- :: ECS Tuning :: Now Available!! Podi Gauges | B6 A4 1.8T
- Starting issues
- Man puts 1,000,000km on his Audi A4 TDI - Video
- ** GruvenParts Developing Billet Intake Link for S4 B6/B7 - We Need Your Help !
- :: ECS Tuning :: Save 15% On ECS Wheel Essentials | 7/6- 7/14 Only!
- I'm new to this so please be gentle...2007 A4 S line 2.0
- Tunning
- Headlights/tai lights
- :: ECS Tuning :: Ignition Service Solutions | B6 A4 1.8T
- :: ECS Tuning:: FREE SHIPPING ends 6/28 MIDNIGHT
- Summer Start MEGASALE!
- Tech help please. Ecu immo off, cluster not original
- Rear wheel bearing or something else?
- :: ECS Tuning :: Forge Motorsport Components | Audi B6 A4 1.8T
- Engine and trans build options
- Changes through the years
- 18s on a 07 A4 Cabrio?
- Sunroof issues
- A/C problems
- RAM air intake
- One of two key fobs not working
- :: ECS Tuning :: Time Is Ticking!| Save Up To 15% On ECS Timing Belt Kits!
- :: ECS Tuning :: #SaveThePans | B6 A4 ECS Street Shield
- Automatic Shift Knob Compatibility?
- electrical?
- 03 audi a4 1.8 problems starting
- :: ECS Tuning :: Performance Rear Differential Mount | Audi B6 A4
- 03 A4 Quattro 1.8t Coolant Reservoir Overfloing...NEED HELP!!!
- Mysterious rear backup light bulb error
- :: ECS Tuning :: Solo-Werks S1 Coilovers | Audi B6 A4
- Replacing my headlights?
- Replace "Chorus" car radio with an "aftermarket"
- :: ECS Tuning :: RS4 Jack Pad Kit For Your Audi B6 A4
- :: ECS Tuning :: Aero Wiper Conversion Kits | Audi B6 A4
- Immobilizer Light on after Instrument Cluster replace attempt
- Suspension ????
- clunk or knocking noise while stationary
- Transmission belt
- :: ECS Tuning :: Audi ECS Carbon Fiber Parts | Up to 25% Off!
- :: ECS Tuning :: Memorial Day Sale | Up to 25% Off RS Style Grilles & Alzor Wheels!
- Rebuilding a 3.0
- :: ECS Tuning:: Summer Prep Sale Event! | Up to 30% off your favorite brands!
- FREE SHIPPING through Memorial Day!
- Less than 24 hours away from launch!
- Bilstein HD rear fitment issue
- New to Audi
- A4 immobilizer issue, please help!
- Ahhhh! Front Passenger door not opening at all? A4-B6 1.9 TDI
- :: ECS Tuning :: P3Cars VIDI For Your Audi!
- :: ECS Tuning :: Valeo Clutch Kit/Single mass Flywheel Conversion | B6 A4 1.8T
- car wont start after fuel leak?? plz help !
- Abnormal engine sound of my BEX engine
- General quality/fitment of Borla exhausts
- Gas door warning light on dash
- :: ECS Tuning :: NEW!! Tow Hook License Plate Bracket Kits for your B6 A4!
- :: ECS Tuning :: Assembled By ECS Oil Service Kit Sale - Save 10% | Audi B6 A4 1.8T
- Coolant Issue
- Oh you know just another weird coolant issue
- :: ECS Tuning :: ECS RA4 240mm Clutch Conversion Kits | Audi B6 A4 1.8T
- Voltage of Starter Solenoid signal wire
- AutoPreme Prices (2 Weeks Away from Launch!)
- :: ECS Tuning :: Audi B6 A4 1.8T ECS Vent Pod Boost Gauges & More!
- Check engine light is on and I need help with these VAG codes
- Smoke after extended idle only??
- Software coding..how to calculate?
- Seat-belt chime How to ENABLE!? A4 B6
- :: ECS Tuning :: Bentley Service Manuals & Scan Tools | Audi B6 A4
- A4 Starting problems
- 2003 1.9tdi Avant (AVF): Turbo hose
- Another "PRNDS backlit". 2004 1,9 tdi
- :: ECS Tuning :: ST Suspensions Rebate Sale!
- Audi A4 TDI overheating going up hill 😕
- P0243 code
- AEB valve head on AWM?
- Injector swap ?
- Audi a4 1.8t 5-speed automatic transmission.
- 2005 A4 Avant 3.0 quattro- Hard time finding brakes
- Strange idle shimmy - 3.0 6spd Guru's needed please!
- 2003 Audi A4 1.8T Transmission
- Emergency Flashers Always On
- Looking For A Quick Answer !!
