- 1.8T,2.0 or 2.4v6
- no power 1.8t please help
- 2002 Audi A4 coolant leaking problem
- How long are tires good for "AGE WISE" regardless of tread?
- Alarm sound in the truck and hazards on and won't turn off
- Driver side brake leights, headlight and turn signals not working
- Anyone have a stock Cat converter for the 1.8T
- 1.8t Quattro - Random ESP light
- Code 17072 Car will not Start
- The H&R Catalog for your A4, from AWE Tuning, alive and well.
- FOR SALE: Rear black B6/B7 seats and cargo cover, trunk hatch off an 03 WAGON
- A4 B6 cranks but won't start 01314 - Engine Control Module - 49-00 No Communications
- Dipstick Funnel
- Audi a4 1.8t 2003 Leaking problem
- hey guys..knocking noise and no start issue.
- B6 1.8T vibration w/ steering wheel shake w/ LOUD clanking noise
- P0507 P0171 all cylinders misfiring
- turning shudder - 1.8 quattro
- A4 Quatro 1.8t Engine stutters at 3000 rpm
- :: ECS Tuning :: APR Fall Sale 9/24 Through 10/14!!!
- Power Antenna, How is the power transmitted?
- Tunk lid A add-on badge
- Transmission code importance...
- engine check light
- No Warm up and Fan never stop.
- HELP!!!!!!
- Aftermarket Stereo Install Issues
- How to Replace Trunk Switch
- OEM brake upgrade questions, carrier and wheel fit
- Hello! 2005 B6 3.0 timing belt
- Cracked Bushings
- Can somebody check this vin number?
- P0421 and misfires 04 A4 3.0
- 2002 a4 3.0 v6 super charger
- S4 V8 in an A4?
- :: ECS Tuning :: RS4 Rear Sway Bars - BACK IN STOCK!!
- Air Intake resonator?
- water leak at windshield base...
- A4 B6 Right Rear Door lock removal
- Lost of power and check engine light flashing
- replacing/upgrading turbo
- Front 2 Turn Signals dont work
- Take advantage of the Fall Sale on G.I.A.C. Performance Software at AWE Tuning.
- :: ECS Tuning :: Cupra R Lip Spoilers Save 15%!!!
- Seafoam question B6 3.0
- 2005 Audi A4 3.0 Multiple Cylinder Misfire
- Installing Sub woofers
- Can the radiator cooling fans be removed without service mode?
- Temperature gauge
- Audi A4 B6 1.8T Overheating Issue
- Starts, then stalls
- 2004 s4 cab hazard flashers come on intermitently
- The Brembo A4 Catalog from AWE Tuning
- :: ECS Tuning :: B6 A4 Exact-Fit Brake Lines - BACK IN STOCK
- auto motor, manual car
- Tips on replacing front brake pad springs?
- New Product Launch!!! P3 Cars Vent Integrated Digital Interface B6 A4/S4 & B7 A4/S4
- squeaky chirping sound in front at idle
- INstalling heater core in audi a4 B6
- Audi A4 Just Started Vibrating - Ideas?
- Possable cvt issue
- Help! Large oil leak
- Buying used, what to look for?
- Help with 2003 A4 avant electrical problems
- Immobilizer Issue?
- Right-Hand Drive Power Window Regulators
- Should I buy? What to look for?
- Labor Day Special at Detailer's Domain
- Stock Jack Location
- A4 2.0 SE Petrol issues
- Get your A4 ship for free. Courtesy of AWE Tuning.
- 08 TT rims on 03 A4? 52mm offset
- Water pump, timing belt and potentially bent valves
- Buring smell when using windshield washers
- noise from clutch on realease under load
- Turbo Problems: Need advice
- Anyone fit the 8" Dynaudio MW170/172 in the front doors? B6 line
- AMB Vs. AWM
- MY GERMAN SPECIALIST CANT EVEN FIGURE THIS OUT. Can You?
