- Glowing red manifold/turbo and rattle.
- a few iphone pics of the joey mod results from last weekend...
- Is there a way to tell from a vag scan when somthing happened?
- joining the 3.0 members d-base
- Those with Bilstein + Sport Springs, what perch did you set front and rears at? I'm hoping for 25"
- Oscilating Idle. My First Post Here.
- anyone used energy suspension?
- Will the Bentley CD show me the wiring diagram for the rear oem radio amp (non bose)?
- Flow Audi Trackday! (56k I don't think so...)
- Check Engine Light Question
- Introducing the New Hartmann RS6-204
- Any one partiing out a B6??
- thorttle body
- Timing Belt Inspection- Should Be Replaced!
- zOMG...B6 3.0 Turbo!
- Since the Koni Sports are going in tomorrow, ideas on the dampening settings?
- Nice 6 speed Avant 3.0 on Chicago CL....
- Anyone w/ some 17" for sale? Preferably in Northeast.
- Stupid Question
- 2 more days!
- APR Customer Appreciation Day and Grand Opening
- What's a good place to list a pair of Vibrant 3.5" tips FS??
- Anyone have pic's or diagram on how the hood latch
- B6 A4 reliability - better info - please sign up
- DIY mods
- finally decided to go with coilovers.. but which out of all of them offer great handling/comfort?...
- who all has 19" rims? Looking to upgrade wheels
- Anyone have an S4 bumper grille to sell? I want to do the "EddieMod"
- GROUP OPINION - what's everyone's thought's on buying a used Milltek HFC with about 10K on it?
- 2003 A4 3.0
- EVAP Purge Valve Wiring help
- Would I have any issue if installing 205/60/16 winters instead of stock 215/55/16? Tirerack shows
- Fuel trim problem.... Help Needed!
- 03 A4 tiptronic trans failure tips
- Audi part number for spoiler? door blades?
- Probably a stupid question, but on genuinevwaudiparts.com when it says left and right tail light....
- Look what UPS delivered today...
- What is the P/N for the interior carpet in an A4 sedan
- AudiWorld's Petit Le Mans 2008 gallery is live!
- Joey mod complete...
- Dead Speedo and CEL light
- Need Help, my RNS-E seems to be acting up, I have zero signal going to the rear (rear speakers)
- Do you ever just get sick of your Audi?
- Anyone near Kansas City that can do me a favour?
- Sometimes it's good to see your car from a different perspective. =)
- got pics of after market single din radios with the 2 din mounting kit?
- My SSK or something is out of whack...
- Question about B6 E-code Turn signal/Blinker light bulb
- Dash cupholder part# request
- Need a part number please: Rear Rubber exhaust hanger. L or R, probably same.
- Paging any welders, X1rider? What is the proper way to remove a downpipe flange to change its angle?
- I've STFA, and temp gauge saga continues:
- Timing belt replacement - recommendations in New Jersey
- More misfire fun...
- Is there a published DIY for the 1.8T timing belt on the B6 A4? Looking for a friend, thanks!
- Someone suggested the JHM Shifter. That's a piece of art, too bad its covered by the boot.
- Many thanks to nanotech for a great front door window regulator replacement how to on a B6...
- What is the difference in the Control Arms between OEM sport suspension and OEM non-sport?
- What could this be? I dont think its oil but....
- experiment - painted hood grill. Too much silver?
- What is the order of the cylinders on the 1.8T engine?
- Engine/Electrical Troubles
- Brake light on panel blinks
- Drove new A4...
- Body alterations
- Re-building coilover struts....leaking
- What warning light should one expect if the clutch loses hydraulic pressure?
- Sorry if repost but this is a prime example of when NOT to cut corners.
- Car has OEM 35w HID's. Is there am upgrade to 55w that worked with the OEM
- Hey just curious guys regarding CAPs/FATs... 6speed Quattro 1.8, use Fats Rpm or Caps?
- Remember my beautiful custom made FMIC I had made and installed last summer (2007) well...
- Gonna Joey mod my headlights this weekend...
- Question about what gas we can use on 1.8T
- Which of these springs will give the bigger drop to my USP with koni sport shocks.......
- I just realized that a BBK upgrade is not as far fetched as I had anticipated.
- some good winter mod ideas?
- anyone done the boat mod?
- PSA - you guys may wanna clean behind your door flares. i checked mine...
- going to install my wheel stud kit..do i use thread locker or antiseize?
- Remote key not working properly - Please help
- Strange misfire issues when the car is cold..
- Thinking to DIY paint the lower
- Hartmann Wheels Blem Sale
- I've had a annoying buzzing noise comming from my dashoard just
- Do CV axles need to Break in?
