- ESP symbol light is now on constantly since reconnecting my battery
- $1700 poorer, car has a new rack!
- GIAC question
- Coolant leak
- Anti-Sway Bar vs. Rear Stabilizer Link
- Opinion on brake pads and rotors
- Tgr_Clw - YGM
- My subwoofer install nightmare...
- can someone post high res pics of their 04 a4?
- looking for a set of chrome spinners for the audi. you think i can fit 22's? pics?
- anyone know the part number for the hex screw that holds the sideskirts on?
- Not a good way to start the morning...first major repair of car
- Can you guys recommend some good tires?
- how good is apr exhaust ?
- Than,I have spoken to the Borla guys and they said they don't have a system for the 3.0 v6...
- wheel spoilers - help with part #'s
- A4 2004 3.0 CUSTOM EXHAUST, DOES ANYBODY HAVE A FAVORITE?
- best performance mods without sacrificing reliability...
- 2004 A4 3.0 BAD FRONT BEARINGS AT 47000 MILES?
- Audi Newbie Questions
- Those of you who have your own floor jack what weight is it rated for?
- Time to pick myself up a USB VAGCOM cable - suggestions?
- Anyone know the part number for the cigarette lighter...
- Any one have a vin guide so i can see what options the cars im going to look at have??
- Who's yer daddy? ... Larry Birkhead!!!
- Rear brake pad / caliper question
- 'nother oil question: high miles, high speeds...
- Anyone have experience using a fuel system cleaner additive called BG 44K?
- What would cause my fans to come on when the car is off?
- Lease turn in/purchase Questions
- I got chipped/stage 1+(YAY) and i really like it, BUT....
- I need a 2nd key and have been reading up on the immobilizer issue
- wiper blades
- Anyone have their hazard light stay on all the time or flash on/off with the car locked.?
- I like to dump the clutch in the rain for some fun, the B6 reacted differently than my B3
- Don't ever go to Brookline Audi in MA for any type of service at all...
- How often should I change oil on a car driven low miles?...
- how to install boost controler?
- Petrol engine users - EPC
- Oil leaking out from under car...Checked the oil level and it looks like the dealer put to much in.
- Back in Summer mode!!! New wheels and Suspension!
- when i did the ghost sunroof fix i think I lost something, was something connected
- Anything other than an air compressor?
- so who's got the best price on black housing single xenon e-codes? ECS?
- So "quiet" exhausts seem to be Milltek and APR. That right?
- What are the symptoms of a bad/on it's way out steering rack? Or is this the tie rod boot?
- 2002 A4 without latch system- is audi required to install it?
- I'm running out of places where I can find an S4 rear bumper for cheap. Any ideas please???
- So so sad....
- Alternator replacemen
- Looking for 2004 Avant, need help with numbers...
- 17" to 18" wheels - Issues?
- looking at an 03 1.8tQ 5sp aprox 47 k on it, any danger areas i should look for
- 04A41.8T tremmor in peak toque range, surging in higher rpm, APR tuning
- Looking for a good stereo shop around San Diego, CA that knows what they're doing
- Does anybody know anyone on the GM design team in GM performance division?
- DV replacement
- what is the max boots that the stock turbo can handle?
- Best Place to get Motul Transmission fluid?
- Question for those w/Genesis injectors
- Look what I got.....
- Vac line unconnected but still boosting?
- 6-Speed fluid changed! But found something else leaking :( Anyone ID this?
- Paging Kevin Euro addict jailbait whatever.
- Going to change transmission fluid finally this afternoon...any tips?
- GMG Tuning...
- I've been tring to install my ecodes for about 4 weeks now...
- Can someone please confirm if the rear sunroof drainage holes are in the front side of the rear
- Will DIY maintenance Void Warranty
- Oettinger sides, how do you attach them ? (not over the OEM)
- so...mobil 1 0w-40 or castrol 5w-40.......1.8t
- Need help ASAP! In the middle of the coolant flange replacement!
- Will this size wheel fit on a B6? 8.0 x 18 ET 25, 5/112 I'm used to seeing a 35 ET.
- bah, 4 years and 40k miles the ignition switch is garbage. i guess my hard start
- scratched rim
- groaning sound during slow turns...power steering pump?
- boost gauge - tee adapter question
- When to do timing belt/tensioner on 3.0?
- installed AMS SS, forgot to mark the tranny linkage so my shifter sits
- need help asap, oettinger front and S4 ecodes dont fit
- Don't know if this is a repost but good god.
- Pics of VM 18" Gunmetal RS4's on Dolphin Grey A4. I know, I know the car is still dirty.
- VAG COM HELP
- What is this?