- 8E0 907 279 E CECM For Sale!! 105 dollars shipped!!
- Looking for caps: 8E0 601 165A
- Replacing Valves
- Input?? Suggestions??
- HELP, ADVICE, and INPUT NEEDED PLEASE!!!
- Rear Blind Switch Part Number
- Multitronic Failure
- 4x4 Killed My Audi
- cruise control and stereo inoperative, and 4 chirps from alarm
- :: ECS Tuning :: B6 A4 European Grilles!!
- Can I replace the AC Compressor?
- A4 Security Alarm Disconnect
- GoPro Introductory Pricing
- Audi A4 2001 B6 2.0 problems assistance much appreciated
- A4 Quattro Questions!
- :: ECS Tuning :: B6 A4 1.8T Ultimate Timing Belt Kits
- why is one part of my air intake covered with duck tape?
- AWE Tuning catalog incorporates Sachs Performance Clutches.
- Static, help for the Noob!
- '03 A4 1.8t oil pressure light
- B6 to B7 bi-xenons retrofitted, DIS high beam warning
- 2003 A4 3.0 issue *help*
- Flywheel timing?
- strange jerk as i accelerate, opinions?
- How to make your Audi last and a few concerns
- New to audi and looking to do some mods
- Upper Control Arms
- turn signal
- TWO WEEKS until S-FEST West! Register now to ensure your spot & door prize!
- Small hair particles on top of dashboard
- :: ECS Tuning :: :: ECS Tuning :: B6 A4 Rear Differential Service Kits!!
- Sell Your Audi A4 on Global Autosports!
- :: ECS Tuning :: Schwaben Floor Mats!!
- Coolant Hose
- Just turned 187,000 miles this morning...
- TCU Rebuild
- 2 simple questions please
- Name that part??? :)
- New Valve Cover Gasket Causes Misfire?
- transmission bolt
- 2002 Audi A4 vibrating
- 04 Audi A4 - I HATE THIS CAR!!!
- Newbie here, need Audi help
- Coolant Flange and PCV valve
- Having trouble cleaning your wheels? Not anymore - Wheel Woolies are here
- ~~~ Car Lost 90% of Power while driving!
- Replacing Thermostat Question - HELP!?!
- Handling, looks and quality. The H&R A4 Catalog, from AWE Tuning
- Washer Fluid Res question
- One of those threads: Is my CVT going bad?
- 2003 1.8t, rough idle, misfire codes, HELP PLEASE
- A/C water leak onto passenger floor
- Water leak
- Homelink Problem...no flashers, no learning
- Turbo Size
- The BBS A4 Catalog, from AWE Tuning
- alarm acting up/down
- Wanted b6 FMIC intercooler
- Misfire Help !
- Heated steering wheel
- Rusty cams
- Please help with diagnosis!
- B6 Avant Rims question
- HELP: Audi a4 B6 1.8t stumbles randomly
- Black Lug Bolts
- How to remove 2004 B6 Avant emblem ?
- Waterfest 18 Special Starts Now - Get your detailing gear before the big day!
- 2003 A4 Pulsing vibration during acceleration
- B6 Headlight Level Warning Light questions.
- New to the forum
- Trunk light and keyless entry not working
- Slow leak from passenger side engine
- best shocks
- Corners, be afraid: The Bilstein Catalog, from AWE Tuning
- 04 A4 new coil packs affecting alt light?
- piston question
- AC help
- Radio fading in & out after Window Regulator repair
- Test Pipe
- :: ECS Tuning :: B6 1.8T APR Summer Sale!!
- Where To Start
- Is 2002 rear bumper 1 piece or 2 pieces?
- 02 A4 3.0 rough running at idle.
- nox sensor and best shocks
- Audi A4 B6 TDi 130 Limp Mode - Advice
- Advice on Repair vs Scrap
- .:Eurocode Tuning:. APR Summer Sale!!! July 1st thru Aug 3th
- My 2004 1.8T A4 CVT Flashing PRNDS (TCU/TCM) story - call it paying it forward
- Oil Pressure Warning...
