- How about this for a thread.... Car insurance
- Anybody running the red 4.2L V-8 coil packs (115S?) and if so, how are they working out?
- how much is a used set of coilpacks and a bpv worth?
- Any long term negative effects on motor/turbo, etc. from going Stg1 or 1+??
- Window switch gremlin?
- Wheel Works f@#ked up my stock rims....
- New member to the AW forums
- For those with a DICE system, where did you run your wire to?
- Pulling out my speedbleeders screws for OEM. Anyone have a part number for....
- Just need to verify the nature of these DTC's, per STFA:
- How do you change a broken tail light
- Does the seat back repair kit (PN 8E0898035) come with one or both clips?
- Paging Miktip or other B7 brake gurus -- I need info on S4 carriers
- I found my screech! Bastard, you made me think it was the turbo. I hate you screech.
- No harm done Bros. There are a lot of jack aases out there in other
- Battery replacement help... preferably Canadian
- B6 2.0L Manual Reliability
- Purchasing an A4, dealer trying to screw me?
- VMR Wheels | Brand new V710: 19x8.5 +35 Available in July! Pre-Order your set now!!
- "Dynamic Headlight" light keeps coming on, help
- maybe very dumb question: Can a coil from a 3.0 fit a 1.8 ? I have a coil out on my girl 1.8,but thc
- Body colored lower cladding
- Quick questions - 1. maintenance - 2. LED's
- car cover? what's the best one? thx.
- another A/C question
- a/c ?
- another suspension ?
- 3.0QM Clutch issues
- power windows all stopped, any ideas
- Engine Oil Dip Stick
- Where can you scan a car for codes? My check engine light just came on...thanks.
- just clayed my windshield glass and WOW. what a difference.
- Please help with VAG-COM and activation of a new key...
- how to find and change cabin and air box filters on 2005 audi a4 b6 ??
- I can see! It's my HID Install...
- Avant is gone today...
- So I got my car dynoed over the weeked, and I was very impressed at the results
- I need some help with my 03 A4 1.8T Quattro
- couple problems, need help with
- 25th anniversary for sale.
- anyone done a Stratmosphere Induction upgrade for a 2002 1.8 T?
- Audi takes magnificent Le Mans win..
- B6 vs B7
- 18" RS4 replicas - $500 shipped
- Audi A4 B6 ballast headlight problem
- gas mileage
- Guys, I need a reco on a sub.... my plan has fallen apart.
- Paging QuattroFan02...did my logging today.
- Timing Belt Help
- wheels and tires?
- Is there glass roof for a4 b6 ???
- I'm stumped, replaced acc.belt, replaced tensioner and I still here screeching under load.
- Allow me to reintroduce myself...
- sunroof issue... help!
- Any1 know where I can get a new sun visor hook aside from the stealership?
- I'm getting my car dynoed tomorrow morning...
- Leaky gasket/turbo??
- slow forum = stupid post by me. Post your old sigs?
- Does this cat look too small?
- help, car turns but will not start
- Need electrical (circuit breaker) information.
- There's a new pic whore in town...
- anyone have the Audi sun shade? How well does it fit the windshield?
- Changing the ATF.
- Fellow AW'ers, I need your opinion: Engine Bay, polished or blacked out
- Enjoy the video
- Master Cylinder
- well... it was only a matter of time....dragged it out this long...
- Paging Tgr_Clw - YGM
- while i was getting APR 1+ done, i saw a dismantled k03 in the shop
- Here is an old pic of my K03 next to my GT28rs. No comparison. Would never go back
- Anyone here running a GTRS w/Revo [besides tuneda4]? AWE's "BT" kit is losing appeal to me...
- Left rear tire excessive wear
- Is there reason for concern?
- Thinking about doing my first engine mod.....need advice.
- Just modified my front caliper guide pin bushings. ....
- Paging GDawgA4, new intake temp log, temp @ 86F~.
- No new threads = boring = my post (originally in Wheels/Tires)
- Can anyone get the pics back up in the fuel filter DIY thread? Want to do it, but would like the
- why don't we get these seats in the US/Canada
- Argh, curse of the CVT transmission strikes one more owner.
- Is a leaking cam shaft seal a major issue? Dealer wants over $500 to fix, but can't I just watch
- Currently at stealership getting car aligned, inspected and having a leak checked...wish me luck :(
- Okay, need help again diagnosing a problem that just started a few days ago...