- Independent Map Light Mod - Where to find it now?
- Are there any car shows coming up in the midwest?
- Is it difficult to swap Symphony head units? Experiences/Thoughts...
- What do you all think about this wheel?
- need a source for a decent torque wrench - suggestions?
- Not a fan of the stagger, but then again, LMs, hmmmm.....
- Guess what I've been doing today... all day...
- Symphony Radio SAFE mode lockout
- Trouble getting oettinger front on.
- the best coilpacks......?????
- Oil- where to get?
- Anyone know where I can buy a set of Moda or Radius R6's?
- Audi/VW G-005-000 Manual Tranny Oil "use until" date
- humming noise from underneath car
- Picked up some techron fuel injector cleaner. [stupid?] question
- Timing belt question part II - Setting the belt adjuster?
- Very slight clunk when coming to a stop or starting...sway?
- Phisherman Fakes the Funk with Bogus Email Scams
- Timing belt and Revo software questions..
- AWE Tuning Package Special for April
- Need P0421 and P0420 ghetto fix - already STFU
- Are the rear brakes on an 2002 A4 1.8t q the same as on a 2001 A4 1.8t q?
- got the Hitachi CPs in, doesn't seem to increase performance but the DIS shows
- can anyone tell me where the relays are in our cars?
- S4 Blades GB ending this weekend
- Stock door blade is loose, missing a screw! Does anyone know what size screw holds
- I need help resetting keyless entry after replacing switchblade.
- Dealer drove car 17 miles. Does that seem right?
- Paging Devius!
- Pre-purchase inspection help... control arms and washer cylinders?
- my car doesn't crank easily when cold. turn key and nothing happens
- Audi A4 reliability - how does it truly compare?
- Where to buy a 3.0 engine?
- I may as well post this question to you guys since I might be waiting for hours before ...
- ESP light???
- Phishing alert
- Repaired A4 after accident
- A4 Avant Tailgate not closing properly ( occasionally)
- Intermitent power loss.....
- 8" of wet, heavy snow last night! So glad I kept my winters on!! Time to have some fun...
- anybody seen those rainX Latitude wiper commercials too?
- Carbon Fiber Mirror housing ....... (pics)
- Motive power bleeder owners...looks like the one I got is broken?
- i have a chipped hvac button :( anywhere to get a replacement unit or mask it?
- paging Chalfont..can you email me the pics of that junk you put on your buttons/switches?
- B6 A4 ultrasport - rear bumper part # ?
- Why doesn't something like this show up on our shores
- I NEED SOME ANSWERS ANYONE HELP
- Fuel additive + Unleaded gas = Engine light ON
- This is what happens when you go the cheap way. I have a bit of a situation.
- Looking for 2004 a4 1.8t quattro tip sport. black/white less than 50k mi. San Diego or Orange county
- Correct tire pressure?
- anyone have a passenger side caliper available... mine is dead. Thanks
- Anybody have front caliper carriers from a 1.8T sitting around they want to get rid of?
- SAFE MODE-SYMPHONY II Problem...Help!!!
- URGENT: B5 RS4 Replica Wheels - 17inch, will they fit on my B6 A4, and will they clearB6S4 Brakes?
- CEL light just came on!
- Does anyone know if B6 S4 recaro seats will fit in a B6 A4?
- Looking for used vehicle options list based on VIN.
- Any one knows the size/type of the taillight bolt (sedan)?.
- :: ECS Tuning :: B6 A4 Hella Red / Clear Taillight Kit - On Sale!!!
- I guess you can't "pop-start" b6 A4's
- Paging Diagnosticator1, Brake Pad Warning Light
- Mirror housing identification
- Lease up. Can't decide what to do. Should I turn it in or buy?
- anyone put one of these (rieger knob) in a B6 yet?
- 40k service and coilpacks
- Anyone have a Current D-Navi Western Canada CD for Sale?
- Is this piece important? (front splash guard)
- Doing timing belt kit.. Need special tool for belt tension?
- 02' Drivers door cross beam and window issues ==>
- Strange Problems with Audi
- Paging Diagnosticator1: Still running/happy with the Akebono Euro Ceramics?
- High Iron content in oil sample,can someone comment, please.....
- Wheels and LED lighting Question
- Rough idle, MIL light did not go on, does not run rough.,..
- Upgrading from an Avant A4 rear bumper to S4 rear bumper (for Canadians)
- it took 1 week to arrive, but Hitachi coil packs from 1stvw are here, made in japan
- UPDATE....Sportec + S4 grille
- Where can I buy (CPP) suspension control arms?