- teh million and one sensors in the car
- Who is using the Avic D3 or Audi NAV? Is there something else a little cheaper?
- Please Help!!! Looking for Part Number
- So after 94,000 miles, I finally lost my first coil pack...it was a J model. So, I have 1 R and
- Front tires are shot: As a follow up to my post about a vibration that has been getting worse...
- Oettinger`s Fall into Winter Sale Starts October 1st
- Audi Junki - oil change question?
- Brake malfunction? (sort of long)
- Bumper Misalignment
- R Rear and L Rear light warning?
- PSA- if anyone is interested in retrofitting your B6 with OEM sirius, I just listed in classifieds
- Factors for determining ignition timing?
- Headlight issue rectified!
- Your last chance to get Bilstein Shocks and Coilovers at the current price
- Need Jack stands recommendation for our B6 A4
- Porsche ???
- :: ECS Tuning :: InPro Chrome Mirror Cover Set - Back In Stock !!!
- I've developed a strange problem. Anyone have their coolant overflow reservior separate?
- :: ECS Tuning :: B6 A4 Valeo European Headlight Kit - Back In Stock !!!
- For those Audi owner with chipping black electrical switches, simple fix
- Oil Pressure light on on 2002 A4 3.0
- Readiness code problems
- TCM in 2004 A4 1.8T
- '03 A4 Avant headlight problem
- I'm getting 18.8 MPG. What the hell?
- is there anything that I need to check/do with my car @ 47-50k?
- Anyone VAG there car after the N249?
- Should I?
- N249 - Wow!
- any mets fan here?
- I was bored so I decided to paint the rear trim on my S4 bumper. I like the results
- Question for DIY experts.....another sealant question related to Cam Chain Tensioner gaskets
- Aero wiper kit question?
- N249-Two thumbs up!
- change rear bulb screw up...
- Anybody using 10% ethanol on their chipped cars??
- She's still running!
- VMR Wheels | FALL SPECIAL - RECEIVE FREE MOUNTING AND BALANCING!
- Anyone have b6 18t 5-speed sprot pak springs? I need a set bad...
- **Revo Techniks National H2Oi Sale Begins Today!**
- ***Now Shipping*** A.W.E. Tuning Performance Brake for the for B6 A4
- Selling a full set (all 4, front & back) of Bilstein Sport shocks. Half price
- 100,000 mile check up results!
- I saw a Euro B6 A4 on my way back from class...
- engine cover?
- What kind of tint comes stock on our cars?
- what is the n249 mod?
- Selling a full set (Front & Back) of Koni Sport shocks. Half price.
- My new improvement
- Is there a measuring block to check the VVT solenoid?
- Poll: What brand/model tire are you currently running on and what brand/model will you get next?
- Repost: PureMS.com Summer Coupon Codes!
- Anyone know if any of the PODI, AWE, and ECS boost gauges dim with
- VMR Wheels | 18" Winter Tire Packages!
- Speaking of winter tires...
- Badly scuffed/scratched some interior panels on my car... is this the solution?
- Quick question: Bulb number for the A4 tail light? Thanks!
- VMR Wheels | 19" V710 Available! Wheel and Tire Packages available!
- Local mechanic for timing belt
- Questions: Cam Chain Tensioner gasket and RTV Sealant......
- Question about how to best mount my icelink...I previously had it mounted to the top of the
- In general, how thick should a front splitter be? 1/4", 5/16", 3/8". I'm thinking 3/8'
- Back of Driver's Seat falling apart - '02 1.8T
- :: ECS Tuning :: ECS Vent Boost Gauge / Pod Kit - Lower Price - Free Shipping !!!
- 2002 A4 1.8T, 6200 miles - what is it worth?
- APR stage 1+ questions
- Quick question/survey for A4 owners
- I really love planting my head in my hockey bag and taking big whiffs of that joyous smell
- any ideas?
- A.W.E. Tuning B6 A4 Vent Mounted Boost Gauge Kits In Stock and Ready to Ship
- Is my rear suspension dead? 2002 A4 w/ Sport
- Tree sap
- did my n249 bypass this morning and this is how it went...
- PSA. AMS Short Shifter 5sp for sale on AZ classifieds.
- wanted a new sig so i took a few shots of my car this past weekend..which one do you think is best?
- Steering and Clutch Becoming "Heavier?"
- I'll go with H&R sport springs, bilstein sport shocks but whats the dif. between coilovers...
- Who was it recently that had issues with car stalling and ESP light coming on upon restart?
- Induktion Motorsports Presents: H2O 2008 Specials! GIAC / AWE / STACK / EVO / More!!
