- hmmm tempted to get revo flash tomorrow, but it would be nice to have $500
- stereo adventures
- any one has a pic of blacked out front grills on a silver car ?
- Need your help: how to disassemble the driver's door armrest/handle ?
- Paging MikTip...
- STaSIS @ Inskip Audi Warwick, RI
- a number of questions (tires, suspension, etc)
- what would you do... pay more up front for 4 replacement tires or pay more in the long run?
- my 02 A4 1.8t died on me today
- when I was wiring the stereo today (6 RCAs + remote) I noticed connector 1 is single solid connector
- coin tray stuck.....help!
- Window control...
- damn, that was the worst blower motor job i've ever done, the last bolt on the back is impossible
- I've got a real puzzler here tonight. for you guys
- Exhaust question
- Injector question...
- ran the b6 hard today for 4 hours and was so impressed once again...
- Is there any way to tell if you are low on manual tranny oil w/o going under the car?
- Engine cooling performance
- anyone looking for a glovebox 6 disc changer? e-mail me.
- collapsed piston heads?
- To chip or not to chip
- What is the difference between 3.0 carriers and the TT carriers ?
- argh, while installing an amp power cable it starts raining, and i dropped the 10mm air intake nut
- spoke w/ buddy at the dealership regarding trade in
- How do I remove my aftermarket double-din nav unit??
- How to replace city lights in e-codes?
- Tgr_Clw and other DSMIC owners: Ever think about using the rs4 intercoolers?
- Can anyone please tell me the torque value of collared bolt #1 in the pic...
- Any of you fellas with GIAC FX K03 ever spike at 24psi? I found that a bit odd.
- Which giac code can create requested boost of 2510 ?
- Is the owner of the B6 featured in June's EuroTuner on AW?
- How to clean G12 in trunk
- EDIT: asking about a different tire now... Falken Azenis ST115... good or bad choice for our cars?
- To keep or not to keep, that is THE question?
- How do you pull a rear door panel on a 02 B6?
- Affordable Aftermarket air intake filter? K&N? Any suggestions?
- 1.8t MT5 FWD Transmission fluid change, 53K?.. What weight? How many qt.? Switch to synthetic?
- If I could have my own Mastercard commercial, here's what it would look like.
- Anyone have a pic of the ride height of a B6 or B7 with Koni FSD shocks and stock sport springs?
- lemmiwinks
- new time slip...creaping to the mid 14's!
- Can you identify this sensor?
- Scarey aquaplaning moment today
- Paging AudiJunkie!
- Problem today with my back left window
- tire question
- APR Exhaust sitting on my shelf....
- Coolant temperature spike when accelerating hard
- i should be getting my ecodes any day now...i want to swap out my led
- AFE Cold air intake for 2002-2005 Audi A4 1.8t
- *Paging* All Wheel Driver
- *barges in from the A4 B5 board* UPDATE on group deal for 034 motorsport clutches! Get in now. ;-)
- Belt Tensioner
- User Manual
- Has anyone successfully replaced tail light bulbs with LEDs?
- long shot, but has anyone in the LA area done an interior trim swap before?
- I got the 1.64 uspplastic check valves today here's a pic!
- is $14,000 too much for a 2002 1.8t with 85000 miles no warranty
- right front low beam
- Someone try this, make a video, and post it here....
- Spark Plugs
- okay, so it seems like not too many people are impressed with the B8 A4/A5.
- Paging Tgr Clw....
- So the 1.8t
- Allroad calipers FNR-G60...
- Before and After of the H&R/BILSTEIN upgrade
- Brakes Question..
- Had headlights out (xenon) and now they error out...
- Quick Maintenance Questions
- Key
- STFA with no luck: where can i get a replacement B6 headlight housing (xenon)?
- Dension ICE Link FM issue...
- Power window failure
- Clunk/Crunch sound on sharp turns, help?
- Minivan killer..lol. Next project car for me..LOL, i wish.
- Whats this talk of a A3 and A7 convertible?
- Coilovers on; beware, sucky pics.... I'll never make a living with a camera.
- Does the B6 1.8t use the same exhaust manifold as the B5 1.8t (part # 058 253 033 E)?
- old pic of Projekt 8E
- Interior lights not coming on when doors open ...
- Auto windows with key in lock no longer functions... thoughts as to why?
- 20x10's anyone?
- Does anyone have an ATP mainfold for at least a year that DID NOT crack ?
- BT at last....
- Got a new transmission in my 2004 A4 1.8T CVT.... should I treat it like a new car?
