- My Audi won't shift from 1st gear
- UK: Need help, some sort of electrical gremlin!
- Need help with my comfort module!!
- Help! Timing Belt issues
- She's Alive!!
- Steering rack leak
- 7.5J ET43 "18 which spacers to use?
- REAR DOORS WON'T OPEN
- RO: Turbo problem noisy, no boost
- Intake Valve Restore
- Vw/Audi seat connector pins
- ABANDONED 2002 A4 1.8T quattro with manual transmission
- Lost my only key .. how do I bypass
- Brake Servo Rod Adjustment
- B7 Glovebox airbag switch removal to fit B6
- Muffler delete
- Help! Cranks but no start. No power to fuse 28
- UK: Is something missing here?
- Audi Brake problems
- UK: Scrapping My Audi
- Air bag warning light on - Help Please
- Buying a B6?
- A4 2005 wont run.
- Vacuum line help
- 03 3.0 v6 a4 engine sputtering?
- 2005 A4 B6 V6 3.0L M/T "Deleted" Systems
- 1.8T 190PS Overheating while driving
- Manual Seat Swap To S line Seats
- Catless downpipe without exhaust.
- Help! 1.8t rev limiter at 3200 rpms
- ABS pump stuck in open position (always on)
- F***#@! Starter (AMB 5MT)
- LT: Speedo needle shows less than actual speed
- PO171 Code - AGAIN
- 04 A4 rev limiter/limp mode?
- Seat belt electrical connection
- In need of help or Info!
- P0300 & P0302 & P0303
- UK: Starts and stops immediately - anything i can try?
- Engine Management Light Help?
- UK: Just a few things from an Audi diesel noob
- 2003 3.0 fuse box/electrical question
- what do I connect my accessory wire to?
- Transmission replacement
- Need some help
- AU: Help!! 2004 Audi a4 quattro 1.8t b6
- 2004 Audi a4 quattro 1.8t b6
- Audi A4 B6 2007 error code P0404 P0403
- DK: Audi 1.9 transmission failure, 2004 diesel
- Audi A4 start problem
- P0171 code, when cleared engine shaking
- Head and camshaft questions
- B6 Custom Tuning
- 2002 A4 Symphony am/fm antenna booster replacement
- Issue Starting
- Car Shakes while Accelerating
- 2003 A4 Battery Drain
- Does B7 front wiper linkage (transmission) fit B6?
- Misfire in Cyl. 1, 2, and 3
- Retrofiting s-line electric seats
- BG: I cannot find the make of this bumper
- Noob auto transmission question
- Need 2002 A4 B6 Relay location diagrams
- 2001 A4 B6 3.0 Quattro overheating
- Speedo/ABS problem
- Do you have to loosen cam pulleys when changing timing belt?
- New owner seeking advice on some issues
- Question relating to the MMI software/tel button/bluetooth
- Weird sound from TIP
- HELP Please! Car turns on but then turns off.
- 2002 Audi A4 Manual Won’t shift through all gears
- Help service position for 3.0 v6
- A4 B6 instrument cluster parts
- Help door is not opening
- ABS failure P1623 / no communication
- TT: Where can I purchase Audi A4 2011 model piston android rings online ?
- Broken intake actuators. Do they matter?
- Coolant leak under front crank shaft pulley
- RNS-E problem
- BE: Child Lock not working
- Driving without Fuse 31 safe?
- SE: 1.8T , Engine can't maintain normal operating temperature.... ?
- Simple Fix? Fault 01119 Gear Recognition Signal Intermittent
- Overheat now intermitten low oil pressure
- Just bought my first 2005 Audi A4 Quattro B6
- Camshaft position actuator fault 3.0
- Bumper replacement
- 2002 A4 1.8T running fine, today won't start
- 2004 A4 coilpack pinout
- 2016 Audi a4 quattro 2.0t loses power when flooring it
- Missing bolt?
- convertable top issues
- 03 a4 quattro 1.8t oil leak
- Problem code poa11
- ABS control module compatibility
- Error Code 18010
- Coolant leak from metal pipe next to engine head
- Radio volume
- Radio volume
- Need suggestions
- UK: Audi A4 B6 Avant BDG Engine
- Audi A4 2.6 B5
- Symphony II RDS vs. SAT version for 2002 A4?
- CCM?
- UK: 2002 A4 B6 - what wiper blades?
- Abs, eps, air bag light on, brake light flashing
- 2004 a4 1.8t 6spd Flashing CEL, lost ALL acceleration power, please help!
- Slave cylender
- Help with a stuck steering rack?
- Remote Entry - Where is the Receiver on Quattro?
- Headlights: HID vs Halogen
- Key ignition swap
- 2008 Audi A4 Climate control
- Secondary Air Pump N75 delete kit AMB 1.8T
- Immobilizer issues
- Losing coolant in a4 b6 be engine
- 2004 B6 3.0 v6 Quattro Sedan Buying Advice
- Car stalled mid-drive and doesn't start
- Another "Hooked front bumper unknowingly over curb upstand, damaged it when later dri
- I dont have AC in my car :(
- Steering wheel wobble
- Location of High Pressure port of A/C?
- BG: Front wiper problems
- Clogged Cat
- Audi AC not working one side and fix
- UK: Center High level brake light
- Rear subframe compatibility
- New to the game, searching for info!
- A4 B6 Unknown Turbo Issue
- Airbag problems occupancy sensor too high
- heeting steering wheel Audi S4 B6
- 2002 A4 buying advice - misfire
- Trying to decide on an Intake
- Indy repair near Nyack, NY/Northern NJ?