- Paging Myllymaki regarding your 6/5 post about catalytic codes
- Challenge of a lifetime:
- looking for directions on how to replace aero wiper blades. i did a search but could not find
- Oettinger front center grill opening, does it need to stay clear?
- i received light blue TT 386 injectors and compared to my dark blue 03 injectors
- base v. sport package
- Need a new outside mirror assembly- where to buy?
- Question from a Newbie wanna be
- Yokohama closeout savings at Achtuning!
- gas mileage after chipping
- Holy crap my car is slow in this weather
- Aargh! Cannot unlock trunk ....
- what's a fair price for 2 3.0 heads use din decent shape , clean (dr and pass)?
- Revo Technik welcomes Best Foreign Cars of Severna Mark MD to our authorized dealer network.
- Quadfecta! Anyone running with CANTON/MECCA oil filter? A4NCAR used one back in the old forum days.
- Trifecta! I just ran across this Service Manual in print. Anyone have any thoughts on it?
- Valve cover gasket for 1.8T.....RTV or not? What do you guys say?
- Did anyone ever do or find a write-up on replacing the chain tensioner gasket for 1.8T?
- falken wheels question
- Mild hit and run- looks worse than it was
- new audi, but what is that car in the background (a4 coupe?) FIXED THE PIC
- anybody know where to get audi apparel??
- White smoke on startup (head gasket? turbo?)
- rotor size
- Okay, so I added washer fluid to my car today over lunch....
- Anyone know of any 6 speed USP avants available on the west coast?
- Intermittant Climate Control and Power Windows Issue
- Throttle body hose keeps slipping (not off)...new clamp or stock hose can't handle boost?
- 24 HOUR FATHER'S DAY SPECIAL 18% OFF
- Retrofitted my 03 A4 with OEM satellite but now I'm having front speaker problems...
- does anybody have these side markers ?? if so....
- just joined....
- My car is finally out of service mode. Click for new night shots!
- hey guys, I need to replace my driver's door window motor or wire. Does anyone have the
- Belt noise update, need advice. I installed a new OEM accessory belt yesterday
- b5 or b6
- Nice Weather, time to clean the car
- Ok this stupid CEL is irritating.
- (Electrical) Main Engine Wiring Harness Woes
- recaros on ebay..7 hrs left.
- a4 wanted
- Is This worth the price
- What are the fog light bulbs ???
- Anyone interested in Silver S4 lower door wings. email me. In pic post
- best way to hook a dirtbike up to my car?
- just had new slotted/cross drilled rotors put on and they humm and squeak!!! whats the problem?
- my vag cable hasn't arrived yet but this weekend my car developed starting issues
- I hope this is not a dumb question; Are NGK plugs iridium pre gapped
- Trace of leak on the tranny where the Axle connects.. (pass side)
- on the b6 1.8t.. why is their a tick, tick, tick sound on the engine when you open the hood?
- Front right window "screeching" when going up or down.
- ne1 have a cargo net laying around gathering dust?
- New pics after cleaning car up. Windows will be getting tinted in ~12 hours. (BWW)
- Prizm Extended Warranty
- why does my A/C suck?
- after i replaced the battery, key fob problems. 1 works, one has problems
- You guys think I should wash my front wheels?
- Quick ECU related question
- First post..
- oil type for 3.0 engine?
- I know this has nothing to do with Audi.....but...
- Quick turbo question
- Some special deals on Volk wheels here at STaSIS.
- Just want to share some news.....
- Strat SSK people:
- silver b6's with OZ Ultraleggeras, Enkei GTC01, please post photos. :o)
- climate control codes to see speed, fuel etc.
- So my buddy is looking at a 1.8t in VT and wants it badly... but here is the issue:
- Boston Area AWNE GTG: 7/16/08 - Chili's - Burlington, MA
- Need help interpreting a noise I'm hearing........
- Hit & Run Photo
- anyone need a set of used 18' Hartmann RS4 Reps for their A4?
- 3.0 spark plug question: double platinum or iridium?
- My new license plate...
- Catalytic converter code keeps coming back
- Code help please
- D1S or D2S xenon HID bulbs?
- rs4 sway bar question
- When making a turn on slow speeds I hear a clunk underneath.
- Audi Improves to #10 in JD Power Initial QS
- Victim of Design and Technology 2002 AUDI A4 with CVT transmission
- Waaaayyyy OT.....wanting to resize pics on my computer
- Anyone have a write up or experience with checking/recharging a/c system? I don't have a vag if
- Well, couldn't get car aligned...how do you guys have the shop go outside of specs? I wanted toe
- 3rd Annual Colorado 14er Climb!