- Apr 1+ Lean issue, desperate
- Performance
- Auto dimming wing mirrors
- Weekend wrenching....have a one problem and one question....looking for feedback from the pro's.
- Yay. My glovebox just broke. B6 A4 ownership sure is fun.
- ESP light on/ Rear Brake lights on
- Is there a way to have your fog lights on and not your head lights? A4 3.0 2004
- Weekend wrenching......is it necessary to take front wheels off to remove the front bumper?
- Tire Recommendations
- stasis street sports rear height
- Scraping sound after installing RS4 rear sway bar
- Swapping S4 brakes to A4, is it possible?
- didn't get a straight answer last time, will B5 front sway bar fit B6?
- 19" RS6 replica wheels - information and install pics.
- Possible clutch/trans problem with 02Audi A4 1.8t
- what is the spring rate of the OEM sport springs for a 1.8TQ??
- I can honestly say that I have a "clunker".
- Yo Tgr_Clw
- REVO K04: vs Rice-Stang...(street racing and long)
- Hydraulic Fluid
- Aging B6 A4 (100k miles) got new life with new plugs and Seafoam treatment.
- A/C low pressure charging port - where?
- Rear door trim question.
- never realized it would be so hard to find a nice low mileage avant for sale
- Car pulling slightly to the right.....
- CF Trim on Platinum Interior!
- Goddamn, I wish my A4 had the power to do a burn out like this one!!!
- Anybody us an ER Comp FMIC with a BT kit? Mine doesn't fit...
- what is this part and why is it leaking fluid?
- Need help to put a value on my car; '02 A4 1.8TQ
- Ordering new STaSIS TrackSport Suspension. Which spring rates should i go with?
- Dash cup/coin/ESP removal of the whole thing
- Sneak Peek 2!
- Headlight issues
- I answered my own question - but I'll share it with you anyway ...
- washed > clay > clean > polished the beige. sadly it will never bling like a black car
- A 12 cylinder VW GTI... a real monster!!!
- vacuum hose
- Crosspost from SoCal Form: Overstock H-Sport Swaybar Kit: One Only!
- TrueDelta Vehicle Reliability Survey results - Audi A4
- Can I trust Jiffy Lube for coolant flush as long as i watch them do it?
- bulk order about to be placed, ne1 know of current deals on...
- Sneak peek of my next mod =D
- Can someone tell me if these charts look ok?
- Buying 2004 A4 1.8T - Any Advice?
- Help fuel guage reads zero after jumpstart
- HELP: Need to pull any error codes from my totalled 02' 1.8T ECU ==>
- damn, i forgot which diverter valve i have.
- just a small update & pic
- My impressions of the APR K04 vs the APR 1+
- I don't understand why GTRS cars run 440cc injectors, that sounds dangerous
- What's the wire on the side of the battery..
- B5S4 Brake Checklist>>
- need some input..
- Weird noise
- Need some input from the Audi brethren . . .
- Anyone have pics of underbody showing where put support welds for Milltek?
- Would it be ok to remove the center resonator from my milltek and put straight pipes there instead?
- NEED HELP ASAP - Before it rains!!!
- Carlisle PA GTG/Show pics
- B6 A4 parts I need to move.....
- Stock A4 5 spoke 17" wheels wanted in Boston
- What Ultra high performance All season tire to go with?
- Where can I get a set of sportec wheels?
- Some pix from the GTG in Burlington, MA
- Is this ok? Mobil 1 5w40 "for diesel trucks" I found5qt at walmart for $23.00
- Dangit I'm dumb. Missed warranty end date by 20 days. Speakers cutting in/out, radio peeling.
- Another coil pack....ugh
- Do I Need a Full Turbo-back Exhaust? Or Just HFC?
- Got a CEL and need help with this code: 16683
- Can someone help me find the directions for the Ultra Sport Front Lower Spoiler install?
- Heated Mirror Mod
- Driver's Door Seal (Redux)
- I got to sit in a...
- I think this forum needs to chill out a bit....m...
- Anybody plannin on goin to Motorstadt4?
- 3.0L Cold Air Intake - Whats best?
- APR Releases the R1 Diverter Valve!
- Burning rubber smell A4 1.9TDI 80k
- ICS PERFORMANCE has SIGNED UP with Audiworld including SPECIAL SALE PRICING!!!
- Is 0W-40 oil bad to use during the summer time?
- How much did you pay to get your lowers painted?
- Has anybody heard of these guys?
- looks like Wayne's right-angle O2 sensor block took care of my O2-related codes...yay!
