- All H&R Coilovers 10% off for the next two weeks, from AWE Tuning.
- P0302 Issue Crackling noise
- Exhaust Ideas?
- Transmisson removal notes
- Intercooler kit and cold air intake
- Engine Health
- leather seats
- Save 20% off damaged Sonax 5 Liter Full Effect Wheel Cleaner! Limited Qty
- HELLLPPPP !!!! Audi A4 2003 Wipers don't work because an electrical fault !!!
- left rear fog light
- A4 Nav....
- Parting out 2003 A4
- New Alzor 18" Classic Mesh Style Wheels -w- Deep Polished Lips Under $550 a set!
- Roll less for less. All H&R Sway Bars on special pricing at AWE Tuning.
- fan control module - correct ECS part?
- A4 1.8T Quattro Issues
- S4 to B6 brake conversion
- 2 Codes: 0171 & 0172 Lean & Rich
- FS: 17" flik lex wheels
- Looking to Get an '05 Audi A4 3.0L w/125k miles - Need Feedback Please
- Audi A4 2003, Brake lights not working even after new Brake Light Switch.
- 2003 B6 A4 1.8T quattro avant - 'drop in' fuel pump upgrade 350 cHP
- 2004 Audi A4 B6 1.8T aftermarket intakes
- Replacing ECU housing box?
- Question about Radio Swap
- :: ECS Tuning :: B6/B7 A4 FK Highsport Coilovers!!
- overboost driving me nutz??
- Vehicle shifts to "S" mode on its own..
- New Q5, miss my 2002 A4.......
- B6 A4 dual fog lights
- Driver Side Window
- B6 a4 3.0 no start... weird compression readings... (video inside)
- Glovebox door malfunction. Fix it before it gets wor$e!!
- :: ECS Tuning :: RS4 Rear Sway Bar Kits!!
- Can someone tell me what this (broken) emissions part is?
- aluminum trim
- :: ECS Tuning :: B6 A4 1.8T RA4 Conversion Clutch Kits!!
- AWE Tuning's annual BBQ and Car Show is coming up fast.
- What does this warning Light mean?
- Stop everything. Free shipping on all StopTech and Brembo BBKs from AWE Tuning
- Cost of 75K Service with Timing belt
- Removing windshield screen?
- CVT shuddering, hesitation: FYI Personal experience - Cooling!
- Alternator Noises?
- A4 not starting
- :: ECS Tuning :: Alzor Style 621 for Your Audi - 57.1 Fitment!!
- 2005 Audi A4 B6 17766/P1358 - Cylinder 2 Ignition Circuit: Open Circuit
- Vibration / Loss of power at 90km/h 04 A4 3.0
- B6 A4 Misfire on cold start and white smoke intermittently
- GTRS sudden crazy running at part throttle..
- A/C not working need help please!
- Oil Level Sensor 1J0907660b or 1J0907660c
- Were is the ignition fuse on my A4 b6 1.8t
- Door Control Module test?
- blower motor removal
- Wiper arm "spoiler"?
- Cranks but wont start
- oil change length
- Chasis Question
- Bilstein Coilovers, 10% off until July 21st at AWE Tuning
- 2003 Audi A4 B6 3.0 Quattro Blower Motor
- Churning from rear passenger side?! Help!
- ECS interior bulbs for B6 sedan/avant
- Fans running wild - fixed!
- boot lid will not open now key fobs dont work???
- ignition coils
- Trunk won't open from outside
- Test drove 3.0 A4 Wagon - rough idle
- Do my side Mirrors fold?
- B6 A4 1.8TQ WONT START PLZ HELP
- Drivers Side Window/Mirror Switch Help.
- Detailer's Domain - July 4th Special
- Center console armrest door/lid replacement options?
- Guys need help. So peed off
- R-134 low side core valve(schrader valve) replacement
- CVT Class Action Lawsuit
- help with tiptronic
- New battery and car still wont hold charge
- Missfires,dont run smooth :S
- Cat or O2?
- All cylinders misfire???
- Suspension parts to replace with 135K miles
- A4 3L V6 intake actuators
- what is strange panel in trunk?