- Driver's Seat
- Looking for a B6A4 1.8T Manual Trans to help finish some products
- Pardon me in advance for a totally off topic question, but nobody here (in my office) can give...
- what to do?
- Audi Expo 2008 - It's almost here!
- XM for the 2003 B6?
- Mobil 1 15W-50?
- Downshifting and engine stress...
- Navigation Plus on Ebay... will it fit A5?
- What is the grey "thing" on the pic ?
- UPDATE: The AIM MXL Pista data logger installation (pictures and a video clip)...
- Roll into summer with a new set of Oettinger Wheels.
- UPDATE: Decided to re-do the OEM upper dash with a new process/material and this...
- The mysterious CEL appeared once again Friday afternoon and went away this morning.
- radio reactivation
- Back seat removal on 2003 Audi A4
- Anyone have both catalytic converter go out?
- Driving along in my automobile....
- Part Number for Bolt on Upper Control Arm
- GIAC K04 users - Flashload software
- Having car aligned again tomorrow now that I have new summer setup..please help me out here...
- I drove my friend's 02 C32 AMG yesterday and all I can say is wow,
- So I'm pretty sure the genius's at the shop that replaced my radiator filled it with regular coolant
- Does the RS6 front mesh grille fit the B6 A4?
- Got my CEL fixed this weekend...
- Poll: who would be interested in having/contributing to a B6 A4 FAQ?
- faulty gas cap sensor... how to check wiring?
- Un-fricken believable...
- *grabs popcorn and waits*
- trace of oil leak on the belly pan
- Rough hamming noise coming from front tires area....
- Are VMR V708 18" gunmetal rims car wash safe?
- '02 A4 Climate Control Unit / Stereo Issues
- Reminder: San Diego area dinner/GTG this Thursday night!
- Would I be able to find halogen citylights (from the B7s) at the dealer?
- Can't believe I waited this long to get a upgraded intercooler. Those who are running stg 1 or 1+
- Coil Pack part # and other q's
- private audi service in southeastern new jersey
- Can anyone tell me if a Symphony II radio from a B6 fit a 2003 A6?
- 2002 1.8t w/72k, friend looking to buy, what should we look for?
- Did some logging with the Apikol SMIC today...
- Does anyone know how to remove the cubby's under the front seats?
- Help!!!!!! Car Won't Move!!!
- Drivetrain warranty
- Wiper blade replacement help
- OEM Wheel Bolts - Need Size & Source?
- Anyone wants bran new cross drilled rear rotors for A4?? Giving away...
- Having some serious issues.....
- Finally fed up with my halogen headlights. Just bought a 5K Retro Solutions kit and Stealth Bulbs.
- Ugh...spilled some oil on the driveway while changing. Any suggestions on how to clean it off?
- Initial Apikol SMIC impressions...
- Add one more to the Apikol SMIC list!
- I need a new car and the A4 is so appealing. Audiworld I need your help
- Can't get license plate light cover screws lose
- Any tips on reseating the coolant sensor?
- DIY: Blacked out exhaust tips
- Anybody ever attempted to improve the oettingers center mesh and foglight mesh grills?
- Oettinger has what you need to gear up for summer.
- Guys with Milltek exhausts: What do you use to clean the inside and outside of your tips?
- More STaSIS products inbound to Achtuning :)
- Another update. This time I have really good news about the AIM MXL Pista...
- Sold my B6 today. It's nice having no car payment, insurance, gas etc.
- Quick question - driver's window switch
- So after some research on spring/shock combinations...
- OT: what type of spray paint (in the can) would be best for painting a helmet?
- Replacement Brake Pads for B6
- Tgr_Clw how did that track day go?
- What type of sport suspension does the B6 USP A4 have? is it the same as the S4?
- Beeping sound from trunk area on startup.
- UPDATE on my electrical saga (finally I think we got it licked)...
- Please Help! Any tips on how to remove the exhaust tips?
- Rear right lower than rear left? Shock going on that side?
- neuspeed rear sway worth it??
- Anyone know how to remove the power steering reservior on our cars?
- 345mm B7 S4 Brakes....
- Audi Engine Strategy Through 2011 Leaked
- Car suddenly shudders when idle
- Stock Suspension - How long until it needs to be replaced
- CVT V6 owners:
- New to the forums... 2005 A4 1.8T Quattro
- Anyone need a Symphony II radio with Blitzsafe AUX adapter?