- to the owner of this white ultrasport...
- Question about which Vag-com cable to buy
- Question about Adding Coolant (off-brand) and above max.
- puttering suction sound while coasting
- What should the MAF g/s numbers be like on a k04 car? I have some numbers from a log and
- Whats the correct tire pressure for my tire? Im running Dunlop SP 9000's on the stock 17" rims.
- photo's of the new e-codes
- Paging MikTip...
- Getting this faint 'wheeeeee' sound from the rear driver side wheel area
- power loss with hitacki coilpacks?
- Retrofitting RNS-E --> A4 B6 2003 without OEM radio Help please
- having transimission problem at 52k miles
- A4 Clutch issues...
- Sneak peek at the latest B6 A4 developments from the boys at Apikol...
- Has anyone ever performed a wheel allignment on their own?
- I need battery recommendation
- exhaust install take 1.......
- For those of you who have had their lowers painted after an accident on insur's dime: Did you...
- hey Audi Junkie, can i really use dino-oil for auto-rx clean and rinse?
- is there a cover for the airbag that is replaceable?
- identify the "visible mods" (accessories)...
- Exclusive Frankfurt Preview: 2009 Audi A4
- Buying out lease over the phone with AFS or at the dealer?
- anyone in here live around salem oregon with a light weight flywheel...
- B6 S4 Bumper Kit (front/back) - Available for A4?
- turbo upgrade for tiptronic
- Changed oil myself today...
- Seat covers BT. Other options?
- Installing LWB question
- Flashing Gas Cap Light
- what aftermarket flywheel and clucth kit would you guys run???
- Looking for an Audi Service Advisor or... (Diagnosticator?)
- 1/4 mile times ' 03 A4 3.0 vs '07 BMW 328 ci awd
- Blinking brake light after fluid replacement? HELP
- Is there a way to tell if oil is synthetic or regular by lookin at oil on dipstick?
- Ted's Dyno Plots, Dynojet Dyno, Denver, CO. e85 content
- On AWE boost gauge what wire do you plug the illumination wire into??? what color wire etc.
- Must be a new model...W12 TT eh.
- B7 Multi-Function Steering Wheel into 2002 Audi A4
- Aggressive sale on Votex exhausts.
- the bottom part of my armrest latch is chipped...is there a way to replace just this?
- Latest pics of my A4 Avant TDi Sport - Amulet red..
- is it worthwhile to replace the oem symphony sub with a decent 6" peerless along a 10" in the back?
- hose clips - secondary air combination valve
- How to change the fan control module - DIY
- Does your blackberry charger cause interference/static on radio? Anyone know the cause or
- what is stock compression ratio for a 2002 audi a4 1.8t AMB motor?
- Oh, BLEEP! I *BLEEPED* up my turbo!
- Buying products on AudiUSA.com - Problems?
- Dumb question - Adding a picture to your profile?
- Even though I am going from a B7 to a B6, I couldn't be happier......
- Well, summer is over, time to dig the winter wheels out of the shed...
- 03 avant suspension question?
- Can someone tell me where to get just a primed rear lip spoiler for a fair price?
- for eveyone that has heard me talking about my burning oil problem...
- what's the best online retailer to pick up some styling accessories?
- Time for the spring clean up with some new Motul products before the torture begins...
- Hesitation and Bucking
- Hey guys check out my one piece front end.
- New Ipod dock in the armrest, v2.0. Dialup, go read a book.
- New Heat shield tech.
- Help identifying part number
- Can someone tell me if S4 bumpers require any kind of side skirts to line up?
- Paging: Those with 4:1 center diff...
- Gray/silver 4-spoke steering wheel - where to find one in good condition?
- Chassis Dyno results
- NEED HELP FAST,
- Brake Disc Corrosion
- Lime Rock Memorial Weekend Anyone heading there????
- Help 5-spd A4- may need new tranny, upgrades available?
- Help-> 02' 1.8T totalled in crash..can I get speed/impact details from ECU ?
- Stupid Dealership!, help me this part was so hot it was glowing orange!!!
- 40K mile (60K Kms) service - List of maintenance items/points?
- Look at the new mod my neighbor just gave me this morning
- Back in black!!! (long)
- Corner balancing and suspension question
- Pic of size difference between 245/30/20 vs 235/45/17
- Do you think a Milltek non-resonated B6 S4 exhaust would provide droning on my 3.0?
- annnnnd the new wheels
- Look how ridiculously jacked up my virgin A4 was! Was this the standard susp. setup or ultra ?