- HP wheels
- Parting out a 2003 AUDI A4 1.8T quattro Wagon Avant
- July 4th Special @ Detailer's Domain
- Car wont start please help
- Part number please Under Front Bumper...
- motor mount question
- 2004 a4 parking light/turn signal issue
- Front Door Hinge Adjustment DIY - to fix a sagging door.
- Locked out of 1st & 2nd gear
- Bad turbo seals, replace, or repair?
- LOTS of PROBLEMS
- :: ECS Tuning B6 A4/S4 Trunk Lip Spoilers Save 63%!!
- Need your opinion on a 2003 A4
- Hard starting 3.0
- ESP light is on and it doesnt go off
- 2005 Audi A4 1.8t front passenger door panel removal
- Borla, or magnaflow exhaust?
- The South Bend Silent Design catalog, by AWE Tuning.
- 2002 A4 1.8T Reverse Problem (video)
- My quest to eliminate chrome
- '03 1.8t **Oil Light - Red** Under Special Circumstances
- Window won't go up, not sure what's wrong
- Audi TMC Tuner alternative??
- A4 3.0 V6 Timing belt replacement
- performance upgrade help 2.0 non turbo
- Radio symphony 2 question
- :: ECS Tuning :: B6 Aero Wiper Blade Kits!!
- :: ECS Tuning :: B6 ST Coilovers FREE Shipping!!
- Car vibration shimmy update
- Help with A4 1.8T engine temp gauge
- These are the brakes: The Stoptech B6 A4 Catalogue from AWE Tuning.
- Some Vag-Com errors. Any help?
- somoone help me check engine codes on my 99 audi a4 2.8 p1626 an p1392
- Help! AC stuck in ECO mode...
- Code PO431
- Audi B6 A4 1.8T BEX Misfire Under Load
- High fuel consumption after TBelt?
- Spark plugs and other stuff
- To buy or not to buy - 2002 Audi A4 Reliability??
- A4 Coolant in oil
- OEM Porsche Turbo Twist on A4
- Sudden A/C problem
- Differences in Remotes for A4/A6???
- cracked center console
- Where to buy window gaskets?
- 2010 A4
- Park light stays on and left blinker not working
- Buy 4 Get 2 Free - Sonax Full Effect Wheel Cleaner!
- Noob with couple questions. Please help me, Sorry in advance !!
- Ignition angle jumps at idle - 2.0 20v
- :: ECS Tuning :: B6 Ultrasport Lower Grille Sets!!
- a4 1.8t overboost...replaced n75 still getting 17963 upper limit exceeded?
- Thermostat Stuck Open Twice
- Is that a break issue? Need help please
- 1.9 TDI going into limp mode
- idle cam positions on 3.0 needed
- Clutch issue or something else??
- How to by-pass heater core?
- overheating issues. I've searched, but need a little help
- Fluctuating Temp Gauge
- AUDI CLUB NYC?
- Misfire and excessive crankcase pressure
- The Bilstein Suspension Catalog, from AWE Tuning
- immobilizer question. i've stfa's but still need a little help
- Car won't start/Remote not working
- thrown codes and major problems - if you have experience, please help
- hissing under hood while running
- Question regarding vag-com cables
- ESP/APS & GLOW PLUGS DASH LIGHTS..WHAT DO THEY MEAN?
- 2004 A4 Symphony Bose Problem
- Anyone want a sick led audi badge? Sorry, this is the right one.
- Question about Fluids?
- Where to get OEM parts?
- :: ECS Tuning :: B6 Blackout Grille Kit FREE Shipping!!
- Auto Locking?
- VAG codes Oxygen or CAT or missfires? on a4 3.0
- The BBS Catalog, from AWE Tuning
- My transmission went, what now?
- Is there a radiator cap or just overflow tank?
- Battery died, now the ESP light is on