- Cam Tensioner Seal Needs Replaceing
- Any of you guys running these lights? I would love to see them on silver.
- wow, this N249 mod is great, I'm hittin 21lbs in 3rd, not sure why I'm getting more boost now but
- STFA already - water temp gauge went past middle twice; first time slightly, next time to Hot...
- How do you guys make your rotating sig?
- $800
- Power Steering BT: it feels like my power steering pump will be on its way out soon
- where's Mr. trg_clw lately???
- Oettinger; German Parts for German Cars
- what exhaust should i get ???
- powder coating wheels
- which is worth the money coilovers or springs/shocks for daily driving i'm a non-track person.......
- Milltek container arrives here this week. Lots of A4 systems.
- Bluetooth/B6 Parrot CK3000/other BT:
- What's the highest mileage you can safely go without a timing belt change?
- Transmission Control Module
- if i were to replace all the vac hoses with silicone, what sizes and length would i need?
- Details on my Buy-To-Order car program. If you are looking for a used A4, please see inside.
- Are there certain lights you guys recommend for brake lights and tail lights?
- Car die on me :( 2002 audi a4 1.8t 101000 miles
- E-brake is sticking on the rear passenger side
- Airbag soap opera
- Did the N249 mod today...best free mod!
- A few B6 A4's representing this afternoon at the Northeast End Of Summer GTG.
- audi a4 b6 2.0
- Choices to make......
- Need Advice: Replacement Multitronic/CVT
- Cracked leather!!!!!
- Finally powdercoated something!!! (flat black valve cover)
- damn, think k04 just died or is it something else?
- rough idle??
- Brakes???
- Here's a great way to clean the inside of your valve cover
- Watch out boys! I've decided to go bigger but I'm dropping the Full Race tubular exhaust manifold...
- Coolant Flange install question
- Wondering what my avant is worth...
- how many of you have bypassed your n249? If so, any difference?
- Exhaust Q
- I was behind a B7 Cab the other night, and I really dug the tail lights
- Jet Jockey any alignment suggestions for auto crossing/track
- How do I take out my ecu?
- Last Under Warrenty Service Questions...What do I have them look for?
- HELP!!!!....malfunction!!!!
- issues with automatic a4 1.8t
- Only a matter of time before someone came up with these...
- Wow, the vibration gremlins are out VVVVV I'm experiencing a wierd one as well, please help!
- Help. What do you think could be causing this vibration my 3.0 is experiencing?
- Some maintenance items I need clarification on...
- (Xpost) Anyone have an auto-dim with compass mirror for sale?
- Can someone school me on resurfacing the flywheel?
- My solutions for Error code P3081 and p0118
- :: ECS Tuning :: APR B6 A4 Cold Air Intake & ECS Carbon Fiber Engine Cover Kit - On Sale !!!
- Well I called AoA today
- I know this is a B6 forum but I can't help to voice my opinion on the B8
- B5 S4 vs. B7 S4 brake system
- OEM Battery Life
- Wheel clearance at Achtuning, new selection and lower prices!
- Does anyone know the actual part number stamped on this antenna?
- Will a K04 from a B5 A4 (2000) work on my 2003 B6A4 1.8TQM?
- Timing belt long over due
- 1.8T timing belt campaign issues...
- Quick release screws part search
- Keeping Water out of the ECU Box
- Anyway to tell how worn the factory shocks are?
- If you can drive through a vibration, does that usually mean it's a simple balancing issue?
- Audi Extended Warranty Group Purchase, see inside for details if interested
- I possibly need transmission differential
- Rear door window problem: motor runs but window wont go up...
- Has anyone here tried this yet? (running DV right off the intake manifold)
- New check valve iteration (no longer black and grey, now all black)
- I messed up - how much does a USP rear bumper cost?
- I think the flex joint on my exhaust is leaking, what should I expect a repair to cost?
- Random Misfires When Under Boost or Heavy Throttle
- Need Advice-engine stalling at startup
- RS4 e-brake perforated leather handle part number
- JayP - you have the track mounts or the street mounts?
- Lug bolt questions...currently looking at putting 8mm spacers to bring out the rears
- News flash: From Automotive News Europe "Porsche says it controls VW, offers to buy Audi.".
- Poll: If you owned a 6 year old car that you planned on keeping for at least another 4 years
- CVT transmission slippage??
- Engine Speed Sensor (G28) replaced! I noticed an interesting thing though...
- Northeast A4 owners......
- How much is worth a B6 used muffler in good condition?
- what to look for in a4 1.8t used??
- CEL on the car today, turns out bad TC