- FREE AutoPreme Floor Mats!?
- DTC 16825? Any Help
- Jolt in engine power at RPM in between 1500 2000 RPM
- Please I need help with the oil type you used.
- best stainless exhaust?
- :: ECS Tuning:: Performance Sale Event | UP To 25% OFF!
- How to Protect your Floor Mats (A Revolutionary Solution) - AutoPreme Update
- 2002 Audi A4 stuck in park, no key...help!!!
- Do I really need that belly pan?
- :: ECS Tuning :: NEW!! Front Wheel Bearing & Hub Assemblies | Audi B6 A4
- ***Don Nguyen | WannabeRacer.com | Vehicle Wrap - Tint - Plastidip - Custom Decals***
- RPMs fluctuating at 2000rpms...anyone know what the issue is?
- :: ECS Tuning :: New Looks! | Fresh Wheel Options for 2016
- Tool t40028 rotates clockwise or counter
- 02 Audi A4 3.0 avant camshaft oil caps
- :: ECS Tuning :: ECS 2.0T Coil Pack Conversion Kits | B6 A4 1.8T
- :: ECS Tuning :: Get Ready For Spring Brake!
- New member needs help!
- Steering angle sensor replacement or cleaning in a 2003 A4 1.8T Quattro Avant
- Audi a4 2002 key fob issue
- :: ECS Tuning :: Mesh Madness!! | Up To $50 Off 5 Days ONLY!
- wheel speed sensor
- Where to buy G12?
- :: ECS Tuning :: Spring into power with Frankenturbo!
- Concerned about sludge 105k '02.
- Recent f21l purchase and question on 17" sport wheels.
- Coding for A4 2005 3.0
- :: ECS Tuning :: Save Up To 30% On ECS Assembled Kits | Limited Time Only!
- :: ECS Tuning :: Save Up To 15% on Select B6 A4 Control Arms | Act NOW!
- Convertible top hydraulic hose - 2004 Audi A4
- Rough start Rough idle
- :: ECS Tuning :: NEW!! ECS Coil Pack Harness Replacement Kit | Audi B6 A4 1.8T
- 02 A4 1.8t - Vehicle won't run but cranks?
- URGENT Please Help
- What is this?
- AUDI A4 b6 96 kw 1.9 TDI ELECTRIC
- Rear windshield louvers
- What front lip/grill set is this?
- Thermostat won't close, alternator question
- :: ECS Tuning :: H&R Premium Suspension Components | Audi B6/B7 A4
- Please help!!! 02 a4 quattro 1.8t shut off while driving
- :: ECS Tuning :: Performance Drivetrain Mounts | Audi B6 A4 1.8T Quattro
- 3.0 or 2.8 ?
- 2004 B6 1.8T Engine Warp
- CAM POSITION SENSOR
- Is My 2004 Audi B6 A4 Pistons still Good?
- A4 Fuel Filter
- :: ECS Tuning :: WeatherTech All Weather Floor Mats | Audi B6 A4
- Climate control erratic on heating
- Serious Problem Changing 2004 Audi A4 Quattro Driveshaft
- xenon problsm
- 3.0L Burning Oil?
- :: ECS Tuning :: GEOMET® Coated Brake Rotors | Audi B6 A4
- B6 3.0 Cat delete. need advice
- audi a4 automatic transmission shifting hard into drive
- ko4-015 Upgrade
- A4 B6 FWD Oil Pan
- :: ECS Tuning :: Assembled By ECS Oil Service Kits | Audi B6 A4 1.8T/30V
- Convenience System Central Control Unit
- :: ECS Tuning :: Single Mass Flywheel Clutch Kit | Audi B6 A4 1.8T
- Fuel gauge is reverse! HELP!
- Overheating after replacing thermostat and housing, no heat in the cabin.
- 2002 Audi A4 3.0 DTC P0391 P0300 P0304 P0305 P0306
- KO4-015 turbo upgrade
- Chocolate Milkshake in Coolant Overflow Tank
- Low oil pressure
- WHAT Diagnostic OBD reading tool work with A4
- No sound on my Radio, Cant find the problem
- :: ECS Tuning :: 710N Diverter Valves | Audi B6 A4 1.8T
- Heat and A/C Panel Buttons
- Thomas Tibane
- Engine codes B6 2002 1.8t
- AUDI A4 glove box removal and hinge repair DIY
- Is there any safety cut out between auto gear and engine
- Low Idle Stall - EPC Mode - Need Help
- :: ECS Tuning :: ECS Street Shield Aluminum Skid Plate | Audi B6 A4
- Passenger HID issues
- Trunk/boot latch opening issues
- need help car overheating and coolant leak from tank
- A4 B6 1.9 85kW BKE VCDS about injectors
- Help Identifying Leak - 2002 A4 3.0
- :: ECS Tuning :: Black Forest Industries Products | Audi B6 A4 1.8T
- 240K Miles 2003 A4 CVT
- 2003 APR A4 1.8 clutch question
- :: ECS Tuning :: ECS Carbon Fiber Mirror Caps | Audi B6 A4
- Fault Codes Help !!!!