- H&R Springs, 10% off through July 7th at AWE Tuning.
- Looking for upgrades for my 2002 audi 1.8t q
- :: ECS Tuning :: Alzor Style 604 - 18" 5x112 Wheel Sets for your Audi!
- Best High Perform A/S Tire for 1.8TQ Manual?
- Unknown Part
- Cooling fans running when car is off
- :: ECS Tuning :: Stage 4 Front Big Brake Kits!!
- B6 A4 recaro dilemma
- 03 A4 1.8t Won't Start
- HELP, Car won't Start/ crank!
- 04 A4 1.8T ac fan
- Broke Piston Rings
- Transmission problem need help please! Audi a4 2002
- Vaccuum Lines!
- 2014 pricing announced
- :: ECS Tuning :: B6 A4 Euro-Look Halogen Headlight Housings!!
- AWE Tuning's second annual Flashdrive is upon us.
- circuit breaker for windows a4 b6 hood sensors
- chrome fog light trim???
- A/C "Econ" lights up, hot air - but new compressor & thermo-switch??
- 1.8t crank difference
- Quieter performance exhaust and airbox
- Overheated - Now low compression
- Ultra Sport Package lower center grille
- :: ECS Tuning :: ST Summer Savings!!
- Forgeline Wheels, now available at AWE Tuning.
- new 03 1.8t leaking from front and rear main seals
- :: ECS Tuning :: ECS Polyurethane Snub Mounts - FREE Shipping!!
- The updated Hawk Brake Pads catalog, now available with Free Shipping- at AWE Tuning
- Finished My 3.0 Timing belt
- Audi Invoice
- relay locations for 2002 B6 3.0L
- Audi A4 wants to keep going forward after braking! :(
- Totally dead, Battery is good. no lights, no locks, nothing.
- Code P0420 help
- Help with Shifter Screen, Please!
- Boost Issue, Limp mode, And DV issue. HELP!!!
- Help! new Audi owner 05 A4 Avant quattro "skid plate"
- 1.8 triptronic, fluctuates rmp at low speeds!! no codes
- Emergency help needed
- Buying mom an audi
- experiencing issues and spark plug questions
- 1999 audi a4 quattro trans issues HELP!!!
- Temperature gauge behaving weirdly
- Memorial Day Special at Detailer's Domain Starts Now - Stock up!
- Wheel Cap Help Please
- Fuse : Cigarette Lighter
- :: ECS Tuning :: B6 A4 1.8T RA4 Clutch Kits!!
- A break on Brembo Big Brake Kit shipping, from AWE Tuning
- Coolant Leak - First Water Pump Now Thermostat Housing
- Should I buy an A4 has been into accident ($12000 repair cost through insurance)
- changing factory halogen to oem hid...is it possible?
- :: ECS Tuning :: Heated Blind Spot Mirrors!!
- Paint peel interior
- Problem overheating plus no heat, need your help
- Do you ,like nokian
- Doors not Locking - Comfort Control Module Location - in Floor or Under Dash?
- Need good Audi mech in NY SI or NJ area
- 02 a4 headlight dimmer control missing
- Weird Clickng noise coming from accelerator pedal area
- fault codes please help
- :: ECS Tuning :: Schwaben Floor Mats For B6/B7!!
- 245/45 17
- Summer tires
- Help! Question regarding service light
- Stock up on detailing gear before Memorial Day @ DetailersDomain.com
- :: ECS Tuning :: B6 Aero Wiper Blade Kits!!
- Noise (air/hissing) from hose and need expert
- Rust warranty
- Flashing gear selection (rndp) dash lights ?
- Submerged A4 restore
- What kind of turbo upgrade should I use
- Headlight repair tabs installation question?
- All G.I.A.C. Software, still 10% off, at AWE Tuning.
- Rear View Mirror Fell Off
- :: ECS Tuning :: B6 A4 V6 30v Timing Belt Kits!!
- AWE Tuning presents Volkstreffen.
- Footwell lighting / door open detection problems.
- :: ECS Tuning :: B6 Vent Pod Boost Gauge Kits Are Back In Stock With FREE SHIPPING!!
