- New VAG-COM 3.0 Label File
- came across this on AZ, milltek/hjs HFC dyno on 2.0t
- Engine Clicking Noise
- I love the 1-2 shift in my car. It has a mightly satisfying 'crunch'. Lol.
- Warm start problem, diagnosis? Going crazy here now...
- Up keep of an 03-05 A4 Quattro
- HELP! Pinion bearing failure
- help with coolant sensor/ t-stat problem.
- Genesis 380cc vs. TT225
- About to get a APR Stage 1. Will I get a CEL light?
- Whats a reccomended Coolant cleaner/flush product? Should I use zerex super cleaner or
- Left garage this morning, noticed a small amount of clear, slimy fluid directly under engine in the
- Check engine light still on after coilpack install..
- running lights stay on when car is shut off
- how much is my exhaust worth?
- stock radio dead after jump starting
- Functionally, what is the difference between Quattro, MB 4matic and BMW X drive?
- E-brakes in the cold
- Where's the cheapest place to get a Bentley DVD for our cars?
- Not bad for the first tank on injectors...
- Timing belt replacement for A4 2002
- looking for a good 3" test pipe. what are people running?
- exhaust question: milltek
- hello guys.. wat is the oem plug's gap size for a b6 a4? my friend car is stock to the bone but
- Thinking of pulling my knob.
- Anyone on here?
- Gas lid sensor problem
- I'm an idiot
- Replace leaking headlight washer jet
- Need advice on possible fuel pump issue on 3.0
- Front door window regulator replacement howto (long, lots of pix)
- Paging 1/4 scale!
- So could it be a dying battery causing my start problem?
- Next mod on its way... Major brake upgrade to complement my front BBK...
- Need info on grill around fog light and centre of lower grill
- 02' A4 Trunk release motor not working - motor is OK
- I finally got two pictures of what the car's dash looks like with the HVAC system out...
- For my 10,000th post, a brief story about something I did today that I had never done before...
- Nothin like a clean b6 =) PICS!
- Never bled the clutch hydro in, say 6 years... would that make the shifter all crappy?
- Is there a DIY on how to change the battery? What tools am I going to need?
- Warranty Fun - yup, it's been 2 years
- front strut replace
- Timing Belt replacement..... (doing today)
- If you've had your Torque Converter replaced...
- 2003 A4 1.8
- Anyone replace an ignition switch?
- P1654 anyone know what this code means???
- Vac diagram?
- What brake pads have gold around the edges? I have a set and don't know what they are.
- Post pics of Eibach Pro-Kit drop!!!!
- Oil level sensor DIY
- Anyone have a wiring diagram for an Apexi AVC-R?
- Late (or early) x-mas gifts!!!
- (low CAR IQ) Groaning noise when making turns
- Is there a separate vag feature where the Trunk doesn't unlock with the doors?
- Advice on tires: dont mix and match. Anyone have 452's?
- ECU for A4 model 2002
- First 1+ question...
- USP steering wheel (w/ S-Line bage) for Tiptronic switch
- Changed out plugs yesterday, and noticed a little oil in cylinder #1...am I in trouble? I assume I
- Good way to start a Friday morning =D
- Anyone selling their car soon? If so, what are you looking to get?
- Has anyone changed their fly wheel??
- Anyone try putting a b6 s4 exhaust onto a b6 a4? Just the rear portion not sure if it fits...
- Is there an adapter to make it possible to just plug and play a rns-e into a b6 a4 with factory sat.
- quick review of my new BF Goodrich g-force SS A/S
- Saw my first S5 last weekend. WOW! Dealer said the A5 was coming next month, I would love to do
- Lease Buyout... Called.... Deal offered by Audi
- RPM r-505 vs. VM v-708 (RS4 reps)
- Detailer's Domain: GB for P21S Wheel Cleaner/Auto Wash 5 liters
- Storewide APR Sale! - Ecodetuning.com
- Stop tempting me .... I'm trying to be sensible
- Recent pics of my muddy A4
- Pictures from when I switched over from my summer wheels
- Symphony II reception issue
- Tail Light Bulb Replacement
- strange headlight behavior!
- maintenance guidance around DC area
- Another update. This time taking out the complete HVAC system and cutting some additional weight...
- Window Switch Troubles
- 3.0L hesitation/cutout...could use ideas
- Just listened to my voicemail and stealership thinks my CEL is from the catalytic converter
- ACHTUN!NG | EuroMesh Wheel & Bridgestone 750RE Package!!