- Has anyone modified a Nuespeed exhaust with Vibrant 1304 tips?
- A4 B6 CD Stacker problem
- LOL...found this quote while reading radartest's article on the Dodge Charger Police package...
- nokian i3 tires
- Futrell: Neuspeed Race Springs Need to go - BLOW OUT PRICING
- Anybody have a pic of a Brilliant Black B6 with a Delsa/EBay spoiler? TIA
- are there instructions on replacing the change tray? I bought my car and it's missing the tray
- ecu question..
- how long should genesis 380cc injectors last, rough mileage?
- I lost/forgot the code for my navigation system. Is there a way to retrieve it or reset it with new
- CEL - P0456 - EVAP small leak troubleshooting
- buying 2004 A4 - ownership costs
- two thumbs up for Hitachi CP's! Installed a set last night and now it feels like a new car...
- I'm at 46k miles...will the dealer still replace peeling switches?
- Help with underside cover part number (not the belly pan, but close to it)
- No gas consumption info on DIS for 02 1,8t?
- Are there any drop in air filters that don't require oil?
- Anyone have a serpentine tensioner fail on a 3.0l?
- Will stock B6 S4 wheels fit on a B6 A4?
- most of those cheerleaders were not that hot
- I've been waiting for this to arrive for quite a while now
- forge 007 diverter valve
- Sound Dampening Pan
- little over 4 years and 50k miles later, my car sounds like it's falling apart
- injector question??
- 2003 1.8t Rear Valance
- So, am I reading this right about the Tiptronic?
- Rear Shocks Install Question
- Anyone have a parts book to look up OEM number for
- What's Leather and what's Vinyl?
- Can someone post the number for Clair parts? I can't get their website on my pda.
- JHM short shifters now available at Avalon...
- What'd people pay for their Bilstein sport shocks?
- Trunk Liner Review
- anyone getting rid of their 1.8t airbox?
- So I finally have all my supplies for painting my lowers...
- Motorcity Audi Pic Whore Thread - this one's for you Vin!
- 380cc fuel injector question
- which exhaust would be good if i plan on k04 in near future
- Sprint Booster ?
- sweet, another source for E coil packs
- APR stage 3+ install writeup.... and more
- Wooo!!! Just pulled the trigger on some BFGoodrich G-Force KDW 2's....
- New V-Dub Hotness!
- Clump, my clump, my lovely little clumps...
- Since we are on the topic of DIY's today, I have a spark plug question...
- My first major (major for me) DIY: Front rotor and pad replacement.
- Just found this on e-bay, thought one of you guys might be interested
- Daily Driver
- glove box
- apr or giac....?
- Are the sub frames the same in the A4 & S4?
- Paging southsong and quattrothatcould....
- Finally taking the plunge... BT and supporting gear...
- which injectors?
- Anyone interested to upgrade Cluster to Color Display
- Well, I tried to get the cam chain tensioner gasket without pulling the intake cam -
- Headlight and oettinger sideskirt question
- how do you drain the coolant? where is drain plug?
- ESP
- Can someone tell me what the stock sport sway bar size is on an 03 3.0q?
- well fellas I guess it didn't take me long to step into another Audi - just bought a '99 A6
- How bad is Lugging engine? 10 mph in 3rd gear and when start
- My rear bumper(lower) got hit yesterday. Which rear bumper(lower) should I get?
- New battery
- front bumper, comparing this one to stock price and fit
- For my devoted B6 comrades; Wanted to share some of my Spring VMR Slammage :)
- Question for those with painted lowers...
- Engine fan going on after 40k service...never did before...
- Has anyone had their car chipped througb ECStuning.com
- im just sittin front row at the lynrd skynrd concert hammered drunk
- found the next mod for the wagon...
- My Audi D-Navi Navigation complete 11 disk set Rel 7/02 for sale
- evaporative emissions system problem !!!
- Okay, so I'm an idiot...need help with service interval reset...
- Crankcase Breather Hose Recall experience ...
- Here are my first pics with my new suspension...
- anyone with a bentley page regarding the trunk release switches at the drivers...
- Anyone have B7 RS4 reps on their B6? Post pics if you do.
- How hard is it to change front brake pads? Any special tools needed? The pads are squeaking...
- Anyone have a picture of the rear caliper and its connection to the brake line?
- CityLED regulator circuit and LED package update
- Noticing a general increase in engine "roughness" when driving...
- I STFA, but got mixed result. Putting summer setup back on. Non-directional tires, front to back,
- Can anyone share with me images of standard and USP passenger side fog light grille inlets
- Polishing/Waxing Today: Should I use a stronger detergent to get off old wax (i.e. dish soap)?
