAY!! Post your snow picts!
- Any tips on what to look for buying 2003 A4 2.5 TDI 163 Automatic?
- Turn off ESP?
- Just purchased '03 1.8tq tip, question on warranty coverage
- Air & Cabin Filters
- 2002 Manual A4 Avant 1.8T - $16,900k. Should I buy it or not?
- Weird...when I roll up my driver's window, the hazards blink once. Any ideas?
- Quattro/Drivetrain Issue on snow-covered roads: Need input
- First step towards changing tranny fluid...bought the triple square tool! Question for those who
- Hello B6 A4 forum
- how great was the last top gear?
- Help on this hose part?
- You try to help someone out and ....
- Now that the weathers crappy, I'm a happy driver.
- I'm contemplating getting Wet Okole seat covers for both front and rear, black w/ gray inserts.
- So anyone's employers looking for a GREAT intern??
- About to order Proclip but one question for those who have the angled mount...
- Paging MB! Any chance you can re-upload those pictures of 60k DIY?
- Any must see tuners/European car shops in Portland? Open on Saturday
- where can I find this decal
- Need help purchasing a 2003 Audi A4 Cabriolet
- :: ECS Tuning :: ECS Column Mounted Boost Gauge & Pod Kit
- more car problems..fans not blowing, car overheating
- Thoughts on 1.8t Auto reliability & gas mileage?
- That's it man, I'm putting on a test pipe and lighting a styrofoam cup fire....
- B6 A4 FMIC?
- Anyone with a 3.0 and TIP had to have a failing torque converter replaced?
- 40k service done at 31k what should I do now at 40k?
- anyone in here around salem oregon?
- A4 - S4 intercooler upgrade
- Where I can find step by step directions to replace washer fluid pump?
- This is Hilarious...anyone wanna try this one?
- Looking at a new to me 2003 A4 1.8t
- well here goes...anyone in Oklahoma?
- Anyone ever break an oil pressure sensor?
- stock hp to wheels for the 3.0
- paging diagnosticator...all is well that ends
- Trade in with aftermarket rims???
- This is a must read! Dropped my car off at the dealership who replaced the t-stat and the next day
- Install on the new shocks and springs..
- Finally pulled the trigger on shocks
- Tire Opinions...Again
- i have window visors!
- I did my 40,000 maintenance. I am awesome.
- paging Meskeetdog, I have a question for you...
- Iforged Essen Wheel
- AEZ Bimos or Stock Sport 5-Spoke?
- B7 A4 DTM Racing on Speed Channel, 1pm EST.
- Dyno Day Fun (x-posted from the Canadian forum - B6A4 content)
- Anyone help me with B6 versus B5 suspension questions
- Newbee post
- Took the Avant ICE racing on a frozen lake in WI.....it was fun, though Tip FTL, oh well.
- soo sexy...if only i had the $$$
- Starter going???
- Is powersteering affected by cold weather?
- Snub Mount Torque
- what the flow rate of stock 1.8T injectors, how many cc's?
- who parlevous francais? need a translation on the new suspension
- Part number help...
- My driverside door handle broke I have to open only from the out side HELP!!!!
- guess who?
- Is it just me, or does it feel that the stiff setting on the H-sports is too much for the 16"s?
- 110K update....
- Clutch Q
- Was Pick of Destiny a terrible movie?
- Looking for someone with a VAG in Thousand Oaks, Agoura or SFV (CA)
- cooling problems
- Does anyone have pics of b6 s4 brakes on a b6 a4?
- Anyone notice when its goes below freezing loss of windshield fluid?
- Need HELP...k04 Overboosting and oil problems !!!
- I miss sharing pictures with you guys :)
- my punishment for not washing the A4 in over a month...last night the back of my seat exploded off!
- Shot in the dark, but check engine light came on and blinks with a noticeable vibration while
- My rear seat won't latch...
- Carbonio Intake vs Neuspeed....???
- hmm i kno w you get what you pay for but damn, check the lil videos in the ad
- Air noise seems excessive lately? Any obvious checks?
- Looking for anothe A4 1.8 quattro in NW Aarghkansas...
- Took car to local parts shop and had them scan it. Guess what turned up?? Good 'ol P1296 code.
- Mechanic in SE Wisconsin Wanted
- Anyone ever put larger fogs in the Oetty side openings (like a Subaru)?
- ESP light
- Who has the A4 from AudMods.com...think i saw them getting a ticket the other day on the 51 in AZ