- Anyone with a turbo upgrade in SoCal- Orange County willing to give me a ride before I buy?
- symphonyII to symphonyII+ upgrade - cd changer just cycles thru
- Those who had timing belt done for 3.0, did you have the valve cover gasket replaced?...
- Amulet Red w/ Wheels Pics?
- Hmmm. Apparently a B7'er is upset that I was the top poster in the B7 A4 forum...
- This is a rare Audi but this guy sure wants a lot for it.
- Other than Tgr_Clw, who else here has LED rear lights in the Bayview/Finch area in Toronto?
- Apikol SMIC Upgrade results, Take 2 [IAT logs].....
- Wheel Noise
- Had 15mm hubcentric rear spacers on my factory sport suspension...
- Poll: Ultimate "STOCK" B6 ...(edit) ... EXCLUDING S4 !
- B6 sedan and cabrio share same trunk lid?
- repost ? 2 hoses on n80, i disco and can freely blow through one not the other , this normal?
- '02 A4 3.0 Engine clicking noise
- Replacing Coil Pack(s)
- B6 issues
- 3.0 starting issue. Anyone else.
- What would you pay? 02 A4 @ 70k w/ sludge damage
- HELP!!! Engine problem
- Does anyone know the part# for "skid panel" underneath the driver side?.
- $995 18" TSW and Falken 912 A/S tire package special at Achtuning
- So, I went to the dealer today to buy some coils......hahaha!
- Exhaust for sale in classifieds,
- any one know where i can buy a charcoal canister besides the stealer
- Anyone know of any Tuning shops in Fairfax, VA area? DC? MD
- All Carbonio Intakes Now on Sale @ Ecodetuning.com
- Newbie Question: removing trim to access the battery?
- HOWTO for changing wiper inserts on 02 wiper blades?
- Apikol SMIC upgrade - Stage 1+ results ...
- Misfire 2005 A4 3.0
- What to ask for on the last warranty service?
- Who has the bently manual here?
- all of tsb 92-05-01 wipers does anyone have?
- Anyone ever buy wheels from this OE Wheel Distributors on Ebay?
- garmin gps mount
- A few small questions (brakes, factory body kit, and odd start up)
- Headlight Washer
- shifter hard to move
- My run in tonight with a Gallardo
- Is there a switch 12V wire on the headight switch wires?
- evap emissions control = bad cat? advise please 2003 1.8t 126k
- what bumper is this?
- So Long and Best to Y'all
- Minor squeak of belt when a/c compressor is on @ idle
- Wheels
- Help, my brake fluid is overflowing the resevoir...
- 2002 Audi A4 Owners Manual1.8T Quattro
- GIAC Dealer Map - New Features!
- Anyone have a manual trans 1.8T avant they may be looking to part with?............
- Apikol SMIC upgrade --- > stage 1+ testing complete...
- How much would a B6 depreciate from 106K miles to 116K miles?
- X-Post - About to pull the trigger on the DICE ipod integration kit...
- Any recommendations for car covers for use outside
- Check Engine Light in the Snow
- check out this car lltek is selling
- P0118 - engine coolant temp
- JHM -1" Short Shifter installed and Ashtray Re Install
- 2005 A4 1.8T timing belt
- Will these motor mounts work on an 03 1.8tqm?
- what are some good intakes?
- Will this anti seize compound work for my exhaust manifold/turbo?
- Will bleeding my clutch make engagement any smoother?
- Anyone in or around Tampa, FL?
- Weird A/C vent movements...
- BT + snow tires = tire slip in the rain?
- #1 PW by a long shot ------->
- look what i found about oil sludge...
- Unknown Warning Indicator
- +Pics from small photoshoot back in the fall
- GREAT!!! Just got a CEL, guess its time have the stealership fix my homelink in the visor
- since its warm and wet out i smell coolant coming from the front, since i replaced the rad 2 months
- New Mod Sunday: Alpine Stereo Install
- 47 degrees today = first car wash since 11/22. 44 days of dirt, sand and salt gone. =)
- No air (heat) coming from center vents but it is coming out of the side vents.
- coolant alarm
- Repost of trunk fix from Vier Glühende Ringe for Mayhem 100 - with more detail - remove phillips
- are teh temp sensors at the back of the engine and on the lower rad hose the same part?
- why does my coolant look like this?
- Strange sound-Has anyone else experienced this?...
- What is the best site to get Nav parts??? Ipod, Bluetooth, and other accessories?