- Quattro front differential
- VIDEO: Super Slow Acceleration, Limp Mode? Fix loss of power? 2003 Audi A4 B6 1.8t
- Roof lights and vanity mirror lights not working 2003 A4 B6
- Radio doesn’t work after unplug
- Coolant leak from back side of Motor.
- Central convenience module issues?
- Slow front wipers
- Audi a4 long crank over before start
- Selling 2004 Ultrasport 3.0 6MT for parts or repair
- A4 Avant radio and navi question
- Roof rack
- Roof rack removal help!
- CYL 2 Misfire - NOT COIL, PLUGS or Coil wiring?? - Codes provided
- Delayed Start
- HELP !! HELP!!!
- 3.0 engine swap. Having serious troubles and need help
- Front/Rear Premium Cross Drilled and Slotted Brake Kit BRAND NEW
- 2006 B6 A4 Cabrio 1.8T FWD auto - ABS module replacement
- Maybe a dumb question that I think I already know the answer to.
- Power windows/central locking/electric mirrors/speedometer don't work anymroe
- Weird HID Issue
- Blinking Check Engine Light!
- A4 B6 crank no start
- maybe I'm crazy.......
- forced induction advice/ EPC +ESP in RAIN????
- 4 Hood Wires 1 Big Headache / New to forums
- fuel injector cylinder open all cylinders
- Free remap ?
- Help...roof issues!
- Audi a4 b6 1.9tdi 131hp
- AMU head on B6
- A4 B6 2003 side airbag sensor
- Where to roof rack locks/keys?
- 02 a4 quattro 3.0
- 2004 audi a4 3.0
- Audi a4 b6 1.9TDi 131 hp 2002 Engine hiccup
- Auto to Manual swap - HEP tranny from S4?
- 17939 - Camshaft Timing Adjustment: Open Circuit
- Parking Aids??
- 1.8t oil pressure/smoke/turbo
- A4 (B6) Cracked transmission oil pan: Is tranny ruined?
- 2004 1.8 6spd quattro crank no start
- EPC and P0322 won't start
- AU: Just acquired 2002 a4 1.8t multitronic
- Clutch kit for 2002 to 2005 A4 3.0L
- Airbag light comes on after 10 mins
- Brake skidding
- wiring diagrams help please
- Breather Tube Fitting
- Lost 1st and 2nd on my 2003 Audi A4 3.0 6 speed. (Doing a pull)
- PLEASE HELP -P0421 code - installed spacers and now get P0141 (O2 Sensor Heater) code
- What does this stumble mean and will it prevent starting my car
- Uh oh yellow gunk on dipstick
- Stuck in Park after gearbox change
- Rough Idle/Stalling
- 2005 A4 4-CYL, 2.0 LITER WAGON
- Low oil pressure at low RPMs, PCV issues
- Sunroof Popped Down!
- no brake pressure after replacing master cylinder
- What ELSE sounds like a bad tire?
- 1.9tdi Smoking
- No start rapid clicks and sound from ecm
- B6 a4 1.8t side mount Intercooler
- Codes leading to limp mode
- Where's the key fob receiver antenna?
- 1.8t B6 Avant turbo smoke
- Leak after replacing rear coolant flange
- 1BR suspension codes for springs and shocks
- USP Lower Valance & Lower Fog & Center Grills?
- High Pressure fuel pump
- broken dip stick
- Window Regulator issues Front Driver Door
- RS: A4 2.0 FSI
- getAudiparts.com | Last Minute Holiday Savings Promo Code: HOLIDAY2020
- 8K0601025K wheels on A4 B6?
- Both key fobs
- 2003 a4. Key fob inop, alarm set off constantly, doors won't lock
- Breake light, abs and glowplug light, headlight
- 02 a4 avant b6, lower coolant line won't go into radiator
- Electronic slowly dies
- Help I'm stuck.
- Speedometer moving to fast
- 1.8T AC compressor
- 2002 A4 B6 Windows not working
- No Power to HVAC servo's (Flaps)
- Brake upgrades for an ,04 A4 USP?
- deAutoLED Black Friday and Cyber Monday sales are LIVE NOW! Best prices of the year!!
- LCD screen reads 0 l/100km permanently.
- My 2005 (B6) 1.8T Won't crank
- Help with Symphony and rear speakers
- SOCAL - Looking to Sell (2) A4's (2003 & 2004)
- Wild rats ate my baby wires...
- poor acceleration issue no codes but i hope you help me please ?
- ESP light and acceleration cutting out
- How to test transmission speed sensor?
- Clock on dash keeps changing after car sits for couple days
- HELP! ISO discontinued trans mount
- Parts?
- Hot Rotor?
- EE: A4 b6 engine codes?
- A4 V6 top-end engine noise (sound clip)
- Auto lights on 2004
- 2002 Audi A4 3.0 Quattro Ignition & Electrical Issues
- 2005 parts onto 2004
- ZM: Bleeding air from Audi A4 1.8 T
- Audi B6 1.9TDI rattle noise
- Exhaust Flexpipe Removal
- A4 B6 3.0 Diy Smoke test Question
- 1.8T BFB Boost cut at 0.3bar
- Weird squelling noice 1.8 t
- Help with an install of forge splitter valve I think?
- Crash Sensor location passenger Side Airbag
- A4 UYD number plate?
- A4 B6 Subframe
- No Compression - Can't See Why
- front grill dimensions?