- Good buy?
- Replacing/Replaced Both Window Regulators And Have Some Issues
- cylinder 5 misfire , cold start misfires
- VCDS no communication, K2 Line short to ground!
- :: ECS Tuning :: ECS Rear Diff Mount | Audi B6 A4 1.8T
- Turning problem
- Can't decide
- over heating issue
- Any one with VagCom near Qeens
- Need advice/instructions on replacing a 2002 A4 PS pressure hose...
- :: ECS Tuning :: B6 A4 1.8T ECS Tuning Vent Pod Boost Gauge Kit
- What gearbox would cost me less?
- 04 A4 1.8 Qt
- Alternator time
- Reassembled, Fired Up & Died, Now Nothing
- Loss of power, 100€ for the person who will help to solve*
- b6 bumper swop
- Help please
- Help with my 2003 Audi A4 1.8t
- Car won't start please help
- Power Steering Fluid Leak...Help!
- low boost on a 1.8T AMB with PES kit
- LEDS! Reverse, Interior, License Plate - Free Shipping/Lifetime Warranty/Error Free
- ESP and Check engine light all of a sudden
- rochester ny needs parts
- Just Bought audi A4 1.8 Quattro Turbo Wagon
- 2002 a4 quattro 3.0 random missfire
- Help with my Audi A4 1.8T quattro
- Wheel sound "ch ch ch" starting at 20 mph
- Differences between brake rotors
- Coolant Drain Valve - Stuck?
- Buying audi a6
- Engine start blocked by immobilizer P1570
- FCP Groton Water Pump Destroys Engine
- 2003 audi a4 radio dosnt work at all
- Help! 2001 1.9tdi no turbo & slow start
- New headlight switch -problems
- Quattro w power on in corner - helps or hurts at limit
- P0301 code cylinder 1 misfire
- TCM Rebuild
- :: ECS Tuning :: 50% OFF CYBER MONDAY ONLY! Audi Ziza Master LED Kits
- d1s or d2s?
- front end rattle when braking & over bumps
- 2002 A4 Water Pump/heat
- battery keeps dying fog lights dont work
- 2002 Audi A4 1.8t Quattro...Fluids?
- AWE Tuning Holiday Special Pricing starts... NOW. Unlock horsepower for less.
- Black Friday/ Cyber Monday deals from Car Parts Discount
- :: ECS Tuning :: 11th Annual Customer Appreciation Sale|Save up to 25%!!!!!!!
- Many issues.. need help please
- why
- A4 B6 2002 3.0L AVK Timing Belt Replacement
- check engine light flashing, esp, epc lights on
- no voltage on engine connections
- Best options to buy aftermarket turbo for my A4 1.8T
- :: ECS Tuning :: B6 A4 Quattro Solo-Werks S1 Coilovers
- :: ECS Tuning :: B6 A4 Quattro JOM Blueline Coilover System
- :: ECS Tuning :: B6 A4 1.8T ECS Carbon Fiber Engine Cover
- Replacing Driveshaft with a used one
- 04 a4 quattro side mirror turn signal?
- Smoking coming from the top of engine
- Catalytic Conv. 02'-05' Audi A4 1.8 B6 Qauttro
- :: ECS Tuning :: Alzor Wheel Sale | Blow Out Pricing!!
- :: ECS Tuning :: NEW!! ECS Wheel Spacer Fitment Kit
- Help...
- Can't find coolant leak!
- 2003 a4 Quattro won't go into gear
- TCM
- :: ECS Tuning :: B6 A4 1.8T Winter Preparation Essentials
- Looking for a tune/chip b6 A4
- :: ECS Tuning :: B5 A4 1.8T Winter Preparation Essentials
- 2002 B6 1.8t won't start after disconnecting battery
- Wiper help
- 98 1.8t timing belt tensioner
- Special promotion for Audi World Forum members
- A4 pipe problems
- :: ECS Tuning :: NEW!! ECS Billet Aluminum Dipstick | B6 A4 1.8T
- :: ECS Tuning :: Milltek Exhaust Systems | B6 A4 1.8T Quattro
- :: ECS Tuning :: B6 A4 1.8T ECS 2.0T Coil Pack Conversion Kit
- Towbar
- Which chip would be best for my situation?
- Forum group buy with Car Parts Discount
- Question: What kind of rims are these