- Weight cutting taken to the extreme, no make that to another level! :-)...
- I pulled the trigger...
- Sirius reciever trade for XM ?
- How often, (miles) do you change your fuel filter??
- those with bentley/etka/etos
- I think my car's chassis just got a little stiffer, OK maybe a lot more stiffer...
- A question for anyone who has removed the MT shift knob...
- Pulley change with Timing Belt service???
- Exhaust.... Anyone looking for an Exhaust for an Automatic...
- What is the best color for a b7??? Opinions Please...
- Will a VW GTI K03Sport Turbo fit on a B6????
- Please advice on VAG-COM fault Codes A4 2002 1.8 T Q
- Last day to score a deal on the most balanced sub $2,000 suspension out there.
- Any of you guys members of AAA?
- recommended oil change intervals?
- need torque spec for transmision brace bolts
- aftermarket exhaust and re-tune
- Grr... APR driving me nuts. Anybody had issue and APR actually gave good service?
- Advice please on 2004 A4 3.0 Avant
- guess some1 had to steal the torch
- time for nightvision
- Opinions on intake?BPV? 2004 A4 1.8t, 6 speed
- Converting Euro Spec headlights to US spec
- Apikol SMIC's are finished and ready for delivery...
- Short shifter?? Which is best???
- anyone in or around Birmingham AL?
- B6 A4 reliability
- What bolt/hex/cheesehead etc on '02 5 speed manual transmission fill/drain plugs?
- Replacing face in console?
- 2005.5 A4 1.8T Special Edition - Timing Belt Change at 60-70k mi?
- ESP light came on.
- Test drove the Golf GTI today....
- yay Quattro!
- Brake booster problems after plenum drain recall service done?
- Does anyone have the Cigarette Lighter Schematic/Diagram on a 2002 A4 B6?? Not sure how it comes out
- OK. a real noob question here.. how do I identify chassis: B6 or B7
- How to fix broken glove box?
- Achtuning APR holiday sale ends January 4th!
- In the past 24 hrs I have purchased:
- :: ECS Tuning :: ECS RA4 Steel Clutch Kits - Price Drop and Free Shipping !!!
- Looking for help from AW'ers with ETKA regarding brakes...
- XPost.....any comments/ideas appreciated.
- coolant
- Clutch Options?? need to change this month
- Rant...Trip #7 to the dealership since August 06.
- anyone have any experience with BIRA.org? very interesting....
- buying B6 A4 w couple more questions..
- Brake lights come on during cold nights
- euro trunk? anyone running one? i know a lot of the b5 guys run them..
- shifter was frozen sold this morning. could not move it an inch..
- Confirm: Fuel Sender issue?
- What bolt (anti-seize) paste do you guys recommend for the turbo and exhaust manifold?
- Help with Warranty Expired
- Free power upgrade!
- Has anyone experienced an itch to replace their B6 lately?
- Audi ipod adapter question
- What do you call the the underbody cover that runs underneath the car, below the driver and rear..
- Timing belts questions for 3.0 Quattro...
- Anyone got a diy on tiptronic fluid (1.8T) change with filter?
- Squeeky rear seat
- Oil catch can levels?
- To Mike @ Pure
- Wiper length??? 22" on driver and passenger?
- XM radio not in use?
- Need new cams / lifters on 02 A4 3.0 w/74k?
- Satelitte Radio
- Trying to id high pitch howling noise from front of 3.0
- Does anyone know how to change these vac lines coming out of these two round things on a 3.0?
- Changing the front signal light
- A4 and A4 Cab rear Floor Mats...
- Beemer H/S
- Part Number for screw that holds OEM lower door trim
- How the hell do you remove the rear seats?
- 02 3.0 Brake master cylinder reservoir top leak.
- I think I'm turning into MBtB...
- I put my Winter Wheels.....
- Happy New Year to everyone. May the Audi gods keep your cars running in good shape...
- Wishing you a prosperous and mod filled "Happy New Year"
- so its seems like most people think the 1.8t cvt goes kaboom with a chip but i still don't understan
- Completed Crankcase Breather Hose recall today
- First impressions of my GT3076 turbo setup
- 02 B6 Trunk Not Releasing
- Need Help PLEASE ASAP! Clutch Slave Cylinder Bleeding
- Know of any good indy shops in the Minneapolis/St Paul area?
- Installed my APR stealth exhaust this weekend - Love it!
- Auto leveling Headlights