- many many codes
- Slow down! Free shipping on StopTech Big Brake Kits at AWE Tuning.
- HELP! 03 a4 quattro 1.8t red oil light problems!
- Silly But Annoying Problem-- Any One Else?
- DIY: Wiring an AUX into the Symphony II WITH XM radio
- :: ECS Tuning ::Pipercross Filters - Like No Other Filters Available For The B6/B7!!
- Exhaust for the 1.8t
- what coilovers for avant b6 2.5tdi quattro
- HELP OVERHEAT WEIRD NOISE SMOKE>
- A4 P0688/Idle Issues...Help Plz
- coolant sencor
- RPM needle shuddering above 3rd gear??
- Going lower on Coilovers and Cup Kits, at AWE Tuning.
- DIY: Bad Reception of Key Remote and Radio FIX!!! Yes Really.
- Looking for lowering springs
- M
- :: ECS Tuning :: NEW Color Key Fob Covers!!
- Headlight bulb constantly blowing?
- recently moved to woodside, NY
- IS THERE A DIFFERENCE BETWEEN 05 A4 AND 05 A4 QUATTRO HOODS?
- 2002 a4 3.0 quattro
- NEED HELP INSTALLING NEW CAM/EXHAUST SHAFT
- Audi 03 Symphony II stereo removal keys stuck!
- cdc1 and tr1 showing on dash display please help!
- What is this Part and What does it Do
- 03 a4 sound/radio
- Cylinder 2 coilpack overheating
- Fuel Pump help!
- 2004 A4 Accelerator becomes non-responsive while driving.
- Oil filter bracket / Breather Tube - missing pieces?
- CVT Clutch replace job needed
- Timing Belt Tensioner
- INSTRUMENT CLUSTER
- :: ECS Tuning :: NEW Alzor Style 349 Wheel Sets!!
- Turbo or supercharger?
- My rearview mirror
- Brakes and rotors
- Timing belt kits?
- after market radio problems
- 2002 a4 flip key
- spark plugs
- 2002 A4 Quattro
- Updated South Bend catalog. Free Shipping. So clutch.
- hose that tees between suction jet pump and crankcase breather?
- what can cause a noisy fuel pump?
- MIL light came on, possible n80 or gas cap?
- :: ECS Tuning :: B6 In-Dash Cup Holders!!
- PLEASE HELP DIVERTER/PRV FAILURE
- New Clutch parts discontinued from Audi.. Will this setup work
- new to Audi and need help
- Just bought 2002 a4 v6 6 speed.
- 2004 Audi A4 1.8T Codes 0300, 171, 0301-0304
- Clutch replacement soon
- Rising RPM's
- :: ECS Tuning :: B6/B7 Refrigerated Glove Box Kit!!
- thinking of gettin a B6
- Under Manifold Check valve
- AUDI A4 Quattro 3.0 v6 OBD2 auto scanner codes
- :: ECS Tuning :: APR Spring Sale!!
- CVT Class-Action Lawsuit
- Fuse questions
- 04 Audi A4 3.0 V6 engine knocking noise
- Need help!
- H&R Sway Bars on special pricing at AWE Tuning.
- Weird Shutting Off Problem?
- How much mileage can I expect out of my clutch?
- My A4 at a cross roads - repair or replace?
- P0161Oxygen sensor woes on rear sensors
- fuel filler flap
- Average cost of ownership per year?
- New to everything Audi
- Audi A4 1.9TDI chugging when demanding power
- Help with ABS Sensor
- help with cvt and vag com
- Just Posted A Pink Audi A4 in the For Sale Section
- clutch installed and here is my review so far
- :: ECS Tuning :: Alzor Wheels Style 628 for Audi!!
- :: ECS Tuning :: B6 Black Mesh RS4 Style Grilles!!
- Spring Specials on G.I.A.C. Software at AWE Tuning.
- Anyone heard this whistle before?
- Help
- I figured it out-no replies.
- $8800 for a audi 04 Quad 1.8 T a good deal ??
- Hard starting because of a wiper arm swap ???
- Coil Issue
